VWVortex.com - Another Mk2 VR6T
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 40
    Thread: Another Mk2 VR6T
    1. 10-09-2008 04:40 PM #1
      Sold
      '92 VW Mk2 GTi Montana green 2.8L VR6T Obd2
      '98 VR6 2.8L engine: 107k miles on the engine when the swap was done by Black Sheep Performance in Las Vegas. Car was painted some years ago by previous owners and has your usual dings here and there.
      Kinetics Stage I turbo kit
      T3/T4 57 trim
      #30 Injectors
      Kinetics turbo manifold
      38mm Tial Wastegate/ 5psi spring
      2.5" kinetics downpipe
      C2 #30 tune software... the plugged in O2 version(2006)
      kinetic manual boost controller
      Tapped oil pan
      Turbo oil feed line/drain
      Bosch sparkplugs
      -Engine is ready for the next step(Kinetic Stage III), you just need to upgrade to the #42 injectors and the #42 tune
      Custom Intercooler (ATP Front Mount Intercooler Core/CTSturbo intercooler pipes | Thanks Nardie of ctsturbo)
      9.1 Compression Headspacer & ARP Headbolts |Thanks to 034 motorsports -Javad
      NEW walbro Inline Fuel Pump |thanks to Clay
      2 12" Hayden Thin Fans
      New thermostat housing/crackpipe/thermostat
      New Coolant temperature sensor
      New front and rear BFI Stage I motor mounts
      New VF engineering tranny mount
      New coolant overflow bottle
      New front O2 sensor
      New cam position sensor
      New neuspeed Ignition Wire set
      New serpentine belt
      2.5 inch exhaust system /borla muffler
      Schimmel 11lbs battery relocate tray
      Lightweight 11lbs deka(braile) battery
      Drivetrain
      MK3 VR6 Transmission O2A, New Oem VR6 Sach Clutch
      Suspension
      Bilstein sports front struts and rear shocks
      Neuspeed race springs
      Eurosports rear tie bar
      New hd front strut mounts,
      New strut mount bearings
      Brakes
      MK3 DE 11.3 brakes, cross drilled rear rotors, plain vented front rotors
      Wheels and Tires
      15x7 Drivers Edition Wheels, 205/50x15 Falken Azenis tires
      Exterior
      Chrome Door Handles
      Bonrath round badgeless grill
      Inpro crystal clear round lights/H4
      New Jom hood lift
      Smoked front turn signals
      flat black textured fender lights, rear spoiler with 3rd brake lights, hood hatch.
      Interior
      42nd draft design VDO panel/gauges(Boost/vacuum, Oil Pressure, Voltmeter)
      New Nardi steering wheel
      New Hand brake leather covering
      Nardi to Momo wheel adapter
      MK3 DE shifter boot/knob with red stitching
      Custom Upholstered Recaro trophies
      Mk3 leather rear seats with headrest
      New recovered headliner (profesionally recovered), head rest
      Euro seatbelt
      MK3 instrument gauge cluster
      GTi front mats
      New chrome billet mirror control
      Chrome window cranks
      Chrome sunroof crank
      Modified by omllenado at 12:30 AM 4-20-2009
      Modified by omllenado at 12:18 PM 4-22-2009
      Modified by omllenado at 5:16 PM 4-23-2009
      Modified by omllenado at 11:12 PM 4-25-2009
      Modified by omllenado at 12:01 AM 5-29-2009
      Modified by omllenado at 12:03 AM 5-29-2009
    2. Remove Advertisements
      Advertisements
      Nov 27th, 2004
      Charlotte, NC
      2000 VW Jetta VRT, 2000 Audi TT Quattro
      10-10-2008 08:22 AM #2
      Looking good! Some tight clearances back there with the stock mani...where did you get that interesting looking silicone adapter for the DV?
      Mike
      Chapter 11 Dubs: Member #001
      http://www.chapter11dubs.com
    4. Member 2pt. slo's Avatar
      Jan 4th, 2004
      Creedmoor, NC
      98' GTI 2.0T, 12' TDI SportWagen
      10-10-2008 09:03 AM #3
      Quote, originally posted by FaelinGL »
      IIRC isnt that the kinetics piece that comes with the kit?
    5. Remove Advertisements
      Advertisements
    6. 10-10-2008 11:46 AM #4
      Yeah it's just the regular hose that I cut to install. I couldn't find a bigger heater hose that 5/8s from kragen...
      Question:
      I can delete that coolant hose that connects to the throtle body right and just loop the hose back into the overflow bottle.
