Stood beside it in the rain for hours.
Trying to sort out how the carpet is getting wet.
My original post in the "What did you do to your Fox today?" thread seemed to elicit a number of replies expressing similar issues.
As water leaking into the car seems to be a shared and common problem, I thought I would start a fresh thread and copy those comments to it.
Hopefully the Forum will be able to help dry out these leaky cars.
And be able to find it with a search.
Quote, originally posted by j-boogie253 »
I've got the same problem
I fixed my trunk to where it doesn't leak at all, even fixed my sunroof so it doesn't leak either....then found my carpet was saturated on the driver side a month later
I can't seem to track it down, but it seems like it is coming from the corner by the windshield
Sometimes I can see little water droplets by the hood release handle
Not sure if it's the firewall or the windshield
Quote, originally posted by mr.ramsey »
x3 on the wet carpet. I think its leaking from the engine bay. The drains in the drip tray area must be leaking in somehow. Both my driver and passenger side kick panels get wet. The water seems to collect behind the drivers seat for me. Been thinking about drilling some drain holes.
Quote, originally posted by midnightsun »
i just shop vac my back seat after it rains
Same for me. I know my drip tray drain holes are clear and they work, but maybe there is something I can't see where they leak into the car as well
Oh well, I also have to do the post-rain shop vac too or else it'll start stinking
Quote, originally posted by lilgreydentwagen »
mine also does this. i'm thinking it's the seal around the windshield leaking because there is a little bit of rust right where the trim piece wraps around above the dash. it almost always gets wet right above the hood release when it rains. i'm going out now to put my new ish back seat and trim panels in
Quote, originally posted by efritsch »
Odds are the frame under the windshield is rotting away. Had that happen more than once.
Quote, originally posted by geniegate »
Mine does that too, more than "wet" I've had water sloshing around in there, but I've never seen the seats or the dashboard get wet. A total mystery.
As I stated in "What did you do to your Fox today?"...I finally did my vapor barriers for the doors
I used 19 gauge clear plastic (acquired from work) and the adhesive I used was called 3M Window Weld Ribbon Sealer, it's a roll of 3/8" bead similar to strip caulking but way better. You should apply it in a 1/8" bead (I got it a little thick in spots) and roll it flat once the vapor barrier is stuck to it in place.
I wanted to show what I learned and figured this thread was the perfect place to add the info
When I first installed the vapor barriers and tested them over the last two days, I learned something. I adhered the barrier too low on the bottom half
This is what they looked like at first
They had a very small leak after a day of rain so I investigated and found this...
The area circled in red shows a "channel" and the green circles are drain holes. This "channel" (again highlighted in red) is where the vapor collects as it runs down the barrier and then it should drain out of the holes (circled in green). So in conclusion, to have a properly functioning barrier, you must adhere the barrier just below these holes and the channel
This is what it looked like after I applied new adhesive to the proper area (I rolled it on with an old VW window crank :laugh
Sorry for the crappy night time cell pic but hopefully you get the idea
Now I have no leaks in the doors and no more frost on the inside of the windshield when it gets below freezing at night
If the vapour barriers in your car havn't been replaced in the past 25 years, they leak. Or not, but they probably leak at least somewhat. If there are faint water marks on your door cards, then they definitely leak.
Door rubber is only available for 4 doors in North America. For 2 door and trunk seals you have to send away to Brazil. http://www.brazilshopping.com or wait for Alain to head back down there (cheaper shipping).
Well, this is what the packaging says my door seals will fit.
You'd want to do some research to make sure what they call a Chevette or whatever is the same thing in Brazil, but you might be able to find something that fits by shopping for a different car. Assuming of course that they're long enough.
So this is a part you bought from Brazil? how do you know it fits? I have emailed them 3 times and I haven't received a single response yet. (curious) Is the shipping reasonable? Difficult to believe there would be that much difference in molding for the wagons or sedans?! I need to find some molding...What you say?
Removing the fender probably won't get you anywhere useful. Depends where you issue is exactly. This is the sort of things that could involve pulling the dash and/or fender and cutting a access hole(s).
Re: Damp Carpet, Soaked Underlay, Water Leak - Wet Fox (voxwagen88)
I hope the frame under my windshield isn't rotting away...I'm hoping for a simpler solution to my problem
In hopes of finding the leak or leaks, (and just for the hell of it) I detailed even more of my engine bay and underside of my hood
A couple of weeks ago I noticed the carpet in the driver side rear passenger foot well was wet.
The windshield had been recently replaced so I hoped that it was leaking and the fix would be fast and simple. A glass man with 10 years experience shot water at the car for more than an hour and couldn't get it to leak.
The good news was that the windshield didn't seem to be leaking. The bad news was that the leak was somewhere else.
While I was standing in the rain trying to figure out where the water was getting in, I noticed the rain tray plastic cover was pretty much Swiss cheese. Got a new one.
But was this where the water was getting in?
I thought it best to dry out the car before testing it.
And I found a lot more water than I was expecting.
The carpet seemed dry to the touch, but when I lifted it up looking for signs of rust, I found the felt underlay was waterlogged. Checking further, the underlay in the driver's foot well was also soaked.
And that's is where I am. Drying out.
^^^^x2^^^^
I pulled the carpet to find the underlay (cushioning) to be soaked
I've been lucky enough to catch some dry weather so I detailed the bay and again made sure those drip holes were working properly
Got it all dried out now and just waiting for another good down pour
Re: Damp Carpet, Soaked Underlay, Water Leak - Wet Fox (j-boogie253)
Do you drive your car when its raining out or just let it sit? I know that on my fox there is a small hole from the previous owner messing up the position of the jack stand on the passenger side. I can feel the underneath of the carpet with my finger poking through the hole, so I would guess water can spray up there when your driving at highway speeds on a rainy day....
