VWVortex.com - 1987 Ford Thunderbird Turbo Coupe - 65,XXX KMS
    Results 1 to 25 of 25
    Thread: 1987 Ford Thunderbird Turbo Coupe - 65,XXX KMS
    1. 06-28-2008 08:40 AM #1
      PRICE DROP: NOW $7500!
      WAS $8500 Was $10,500
      Up for sale is mint condition 1987 Thunderbird Turbo Coupe. This car has been meticulously maintained, never winter driven, always stored indoors, always garaged.
      The paint is all original, in pristine condition. The Raven(gray/black) leather interior is also in mint condition(a rare interior in rare condition).
      The motor is the original Ford 2.3L turbo with some bolt-ons mods. Originally an automatic car, a 5 speed swap was performed by a professional transmission shop. The auto was replaced with a World Class T5 from a 1991 Mustang, with a Spec Stage 3 clutch.
      Installed in the last month is a rebuilt Holset HY35W turbocharger, 52# injectors, tuned with a Moates J3 adapter. The car has also been converted to a Mass Air meter(80mm MAF) from the stock VAM setup.
      Mods:
      Motor:
      -newly rebuilt Holset HY35W turbo with 3" downpipe
      -80mm MAF swap
      -52lb fuel injectors
      -3" to dual 2.5" exhaust(3" down elbow, 3" downpipe, 3" stainless flex pipe, 3"-2.5" Y, dual 2.5" Dynomax Ultra-flo mufflers, 2.5" stainless steel slash cut tail pipes.)
      -40Bob log header(latest generation, new this season) ( http://40bob.com/ )
      -LA3 computer with Moates J3 adapter(tuneable with PCMX software, Moates Burn1 chip burner)
      -Spec Stage 3 clutch(less than 2000kms)
      -40Bob's gutted upper, knife edged lower intakes(polished lettering)( http://40bob.com/ )
      -Stinger Performance front mount intercooler kit( http://www.stinger-performance.com/stockparts.html )
      -Bailey Motorsports DV30 bypass valve
      -Stinger Performance stainless braided oil feed and return lines
      -Chuck W's poly motor mounts
      -Race Engineering adjustable cam gear
      -Kirban adjustable fuel pressure regulator + fuel pressure gauge
      -AEM UEGO wideband O2 meter and gauge( http://www.aempower.com/ViewCa...ID=67 )
      -Autometer Z-Series: water temp, oil temp, oil pressure in custom EQ gauge pod
      -Autometer Z-Series boost gauge (30vac/30boost) with AEM gauge in A-pillar pod
      -B&M Pro5.0 shifter
      -new Mustang leather shift knob and new leather shift boot from Mr. Gaiter.
      -Gillis adjustable boost valve( http://boostvalve.com/pricelist.html )
      Suspension/Wheels:
      -Tokico Illumina 5-way adjustable shocks/struts(new with warranty)
      -Eibach pro kit springs up front(installed 1500kms ago)
      -Mustang Bullitt springs in the rear
      -Maximum Motorsports adjustable rear lower control arms(height adjustable)
      -17x9" Cobra-R replica wheels
      -new Kumho Ecsta 712 tires: 235/45/17 front(1500kms ago), 255/40/17 rear(less than 200kms)
      On top of these mods are all typical maintenance parts: new rad hoses, distributer, cap, rotor, plugs, wires, new rad in 2002, TFI, coolant temp sensor, IAT sensor, TPS sensor, brakes.
      For almost every modification made, I have the original part, except for the stock IHI turbo. When I added the a-pillar pod, I used a spare A-pillar from a parts car, so I still have the original. I still have the stock wheels.
      More pictures can be seen at http://s212.photobucket.com/albums/cc255/grahamram/ - these pictures are from last year before the rear supsension was complete and before the tailpipes were installed.
      If you would like to see any more pictures or see the car, you can contact call Graham at *
      Asking $10,500, now $9500
      Modified by GrahamRam at 10:03 AM 6-28-2008
      Modified by GrahamRam at 9:54 PM 7-3-2008
      Modified by GrahamRam at 11:30 AM 7-21-2008
      Modified by GrahamRam at 10:50 AM 7-27-2008
      Modified by GrahamRam at 2:28 PM 9-17-2008
      Modified by GrahamRam at 1:26 PM 2-18-2010
    2. Remove Advertisements
      VWVortex.com
      Advertisements
    3. Senior Member Big Dac With Fries's Avatar
      Feb 1st, 2002
      Spatula City
      6000 SUX
      06-28-2008 10:35 AM #2
      How much for this beast?
