VWVortex.com - 2.7t swap
    Results 1 to 2 of 2
    Thread: 2.7t swap
    1. 02-09-2010 07:51 PM #1
      hey i have a 2001 s4 and it was totaled so im getting ready to pick up a 99 a4 is there gonna be any problems with the s4 engine connecting to the stock a4 5 speed tranny
    2. Remove Advertisements
      Advertisements
    3. Member GRMNMUSL's Avatar
      May 22nd, 2009
      New York
      B5 S4 Avant/04' Allroad
      10-03-2018 01:51 PM #2
      Yes it will work once car is a a 2.8. Use S4 ECU and wiring harness. S4 Power steering hose that runs under intake from the back, use A4 2.8 AC line in front by snub (because it wont pull) and the S4 one that goes under. Speed sensor is a 4 pin on S4 and a 5 pin on A4. You just have to jump one pin. Use 2.8 Clutch stuff South Bend works well. Thats it FYI..gears are longer
      on 2.8 Trans it pulls better. Any questions PM Me. BTW...Do not disassemble anything it goes right in and put in NEW Engine mounts when motors out as inlets run right above them and when in car 4-5 hr job due to space.
      Buncha B5's... Too many to list!
      01' S4 Avant/04' Allroad
      Squatt/Chirp/Puff.... Woooooooosh!
