VWVortex.com - DIY: 2009 Premium 7 Radio display colour change
    Results 1 to 19 of 19
    Thread: DIY: 2009 Premium 7 Radio display colour change
    1. Member angelico's Avatar
      Jul 11th, 2008
      Nova Scotia
      Cobalt Blue '09 Passat Wagon 6MT Comfortline
      08-22-2009 05:07 PM #1
      Ok, so here's the problem: The Premium 7 radio display colour does not match the new style instrument cluster. In fact it is a really dark blue and the text is sometimes difficult to read. Now, I'm a fan of blue but it just doesn't look right here.
      Solution: Change the LEDs!
      Tools required:
      T-20 torx driver
      #1 Philips driver
      small flat blade screwdriver or other non-marring pry tool
      Good soldering tools and the knowledge of how to use them
      12* 4mm*4mm right angle LEDs (part numbers at bootom of post)
      STEP 0:
      - the original setup. My camera isn't too good at night without the flash but you get the idea.
      STEP 1 (remove radio):
      - Remove radio as outlined in this thread:
      https://forums.vwvortex.com/zerothread?id=2186433
      STEP 2 (remove front panel):
      -There are 4 clips on the each of the top and bottom, plus 2 clips on the each side that need to be released and then the whole front panel comes off.
      STEP 3 (remove PCB):
      -Remove the 5 philips screws that hold the circuit board to the plastic with all the buttons.
      -The circuit board should just come off.
      STEP 4 (get access to LEDs):
      -Next desolder the the 2 points that hold the display cover to the circuit board (circled) and bend the 6 tabs so they are straight (arrows). I forgot to take a proper picture with the board out at this point.
      -The display should come away from the front of the circuit board now. DO NOT TRY TO DISCONNECT THE CONNECTOR ON THE BACK!! Fold it gently up and behind the circuit board. The LEDs we want to work on are circled.
      STEP 5 (change LEDs):
      -Remove the old LEDs. I found using a pair of solder tweezers worked really well, ideally you want apply heat to both pads at the same time.
      -Clean up the pads with some solder wick and alcohol. If there's too much solder on the pads, it will be more difficult to place the new LEDs. The alcohol just makes the board look pretty...
      -Put on the new LEDs. I found that if you had one pad completely clear of solder and one with just a tiny amount you could hold the LED in place while melting the "soldered" side. Then once it's properly in place, you can add some solder to the "clear" side and it will sit perfectly.
      STEP 6 (reassemble):
      -Essentially, reassembly is the reverse of disassembly. Take the time to clean the display now while it is apart (you can slide the metal piece off the display). Don't forget to rebend the clips and add the 2 points of solder to the metal piece surrounding the display.
      -Put the 5 screws back in place and the whole piece should snap back onto the radio without much force.
      STEP 7 (enjoy):
      -Here are some pics of the finished project.
      EXTRA NOTES:
      -I tried white and light blue LEDs to see which would look better. I decided to go with the white but the light blue would have looked pretty good as well.
      Of course, you can change your other LEDs as well. The ones for radio buttons are 3.5mm*2.8mm and come in a wide range of colours.
      All LEDs are from Kingbright USA. http://www.kingbrightusa.com/default.asp
      Specs:
      light blue = AA4040QBC/D, 470nm, typical intensity 150mcd (seem brighter than stock)
      white = AA4040RWC/A, typical intensity 300mcd (don't seem that bright in radio)
      I believe the stock dark blue LEDs are 465nm and 280mcd
      I have some extras for sale if anyone is interested. Light blue $12us shipped, White $15us shipped. I can also mod your radio for $50 plus shipping.
    3. Member briankstan's Avatar
      May 22nd, 2009
      West Jordan, Utah
      06' 3.6 Passat 4-Motion
      08-22-2009 06:51 PM #2
      I can't believe that VW changed the instrument cluster and not the radio, steering, and door buttons.
      In my opinion it looks very bad.
      Great job on the DIY for this, it's a perfect mod IMO. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    4. Member jhtopilko's Avatar
      Dec 3rd, 2006
      Edmonton, Alberta
      2009 silver leaf passat wagon
      08-22-2009 07:47 PM #3
      Looks good. I may even do my 07.
      The first line of defense is You. H&R springs Bilstein sports APR stage 1, Magnaflow exhaust.
    5. Remove Advertisements
    6. Member angelico's Avatar
      Jul 11th, 2008
      Nova Scotia
      08-22-2009 07:49 PM #4
      Thanks.
