VWVortex.com - How to change air filter remove engine cover basic? 2.0t fsi
    Results 1 to 13 of 13
    Thread: How to change air filter remove engine cover basic? 2.0t fsi
    1. Member 1happydude's Avatar
      Oct 27th, 2009
      Bristol CT
      2006 VW Passat 2.0T
      02-10-2010 12:16 PM #1
      Hey all, I have searched for forums on how to remove the air filter on a 2006 a3 2.0t fsi. I found forums for the vw but not audi.
      Pics would be a huge help cause I need to see exactly what I need to do.
      Any help is appreciated
      Spring is almost here!!!!! Winter tires go AWAY!
    2. Remove Advertisements
      VWVortex.com
      Advertisements
    3. Member boostina3's Avatar
      Jan 8th, 2008
      UK
      - RIP Imola 20th, S54 M Coupe, a3 8p(back in a Coupe Euro S50)
      02-10-2010 12:19 PM #2
      * Unplug the Mass Air Flow (MAF) sensor.
      * Undo the spring clips and pull out the turbo inlet connector.
      * Remove the two T-25 screws on the air snorkle as shown below.
      * Remove the engine cover by pulling up HARD where indicated by the green circles in the photo below.
      * DO NOT APPLY ANY FORCE where indicated by the red diamonds in the photo below.
      * If it's cold weather, make sure the engine is warm so that the rubber grommets warm up and are flexible enough to come off. Cold, brittle plastic and stiff grommets will lead to a broken airbox/cover even if you otherwise do everything correctly.
      * Pull up on the rear driver's corner (near the battery box) first, then the rear corner where the MAF sensor is, then the fronts.
      http://oooo-a3.blogspot.com/20....html
      Modified by boostina3 at 9:22 AM 2-10-2010
    4. 02-10-2010 12:19 PM #3
      the vw gti is same thing so u can use that diy guide.
    5. Member tdotA3mike's Avatar
      Feb 4th, 2009
      Toronto ON, Canada
      2015 AUDI S3 2.0T DSG
      02-10-2010 12:19 PM #4
      Vw FSI's use the same airbox as ours so those instructions would have worked fine...
      New: 2015 AUDI S3 2.0T DSG | Progressive | Sepang Blue | Titanium Grey & Black Interior | Nav | Mag Ride | 19's |
      Old: 2006 AUDI A3 2.0T DSG | Brilliant Black | Premium | Open sky | HPA DSG stage 2 | APR stage 1 | euro LED tails
    6. Member 1happydude's Avatar
      Oct 27th, 2009
      Bristol CT
      2006 VW Passat 2.0T
      02-10-2010 01:19 PM #5
      Awesome pic and info, thats so much!!!
    7. Member 1happydude's Avatar
      Oct 27th, 2009
      Bristol CT
      2006 VW Passat 2.0T
      02-10-2010 03:03 PM #6
      Is this the same cover for the 2.0t fsi passat ang gti? The filters call for the same number and the air box looks like the same shape?
    8. Member tdotA3mike's Avatar
      Feb 4th, 2009
      Toronto ON, Canada
      02-10-2010 03:04 PM #7
      Quote, originally posted by 1happydude »
      should be
    9. 02-10-2010 03:23 PM #8
      [QUOTE=boostina3]
      QUOTE]
      Just did this last weekend. +2 on the stiff grommets. It was 55 degrees and it was scary how hard I had to pull, and then push. Should have warmed up the engine.
      I was checking my HPFP cam follower, (which was in great shape! .) But after I pulled the airbox, I found out that a rodent had been nesting in it! Had to take the airbox apart and vacuum out all the cloth scraps, leaves, and grass. I knew that there had been some kind of critters warming themselves on the engine at night, because my dog went postal on my front grill last week. But I never dreamed they had set up housekeeping in my airbox. Wish I'd had a camera. The good news is that I killed one of the rats, and my dog made up for the grill damage by catching 3 more of them.
      '06 A3, 2.0T, FWD, DSG. Options: sports suspension, Opensky. Mods: Votex, blackout grill, dogbone, philips LED DRLs.
    10. Member
      Jul 17th, 2001
      Philly burbs, PA
      2015 GTi, 2014 S4, 2006 A3
      02-10-2010 03:50 PM #9
      Nice job boostina3 [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    11. Member bazzle's Avatar
      Sep 17th, 2008
      Australia, Vic
      12-28-2014 01:27 AM #10
      well... Ive just myself a good 2010 Audi Sportback S3 after some clown drove into my R32 and wrote if off
      I decided to check the aircleaner.
      Engine nice and hot, undid clips, maf connector, air pipes etc.
      Pulled on the cover like the pic above. PULLED ON THE COVER... YANKED THE COVER
      I reckon its welded on.
      Gave up
      Baz
      Jul 27th, 2005
      Ramona, CA
      '06, A3 2.0t, Sport
      12-28-2014 02:52 AM #11
      This:
      Then try again.
      I find it easier to start with the forward-drivers-side pull point. There's a pretty good handle there. I've chamfered the posts on my car so it's easier to remove, but it still takes a pretty good yank.
      Quote Originally Posted by MachnickiA3 View Post
      stick that in your "fleshy patch"
    13. Member 2006_A3_2.0T's Avatar
      Jan 11th, 2013
      Chile
      12-28-2014 10:56 AM #12
      replace it with an air intake. just my 2 cents
      DM Stg2
    14. Member bazzle's Avatar
      Sep 17th, 2008
      Australia, Vic
      12-31-2014 02:35 PM #13
      Finally........... required a REAL hard jerk on each area.....
      I thought it was going to break in half.
      I forgot to remove oil filler cap. It broke into 2 pieces Luckily it clipped back together again.
      Wiped rubber grease on the grommets when I put it back.
      Baz
      Prev mkV R32
      Now S3 2010
