VWVortex.com - Wagon turbo project
    Page 6 of 6 FirstFirst ... 23456
    Results 126 to 142 of 142
    Thread: Wagon turbo project
    1. 08-02-2009 12:12 AM #126
      I have to move my seat forward a notch to have the folded down so i don't drive around with it down if i don't have too. put on my parked i leave the seat down to prevent fading.
    3. Junior Member
      Jul 10th, 2019
      NorthEast Indiana
      1988 VW Fox Wagon, 1993 VW Fox 2 door(sold), 1973 Roadrunner, 1995 Bronco, '12 Sonata
      07-10-2019 03:16 PM #127
      Long shot here, but are any of you guys still active? I have some questions. I love the build!
    4. Member reddfoxx's Avatar
      Sep 18th, 2005
      CMH OH
      2005 Sentra, 2003 Element
      07-12-2019 11:52 AM #128
      Still here, surprised to see this pop up- I just sold it to one of the other guys. I'll see what I can remember!
    5. Member bluetoes591's Avatar
      Apr 3rd, 2009
      Burnaby, BC
      1990 Fox Coupe GTI, 1988 Fox wagon, 1997 Golf 4dr 1.8, 1988 Fox 4dr RIP, 1989 Fox Wolfsburg RIP
      07-12-2019 12:37 PM #129
      Quote Originally Posted by reddfoxx View Post
      I'm guessing that's your car that Jonathan is stealing parts from then.
    6. Junior Member
      Jul 10th, 2019
      NorthEast Indiana
      07-12-2019 01:20 PM #130
      So to break it down, QTD turbo, oil pan (direct fit?), oil filter flange (direct?), the drain and supply oil lines, and exhaust manifold. I have heard that you need to "persuade" the manifold on. What's the deal with the oil pump and pickup swap, is that a big issue? Did you use a Quantum Turbo Diesel exhaust manifold?
      Sorry for all the questions, I'm very interested in turbo-ing my fox
    7. Member reddfoxx's Avatar
      Sep 18th, 2005
      CMH OH
      07-13-2019 11:59 AM #131
      QTD turbo, pan, filter flange, lines- yes. I'd have to look back through the thread to see which exhaust manifold for sure. I sold the car to Dasbaldguy, not Jonathan, but who knows?
    8. Junior Member
      Jul 10th, 2019
      NorthEast Indiana
      07-16-2019 02:29 PM #132
      Thanks for the reply! I'm looking to boost my fox, but it is so difficult to use parts from other cars instead of full custom set ups (not in budget). I love the build, I read it a couple times a week!
    9. Member reddfoxx's Avatar
      Sep 18th, 2005
      CMH OH
      07-17-2019 11:15 AM #133
      Glad it helps!
    10. Member voxwagen88's Avatar
      Dec 8th, 2001
      North Vancouver
      1990 Fox Wagon, 2003 Jetta Wagon
      07-31-2019 11:33 AM #134
      Would this do for the exhaust manifold?
      https://spaturbousa.com/collections/...-turbo-tmw07t3
    11. Junior Member
      Jul 10th, 2019
      NorthEast Indiana
      08-01-2019 10:39 AM #135
      Yes it will!
    12. Junior Member
      Jul 10th, 2019
      NorthEast Indiana
      08-01-2019 10:41 AM #136
      Just keep in mind that the manifold is set up for an external wastegate. So you'll either need to run one, or fabricate a block off plate and run an internal wastegate.
      *disclaimer* I have not ran the SPA manifold and cannot vouch for its fitment. But I have read on here that it works well.
    13. 08-31-2019 04:20 PM #137
      QTD turbo (3K or Garrett--both exist,) EM, filter flange, oil pain, oil supply and return lines all fit directly to the 1.8L gas engine. A cut-notch-weld is required for turbo-to-body clearance. You might as well make it a generous one so as to allow sufficient space to install and remove the turbo.
    14. Junior Member
      Jul 10th, 2019
      NorthEast Indiana
      09-03-2019 09:13 AM #138
      Is it a must to go to a bigger fuel distributor, like a 5-cyl Audi or a 8 cyl MB?
    15. Member reddfoxx's Avatar
      Sep 18th, 2005
      CMH OH
      09-03-2019 12:01 PM #139
      Yes, the 5-cylinder one lets it dump more fuel in under boost.
    16. Member QuantumSyncro's Avatar
      Apr 28th, 2000
      Des Moines, IA
      97 Jetta TDI, 1990 Passat TDI wagon, 92 300SD turbo
      02-05-2020 01:18 AM #140
      Wow...it's been five years since Longtitudinal was online here, how time has flown....
      Steve
      Did you poison the coffee? Not any more than I usually do.
    17. Member bluetoes591's Avatar
      Apr 3rd, 2009
      Burnaby, BC
      02-05-2020 06:49 PM #141
      Quote Originally Posted by QuantumSyncro View Post
      Steve
      Jonathan is still around, but is divesting himself of Fox stuff and moving on.
    18. Member QuantumSyncro's Avatar
      Apr 28th, 2000
      Des Moines, IA
      02-06-2020 06:44 PM #142
      Quote Originally Posted by bluetoes591 View Post
      Yes, I remember him saying that way back when. I'm surprised that he's not done with it by now honestly, 5 years is a long time to drag something like that out.
      Steve
