VWVortex.com - DIY: Activation of BOTH Rear Fog light
    Page 1 of 7 12345 ... LastLast
    Results 1 to 25 of 171
    Thread: DIY: Activation of BOTH Rear Fog light
      May 27th, 2006
      Montreal (QC)
      Audi A6 2012
      04-05-2009 02:35 PM #1
      Hi,
      I was able to activate both rear fog lights for the CC .
      It works, everything is already pre wired.
      All you have to do is run a trigger wire (000 979 009)from the Euro light switch Pin 7 to the E connector of the J519 module PIN 13
      J519 (Central Electronics Module) is located where the OBD port is. Underneath the drivers side
      Then a minor Vag coding
      in the Central Electronics Module [09]
      Uncheck Bit 1 Byte 3 (to enable both rear fog lights)
      Check Bit 4 Byte 4 (To activate both rear fog lights)
      Uncheck Bit 6 Byte 4 (To activate rear fog lights)
      EDIT :
      To enable only the left rear fog light :
      use the following coding
      Check Bit 1 Byte 3
      Uncheck Bit 4 Byte 4
      Thank you crazywayne311 for the idea
      Lights switch ON
      Dash Board Rear fog light on
      Rear Fog lights OFF
      Rear Fog Lights ON
      Modified by kdagher at 12:02 AM 4-6-2009
    2. Remove Advertisements
      Advertisements
    3. Member Tourenwagen's Avatar
      Dec 28th, 2002
      NJ
      Non-VW
      04-05-2009 04:01 PM #2
      aweome! thanks for posting this. picking up my euro switch next week and wil be doing this [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. Member genuino's Avatar
      Sep 4th, 2006
      Atlanta, GA
      2000 Jetta, 2000.5 4motion Passat, 08 Passat, 09 Passat, 09 CC VR6 4 motion, 09 Tiguan, 09 Touareg
      04-05-2009 05:39 PM #3
      excellent kdagher! I knew I would find a reason to get the euro switch .
      Modified by genuino at 1:41 PM 4-5-2009
    5. Remove Advertisements
      Advertisements
    6. Member
      May 27th, 2006
      Montreal (QC)
      Audi A6 2012
      04-05-2009 11:29 PM #4
      Check Bit 1 Byte 3
      Modified by kdagher at 10:31 PM 4-5-2009
    7. Member crazywayne311's Avatar
      Jan 28th, 2006
      Antarctica
      2017 F150
      04-05-2009 11:53 PM #5
      you took all my glory
      i bought the euro switch and was supposed to get a trigger wire a while ago. but the vw dealership is 45min away. not to mention all my time has been focused on gettin my MK2 back on the road. (which she is back officially on the road)
      awesome deal! so everything we briefly discuss is correct. it was already there...just needed the damn trigger wire. shoulda taken mine out the GLI before i traded it!
      Current: 2013.5 FSM GLI
      Previous: 09 DBP CC, 93 Cabby, 07 DBP GLI, 91 TR GTI 16V, 05 PG GLI....
      Don't **** with Wayne. He is crazy and likes 311.
    8. Member Veedubin02's Avatar
      Mar 25th, 2002
      Chantilly, VA
      Current: 19 Atlas SEw/Tech and 16 Jetta GLI SEL Sport
      04-06-2009 12:18 AM #6
      part number on the trigger wire?
      1991 Toyota Corolla SR5 --- 2002 VW GTI 1.8T --- 2003 Audi A4 3.0 --- 2009 VW CC Sport --- 2010 Jeep Wrangler Unlimited Rubicon --- 2006 Mini Cooper --- 2012 Kia Optima SX --- 2004 Jeep Wrangler Sport --- 2010 VW JSW --- 2016 Mazda CX-5 (Wife) --- 2016 Jeep Wrangler Unlimited Willy's Wheeler --- 2017 VW Jetta Sport --- 2019 Atlas SE w/Tech (Wife) --- 2016 VW Jetta GLI SEL
      May 27th, 2006
      Montreal (QC)
      Audi A6 2012
      04-06-2009 12:58 AM #7
      Quote, originally posted by crazywayne311 »
      I will give you credits
      I just supplied the diagrams to prove it
      Modified by kdagher at 12:04 AM 4-6-2009
    10. Member
      May 27th, 2006
      Montreal (QC)
      Audi A6 2012
      04-06-2009 01:03 AM #8
      Quote, originally posted by Veedubin02 »
      Part Number is 000 979 009
    11. Member crazywayne311's Avatar
      Jan 28th, 2006
      Antarctica
      2017 F150
      04-06-2009 05:14 PM #9
      ha straight ballin! got my trigger wire today! should have rear fogs running in a hour or so!
      May 27th, 2006
      Montreal (QC)
      Audi A6 2012
      04-06-2009 05:41 PM #10
      Congratulations!! Let me know how it goes!
    13. Member crazywayne311's Avatar
      Jan 28th, 2006
      Antarctica
      2017 F150
      04-06-2009 07:55 PM #11
      hey man...ok, so it says my last post was 1:14...so quite possibly 4:15 my time? ok, so the headlamp switch was pretty easy to take apart and installed the trigger wire. i dont know if i took the best path to run the wire but it made its way under the dash. now, on the MKV, none of the harnesses are labeled. the CC has them labeled! took apart that harnesses, installed the other end. zip tied where needed and did the vag coding...yeah, piece of cake! thanks bro!
      oh yeah, and i vacuumed the car out and ate some food. i think i did well on time
    14. Member
      May 27th, 2006
      Montreal (QC)
      Audi A6 2012
      04-06-2009 08:09 PM #12
      lol. Nice!!
