VWVortex.com - oil filter sensors
    Results 1 to 10 of 10
    Thread: oil filter sensors
    1. Member boner's Avatar
      May 18th, 2002
      Ottawa
      95 golf race car, 12 Audi A3 Quattro, 15 highlander
      01-28-2010 10:26 PM #1
      ok, i've done it about 5 times now and each time i forget which wire goes where and it's a giant PITA to get in there later to swtich them around....so, which wire gos on which sensor please!!!!
    2. Remove Advertisements
      Advertisements
    3. Member dogyouare's Avatar
      Aug 9th, 2009
      Port Orange, FL
      90 Jetta GL, 91 Corrado G60, 96 Golf GTI, 88 300SE
      01-28-2010 10:39 PM #2
      its: green to the back one like u shown..
      left is yellow and right is blue
      but someone tell me if i am wrong but the left sensor should be black top and right is blue top...
    4. Member
      Jul 13th, 2001
      Oakland, CA
      01-28-2010 11:10 PM #3
      The yellow wire goes to the high pressure switch (usually the black one). Normally, the low pressure switch is blue and takes the blue wire. See the picture in this thread.
      It shouldn't really matter which switch is screwed into which hole, but yes, the black switch is usually screwed into the left hole.
      Kenji
    5. Remove Advertisements
      Advertisements
    6. Member boner's Avatar
      May 18th, 2002
      Ottawa
      01-29-2010 06:24 AM #5
      Quote, originally posted by Kenji »
      not the first time man has gotten into trouble over the wrong hole
      thanks for the answers guys, really helps
    7. 03-01-2015 07:32 PM #6
      Hey guys hows it going? My Oil Pressure sensor in Black color according to this diagram picture its the one located on the far left hand side ontop of the Metal square housing is Leaking. How much is this to replace and how hard is it to replace?
    8. Member cgeromi's Avatar
      Apr 30th, 2006
      PA
      '98 GTI Vr6 - Black (DE leftover)
      03-01-2015 07:46 PM #7
      Nice diagram. I was just wondering today what the torque spec was for the oil filter housing drain plug. Now I know.
      Jul 13th, 2001
      Oakland, CA
      03-01-2015 10:22 PM #8
      Quote Originally Posted by 94 SLC Storm View Post
      The switch is cheap, but difficult to get to.
      Kenji
    10. 03-01-2015 10:24 PM #9
      Quote Originally Posted by Kenji View Post
      Ok thanks for letting me know
    11. Member cgeromi's Avatar
      Apr 30th, 2006
      PA
      03-02-2015 12:43 AM #10
      It's not difficult if you take off the front bumper cover and then remove the lock and carrier (front end bumper support, etc). Takes a total of 15 min to remove all of this. While you're in there, you should replace out the seal behind the oil filter housing as well as the oil cooler seals and coolant hoses. Then you can sit back and feel safe you won't have to take off the front end for quite some time.
