VWVortex.com - OEM MKVI Climatronic on a MKV on a RNS-510 Screen installed.
    Page 1 of 7 12345 ... LastLast
    Results 1 to 25 of 155
    Thread: OEM MKVI Climatronic on a MKV on a RNS-510 Screen installed.
    1. Member NothernSky's Avatar
      Nov 24th, 2004
      Monterrey
      2016 Passat SEL TDI (2), GLI 2007 OEM+++
      07-01-2010 01:39 PM #1
      I installed the unit and work as expected (mine is VW Jetta GLI 2007 and I did not needed to wire in pararell on Connector C and B)
      Parts I needed:
      1K0 858 069 M 1QB Trim
      5K0 907 044 BT ZJU Climatronic Unit with Celcius, metric system in my country (5K0 907 044 CB ZJU with Heater button)
      1K0 907 530 AD Can Gateway ('S' revision or later might work also)
      3C8 937 049 AB Power Electrical Module (For compressor to work)
      Optional:
      1K0 907 659 Quality Sensor (optional)
      1K0 971 939 C Holder (optional)
      1J0 972 483 A Quality Sensor Conector (optional)
      000 979 009 E Quality Sensor Wire X2
      Climatronic Wiring
      On A Connector (black) extract both; Pin 16 and Pin 20 and put Pin 16 on the place were Pin 20 was, leave the wire on Pin 20 loose (not connected to the harrnes) for later connect the Air Quality Sensor if needed.
      If you have an older VW Model you will MIGHT need this wiring change ATTENTION: Please don´t quote me on this, I just really followed some threads on VWNAVI that mention this change. It did not applied in my case)
      Motors in parallel:
      On C Connector (brown): Pin 7 connected to Pin 10 and Pin 8 connected to Pin 9
      On B Connector (black): Pin 6 to Pin 7
      Quality Sensor Wiring (OPTIONAL if you bought the module that handles it):
      On C Connector (black):
      Pin 1 from Quality Sensor to Pin 20 (which we replaced by Pin 16 on Climatronic, remember?)
      Pin 2 from Quality Sensor is Ground goes to Pin 19
      Pin 3 from Quality Sensor to Pin 4 on Climatronic
      YOU NEED TO MAKE THIS STEPS (My compressor did not work until I performed the 2 step):
      First Step: Basic settings: hold button AC + button straight blowing (third button from left). You will see both buttons leds blinking one after another..let them run till they come to the normal status. Reference: http://www.my-gti.com/2513/volkswage...ostics-mark-vi
      Second Step :Compresor Settings: Starting the engine and hold LONG-AC + heating rear window.Let it run till it comes to the normal status.
      Installed Product:
      Thanks to lala30 and mogwai on the vwnavi forum.
      Last edited by NothernSky; 02-20-2013 at 11:41 PM. Reason: Change control unit description due to metric system
      OEM+ FTW
    2. Remove Advertisements
      VWVortex.com
      Advertisements
    3. Member BETOGLI's Avatar
      Jul 15th, 2010
      MEXICO CITY
      2007 JETTA GLI, 2012 GOLF GTI 35TH ANNIVERSARY
      08-12-2010 06:44 PM #2
      It looks awesome!
      Was it an expensive swap?
      Thanks,
      Beto
    4. Member
      Oct 5th, 2004
      Sterling, VA
      2K6 1K2 BRM / 2K8 7L6 BWF / 85 19 MF
      08-13-2010 03:26 PM #3
      Quote Originally Posted by NothernSky View Post
      I doubt this revision is necessary. But it is possible that CC module (3C8) is required. I am getting the mk6 Climatronic module just for testing, I am a metric guy, I do not want Fahrenheits , so it will be for sale.
    5. Member TXRanger83's Avatar
      Nov 8th, 2009
      Midland, TX
      2016 MKVII Golf GTI
      08-14-2010 01:07 PM #4
      Quote Originally Posted by maloosheck View Post
      Would this be as big of a PITA on the mkVI as it looks like it was in your blog for the mkV, because if not this Fahrenheit guy would be all over that swap.