      Personally, I wanted to change all of the lighting inside the car to blue, but it was going to be waaay too much work.
      yaya, bunch of mods go here... | www.angelico.ca |
      buy my extra stuff https://forums.vwvortex.com/showthrea...olf-things-too
      --Have VCDS in Nova Scotia, PM me if you need a hand...
      Jun 8th, 2008
      Baltimore, MD, USA
      08 Passat 2.0T Apr Stg 2(Sold)|09 A4 Prestiage S-Line Quattro Apr Stg 1|2015 Q5 3.0T P+
      08-22-2009 08:48 PM #5
      i hope i am able to change the entire interior into white leds.
    8. Member SWES2006's Avatar
      Jul 26th, 2006
      02 v6 4mo wagon,08 Komfort wagon,13 cc v6 4mo 17 Passat R-line ,2019 Arteon R-line 4mo
      08-22-2009 09:05 PM #6
      WHY.............................. ??// get a navi please
    9. Member angelico's Avatar
      Jul 11th, 2008
      Nova Scotia
      08-22-2009 10:07 PM #7
      Quote, originally posted by SWES2006 »
      haha, company car, don't want to put too much of my personal money into it. The nav would be cool though!
      Jun 8th, 2008
      Baltimore, MD, USA
      08-23-2009 11:07 AM #8
      the new RNS510 sounds horrible without dynaudio...
    11. Member type17volkswagen's Avatar
      May 2nd, 2004
      Lost River, WV
      17 Tiguan
      08-23-2009 01:26 PM #9
      First off, WOW - great write up.
      Second off - glad to see I'm not the only one that is bothered by the fact that VW's cheapness messed up the mood/feeling/ambience. The first time I saw the new white-light cluster I liked it. When I looked to the radio and saw it was blue, I thought "This just isn't VW's style. They spend lots of time (money) to make sure the interior details are just right. Times must be tough..." Of course that was the Passat 2009 MY running-change. Now that I see the plan was to migrate to the Premium 8 it all makes sense (and works visually). But man, cheaping out on all those cars just wasn't right.
      Thanks for pointing out a way for folks to "fix" this. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Mar 20th, 2001
      2007 Porsche Cayman 5MT; 2009 VW Passat Highline Wagon 6MT; 2017 VW Golf R 6MT Tech Pack
      08-23-2009 03:57 PM #10
      Wow, fantastic change. It looks so much better. Does it still dim with the rest of the panel (I assume it does)?
      Quote Originally Posted by 20aeman View Post
      No, the real enthusiast vehicle would be the RX8. It combines V12 Lamborghini gas mileage with Hyundai Genesis 4cyl. performance.
    13. Member Squillo's Avatar
      Sep 17th, 2004
      Central Florida
      2006 VIP Passat, a few others too
      08-23-2009 07:53 PM #11
      I just changed my head unit, but that is a very good write up thanks
    14. Member angelico's Avatar
      Jul 11th, 2008
      Nova Scotia
      08-24-2009 01:05 AM #12
      Yep, it dims just like factory. Finally drove it at night tonight, I think it's a little brighter than it should be so I think I'll take it apart and make an adjustment or 2.
    15. Member
      Mar 20th, 2001
      08-30-2009 08:33 PM #13
      How did switching to dimmer LEDs work out?
    16. Member angelico's Avatar
      Jul 11th, 2008
      Nova Scotia
      09-01-2009 05:35 PM #14
      I haven't been driving around after dark very much (10pm this time of year), so I didn't get around to this until today. I just changed the inline 820 Ohm resistors to 1000 Ohm to reduce the current to the LEDs. They seem just a little bit dimmer, a good match anyway. I really happy with matching colour now.
    17. Member RafaGolfBr's Avatar
      Dec 17th, 2001
      Coconut Creek - FL
      15 GTI SE
      02-19-2010 06:57 PM #15
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] to DIY!
    18. 12-29-2010 08:18 PM #16
      Can someone post the pix to this?
    19. Member angelico's Avatar
      Jul 11th, 2008
      Nova Scotia
      03-06-2011 08:02 AM #17
      thread from the dead
      new server and pics back online.
    20. 06-17-2011 08:22 AM #18
      nice write up. I may look into this. This weekend I am doing the factory bluetooth install. Should be a fun install..
    21. 06-18-2011 11:40 PM #19
      What I have noticed is that the red is much easier to focus than the blue. Human eyes are not very good at focusing bright blue, much better with red, and red doesn't blow your night vision as much as a lot of blue. I like the look of the red and blue, but if I had my choice, I would like to see red digits and words on the dash and blue pointers on the dials. Lot of work to convert it all over, but that would be more functional.
