VWVortex.com - polo/ibiza stub axle on a golf mk1 to mk3 guide
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 50
    Thread: polo/ibiza stub axle on a golf mk1 to mk3 guide
    1. 04-23-2009 11:53 AM #1
      The polo stub axle is from 1995 to early 2002 ie 6n, also seen on Seat Ibizas form 1998 to 2002
      It tends to be the 16v and diesel Polos that have rear disk brakes
      The complete assembly can used but if you use the polo calipers you will need to get flexy pipes with the bango
      There are two sizes of calipers: 34mm and 38mm
      Both sizes have been listed for the mk2 in the past, and Mk4 golf has 38mm ones
      You will just have to see what is allready fitted and use the same size or you may need to reset the brake bias compensator
      Mk4 golf calipers will fit but Mk4 carriers wont (same as if you were fitting Mk4 calipers to a Mk2/3 golf)
      All mk2 and mk3 and polo carriers will fit
      Discs and backplate
      Polo calliper
      Hear is a list of part numbers used:
      right side
      stub axle =6n0501118
      hub complete with nut and cover and ABS ring = 6x0598477
      splash shield = 6n06 156 612
      brake disc = 6n0 616 601a
      bolt stub axle to beam =n90758901 (4 of per side) M10x30
      bolt for brake carrier =n90740301 (2 of per side) M10x1.25x30
      left side
      stub axle =6n0501117
      splash shield = 6n06 156 611
      With all the old stub axle removed you shoud be left with this.
      If you have a mk1 at this stage you will have to grind the bottom rear corner to let the stub axle sit flat
      It is best to clean the axle threads out with a M10 tap since the Polo bolts are a bit longer
      New stub axle and stone gard
      ones the stub axle face is cleaned up you can fit the axle and back plate
      and torque the four bolts to 60 nm or 44 ibf ft
      then you can fit the hub new hubs will be pre greased but i tend work some grease
      in to the bearing then torque the self-locking 12-point nut to 175 nm or 129 ibf ft
      then fit the cap dont over fill with grease or the cap will blow off
      Then check the hub face is clean and flat and fit the brake disk and tighten the screw
      Longer bolts for calliper carrier M10x1.25x30 i went for hex bolts instead of alan bolts
      Fit the carrier and torque to 65 nm or 48 ibf ft
      Then fit the pads and reset the pad clearance on the caliper and fit bolts and torque to 35 nm or 26 ibf ft
      Refit the hand brake cable and ajust
      Fit wheels and torque wheel nuts to 110nm or 81 ibf ft with the car on the ground
      then work the hand brake and pump the brakes
      If you fitted new calipers you would obviously bleed them at this point
      Finished:
      this a list of cars that have the stub axle with the part no 6n0501117 and 6n0501118 fitted
      Polo/Derby 1995 , 2002
      Polo Classic/Variant 1997 , 2000
      Cordoba/Vario 1997 , 2002
      Ibiza 1997 ,2002
      Modified by MUSHY 16V at 8:55 AM 4-23-2009
      Modified by MUSHY 16V at 8:56 AM 4-23-2009
    2. Remove Advertisements
      Advertisements
    3. Member typeSLone's Avatar
      Feb 7th, 2002
      Stock blocks, NJ
      91 GTI VR6, 06 A4Q 2.0T
      04-24-2009 12:09 PM #2
      I like that rear bearing setup much better than what the mk2/mk3 cars have. Makes rear brake jobs a piece of cake with no bearings and races to play with.
      Unfortunetly Im not sure what the availability of those parts in the us are. I should go and see whats actually available in the warehouse.
      07 Jetta 2.5 - the daily driver
      91 GTI VR6 - the all motor mess [email protected]
      06 A4Q 2.0T - all the boost - gone but not forgotten
      87 and 92 Jeep Cherokees - Lifted, loud and filthy - long gone but never forgotten
      Caste Systems Performance Lugtronic
    4. Member typeSLone's Avatar
      Feb 7th, 2002
      Stock blocks, NJ
      04-24-2009 12:12 PM #3
      Just checked parts on command. Those stub axles, bearings and brake discs are not available in the us warehouses. Its a shame, thats definetly one setup I would run.
      I bet for the us guys world impex or northside could get that stuff.
    5. Remove Advertisements
      Advertisements
    6. Member VWn00b's Avatar
      Mar 4th, 2005
      Dallas, Tx
      1997 Jetta
      01-28-2010 06:25 PM #4
      bump for the hell of it.
      anyone come up with info on getting these parts in the US?
    7. Member Sosl0w's Avatar
      Aug 21st, 2003
      Fredericksburg, VA
      10-27-2010 02:13 PM #5
      Quote Originally Posted by VWn00b View Post
      this
      B5 S4
      84 GTI (Sold)
      03 24v turbo (sold)
      Aug 28th, 2007
      11-01-2010 12:00 PM #6
      Ive been looking for a way to fit 20th/GLI brakes on my MK3 as i have R32 brakes on the front which is causing the rears to look tiny. Seems like this is the ticket. I have an overseas parts hookup im going to see if he has some polo stub axles...anyone interested in a set?
    9. 02-15-2012 02:43 PM #7
      When using this set up does it keep the mounting face of the disc at exactly the same distance from the axle as the mk 2 set up? my wheels are right on the edge of my arches as it is and dont need them pushed out any further!!!!