      Looks good though NorthernSky, liking how clean it looks on the screen
      2016 GTI Pure White | Autobahn | PP | DAP | LP | 6 Speed | LED Tails w/ Rear Fog & Amber Turn Signals | EU Siren | EU Power Side Mirrors | EU Sun Visors | EU 8" Nav | VCDS |
    6. Member
      Oct 5th, 2004
      Sterling, VA
      08-14-2010 01:38 PM #5
      Quote Originally Posted by TXRanger83 View Post
      This is easy swap. I just prefer these nice little temperature displays in mk5.
    7. Junior Member varial72's Avatar
      Jun 2nd, 2009
      2007 VW GLI
      08-16-2010 08:28 PM #6
      How much did this cost you? It looks awesome.
    8. Member BETOGLI's Avatar
      Jul 15th, 2010
      MEXICO CITY
      08-16-2010 10:26 PM #7
      Quote Originally Posted by varial72 View Post
      +1
      Oct 5th, 2004
      Sterling, VA
      08-16-2010 11:24 PM #8
      All 3 modules listed above (CAN, CECM, Climatronic) can be found at approx. $500.
    10. Member BETOGLI's Avatar
      Jul 15th, 2010
      MEXICO CITY
      08-17-2010 12:57 AM #9
      Thank you so much Maloosheck, And where can I find these parts? I know that at VW Parts, but I think there might be cheaper options even these are OEM Parts.
      Regards,
      Beto
    11. Member
      Oct 5th, 2004
      Sterling, VA
      08-17-2010 01:10 AM #10
      Quote Originally Posted by BETOGLI View Post
      The MSRP of these 4 parts is $1,300. Online vendors list them for approx. $1,000. If you are interested in these 3 modules, shot me a PM and I will let you know what can be done.
    12. Senior Member NoDubJustYet's Avatar
      Mar 25th, 2002
      VA
      MkVII GSW & Atlas R-Line
      08-17-2010 04:21 AM #11
      damn, that's a lot of work. good job!
      hell, i'm scared to upgrade the firmware on my RNS-510 from 1100 to whatever it is now.
    13. Member JetTurbo's Avatar
      Sep 17th, 2001
      South Florida USA
      2018 GTi ab mt, 2008 b6 Passat 3.6 4-Motion
      08-17-2010 06:07 AM #12
      Does the Mk6 Climatronic have some equivalent to the Mk5 Climatronic alternate displays?
      MPH actual
      reference: FAQ - Climatronic Speed Reading
      2018 US a7.5 GTi ab mt, 2008 US b6 Passat 3.6 4-motion - 2012 a6 Golf R (deer strike totaled @ 175k mi), 2006 a5 GTI p2 mt (sold 230k mi / 7 yrs), 2001 a4 Jetta se 1.8T (sold 175k mi / 5 yrs)
    14. Member BETOGLI's Avatar
      Jul 15th, 2010
      MEXICO CITY
      08-17-2010 08:41 PM #13
      PM sent... Thank you so much Malooshek.
      Regards,
      Beto
    15. Member BETOGLI's Avatar
      Jul 15th, 2010
      MEXICO CITY
      08-17-2010 08:43 PM #14
      Regards,
      Beto
    16. Member NothernSky's Avatar
      Nov 24th, 2004
      Monterrey
      08-20-2010 12:30 PM #15
      For people that does not know how the quality sensor looks like here it goes:
      Refrence literature:
      http://www.my-gti.com/1267/climatron...n-and-location
      Diagram:
      OEM+ FTW
    17. Member BETOGLI's Avatar
      Jul 15th, 2010
      MEXICO CITY
      08-20-2010 03:08 PM #16
      Northensky,
      Thank you so much for sharing this info!
