VWVortex.com - I have RUST in my tank, and HATE in my heart...
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 45
    Thread: I have RUST in my tank, and HATE in my heart...
    1. Member rar335's Avatar
      Dec 7th, 2006
      Holbrook, NY
      82 Caddy (Parked), 89 Cabby (Sold); 84 GTI (Sold)...
      03-24-2010 08:58 PM #1
      So I dont come off as a dumb *****, the hate is only for the Rust in my tank!
      I have been trying to troubleshoot some issues I have been having with my 89 cabby. She had a 2.0 swap early 2008 but unfortunately has mostly sat ever since. I figured it was a clogged fuel filter. But it turns out that there was never one installed after the swap, . So I took a look inside the tank and found this
      If you look closely you can see all the rust chips at the bottom of the tank and the rust on the tank pump
      Fuel Level Sending Unit
      I am going to replace it all
      Tank
      Fuel transfer pump
      Fuel pump
      Fuel Pressure Accumulator
      Fuel Filter
      And I am going to attempt to clean the lines (never did that before)
      Everyone I have asked says its a pain to pull the tank and replace the fuel system. I have done a lot of searching and found some good DIY threads for everything but the fuel tank removal. Anyone have any tips, suggestions?
      Modified by rar335 at 10:40 AM 3-26-2010
    2. Remove Advertisements
      Advertisements
    3. Member tolusina's Avatar
      Oct 18th, 2004
      '95 Ranger, '81 Trek
      03-25-2010 12:33 AM #2
      Rust is caused by water intrusion.
      Check the filler neck and all the fuel vapor hoses for splits, cuts, leaks and fix them.
      Quote Originally Posted by kamzcab86
      I hate reading: "But I bought this car for $500 and don't want to put another dime into it."
      ____(hey, it's VW AND it's electrical, what's not to fail?) neoBentley+
    4. Member rar335's Avatar
      Dec 7th, 2006
      Holbrook, NY
      03-25-2010 12:38 AM #3
      Quote, originally posted by tolusina »
      I didn't think of that, I can purchase a replacement filler neck. Then it should be new from back to front. I think I will use the POR 15 fuel tank sealer in the new tank just to be safe... Thanks! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    5. Remove Advertisements
      Advertisements
    6. Member
      Jan 3rd, 2006
      Former 1985 Cabriolet owner
      03-25-2010 11:55 AM #4
      Wow, that's fugly!!!!!!
      -dasdachshund
      A cowboy was out riding when a dude came along and hollered, "Git along, little doggie!"
      The next day the cowboy showed up with a dachshund.
    7. Member rar335's Avatar
      Dec 7th, 2006
      Holbrook, NY
      03-25-2010 12:03 PM #5
      Quote, originally posted by dasdachshund »
      -dasdachshund
      Yea it is I'm taking the tank off today. Not really looking forward to it.
    8. Member rar335's Avatar
      Dec 7th, 2006
      Holbrook, NY
      03-25-2010 11:36 PM #6
      Tolusina, you were right...
      After I took the tank off I found rust in an upper hose, didn't have time to investigate properly but there shouldn't be rust in there... Should have all the new parts monday, we will see if this does the trick... Thanks again for the advice...
      Modified by rar335 at 11:45 PM 3-25-2010
    9. Senior Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      90, 92, 93 Cabriolet They own you.
      03-26-2010 08:19 AM #7
      You didn't drop your axle? wowsers.
      From the pic's I would have to say that part of your problems was the fuel tank sender seal. There is too much rust on the top in the pics as well as the amount of rust on the seal (o-ring) itself.
      I would clean the bejeezers out of the sealing surfaces as it looks as if water was pooling around the tank top.
      Modified by briano1234 at 8:49 AM 3-26-2010
    10. Member djoutsider711's Avatar
      Mar 21st, 2010
      Tulsa, Ok. USA
      1993 & 1986 VW Cabriolet
      03-26-2010 08:34 AM #8
      Quote, originally posted by rar335 »
      CAREFUL WITH POR-15 .. It has been along time since I have read over the specs for the tank sealer but from what I remember about the standard paint it only worked ON TOP OF rust. It there was no rust it literally peels off. I am sure the tank sealer works differently but you still want to follow the instructions meticulously. Other than that.. POR-15 is to rust like duckape is to vinyl tops. A temporary fix. :-P
    11. Member rar335's Avatar
      Dec 7th, 2006
      Holbrook, NY
      03-26-2010 08:51 AM #9
      Quote, originally posted by briano1234 »
      Course I did, no other way to do it. I just didn't want to remove it completely because then I would have had to bleed the brakes. I gently loosened the tabs holding the brakes to the body of the car. Unbolted the axle and lowered it with a jack. Very straight forward. The pic is after I was finished removing it. I bolted it back up to protect the brake lines, just in case it swung. Thanks!
