VWVortex.com - So, I have compiled a list of common issues and remedies for the 2.0T
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 98
    Thread: So, I have compiled a list of common issues and remedies for the 2.0T
    1. 07-31-2007 01:41 AM #1
      So, I’ve compiled a list of common issues and common solutions based on what I’ve seen on the forums. Please research any possible fix before performing it. Personally, I’ve only had a bad pcv, so I’m basing a lot of this based on my understanding of the issue. Please let me know if something needs to be changed or added…I’d like to make this as good a possible.
      If your car is stock and you still have warranty, then all the items below should be covered under warranty. If you are not stock, then the failed component may or may not be covered under warranty depending on what caused the failure, though this thread is not a warranty debate thread.
      Disclaimer: This is a general guide only. Any problem with the car should be diagnosed by a competent and trained individual. All information provided is for information only and is not designed to replace a service manual or professional help. Use at your own risk.
      1. Diverter valve failure
      2. PCV failure
      3. Broken intake ducting
      4. Cam lobe wear
      5. High pressure fuel pump failure
      6. Air conditioning does not work
      7. Tumble flap failure
      8. Cold start problems
      9. Misfires
      10. Low fuel pressure sensor failure
      Background:
      The stock diverter valve (dv) is prone to failure, whether chipped or stock. The diaphragm is prone to tearing (the orange shown in the pic of the stock dv (in the middle) below-may be a different color depending on the version of dv you have.)
      Symptoms:
      -A failing diverter valve will generally lose boost.
      -The boost can be checked either via a boost gauge, or the vag-com (mb 115). You will see a huge drop in boost when the dv goes bad.
      -Pin-hole DV failures usually allow boost to spike, but will then suddenly vent boost.
      Tearing in the DV usually only allows 6-7 PSI. Boost will not spike.
      -You may see 000665 - Boost Pressure Regulation: Control Range Not Reached
      p0299 - 002 - Lower Limit Exceeded - Intermittent
      -Alternatively, you can remove the dv, and inspect the diaphragm for tears. It is held onto the compressor housing by three bolts:
      Solution:
      -You can replace it with the stock dv, vw #06F 145 710 C. This is the latest dv as of this post, however, many people have also seen failures with the “C” dv. VW is also supposedly coming out with a “G” dv, part # 06F-145-710-G, though it is not officially released as of this post.
      -You can upgrade to the Forge DV #fmfsitv. Pics of the Forge DV are shown above.
      2. Positive Crankcase Ventilation failure
      Background:
      The positive crankcase ventilation is supposed to let gases get sucked from the crankcase to the intake manifold when under vacuum. The problem is, when the pcv system fails, and allows positive pressure (boost) to go from the intake manifold back into the crankcase.
      The latest PCV is the “G” version. To see which version you have, take a small mirror, and stick it under the pcv valve. The last letter identifies the revision (“E” is shown below). The part # is under the round section:
      Symptoms:
      -Typically you will see a slight drop in boost pressure. When my pcv failed, I saw a 2 psi drop across the board.
      -Some oil will be pushed out through the oil filler cap, and onto the valve cover, and may possibly go towards the coil packs. There may also be some oil on the bottom side of the engine cover, where the oil filler cap is.
      -There might be a slight decrease in MPG.
      -Rear PCV failure usually results in oil accumulation around the DV, and will produce a little blue oil smoke at WOT applications.
      Solution:
      -There is the Digitalhippie fix which puts a check valve into the line from the crankcase to the intake manifold. For those who want a spare of the hose where the check valve is installed, the part number is 06F 103 221 F. You can read more about it here: http://www.golfmkv.com/forums/...=8952
      -You can also upgrade to the latest PCV “G” valve. There have been very few failures reported with this PCV. Please verify the PCV you have before upgrading.
      Part numbers for this upgrade:
      PCV valve cover assembly: 06F 129 101 G
      PCV valve cover gasket: 06F 103 483 E
      PCV valve cover to turbo hose: 06F 103 215 A
      PCV tube to turbo metal gasket: 06F 145 757 F
      -If you did the DH pcv fix, and you have a rear pcv failure, then you will need to change the tube labeled as "Exhaust turbocharged gas outlet" showin in the pic above. the Part #'s are the last two shown above (06F 103 215 A & 06F 145 757 F)
      Background:
      Some people have reported that part of the intake ducting that connects to the stock engine (the part in front of the accordion section) breaks off and gets lost, or worst, gets stuck and/or shredded by the fan. Due to its location, the loss in power should be minimal.
      Symptom:
      -You may notice that part of the ducting is missing.
      -You may see shreds of the ducting in and around the fan.
      -You may see the coolant temps rising possibly due to a part of the intake ducting getting stuck and not allowing the fan to turn. If the coolant gauge goes into the red, then immediately shut the engine off, and check to see if the fan is operating.
      Solution:
      -If the fan is damaged, then you may need a new fan.
      -An aftermarket intake will replace the ducting section, and is a possibly solution.
