VWVortex.com - F.S 82 Rabbit 2 door diesel LS!! 50+ MPG!!!
    Results 1 to 6 of 6
    Thread: F.S 82 Rabbit 2 door diesel LS!! 50+ MPG!!!
    1. Member 80_quattro_'s Avatar
      Sep 24th, 2006
      Columbus, Ohio
      B5 A4TQM, Mr2 turbo,98 GSR teg, CBR 600
      01-03-2008 07:42 PM #1
      i bought this to put my turbo diesel motor in, but i have too many other cars and projects that i am in the middle of, so it needs to go, i bought it from an older man who ran a local oil drilling company and they used it to check on the wells, the car has not seen winter salt in over 10 years, so the body is very solid and 98% rust free, only rust is on the dent on passenger side and its just surface. i will post pics later. it has new belts, hoses, thermostat, glow plugs, water pump, tires have only a few hundred miles on them, new timing belt, and pump timing set, head gasket and bolts along with new intake and exhaust gaskets, head was pressure checked and milled so its flat and not cracked, car runs great, has great compression, starts up first time in 10 degree weather, has A/C which works but needs recharged after i put a new compressor in, i didnt charge it yet. has new alternator and starter also. everything works, upshift light, rear defrost, gets 50+ mpg. car has around 170k miles, which is nothing for a diesel. i just changed oil, coolant, gear oil, fuel, oil and air filters. i also have new shifter bushings, the paint is faded, headliner is gone, and theres no exhaust, i am asking $1,300 OBO its a good car and i would like to see it go to a good VW lovers home, before i list it on ebay and craigslist
      -2001 A4 1.8t quattro, S-Line, St coilovers, S5 18"s and 4.2 V8 swapped!!
      -2014 Ram 2500 Tow Pig for MR2
      -1991 MR2 turbo, built, 740 whp
      -2015 Jetta SEL TDI 6- spd- wifes whip!
      -2007 BMW G650 X Moto -2001 Jetta SEL wagon,slammed, 2.slow- daily status
    2. Remove Advertisements
      VWVortex.com
      Advertisements
    3. Member funnee84bunny's Avatar
      Jul 30th, 2007
      state of jefferson oregon
      87 K-5 Blazer Bunch of broken Japanese stuff
      01-03-2008 11:16 PM #2
      bump for this thing.......somebodys gonna get a steallllllllllllll! just got an 81 diesel that started up on the first crank after sitting for three years with an eighth tank of diesel. bulletproof period
      Quote Originally Posted by Skot53 View Post
      Damn you and your odd statehood.
      Quote Originally Posted by jnm2.0t View Post
      I mean if you're so paranoid that you think the government has nothing better to do than fuxk with random people then not sure what to tell you.
    4. Member 80_quattro_'s Avatar
      Sep 24th, 2006
      Columbus, Ohio
      01-04-2008 01:57 AM #3
      thanks for the Bump! also have a cd player that goes with car, but not installed. call me at (419) 618-4207 or [email protected] if you have questions. heres the pics:
      dent on side
    5. Member 80_quattro_'s Avatar
      Sep 24th, 2006
      Columbus, Ohio
      01-06-2008 09:04 PM #4
      Bump for a car that will easily pay for itself in fuel saved in no time!!!
    6. Member whiteshirttdi11's Avatar
      Jul 2nd, 2007
      Philadelphia
      00 Golf TDl, 83 Rabbit GTI
      01-06-2008 11:58 PM #5
      very tempting....
    7. Member 80_quattro_'s Avatar
      Sep 24th, 2006
      Columbus, Ohio
      01-08-2008 07:58 PM #6
      CAR IS NOW SOLD!!!!!