    12. Member rar335's Avatar
      Dec 7th, 2006
      Holbrook, NY
      03-26-2010 08:59 AM #10
      Quote, originally posted by djoutsider711 »
      This is the product that I will be using, http://www.por15.com/FUEL-TANK.../FTRK/ Its the por-15 fuel tank kit. Have you used it before? I was going to buy a new tank but there $170, this is $75. Might just have my old tank boiled out and cleaned very well. LMK what you think...
    13. Member rar335's Avatar
      Dec 7th, 2006
      Holbrook, NY
      03-26-2010 09:15 AM #11
      Oh man, you have fugly tires, too!!!!!
      And are you flipping off your emergency brake cable bracket?
      -dasdachshund
      The bird is pointing at the fuel pump and my tires are brand new less then 500 miles in them. What exactly is fugly about it
      Modified by rar335 at 10:33 AM 3-26-2010
    14. Member
      Jan 3rd, 2006
      03-26-2010 09:27 AM #12
      Sorry, you really do have hate in your heart. I thought I used enough smiley faces to convey my thoughts.
      Post deleted. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      -dasdachsund
    15. Member
      Feb 11th, 2008
      Philadelphia, PA
      2003 VW GTI 20th ANNI
      03-26-2010 09:44 AM #13
      if you have hate in your heart, let it out.
      wat power
    16. Member rar335's Avatar
      Dec 7th, 2006
      Holbrook, NY
      03-26-2010 10:31 AM #14
      -dasdachsund
      I want to APOLOGIZE! In no way was I trying to rub you the wrong way or to come across as a *****. I only have hate for the rust in my tank. Its very hard to recognize sarcasm thru text (we should create a sarcasm font). I am on Vortex to meet new people that love VW's the way I do and to learn. I respect everyones opinions and am glad because you can look at things in a different way. So maybe we should start over.
      You think my tires are fugly. I think that the wheels are fugly because the clear coat is faded. and all needs to be redone ...
    17. Member tolusina's Avatar
      Oct 18th, 2004
      03-26-2010 10:46 AM #15
      There's a nearby junkyard, or someone nearby is parting a Cabby with a good tank, find one used.
    18. Member JPX's Avatar
      Nov 6th, 2005
      San Jose,CA
      1989 Cabriolet
      03-26-2010 12:00 PM #16
      That was my first thought too. Good move dropping the axle just enough to yank the tank.
      But if you HAD been able to remove the tank without dropping the axle, you would have become a legend.
    19. Member Moljinar's Avatar
      Sep 20th, 2001
      Indianapolis, IN
      89 Cabby, 87 Cabby, 85 Cabby, 90 Jetta, 83 GTI
      03-26-2010 01:52 PM #17
      Check out this post in the LouisvilleVW forum. Last I heard it was still available. http://louisvillevw.org/forums...-Tank
    20. Member rar335's Avatar
      Dec 7th, 2006
      Holbrook, NY
      03-26-2010 02:26 PM #18
      Quote, originally posted by JPX »
      Thanks, being a legend would have been fun
    21. Member rar335's Avatar
      Dec 7th, 2006
      Holbrook, NY
      03-26-2010 02:27 PM #19
      Quote, originally posted by Moljinar »
      I had to regestar on that site so I can send him a PM. Thanks hopefully he will ship to me... [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    22. Member
      Jan 3rd, 2006
      04-07-2010 10:36 AM #20
      Just getting back to this post......sometimes my attempts at humor are a bit.......off. My bad. [IMG]http://*****************.com/smile/emthdown.gif[/IMG]
      Hows the build going? [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      -dasdachshund
    23. Member vdubbugman53's Avatar
      Nov 7th, 2006
      Denver, CO
      2013 Turbo Beetle, 2003 New Beetle
      04-07-2010 11:27 AM #21
      hell for 170 i would buy one brand new. that sounds cheap to me (not you the fuel tank)
    24. Member rar335's Avatar
      Dec 7th, 2006
      Holbrook, NY
      04-07-2010 08:18 PM #22
      -dasdachshund
      Good... I decided to remove my rear beam and clean it up along with the wheel wells and rear discs. Ill put up some pics, came out pretty well... I had to source all the new fuel parts, I replaced everything. Just waiting on a few more parts to arrive and Ill be able to put it all together. Prob is my wife said I can't spend anymore loot on the dub until we get back from vaca. so I won't have the fuel tank until the end of April.
    25. Member rar335's Avatar
      Dec 7th, 2006
      Holbrook, NY
      04-07-2010 08:20 PM #23
      Quote, originally posted by vdubbugman53 »
      I definitely am, but I found one for a little cheaper thanks!
    26. Member rar335's Avatar
      Dec 7th, 2006
      Holbrook, NY
      04-08-2010 05:14 PM #24
      So I decided to clean up the rear beam, breaks and wheel wells while I was waiting for my fuel parts to arrive. Here are some pics...
      Before...
      After...
      Modified by rar335 at 6:04 PM 4-8-2010
    27. 04-08-2010 10:01 PM #25
      That looks awsome ! Great job...
