VWVortex.com - O.K. I finished my Bora R fog light install
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 51
    Thread: O.K. I finished my Bora R fog light install
    1. Member james dean r32's Avatar
      Jul 31st, 2006
      Seattle
      04 .:R32/88 e30 convertible
      01-28-2008 01:49 AM #1
      O.K. I finished my Bora R fog light install. Here is how I installed mine. I hope this helps anyone else that is going to do this. Please don't rip me if you have a better way or if I miss something.
      I received the kit from OEMPLUS (thanks). What I got was the grill and the fog lights only. Because this is a new mod there was no instructions and no wiring harness.
      Well here we go.
      1. Take off upper grill and the bumper off. The upper grill just snaps off (don't forget to take off the hood pull lever). The bumper has screws at each fender wheel well (5 - 6 screws), at the bottom of the bumper connecting the skid plate (12- 16 screws), 5 screws behind the upper grill and one 10mm nut behind the bottom outer two grills. Disconnect the sensor from behind the drivers side grill as well.
      2. On each lower grill opening cut off the out side grill support and on the driver’s side cut off the sensor mount. I believe this sensor is for outside temperature.
      3. Make the fog light brackets. I used three pieces of plastic glued together with GAS and Oil seal all. I wanted to be able to adjust the fog lights so I used a swivel bracket from a cheap pair of fog lights I bought from Schucks for $19.99. I glued and screwed the bracket I made to the top of the grill opening. Make sure you screw the bracket at the very edge or else it will go through the front and be visible from the out side.
      4. On the passenger side I had to trim the plastic housing down that goes to the oil cooler so the passenger side fog light would fit in. On the driver side I had to bend the horn brackets up so the drivers side fog light would fit in. (SORRY NO PICTURES OF THIS.)
      5. Run the wire from the switch. I bought a fog wire harness from Thip at TKO Motorwerks (thanks Thip your always a big help) that would work with my euro switch. (I think 20 squared has them as well). The wire harness consist of a relay with one wire that goes to the switch, one wire that goes to ground, one wire that's fused and goes to the battery and two wires that go to the fog lights. Yes you could make your own wire harness but the one I bought already had the correct pins at the end of the wires for the euro switch and the fog light plugs ( just plug and play). I don't use the rear fog so I used the two settings on my euro switch for my two sets of fog lights up front. On the harness for the euro switch the pin # 8 is for the front fog light and pin # 9 is for the rear fog light. I wanted to be able to pull the switch out to the first setting to turn on the Bora R fog light on and the second pull position for turning the stock fog light on, to do this I just switched the wires going to pin # 8 and pin # 9. I also bought the plug and ground wire that inserts into the fog lights from a VW dealership. The part #’s are, for the plug (1J0 973 722) and the part # for the ground wire is (6X0 971 071 A) or (6X0 971 071 B) depending on what thickness of wire you want to use. I used the thicker wire.
      6. This is where I grounded the relay and the two fog lights.
      7. Reinstall the bumper and do any adjustments to the fitting as needed. I had to pull my bumper off about 5 times to make adjustments for the fog lights to fit.
      8. And here is how they look installed
      9. For now I have the outside air temp sender wire tide here.
      It has worked fine so far.
      I have driven in the night with them and like the light they produce.
      Hope you like it and I hope this helps anyone else.
      Here are some pictures with the lights off.
      Modified by james dean r32 at 8:30 AM 1-28-2008
      Modified by james dean r32 at 7:56 PM 2-10-2008
    2. Remove Advertisements
      Advertisements
    3. Member Henman's Avatar
      Nov 2nd, 2003
      2004 DBP R32
      01-28-2008 01:51 AM #2
      Any shots of the car with the lights off?
      DBP Mk IV R32 with some add-ons
      Delivered June 2004
    4. Member james dean r32's Avatar
      Jul 31st, 2006
      Seattle
      01-28-2008 01:58 AM #3
      Ya know I thought I did but I guess I don't. I will take pictures tomorrow and post.
      Modified by james dean r32 at 11:25 PM 1-27-2008
    5. Remove Advertisements
      Advertisements
    6. Member xOphear's Avatar
      May 20th, 2004
      Bremerton,WA
      2004 R32 / 2008 GTI
      01-28-2008 06:08 AM #4
      looking good Jim
    7. Member vr6fanatic's Avatar
      Apr 4th, 2003
      Mass
      2004 VW R32, 2016 VW GTI .
      01-28-2008 06:58 AM #5
      Nice job [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Many people enjoy eating apples and oranges, but in the end they are still… just apples and oranges. The R32 is passion fruit. . Live Long and Prosper.
    8. Member moacur's Avatar
      Sep 22nd, 2006
      Minneapolis
      05 S4 - 964 911T
      01-28-2008 07:33 AM #6
      Very nice [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Mar 2nd, 2005
      Reno, NV
      2017 F-150 Lariat Supercrew w/3.5 Ecoboost & 10 speed auto, 2015 Nissan XTerra PRO-4X
      01-28-2008 08:33 AM #7
      Perfect write up [IMG]http://*****************.com/smile/emthup.gif[/IMG] . Now you gave me ideas
      Stock truck dyno: 340 hp, 464 tq
    10. Member oneighturbo's Avatar
      Oct 11th, 2004
      DE
      Cayenne S, MKI GTI, MKII GTI, MKIV GTI, MKIV R32, B7 S4, B8.5 S4
      01-28-2008 09:19 AM #8
      Great write up, thanks.