      I am glad it worked.
      Check your IM
    15. Member 07SalsaGLI's Avatar
      Aug 28th, 2001
      Toronto, Ontario
      2011 BMW 335i coupe & 2009 328i sedan
      04-07-2009 09:39 PM #13
      Thanks kdagher! Any interest in doing this for a fellow Vortex'r for a few bucks? I spend a lot of time in Montreal
    16. Member crazywayne311's Avatar
      Jan 28th, 2006
      Antarctica
      2017 F150
      04-07-2009 09:52 PM #14
      it takes maybe 30 minutes tops and then vag com changes. that is if you know how to read the connectors and take them apart. i remember the first time i tried on the GLI and i was rather frustrated
    17. Member
      May 27th, 2006
      Montreal (QC)
      Audi A6 2012
      04-07-2009 10:24 PM #15
      Quote, originally posted by 07SalsaGLI »
      Come to montreal, and ill do it for you.
      Free of Charge
      Just buy the trigger wire 000 979 009
    18. Member crazywayne311's Avatar
      Jan 28th, 2006
      Antarctica
      2017 F150
      04-07-2009 10:54 PM #16
      couple pics of my rear fog done
    19. 04-07-2009 11:30 PM #17
      Looks great. I wish I had enough skill to do this. If I understand correctly most of the parts are already in the CC except for the light switch and a trigger wire (no idea what a trigger wire is).
    20. Member
      May 27th, 2006
      Montreal (QC)
      Audi A6 2012
      04-08-2009 12:31 AM #18
      Quote, originally posted by grandbay »
      will post pics of what a trigger wire looks like.
    21. Member crazywayne311's Avatar
      Jan 28th, 2006
      Antarctica
      2017 F150
      04-08-2009 06:58 AM #19
      ha its a yellow 16/18 awg wire about 18" long...and has a funny connector pin at each end
    22. Member 07SalsaGLI's Avatar
      Aug 28th, 2001
      Toronto, Ontario
      04-08-2009 02:13 PM #20
      Quote, originally posted by kdagher »
      Free of Charge
      Cool ! I will be in Montreal April 16th to the 16th. IM me with your email so I can email you directly. THANKS!
    23. Member piperpilot964's Avatar
      Aug 24th, 2009
      CT, USA
      2009 CC Sport, Candy White
      10-29-2009 10:36 PM #21
      Just finished the whole euro switch install and rear fog activation....
      A few things to add to this for clarity and ease if you have never opened up the dash or connectors on a CC, like I had not.
      Remove your storage bin in the left knee panel. Open it, and there are two large plastic tabs in the top part of the dash inside the bin. Push them up and the bin will hinge down and you can pull it away. Makes running the trigger wire very easy.
      The connector plug that goes into the light switch... Snip off the factory wire tie on the end. Then use a tiny flat head to open the clip on the side, give the shell a twist and it will slide apart. Pay attention when inserting the wire into the plug so that the spring side of the pin faces the holes on the connector side. Snap the shell back on, put on a new wire tie and run the trigger wire down toward the ECU. Use a couple of zip ties to secure it in place. Plug the light switch back in.
      Connector on the ECU module is E as noted. Both E and F are the same physical connector. You wil see a red bar running the length of the module between all the plugs and it will say "Auf" with an arrow pointing to the passenger side. Slide that puppy in the direction of the arrow to remove plug E. Once the plug is out, you will see a tiny tab on the plug...put a tiny flat head into the tab, twist a bit and the plug housing slides out of the shell to reveal the pin out numbers and allow you to insert the trigger wire. There is only one pin 13 labled on the whole connector so you can't eff that up. Pay attention to how you insert it so the spring side of the wire pinfaces out the holes on the side of the connector. Pop the plug bac in, slide the red bar to towards the driver side and tehn button up the dash panel.
      Follow the VAG Com instructions and the you are off and running with rear fogs. Whole process should take you like 45 minutes tops.
    24. 10-31-2009 04:08 PM #22
      I have a stupid question. I was planning on doing this today but missed the delivery of the cable for the vag com part that came today. If I do the wiring today, will there be any problems with the lighting if I wait till Monday to do the vag com changes?
    25. Member piperpilot964's Avatar
      Aug 24th, 2009
      CT, USA
      11-01-2009 05:02 PM #23
      I dont think you'll have any lighting issues with the trigger wire and switch there and no vag codding.
    26. 11-02-2009 01:21 PM #24
      Quote, originally posted by piperpilot964 »
      I have recoded and am waiting for my local dealership to get the wire in. Hopefully, wed.
      Thanks for the posting, kdagher
    27. 11-03-2009 12:49 AM #25
      EDIT: Wow I am a massive idiot, I didnt pull it out one more notch for the rears. Everything is working great! Thanks for the tips, they really helped.
      Also got my clear turns on, so I'm happy
      Modified by TennisBall at 8:58 PM 11-2-2009
