VWVortex.com - Hoses related to Cruise Control on the cabrio?
    Results 1 to 9 of 9
    Thread: Hoses related to Cruise Control on the cabrio?
    1. 02-12-2010 11:17 AM #1
      Has anyone been able to fix the intermittent cruise control issues on their Cabrio?
      Mine works perfectly every morning for about 3 miles, then cuts out. I've replaced the brake light bulbs, which honestly did seem to help with consistency (it does work the first time I turn it on every time now), but it still cuts out.
      So I'm wondering if maybe I've got a vacuum leak somewhere, thinking maybe pressure builds up and it leaks and shuts down....
      I got my ODBII cable this past weekend, so I can finally troubleshoot my ABS issues too...
    2. Remove Advertisements
      Advertisements
    3. Member DaveLinger's Avatar
      Jul 6th, 2005
      Fairmont, WV
      B8 S4, C5 A6, 82 Rabbit Pickup 16v
      02-12-2010 02:04 PM #2
      Check the mk4 forum FAQ sticky for the "Bentley" cruise control test. It's the same procedure on a Cabrio and will allow you to check for vacuum leaks.
      Although, usually, it's just a crappy cruise control module. Extremely common in mk3s.
    4. Member scidanw's Avatar
      May 11th, 2007
      Leavenworth, KS
      87 Scirocco 16v, 09 Jetta wagon, 07 Rabbit
      02-13-2010 01:10 PM #3
      Good reading on this in the MK3 FAQ too:https://forums.vwvortex.com/zerothread?id=3434133
      General summary: yes, the CC module is often at fault. Solution: remanufactured(businesses that do this are listed in the FAQ) or buy a new one.
      Mine works intermittently, usually after blowing heat through the left-hand duct on the dash for ~15-20 minutes. I've done the test, all of the switches work fine and all of my vacuum hoses are immaculate. I'm just putting off buying the new module right now.
    5. Remove Advertisements
      Advertisements
    6. Member DaveLinger's Avatar
      Jul 6th, 2005
      Fairmont, WV
      02-13-2010 02:07 PM #4
      Sorry, I meant the mk3 forum. It's a mk3 module after all.
      And for the record, I tried that mod and followed it to the T and it didn't work.
      Modified by DaveLinger at 2:08 PM 2-13-2010
    7. 02-14-2010 11:27 AM #5
      Wow, $250 for a new module? Which will probably crap out like the original....
      I think the Audiovox solution may work, but I'm not eager to dump the cash right now.
    8. Member DaveLinger's Avatar
      Jul 6th, 2005
      Fairmont, WV
      02-14-2010 08:43 PM #6
      Quote, originally posted by Raketemensch »
      You can check the mk3 classifieds for used ones. I got a used one and it's not 100%, but it works a heckova lot better than my old one.
    9. Member scidanw's Avatar
      May 11th, 2007
      Leavenworth, KS
      02-17-2010 12:41 PM #7
      Quote, originally posted by DaveLinger »
      The relay mod? I saw that results among the relay mod's creators were mixed to say the least. Judging from the reading, even some of the rebuilt ones don't work consistently either.
    10. Senior Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      90, 92, 93 Cabriolet They own you.
      02-17-2010 01:18 PM #8
      Have yall tried to clean the electrical switches on the brake and clutch pedals. I can imagine that if the vacuum part isn't sealing correctly then there could be the cause of your vacuum leak.
      You could test some of it with a mightyvac, and see if the majority of the system will hold a vacuum. As if you don't know that then all the rest is futile. As you pull a vacuum then you can watch to see if it is bleeding off.
    11. 02-18-2010 02:52 PM #9
      So true.
      I was lucky with my '02 Cabrio in the eight years I owned it, but my daughter's '97 Jetta was a bear (and a fortune) to fix.
      Now: '14 Tiguan R-Line 4motion ... '13 Tiguan S ... '02 Golf GLS TDI
      Past: '03 New Beetle Turbo S ... '74 Thing Acapulco ... '09 Eos Komfort ... '97 Jetta GT ... '02 Passat ... '02 Cabrio GLX ... '71 Super Beetle ... '93 EuroVan MV Westy ... '86 Jetta GLI ... '81 Pickup LX ... '85 Vanagon
      Future: on the prowl ...
