VWVortex.com - VR6 Distributor Cap & Rotor Replacement DIY Guide
    Results 1 to 17 of 17
    Thread: VR6 Distributor Cap & Rotor Replacement DIY Guide
    1. Member andylyco's Avatar
      Apr 21st, 2003
      Hbg PA, Las Vegas, Brian Head UT
      '93 SLC, '98 Boxster, '06 911 C2S, '08 Boxster RS60, '04 Bajaja (ALL MT!)
      07-03-2007 07:47 PM #1
      I purchased my Corrado with 120K on the clock, and the distributor cap, rotor plugs, and wires were all close to new. I am about to turn 149K, so I figured it was time to update some parts! This is a very easy DIY, with the exception of removal of the rotor, which can be a PITA.
      You'll want to remove the plastic trim above the distributor for easy access to the cap and rotor. The screws that mount the cover are 12 point 8mm (triple square); they are the same as the inner cv joint bolts. (Also used on Scirocco 16V wheel caps, so if you can find a 16V Scirocco wheel cap tool, you're set!)
      Here is a picture of the tool I use, and the trim piece removed:
      This next image shows the order of the plug wires on the distributor cap. There are numbers stamped inside the plastic grooves (on the intake manifold) for the spark plug wires.
      Remove the plug wires from the distributor cap, taking care not to pull from the wire, but from the black rubber end. (If you are planning to replace the wires, you needn't be so careful.)
      Unplug the metal ground strap behind the #5 spark plug wire.
      Next, using a flat head screwdriver or pliers, remove the 2 metal spring clips that hold the cap to the distributor:
      The cap should pop right off, revealing the rotor. There is a plastic dust cap that is sandwiched between the cap and distributor- it will flop loose. This is normal.
      At this point, I broke off the outer part of the rotor. (that spins in contact with the underside of the cap) With that off, you can remove the dust cap. NOW you can crush/pull off the rotor without fear of damaging the dust cover.
      Removing the rotor is the hardest part. You can't pry it off, because you could damage the shaft. You can't hit it with a hammer for the same reason. I used a large pair of channel lock pliers to crush the rotor plastic, and then gently wiggled it off the shaft.
      This is my rotor after I was finished removing it! The yellow arrow points to the end of the rotor I broke off in order to remove the dust cover. The red arrows point to the main shaft of the rotor that I crushed to remove from the distributor shaft.
      This is what it looks like with the rotor and dust cap removed. Note the small amount of black rotor plastic left in the groove in the side of the shaft.
      Now to reinstall. Don't forget to place the dust cap on before pressing the new rotor back on the shaft! See the next image- there is a small tab on the dust cap that fits in the groove on the side of the distributor. (red arrow) On my dust cap, note that that "Made in Germany" was written on the dust cap on the side closest to the front of the car.
      There may be a special glue for the rotor, but I used some all purpose "weatherstrip adhesive" that I had laying around. (The same 3M yellow 'gorilla snot' I used to hold the timing chain covers to the side of my engine- yellow arrow in next image.) Apply a thin layer of glue, and press the rotor on ths shaft, taking note that it slides completely in the groove. There is a notch inside the rotor; it is near impossible to install it incorrectly.
      Next, double check that the dust cover is in place, and install the new cap. It can only be installed one way, due to the 2 spring clips and ground strap. You may need to use small pliers to pull the clips over the edge of the new cap, but I did it with my fingers. Note the metal ground strap in this image:
      Install the plug wires in the correct order. If you forgot to make a note of this and you completely removed your wires for some reason, use this handy cylinder number guide:
      All finished! See- it wasn't THAT bad!
      I keed, I keed!! This was me doing timing chains March 2006.
      Modified by andylyco at 10:44 AM 10-12-2007
      Las Vegas Real Estate: RealEstateAndy.com
      Brian Head, Utah Ski/Board Rental Condo: BrianHeadGetaway.com
    2. Remove Advertisements
      Advertisements
    3. 07-03-2007 08:50 PM #2
      Great work! Very helpful and detailed. Who needs a Bentley when you have photos and practical experience? Thanks for sharing!