      -You might be able to tape or epoxy the sections together, so that it will make them harder to come apart. You may also remove the top piece alltogether.
      4. Cam lobe wear
      Background:
      Excessive wear of intake camshaft lobe that drives the high pressure fuel pump. The wear limits maximum pump piston lift, causing fuel rail pressure fluctuations. The intake cam drives the fuel pump:
      Please see also #5 below.
      Symptom:
      -Fuel cut-out when driving, esp. under WOT.
      -Fuel cut-out symptoms range from soft pulsations of power to long-pulse bucking while in high-gear high-load situations (high gear at WOT, or up a grade). MIL may flash if cut-out is severe. Car will also go into hard-limp (no boost, 4500RPM limit) if severe enough.
      -MIL ON
      -P0087 Fuel Rail / System Pressure - Too Low
      -P1093 Fuel Trim 2, Bank 1 Malfunction
      -P2293 Fuel Pressure Regulator 2 Performance
      Solution:
      Increase surface hardening of camshaft lobe for the high pressure fuel pump. Improved intake camshafts have Part No. 06F109101B. Refer to TSB# 15 07 04
      Background:
      The high pressure fuel pump sometimes is not able to supply enough fuel, especially at low to mid range RPMs because it is cam driven. Please note that the high pressure fuel pump is different than the in-tank fuel pump. Please see also #4 above.
      Symptom:
      -You may see the following DTC
      004767 - Low-Pressure Fuel Pressure Regulation: Pressure too High
      P129F - 001 - Upper Limit Exceeded - MIL ON
      Solution:
      -If you are chipped, then try to put the car in stock mode to see if the fuel cuts will stop. If it does, then you might want to wait until a fuel pump solution comes out. APR and Autotech are currently working on solutions.
      -If you are stock, then it is possible that you have a bad fuel pump. The dealer should replace this under warranty.
      Background:
      The air conditioners manuf. By Zelex and Valeo tend to fail. They can be identified by the pulley:
      Symptom:
      - Air conditioning does not cool, air conditioning compressor may seize.
      Solution:
      - On the 2.0T engine a new Sanden compressor Part No: 1K0820803 index S must be installed. Refer to ETKA for the latest part # for the other engines. This should be covered under warranty.
      Background:
      The tumble flap motor is prone to failure. This is probably the most common problem I’ve seen when scanning cars with the vag-com. A little background on how the tumble flap works:
      Symptoms:
      You may see the following DTC’s
      -012599 - Intake Manifold Runner Control: Basic Setting not Completed
      P3137 - 001 - Upper Limit Exceeded – Intermittent
      -012691 - Intake Manifold Runner Control: Open Stop outside of Valid Range
      P3193 - 002 - Lower Limit Exceeded - Intermittent
      -008196 - Intake Manifold Flap; Bank 1: Stuck Open
      P2004 - 008 - Implausible Signal - Intermittent
      - 012600 - Intake Manifold Runner Control: Regulation Deviation
      P3138 - 008 - Implausible Signal - MIL ON
      Solution: The intake manifold flap motor needs to be replaced.
      8. Cold Start Problems
      Background/Symptom: Troubles starting car when cold
      Solution:
      -Some people have reported that it was related to a certain gas, so maybe try a different gas station/company.
      -Get the latest software reflash.
      -Could also be a bad coil pack.
      9. Misfires
      Background/Symptom:
      -Misfiring either under idle or under boost.
      -Scan for DTC’s. See which cylinder is misfiring, and swap coils and or plugs to see if the misfire follows.
      -Coil pack misfire (non-fire, lol) symptoms are shorter duration, rather violent, and also result in backfires from unburnt fuel entering the exhaust system. The MIL usually starts flashing. Car may or may not go into limp.
      Solution:
      -Replace coils and/or plugs
      -Could be a bad fuel injector
      A special thanks to DirtyDisco. and syntrix for providing some of the info used in this post.
      10. Low Fuel Pressure Sensor Failure
      Background/Symptom:
      You may get the following DTC’s:
      012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
      P310B - 008 - Implausible Signal - Intermittent - MIL ON
      P129F - 001 - Upper Limit Exceeded – Intermittent
      -The first symptom is typically stalling when first starting the car cold.
      -Typically, the problem gets worse, and can lead to fuel cutouts at almost any rpm and/or car stalling/running lean/rich
      Solution: Replace low fuel pressure sensor (thurst sensor), vw part #06E906051J
      Sometimes, the high pressure fuel pump will be replaced at the same time (#1 in pic below)
      Modified by D.Passat00 at 9:37 PM 1-28-2008
      Modified by D.Passat00 at 9:39 PM 1-28-2008
    2. Remove Advertisements
      Advertisements
    3. 07-31-2007 01:58 AM #2
      Excellent!! I think you may ACTUALLY WORK on VAG cars!!
      VW Master Tech
      2017 bagged GLI
      2018 Tiguan SEL-P
      Karma,it is every where you will be.