      Regards,
      Beto
    18. Member BETOGLI's Avatar
      Jul 15th, 2010
      MEXICO CITY
      09-11-2010 02:04 PM #17
      Parts I needed:
      5K0 907 044 BT ZJU Climatronic Unit (5K0 907 044 CB ZJU with Heater button)
      Hi Nothernsky, You went with the option with part number 5K0 907 044 CB ZJU (with Heater button) For the Climatronic unit right?
      In advance thanks.
      Regards,
      Beto
    19. Member
      Oct 5th, 2004
      Sterling, VA
      10-16-2010 04:41 PM #18
      Interesting, I have just installed mk6 Climatronic panel in my Jetta and after a basic adaptation of the flap motors I did not have to do anything to turn on the ac compressor. It works just perfect! Few pictures after the break .
      BTW I have US panel installed right now and the RNS shows Celsius temperature. So the configuration is done via something else, maybe cluster (mine is set to GB).
      Of course I have a code for the air quality module, but that will be fixed as soon as I make the harness for the sensor.
    20. Member BETOGLI's Avatar
      Jul 15th, 2010
      MEXICO CITY
      10-16-2010 06:26 PM #19
      That's awesome, great work Maloosheck! I just received the harness you sent me for the EU alarm siren, it looks pertty cool... Are you going to add a DIY of it an thread.
      Thanks you so much!
      Cheers,
      Beto
    21. Member NothernSky's Avatar
      Nov 24th, 2004
      Monterrey
      10-17-2010 03:02 PM #20
      Excellent
      I agree about the Celcius is managed by the cluster, I have set to GB too, but that is ok were I live. Change the metrics on the cluster and see what happens since you have a Farenheit module right?
      Did you have the same error code like this?
      It seems all of us are getting this code if the car is pre 2007.
      OEM+ FTW
    22. Member BETOGLI's Avatar
      Jul 15th, 2010
      MEXICO CITY
      10-17-2010 10:05 PM #21
      Excellent
      Just read in VW Performance that you can easily change from Celsius to Fahrenheit and vice versa doing the following the following procedure:
      Start the car, and with the engine running, turn the fan on to any position. Press and hold both your Auto and your Eco buttons together until the settings swap themselves over.
      cheers to everyone,
      Beto
    23. Member
      Oct 5th, 2004
      Sterling, VA
      10-17-2010 11:25 PM #22
      I did not have this code when I installed the Panel. I let my wife drive the car tomorrow and do the scan again.
      What's more interesting I swapped the panels to EU version w/heater and I have two codes about the center vent motor. I have to recheck the wiring because I did not have these errors with the US version of the panel.
    24. Banned
      Nov 7th, 2008
      Raleigh
      MKII & a Wookie
      10-17-2010 11:29 PM #23
      Wow, this is totally awesome work..
    25. Member
      Oct 5th, 2004
      Sterling, VA
      10-19-2010 09:38 PM #24
      Well, even my Euro panel was able to start communicating with the stepper motors. The only error code I have is:
      Tuesday,19,October,2010,18:29:53:13569
      VCDS Version: Release 10.6.1
      Address 08: Auto HVAC Labels: 5K0-907-044.clb
      Control Module Part Number: 5K0 907 044 BF HW: 5K0 907 044 BF
      Component and/or Version: Climatronic H14 0608
      Software Coding: 0000000000
      Work Shop Code: WSC 05311 115 08193
      ASAM Dataset: EV_Climatronic A01001 (VW36)
      VCID: 70E5AB191AD1
      1 Fault Found:
      9479189 - Signal Line for Air Quality Sensor
      B10A4 15 [009] - Open or Short to Plus
      Freeze Frame:
      Fault Status: 00000001
      Fault Priority: 3
      Fault Frequency: 7
      Reset counter: 75
      Mileage: 125295 km
      Date: 2000.00.00
      Time: 19:54:06
      My car is coded to Offroad (CAN-Gateway) and UK (Cluster). Other than that I do not recall anything unusual.
    26. Member BETOGLI's Avatar
      Jul 15th, 2010
      MEXICO CITY
      10-20-2010 12:22 AM #25
      Great Maloosheck!
      Cheers,
      Beto