      I've often wished that there was a "Garage" section on the Vortex to keep writeups like this handy, versus simple stickies...
      (Yes, I do have a Bentley, and use it quite often...)
    4. 07-04-2007 12:12 AM #3
      A+ [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    5. Remove Advertisements
      Advertisements
    6. Member jds92slc's Avatar
      Nov 27th, 2004
      Boston MA
      92 Corrado VR6 - 09 TDi JSW
      07-04-2007 12:46 AM #4
      I would love to see this forum go this direction more often. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. Banned
      Oct 13th, 2005
      07-04-2007 10:36 AM #5
      oh wow now i seen it all.. pop 2 clips and swap something out
    8. Member andylyco's Avatar
      Apr 21st, 2003
      07-04-2007 02:12 PM #6
      Quote, originally posted by 1 Low Coupe »
      I KNEW there would be some know-it-all who ragged on me for doing such a simple DIY. I suppose you popped out of your mommys tummy with a triple-square in your hand, ready to replace timing chains on a VR6? We all started somewhere, and I took pictures of the job for future reference on these forums, so I figured why not make a photographic DIY for people who might want to try it themselves. I have plenty more DIY's in the works, and I've contributed to countless others!
      How many DIY's have YOU posted to the forums?!?
      I mean besides your locked "build thread"
      Modified by andylyco at 1:14 PM 7-4-2007
    9. 07-04-2007 03:17 PM #7
      Good write up [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      You may know better than i, but i never glued my rotor back on, and so far it's been fine. I know it's glued from the factory but i figured i would save myself the hassle of having to crush it off in the future. Happy 4th!
    10. Member andylyco's Avatar
      Apr 21st, 2003
      07-04-2007 03:53 PM #8
      Quote, originally posted by mkalajian »
      Good write up [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] You may know better than i, but i never glued my rotor back on, and so far it's been fine. I know it's glued from the factory but i figured i would save myself the hassle of having to crush it off in the future. Happy 4th!
      You are probably right, but I was going by the Bentley manual instructions. I didn't bother to buy the special glue the Bentley suggests; I just used stuff I had laying around the garage. Just a little extra insurance! I know the old 16V 4 cylinders needed glue on their sideways rotors as well, but I did rotors on them without glue, and they worked fine. Glad to hear it will work either way!
    11. 07-04-2007 04:09 PM #9
      I'm thinking about doing a coilover install/ suspension refresh DIY as i'll be doing both to my car soon. I wonder if it would be helpfull.
    12. 07-04-2007 04:13 PM #10
      mine has a set screw
    13. 07-05-2007 02:58 PM #11
      Quote, originally posted by a_riot »
      Yes it would be helpful because I will need it
      Done, deal. Keep in eye out for it in a week or 2.
    14. Banned
      Mar 27th, 2003
      07-05-2007 03:15 PM #12
      Quote, originally posted by uilyvr6 »
      as does mine. yet, the bentley specifically states to destroy it to remove.
      weird.
    15. Member darrenbyrnes's Avatar
      Jan 3rd, 2005
      Minneapolis
      2001 Audi TTq
      07-05-2007 04:32 PM #13
      Nice write up...I have used a torx bit on those cover bolts, though...they seem to work well.
      Never underestimate the stopping power of a tree.
    16. 07-05-2007 05:16 PM #14
      x2...no crushing anything
      '11 Routan SE (black), '01 Jetta GLX VR6 5spd (silver)
      FE ///Motorsports VCDS Hex-Can, if you need help.
    17. Forum Elder SLC4EVER's Avatar
      Oct 7th, 1999
      San Diego
      '93SLC '94SLC
      07-05-2007 05:32 PM #15
      Nice job Andy. [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Dak
      I drive waaay too fast to worry about my cholesterol.
    18. Semi-n00b
      Sep 5th, 2011
      Montreal
      01-13-2013 06:51 PM #16
      There's few pictures missing like the cylinder number guide could you upload those pictures again please?
