VWVortex.com - Where's my PCV Valve???
    Results 1 to 14 of 14
    Thread: Where's my PCV Valve???
    1. Member travis_gli's Avatar
      Jan 31st, 2008
      Colonial Park, PA
      '05 Volkswagen Jetta GLI
      07-17-2010 04:59 PM #1
      Where in the world is the small PCV check valve?
      that one...
      Or do they not use these in the newer 1.8t's? I have an '05.
    2. Remove Advertisements
      VWVortex.com
      Advertisements
      Apr 11th, 2010
      Gainesville, FL
      07-17-2010 05:07 PM #2
      Under the intake manifold. Follow the Y breather hose down from the right hand side of the valve cover until you come to a T-piece . The PCV valve resides in the T-piece.
    4. Member VDuBPL's Avatar
      May 10th, 2006
      LongIsland, Ny
      Just sold my 05 1.8t gti
      07-17-2010 05:22 PM #3
      Quote Originally Posted by bassep View Post
      What?
    5. Member White Jetta's Avatar
      Mar 17th, 2002
      Massachusetts
      Why don't you take a seat over there
      07-17-2010 07:03 PM #4
      Quote Originally Posted by VDuBPL View Post
      Thats not a picture of it, they use the one that looks like a hockey puck, its sits connected to the turbo inlet pipe.
      Thats mine connected to the adapter to bring it down to 19mm.
      Wrong, that is the PRV. The OP was correct with that picture, it's under the manifold in a T section leading into the manifold to suck in vapors.
      It's #27 on this diagram, the PRV is #11
    6. Member travis_gli's Avatar
      Jan 31st, 2008
      Colonial Park, PA
      07-18-2010 01:32 AM #5
      Thank you Now how in the he!! do I get to it
      this should be an adventure at best
    7. Member White Jetta's Avatar
      Mar 17th, 2002
      Massachusetts
      07-18-2010 08:04 AM #6
      You need to remove the engine cover, upper and lower. Then you can unbolt the metal try with all the hoses, N249, and N112 under it. There are 2 10mm bolts holding it down.
    8. 07-18-2010 09:25 AM #7
      search first... come on.. if you would have looked in the faq you would have found it with the diagrams... I'm going back to my cave and not coming back here for awhile again I hate all these pointless threads where the answer could have been found easily within a couple seconds of looking
    9. Member White Jetta's Avatar
      Mar 17th, 2002
      Massachusetts
      07-18-2010 10:59 AM #8
      Quote Originally Posted by weenerdog3443 View Post
      It would be nice if before someone could troll the forums that they had to read the faqs first and sign that they read them and had spent a few hours in there before posting.
    10. Member
      Jul 2nd, 2002
      Orlando-ish
      2011 Hyundai Sonata GLS, 2002.5 Jetta 1.8T (gone)
      07-18-2010 11:24 AM #9
      There's always hazing... could have sent him on all sorts of wild goose chases all over the engine first.
    11. Member respect_my_fast's Avatar
      Nov 18th, 2007
      Lynn MA
      86 Frankenstein. 83 cabby 73 ghia 00 1500 95 trooper
      07-18-2010 12:19 PM #10
      or you could just help the guy out, its not like he asked where his lug bolts are
      "Why did you do that?"
      " I dunno, because is cool?"
      "Your an idiot"
      -FossZ
    12. Member travis_gli's Avatar
      Jan 31st, 2008
      Colonial Park, PA
      07-19-2010 06:04 PM #11
      Quote Originally Posted by respect_my_fast View Post
      thank you
      and thanks for the legitimate answers it's really appreciated and hard to find on here anymore
      FYI: I spent 30 min. in the garage over the weekend on the laptop looking, found some things however nothing clear enough to have at it.
    13. 11-03-2010 07:24 PM #12
      [IMG]This is the PCV valve in my jetta.
    14. 11-03-2010 11:08 PM #13
      Here you go Travis. Check valve is item 6. Not all vehicles use item 10. I have a different hose for item 10.
    15. Member travis_gli's Avatar
      Jan 31st, 2008
      Colonial Park, PA
      11-04-2010 09:38 AM #14
      Thanks guys, I'm actually removing it entirely and introducing a catch can. I'd rather the sludge get caught in the can than clog the crap out of the check valve.
