VWVortex.com - Sale Sachs & Clutchnet Clutch kits W/ flywheel From $299.95 Shipped
    Page 4 of 12 FirstFirst 12345678 ... LastLast
    Results 76 to 100 of 297
    Thread: Sale Sachs & Clutchnet Clutch kits W/ flywheel From $299.95 Shipped
    1. Member ejg3855's Avatar
      Sep 23rd, 2004
      Rochester, NY
      1993 UrS4, BT-TT, tdi golf, a3, tdi CJ7 project, rangerousmaximus
      10-22-2008 05:28 PM #76
      PM'ed
      I've been around this game to long.
      BREAKOUTMOTORSPORTS - Focusing on B5 V8 Swaps.
    2. Remove Advertisements
      Advertisements
    3. Banner Advertiser
      Jan 12th, 2005
      92 Corrado SLC , 92 Audi S4
      10-23-2008 12:44 PM #77
      Replied
    4. Member Mike.Mike.'s Avatar
      Apr 19th, 2006
      Buffalo, NY
      MKV .:R32
      10-23-2008 08:31 PM #78
      What would u recommend for a k0402x upgraded car?
      http://ihardlyknowher.com/mrplumnasty
      | MKV R32 | e82 128i |MKIV 1.8t Jetta (gone) |
    5. Remove Advertisements
      Advertisements
    6. Banner Advertiser
      Jan 12th, 2005
      11-03-2008 10:51 AM #79
      5 or 6 speed?.
    7. Banner Advertiser
      Jan 12th, 2005
      11-05-2008 11:01 PM #80
      Added Two more complete new 6 speed kits.
      -----02M Clutch Kits 6 Speed Fits 337-20th-GLI-Quattro TT -----
      ------Full Clutch Kits contain clutch disc, pressure plate, Steel Billet Flyweels, flywheel and pressure plate bolts,Release bearing and alignment tool----
      $639.95 Stage 1 Sachs Clutch Kit with 16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM OE Sachs Pressure Plate,Sachs Unsprung Disc,6 flywheel & 6 pressure plate bolts, OE release bearing.
      STAGE 1 KIT
      $699.95 Stage 1+ CLUTCH KIT with 16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM OE LUK Pressure Plate,Clutchnet Sprung Hub Full face Organic Disc,6 flywheel & 6 pressure plate bolts, OE release bearing.
      STAGE 1+ KIT
      Modified by FourSeasonTuning.com at 9:35 AM 2-7-2009
    8. Member 03redgti's Avatar
      Feb 18th, 2006
      Central PA
      03 BT 1.9t GTI
      11-18-2008 08:29 PM #81
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] for clutchnet
      100% stock
    9. Member Mike.Mike.'s Avatar
      Apr 19th, 2006
      Buffalo, NY
      MKV .:R32
      11-20-2008 07:11 PM #82
      Sorry for such late post..5 speed k0402x..Prob around around 250whp but im going to push for a bit more
    10. Banner Advertiser
      Jan 12th, 2005
      11-20-2008 08:33 PM #83
      Stage 1 $325
      http://www.fourseasontuning.com/?product=595
      The next step is a stage 1+ upgraded disc. $425
      http://www.fourseasontuning.com/?product=321
      Stage 2 Upgraded disc and 2X Clutchnet pressure plate $589.95
      http://www.fourseasontuning.com/?product=322
      Call to order and will upgrade to steel billet flywheel from the cast ones (stage1+ and stage 2) while supplies last.
    11. 11-27-2008 08:48 PM #84
      sorry is a 6 speed leon cupra 2003 jeje same as gli an 337# (240mm)
      with aluminum spec flyweel.
      is it compatible with your 4 puck sprung center disk????
      Modified by golfa89 at 5:49 PM 11-27-2008
      Modified by golfa89 at 5:53 PM 11-27-2008
    12. Banner Advertiser
      Jan 12th, 2005
      11-28-2008 11:37 AM #85
      If the Spec flywheel would work with a stock disc then it should work with the 4 puck sprung hub.
    13. 11-29-2008 04:06 PM #86
      yes it can work with a stock type of disck 240mm
      are you sure it does?
      it could be intresting to actualy put the parts togeder cos is diferent in the center to the one from clutch net the center is not flat.
      is like convex like a dome in the center and uses 1.8t triple square type of bolts i am afreit it may rub with the sprung center i live in mexico so i dont have acces to the parts and buy and not use is not the best investment you now.
      help me to make shure so i cand buy one
    14. Banner Advertiser
      Jan 12th, 2005
      11-29-2008 08:25 PM #87
      The thickest side faces the pressure plate side not the flywheel side.
      If your flywheel has a dished area where the flywheel bolts sit then the springs or cover from the disc will not hit the flywheel bolts.
      http://fourseasontuning.com/pa...F.jpg
    15. 12-18-2008 10:55 PM #88
      How about a clutch kit for my front track b5 a4 1.8t stock setup thanks.
    16. Banner Advertiser
      Jan 12th, 2005
      12-19-2008 12:27 AM #89
      1.8T Clutch Kit $499.95 228MM Clutch Kit Stock weight Single mass Cast flywheel
      1.8T Single Mass Clutch W/ Cast Steel Flywheel
      Modified by FourSeasonTuning.com at 7:17 PM 2-10-2009
    17. Member T-Boy's Avatar
      Jul 16th, 2003
      ATL
      01-18-2009 03:13 AM #90
      What kinda abuse will the stage 1+ kit take for the 02m trans.
      and how long are the prices and free shipping good for?
      Modified by T-Boy at 6:14 PM 1-18-2009
      APR Stage 3071R+
    18. Banner Advertiser
      Jan 12th, 2005
      01-25-2009 02:30 PM #91
      Im sent
    19. Member T-Boy's Avatar
      Jul 16th, 2003
      ATL
      02-04-2009 08:50 AM #92
      Order placed.... [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      APR Stage 3071R+
    20. Member T-Boy's Avatar
      Jul 16th, 2003
      ATL
      02-10-2009 10:11 PM #93
      Got it in, looks like i'll be having fun this weekend.....thanks [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      APR Stage 3071R+
    21. Banner Advertiser
      Jan 12th, 2005
      02-11-2009 10:35 PM #94
      Your welcome.
    22. Member T-Boy's Avatar
      Jul 16th, 2003
      ATL
      02-15-2009 04:55 PM #95
      Installed, but I do have a question.
      My engagement point is really high up in the pedal travel, is this normal?
      I've had a few different setups throughout the years, and this kit is the first one to engage and disengage that high up in the pedal...
      APR Stage 3071R+
    23. Banner Advertiser
      Jan 12th, 2005
      02-15-2009 05:03 PM #96
      Im sent with questions.
      Your kit had a OEM pressure plate and a flywheel made with a stock step height.
    24. 02-22-2009 04:02 PM #97
      will pm very soon
    25. Former Advertiser
      Feb 2nd, 2009
      Long Island NY
      02 VW GTI 1.8t
      02-24-2009 09:27 PM #98
      Four Season Tuning = the best [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    26. 03-19-2009 11:59 AM #99
      Good deals [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by New2theGame at 10:03 AM 3-19-2009
    27. Member ejg3855's Avatar
      Sep 23rd, 2004
      Rochester, NY
      03-30-2009 12:30 AM #100
      does the stg II pressure plate require a stronger shift fork ?
      O2J