      I understand the disk face must be the same as you use the mk 2 carriers but just the mounting face i am asking about.
      Cheers. Yes i know the thread is old
    10. Junior Member 1 6 D's Avatar
      Jan 21st, 2009
      07-16-2012 03:23 AM #8
      Are wheels wider with this set of brakes than stock 226 brakes?
    11. Member d-bot's Avatar
      Sep 6th, 2004
      Seattle
      S1 Storm 20vSC-AWD, 93 Corrado VR6
      02-26-2013 11:01 PM #9
      Quote Originally Posted by 1 6 D View Post
      bump for this answer.
    12. Member PinoyVR6's Avatar
      May 23rd, 2003
      Norwalk, CT
      90 Nugget Yellow Corrado, 2003 Jetta W>E
      03-05-2013 11:04 PM #10
      Bump
    13. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      12 Golf 2.5, 90 Jetta GLI 16v, 99.5 Cabrio Highline, 92 Golf GL
      03-11-2013 08:32 PM #11
      Quote Originally Posted by d-bot View Post
      In the thread I saw on clubgti, they said no. I don't see why it really would be anyway.
      I'm looking for a way to do this with a 5 lug conversion, but apparently the Mk4 stub axles have a bigger diameter than the Polo ones (ie a 5 lug hub/bearing won't fit on a Polo stub axle).
      A2Resource
    14. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      10-20-2013 03:31 PM #12
      Quote Originally Posted by VDub2625 View Post
      Just to follow up on this, I found that you can use Polo 9N bearings (part 6Q0598611), which are 28mm inner diameter (like these stub axles) and 5 lug. Then it's just a stock mk4 brake disc.
      A2Resource
    15. Member Malkierie504's Avatar
      Oct 6th, 2007
      New Orleans, Louisiana
      current: '60 Cadillac ambulance/hearse combo, '01 MK4 GTI GLX Sold: 88 Nissan Pulsar xe w/ sportbak
      11-11-2013 10:10 PM #13
      has anyone sourced a good state side supplier for these parts yet? or have a good non-us source. I thinki good case could be made to offer this as a kit to the mk3 community for a reasonable price here in North America.
    16. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      11-12-2013 01:37 AM #14
      Unfortunately I've found the parts bought at a Euro dealer are like $500 I hope superior could find a much more normal source.
      Sent from my LG-LS970 using Tapatalk
      A2Resource
    17. Member Malkierie504's Avatar
      Oct 6th, 2007
      12-24-2013 07:30 AM #15
      Think you could post the party numbers for the stub axles?
    18. Member d-bot's Avatar
      Sep 6th, 2004
      Seattle
      12-24-2013 10:37 AM #16
      So I am reading this as this Polo 9N stub axle will accept a mk4 bearing and hub assembly. Is this correct?
      Thanks. I plan on doing this swap but depending on what parts I can get, aka the polo parts, I may just use all mk4 parts instead. Then just mod the beam to accept the brake tabs.
    19. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      12-24-2013 01:05 PM #17
      You read that wrong. A polo 9n BEARING (28mm) will fit on a polo 6n stub axle (the ones mentioned earlier in this thread). Then a mk4 brake disc fits.
      A2Resource
    20. Member Malkierie504's Avatar
      Oct 6th, 2007
      12-24-2013 02:08 PM #18
      I was looking for the 5 lug polo hub part number. I'd like to put this swap into a mk3 jetta vr6.
      Posted via Topify on Android
    21. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      12-24-2013 03:20 PM #19
      I posted it. The bearing and hub are integral like a mk4.
      A2Resource
    22. Member d-bot's Avatar
      Sep 6th, 2004
      Seattle
      12-24-2013 11:23 PM #20
      So pretty much a bunch of over priced euro parts and you can do the swap. Looks like I will mod my beam to take the cheaper full mk4 conversion.
    23. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      12-25-2013 04:23 AM #21
      I've heard of adapter plates (custom), but not beam mods. Post if you do.
      A2Resource
    24. Member
      Mar 23rd, 2008
      N/A
      N/A
      12-29-2013 01:21 PM #22
      My son is in the Army, and will be stationed in Germany late next year.
      I'm thinking that (if I remember when the time comes) I may be able to get him to look for reasonably priced used parts, and have him ship them home to the U.S.
      As interesting as the conversion looks, I don't find maintaining conventional wheel bearings to be a burden, nor have a problem when they eventually wear out. So, I'm not looking to spend a whole lot on the conversion.
    25. Member GTi2OV's Avatar
      Oct 10th, 2002
      03-04-2014 09:36 PM #23
      Any updates from anyone? Whether it be Polo parts or mk4 custom parts.
      PVW 5/11
      89 golf gl ~ 08 passat gl~ 11 touareg gl
    26. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      03-05-2014 03:17 AM #24
      I haven't been able to get the 5 lug stuff working. The sub axles are way to expensive new and I haven't been able to find anything used. The 5 lug bearings might or might not fit after research too, but they're cheap.
      A2Resource
    27. Member GTi2OV's Avatar
      Oct 10th, 2002
      03-08-2014 01:10 AM #25
      I would love to have this rear brake setup! I want to know more!
      PVW 5/11