      Have you noticed any movement with the lights while driving?
    11. 01-28-2008 10:54 AM #9
      WOW ,looks so clean! better than mine. I put my hella de's on the lip of the foam re-bar and have no problems, plus I just wired straight to the oem fog light wire, no relays... Ive been through minor snow, floods and all that a big storm brings and my fogs have been good. Knock on wood...
      Nov 17th, 2004
      Allentown, PA
      2004 DBP R32 (Sold), 2003 Passat W8, 2016 Jetta Sport 1.8TSI and 2017 Jetta SEL 1.8TSI
      01-28-2008 11:18 AM #10
      That looks really nice!!
    13. Member james dean r32's Avatar
      Jul 31st, 2006
      Seattle
      01-28-2008 11:37 AM #11
      Quote, originally posted by oneighturbo »
      I haven't noticed any movement while driving but if I do I am going to put a bracket at the bottom of the fog lights as well.
      I added more pictures with the lights off.
    14. Member dashrendar's Avatar
      May 2nd, 2004
      Little Rock, Ar
      '00 Jolf 1.8T, '02 Jetta 1.8T
      01-28-2008 11:37 AM #12
      those are clean looking.
      |ScArE BeAr MafIa|Low.Life.Society|WetDub|726|XBOX GT:DrNotSoHorrible
      Quote Originally Posted by UberDub18t
      Dash invented the double
    15. 01-28-2008 12:17 PM #13
      Looks good, how long did it take to do?
    16. Member james dean r32's Avatar
      Jul 31st, 2006
      Seattle
      01-28-2008 12:31 PM #14
      It's hard to tell because I did it over period of time because I rarely get a single full day to work on projects. If I had all my tools and all the parts needed I would say it would take about 4 or 5 hours. This is just me though I am not a fast worker. Most of my time working on my car is used up looking for the right tool or trying to remember where I left it .
    17. Senior Member abeR's Avatar
      Sep 13th, 2002
      Joe's Garage / Deals Gap
      gorf
      01-28-2008 04:20 PM #15
      lookin good.
      rock on.
    18. 01-28-2008 05:25 PM #16
      I don't really like how they shine out the side of the grilles as well in the pictures... I might find some sort of rubber-grommet that will prevent that from happening since the lights don't click-into anything.
    19. Member
      Nov 7th, 2006
      SL,UT LA,CA
      95 BMW M3
      01-28-2008 06:13 PM #17
      how big are those lights? and where did you get them from? and does this oemplus place have a website?
      Modified by xthompsonx at 3:15 PM 1-28-2008
    20. Member james dean r32's Avatar
      Jul 31st, 2006
      Seattle
      01-28-2008 06:21 PM #18
      Quote, originally posted by smashR32 »
      I will look at it again tonight at night. I think it would be hard to put a rubber-grommet in it if you want to be able to adjust them. I didn't notice the light coming through when I was looking at them last night. But your right it would look better if the only light that was visible was what was being projected through fog light opening.
    21. Member james dean r32's Avatar
      Jul 31st, 2006
      Seattle
      01-28-2008 06:33 PM #19
      Quote, originally posted by xthompsonx »
      The web site is. http://oempl.us/
    22. Geriatric Member
      Aug 31st, 2004
      New Jersey
      2018 F-150 Raptor - 2004 R32
      01-28-2008 06:45 PM #20
      '85 Golf (SOLD) - '91 Jetta GL (SOLD) - '97 Jetta Trek (SOLD) - '99 Jetta Wolfsburg (SOLD) - '02 GTI 337 (SOLD) - '04 R32 (SOLD) - '04 R32 - '10 GTI Autobahn (SOLD) - '12 Golf R (SOLD) - '13 Tiguan SEL (SOLD) - '13 Golf R (SOLD) - '15 GTI Autobahn (SOLD) - '15 Tiguan R-Line (SOLD) - '15 S3 (SOLD) - '18 RS3 (SOLD) - '18 Raptor
    23. Member Justinsane's Avatar
      Jan 21st, 2008
      Cyberspace
      2013 Suzuka Gray S4
      01-28-2008 08:00 PM #21
      Quote, originally posted by johnnyR32 »
      Lookin good sir!
      » - Patrol
    24. Member LASA VR6's Avatar
      Aug 29th, 2003
      Mk4.:R, Mk 7R
      01-28-2008 08:06 PM #22
      good job , Very well executed... [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    25. Banned
      Feb 26th, 2007
      01-28-2008 08:12 PM #23
      that looks mint [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    26. Member ragu9000's Avatar
      Apr 16th, 2007
      NJ
      2004.5 Gli 99 grand cherokee
      01-28-2008 08:25 PM #24
      real clean and awesome man...always wanted some fogs on my GLI
    27. Member Harepower's Avatar
      Jan 23rd, 2007
      Eagleville, TN
      07 Silverado, 2012 Forestor
      01-28-2008 09:16 PM #25
      That looks great. Thanks for the install piece. I will be following suit soon. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