      "I was thinking about what a friend had said, I was hoping it was a lie."
    4. Member lowblackdub's Avatar
      Sep 12th, 2000
      Tiny, ON.
      1988 Ford Mustang LX, 2006 Mini Cooper S, 2014 Volkswagen Sportwagen TDI
      06-28-2008 10:41 AM #3
      Amazing car... looks like my cousin's old ride.
    5. 06-28-2008 11:03 AM #4
      Quote, originally posted by Big Dac With Fries »
      Forgot to put the price.
      $10,500
    6. Member bignivanut's Avatar
      Dec 11th, 2006
      Bluevale Ontario
      2004 jetta TDI sedan, 1990 GTI stock resto project.
      06-28-2008 11:17 AM #5
      WOW
      I had 2 88s and 1 87, all 5spds, still have 1 87 auto parts car.
      They were a fun car even in stock form! [IMG]http://*****************.com/smile/emthup.gif[/IMG] This one is even better. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Wish I was in the market, thanks for the flashback.
      if it needs a spark, it must be broken or you aren't using the right finger(s) try your thumb
    7. 06-28-2008 11:19 AM #6
      Quote, originally posted by bignivanut »
      WOW
      If you think stock was fun, try it with double the power. ~30psi from a Holset = fun. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    8. Member i4turbo's Avatar
      Oct 25th, 2006
      London, Ont
      '86 Jetta TDI
      06-28-2008 11:36 AM #7
      I owned 2 87 TCs both 5spd... AMAZING CARS
      You cant kill the dam thing... all day abuse nothin happens
      10.5k is too much for me right now... but good luck on sale
    9. 06-28-2008 11:38 AM #8
      I should also mention, since it's an 87....NO EMISSION TESTING EVER AGAIN!
    10. Member bignivanut's Avatar
      Dec 11th, 2006
      Bluevale Ontario
      06-28-2008 12:14 PM #9
      It would probably even pass as it is. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      I had my 87 up to 245 out on the prairies, it had a wrinkled up Lrear quarter and felt a little squirrely at that speed.
      ever test it on 1/4 mile?
      It needed a headgasket after I got home.
    11. 06-28-2008 12:35 PM #10
      No 1/4 times on it. I was planning to get it out this year. I may get it on the dyno soon.
    12. 06-28-2008 12:39 PM #11
      Quote, originally posted by i4turbo »
      Forged bottom end from the factory. These will take over 500hp(been done by lots of people on Turboford.net).
    13. Member
      Mar 15th, 2003
      London Ontario Canada
      06-28-2008 05:16 PM #12
      as much as i dont care at all about turbo coupes, that is ****ing badass [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] :thumbup
      edit: does this thing have LSD ?
      Modified by optiks at 1:17 PM 6-28-2008
    14. 06-28-2008 06:40 PM #13
      Quote, originally posted by optiks »
      Yeah, it's got an 8.8" posi with 3:73 gears.
    15. 07-01-2008 01:43 PM #14
    16. Member BoraVR's Avatar
      Mar 13th, 2005
      Toronto
      '87 MK1 Cabby, '08 B6 Passat
      07-03-2008 01:46 AM #15
      seriously badass car [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Mk1 Mayhem
      ______________
      VRSociety #142
    17. 07-03-2008 09:58 PM #16
      Quote, originally posted by BoraVR »
      Thanks!
    18. 07-04-2008 11:21 AM #17
      Now in AutoTrader.
    19. 07-05-2008 03:04 PM #18
      What a sexy machine, good luck with the sale, worth every $.
    20. Member lowblackdub's Avatar
      Sep 12th, 2000
      Tiny, ON.
      07-06-2008 12:26 AM #19
      Have you posted it up on http://www.gtamc.com?
    21. 07-06-2008 11:58 AM #20
      Quote, originally posted by lowblackdub »
      I'm a member but have no posts, so I can't post a FS ad there.
    22. 07-21-2008 12:37 PM #21
      Price lowered to $9500.
    23. 07-27-2008 11:50 AM #22
      Price lowered again. $8500
    24. 08-04-2008 03:13 PM #23
    25. 09-17-2008 03:28 PM #24
      $7500.
    26. 09-20-2008 11:28 AM #25
      SOLD!