      Modified by omllenado at 8:48 AM 10-10-2008
    7. Former Advertiser CTS Turbo's Avatar
      Oct 2nd, 2008
      Vancouver, BC
      01 S4, 02 996TT, 04 A4, 12 Golf R, 15 GTI, 12 TTRS
      10-10-2008 04:40 PM #5
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] niiiiiiice
    8. 10-10-2008 04:50 PM #6
      Quote, originally posted by Clay @ CTS Turbo »
      Thanks for your help Clay [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Aug 24th, 2006
      05 LGT Ltd
      10-11-2008 10:25 AM #7
      Quote, originally posted by omllenado »
      Question:
      yes. just make sure you plug the TB return line also.
    10. 10-11-2008 11:16 AM #8
      I'm actually running thin fans so I gained a little more room at the driver side...
    11. Member SINISAR32's Avatar
      Mar 4th, 2008
      Trisity
      2004 VW R32T
      10-11-2008 02:24 PM #9
      Miss that thing
      Im glad you toook over where I stoped
    12. 12-04-2008 12:02 AM #10
      10psi is fun. Can't wait for 15-17psi.
    13. Member xpalendocious's Avatar
      Nov 28th, 2003
      El Sobrante CA
      560AWHP VR6T Quattro 92 GTi / 2004 Touareg 4.2 / 1992 GTI VR6 PRPLVR6 / 88 Vanagon GL Weekender
      12-04-2008 12:47 AM #11
      damn havent seen your car in a while
    14. Member firestartergli's Avatar
      Feb 13th, 2004
      Edmonton, AB
      90 434WHP VRT GTI, 85 mk1 Conv, 1982 VW Caddy, 89 5L mustang Turbo'd, 2013 Tiguan daily, and more
      12-04-2008 02:30 AM #12
      I really like your car, good stance, I have a mk2 GTI with a VRT as well, still 4 lug though, I was wondering what the azenis looked like on factory DE wheels as I am swapping to them wtih the 5 lug over Christmas, Cheers man, Good looking car you have there
      Check out Buster, my Nitrous fed VR6 mk2 GTi here
      https://forums.vwvortex.com/showthrea...9#post75591029
      Trouble from the get go!!!
    15. 12-04-2008 10:29 AM #13
      Quote, originally posted by xpalendocious »
      Yeah man what's up with that?. haha I wish I have 3.0L, ur car is my cars idol. Still need some tuning
    16. 12-04-2008 10:30 AM #14
      Quote, originally posted by firestartergli »
      Thanks, but sometimes I wish I have 4 lugs coz I couldn't run bbs rm's and wider 9s. The 11" brakes not really that great after putting on that turbo.
      Modified by omllenado at 7:32 AM 12-4-2008
    17. 12-10-2008 09:57 PM #15
      oliver, have u thought of spraying the Intercooler flat black??
    18. 12-10-2008 10:23 PM #16
      Quote, originally posted by vdub4tw »
      I thought about it but I don't wanna mess up the intercoolers cooling efficiency. Might be putting a black screen mess to hide the teeth
    19. Member sxracer001's Avatar
      Jun 27th, 2005
      12-11-2008 10:17 PM #17
      check out eastwood, they have radiator paint
    20. 12-12-2008 01:36 AM #18
      Quote, originally posted by sxracer001 »
      Thanks for the info.
      Oh I need one of those triangle mirror thingy.
      Modified by omllenado at 10:39 PM 12-11-2008
      Modified by omllenado at 12:28 PM 3-21-2009
    21. Member MKIIsleeper's Avatar
      Jul 7th, 2000
      Lower Mainland, B.C.
      12-12-2008 09:49 PM #19
      Nice and clean!
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] for a Montana VRT twin!
    22. 12-13-2008 03:53 PM #20
      Quote, originally posted by MKIIsleeper »
      Nice and clean!
      U have one too?. Any pictars?.
    23. 01-09-2009 03:30 AM #21
      Before garage shots.
      She's been hinernating in the garage since Dec so I gave her some treats a few days ago... Chromesicle
    24. Member Jettin2Class's Avatar
      Jun 26th, 2002
      02 Passat Wagon
      01-20-2009 10:53 PM #22
      Nice stuff all the way around. I've had my FMIC lightly misted black ~forever. I can show you 8 near consecutive dyno pulls right on top of each other. Unless you go gonzo and clog fins and such, I don't think it makes much difference.
    25. 01-21-2009 12:06 AM #23
      Actually I was thinking about doing that or a black grill.
    26. Member Jettin2Class's Avatar
      Jun 26th, 2002
      02 Passat Wagon
      01-21-2009 07:42 AM #24
      Old picture that I've cleaned up a bit since then and hacked the last few fins:
    27. 01-21-2009 10:56 AM #25
      That's a sleeper right there