    4. Member DeathMoJo's Avatar
      Oct 8th, 2006
      Oak Harbor, WA
      '13 VW GTI CW - Wolfsburg Edition, '04 VW R32 - DBP (sold)
      07-31-2007 02:14 AM #3
      beautiful write up!
      This needs a sticky!
      United States Navy
    5. Remove Advertisements
      Advertisements
    6. Member milan616's Avatar
      Aug 5th, 2006
      Burlington, MA
      2007 VW GTI
      07-31-2007 08:13 AM #4
      Threads like this are why we need a forum sticky like the Mk5 forum.
      NEK
      valar morghulis
    7. 07-31-2007 09:58 AM #5
      If you add symptoms (driveability) other than DTCs in some of these, like the Tumble Flap, etc., this thread would be awesome-er-y.
    8. 07-31-2007 10:05 AM #6
      Bookmarked.... hehe
    9. 07-31-2007 11:04 AM #7
      Quote, originally posted by DirtyDisco. »
      like i said in the first post, i haven't experienced a lot of these problems. also, those that i've talked to with the tumble flap problem haven't really noticed anything different about their cars. but of course, if anyone has something additional to add, then i'd be happy to incorporate it...this is meant simply as a starting point.
    10. 07-31-2007 11:17 AM #8
      if severe enough.
      Front PCV failure usually results in oil accumulation around the filler cap, etc. as
      described.
      Modified by DirtyDisco. at 9:20 AM 7-31-2007
    11. Senior Member
      Aug 20th, 2000
      In a minivan by the river with a squirrel and rat
      grey ghost wagon and a 944
      07-31-2007 11:38 AM #9
      Good stuff D!
      Here's another pic of the intake piece:
      MOEW: ٩(●̮̮̃•̃)۶ Zomg Zombies ٩(-̮̮̃-̃)۶ ٩(-̮̮̃•̃)۶ ٩(×̯×)۶ ¯\(°_o)/¯
    12. 07-31-2007 11:51 AM #10
      if severe enough.
      described.
      thanks for the input!
      so, for the rear pcv failure, replacing the hose in the back labeled as "exhaust turbo gas outlet" in the pic below with the latest one should fix that problem right?
    13. 07-31-2007 11:52 AM #11
      Quote, originally posted by syntrix »
      Good stuff D!
      LOL... looks like the one from my MkV GTI... which lodged into the fan, and burnt
      out the motor.
    14. 07-31-2007 11:53 AM #12
      Good stuff D!
      thanks for the pic...do you mind if i use it?
      oh, and my piece came off a few days ago too...it was just sitting on top of the intake...luckily i saw it when i did before it had a chance to fall into the fan.
    15. Member
      Jul 6th, 2006
      2012 VW GTI 4dr Sunroof/Nav
      07-31-2007 12:25 PM #13
      I love you man!
    16. 07-31-2007 12:59 PM #14
      Quote, originally posted by D.Passat00 »
      Yessir.
    17. 07-31-2007 01:27 PM #15
      Yessir.
      cool, so the parts needed for the rear hose/tube should be these two correct?:
    18. 07-31-2007 01:31 PM #16
      them's the ones [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    19. 07-31-2007 01:34 PM #17
      You get a big hissing/whooshing sound when your DV fails too!
    20. 07-31-2007 05:20 PM #18
      This is brilliant. Thanks DPassat.00
    21. 07-31-2007 06:13 PM #19
      I'm confused....
      NO Wait... Maybe I'm not... j/k
      This thread just idiot proofed the general tuning problems of the 2.0T
      I like this better then the "No Drama" Thread
    22. Member Sincity's Avatar
      May 16th, 2005
      '07 GTI APR Stg II RIP. '09 C63 AMG Kleemann Stg II. Trade '08 RDX for MKVII R or GTI.
      07-31-2007 06:20 PM #20
      This is awesome. Thanks DPassat [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    23. Member bigred35's Avatar
      Mar 10th, 2002
      Orange, CA
      2015 Honda Civic Si
      07-31-2007 06:22 PM #21
      Very Nice! (Borat voice)
    24. Member 91 16V Jetta's Avatar
      Dec 6th, 1999
      Vancouver USA
      2012 GLI APR K04
      07-31-2007 07:04 PM #22
      Hopefully VW will look at this too [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    25. 08-16-2007 12:16 AM #23
      Quote, originally posted by VWAUDITEK »
      i don't actually work for VW, though i do most of the mods on my car myself.
    26. 08-16-2007 01:05 AM #24
      Great write up and thank you for the information it will be very helpfull! I checked my PCV valve and it is the "E" version so I do not know if it needs to be replaced? Can one of you guys give me idea of how I pull it off and how you can tell if it is broken? PLEASE HELP! Thank you!
    27. 08-16-2007 12:31 PM #25
      great write up, haven't had alot of issues myself, but will be replacing my dv this weekend so I will get you pics of riped one, and next week I am taking it in for the flap so will take some pics of that for you as well