My fox shares the same issue as many other fox owner's do.
The water getting into my car has to do with seal. It does not come through the bottom, but rather the top of the seal (looking at it from the inside).
Take off the bottom rubber trim at the edge of the dash to see if it comes from there.
Re: Damp Carpet, Soaked Underlay, Water Leak - Wet Fox (JGWarner)
Quote, originally posted by JGWarner »
Where did you buy a new drip tray?
Dealership.
Had to stretch it to get it on. Fit is a bit frustrating, but it didn't snap during the install.
The drying out continues. Both rear passenger foot wells are now dry.
The driver's underlay is still more than damp.
For "fun" I checked on the passenger side, and compared to the driver side found only a little water. Just the outer half of the underlay was wet. The underside of the carpet was moist.
Took a peek at the vapour barriers in the doors and they seemed fine.
Getting there.
Quote, originally posted by mike in SC »
Do you mean you have water coming in at the top off your windshield?
voxwagen88 said:
Sorry, I didn't describe how I imagined it might look.
The water comes in from the bottom of the windshield. Somehow, someway the water seeps from behind the windshield and past the seal.
I have also had to seal a few pinholes in the drip tray. This also created a problem with rust along the seam along the upper (but inside, above the fuse box) firewall.
The drains in the rain tray seem to be clear. A weighted string can pass from the rain tray to the bottom of the wheelhouse liner with out a problem.
The vapour barriers in the doors do look a bit suspect.
Some tears and cuts. There is a waterline on the back of the door cards.
Off to get some new plastic.
The doors themselves should have drain holes in them though. I can't see that much water getting in to the carpet from the doors and you not noticing it. Did you actually check the under the underpad? To look at the floor itself? Also, are there any grommets in your firewall that are loose/missing/in crap shape? I would pull the carpet and under pad right up and check the floor pan itself. VW's have big grommets in the floors that tend to let water sit around the edge as the get old and the floor starts rotting. I had a Passat that had holes in each location where the grommets used to be.
If you can't find water leaking from the top, than start checking the bottom. It could be wicking up water from underneath.
Judging from the water/mold/mildew on the back of the passenger side door card and the water mark on the p side underlay, I think most of the water on the moist side is getting in past the vapour barrier.
The poorly fitting trim between the door and the glass must let a lot of water in.
Some of that water must be splashing the vapour barrier and coming through.
The drain in the door is clear, but it did look like little streams of water had been coming through the lower edge of the vapour barrier.
Perhaps it is a little bit of water adding up over years that has soaked the carpet.
Odd, I thought, to find grommets in the floor. They seem watertight. The paint is intact over them.
Will be checking the firewall for missing grommets.
Bleach wipes took care of the mildew on the door cards.
And the doors.
I cleaned off the old vapour barrier residue.
Made new barriers with the thickest plastic sheeting I could find at the building center.
Held in place with construction grade red Tuck Tape.
Tested the barriers by washing the car.
The passenger side stayed dry. The Driver's side failed.
Water found its way through 3 places on the lower edge where the tape overlapped.
Retaped it. Will test again.
Part of the failure may have been that 2 of the 3 clips holding the upper door trim in place had come unglued from the trim.
Not much was pressing the glass in place against the outer trim. Seemed quite a bit more water came in the D-side than the P-side.
Reglued fro the re-test.
My fox has the same problem. It is not nearly as bad as before the windshield was repalced. However, I have some holes to take care of near the front sills.
I am having these holes welded shut, hopefully next week.
If anyone here has the leaking problem too, as I expect them to have, take the time to check this area before it's too late.
I redid the vapour barriers. Using a bit of Body Caulk to help control the the water.
The Driver side let a drop or 2 through after 30 seconds of hosing down the window.
The Passenger side stayed dry.
Both were dry after 30 minutes of light rain.
I'm becoming convinced that the driver side is much harder to make water tight as the outer door trim at the bottom of the window fits so poorly.
Carpets are staying dry.
Must be getting closer to a fix.
The car has been out in the rain most of the week. Gotta love rain to live here.
The vapour barriers are holding. I'm confident enough in them to put the door cards back on.
The drip tray seems to be working as the middle of the car seems to be staying dry.
But I still have a puddle.
The driver side foot well is wet at the bottom of the inner fender liner (if that is what it is). The puddle is down from where the wiring harness starts to make its way to the back of the car.
There seemed to be water under the sound insulation. I lifted up the outer half. The floor was moist all the way back to the seat.
I could see how water might be getting to the rear passenger area. The channel in the floor board could be funneling water from the front to the rear.
I'm hoping the puddle was water that had been trapped under the sound insulation collected in one spot, but I doubt it.
I poured about 10 litres into the rain tray and none came inside.
The struggle continues. Let it rain.
Your efforts and observations are an encouragement to us all!
I just discovered TWO new holes in my floorpan this week one of these days I'll have to strip the interior and do some leak hunting and cutting/welding. Hopefully it can wait till next year. Up til now I haven't seen a drop of water, but obviously it's getting in somewhere.
That did nothing.
I've built a wall of body caulk around the grommet where the water is pooling to see if I can tell if it is coming in from the grommet or somewhere along the path of the wiring harness. Or both.
Your persistence is really amazing! You're going to make some ground breaking discoveries for Foxers everywhere. Good luck with this, it certainly looks like you're going to have to pull the dash...
Related Threads
Ask a question
Ask a question
VW Vortex - Volkswagen Forum
84.4M posts
1.5M members
Since 2001
