VWVortex.com - For those with Byte 18 issues... (MK6)
    Page 1 of 7 12345 ... LastLast
    Results 1 to 25 of 151
    Thread: For those with Byte 18 issues... (MK6)
    1. Member blackgl98's Avatar
      Jan 22nd, 2006
      Hull/Ottawa, Canada
      2015 Golf 1.8T Comfortline
      08-31-2010 04:09 PM #1
      Moderators, you might want to consider putting this as a sticky.
      Here are the instructions that [email protected] gave me a while ago.
      I had byte 18 coded to 04 by mistake. What you need to do if that's your case, is recode byte 18 again. Here is the procedure. Before doing anything make sure all your doors are unlocked and that they are closed properly.
      -Go to byte 18 in central electronics 09 and recode it to 03.
      -Do not it enter, click either on byte 17 or 19 and byte 18 will stay to 03.
      -Afterwards, close your long coding screen and click do it! New long coding will be accepted.
      -Close all you Vag-Com screens, turn the ignition off and unplug the cable from the obd port.
      -Get out of the car, lock your doors and wait at least 2 mins so that the bcm falls asleep.
      -After that, unlock all your doors, turn ignition on plug the cable back and re-open Vag-Com.
      -Go back to your long coding in central electronics at byte 18. Recode it to 00. Close you screen hit do it! And long coding should be accepted.
      -Again, close all your Vag-Com screens remove the cable, turn ignition off and test your lights. Everything should be working properly.
      Let me know if you have more questions.
      It worked for me and 2 other people, chances are, it will work for you if you coded byte 18 by mistake.
      VWVortex.com
    3. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      02 Gti, 12 Tiggy SEL
      08-31-2010 05:31 PM #2
      This applies to vehicles with the a BCM only:
      Byte 18 is the master lighting scheme for most of the exterior lights. Unlike previous generation 09-Central Electronics modules, the BCM equipped vehicles do not have the conventional "Cold Light" diagnostic bits. This is critical when replacing conventional bulbs with LED's, since the lamp check system (i.e. coding) isn't as easy to modify. In some cases, there is not a work around for the lamp check.
      Typically the real coding is covered (hidden) from the factory with 00 shown in the coding. So, if someone recodes their BCM equipped (Mk6 or equivalent VW, Audi, Seat, Skoda) to anything else and the exterior lights freak out, simply recoding it back to the stock 00 will not fix it.
      The fix is finding out what the stock setting should be and entering that coding. VCDS Our current release includes some of the common documented and tested coding values. If a registered Ross-Tech customer has a problem they can contact us via email. We may not have the answer, but we can try.
      VW:
      Hex 03 is the default setting for the NAR (North American Region including Canada) Golf and Gti.
      Hex 06 is the default setting for the NAR Jetta.
      Both of those are available in the Long Coding Helper with the current VCDS release.
      Other models may be covered in the Long Coding Helper when available.
      I welcome any other VW family Make or Model feedback or comments regarding Byte 18. Since we don't have all of them documented, this thread could be very useful for members that do cross that Byte 18 line and need help. Golf owners can refer to this thread if they need assistance with LED tail light retrofitting: LED tail Install with or without Rear Fog
      To clear up any confusion on terminology, BCM = Body Control Module. This module is also known as J519 -or- Address 09 - Central Electronics. This is a scan from a stock 2010 US market Gti:
      Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
      Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
      Component: BCM PQ35 H+ 103 0536
      Revision: 00103 AC
      Coding: 6D180A1E90272AC48088008550000D0441050086434D8D6064 8020200000
      Shop #: WSC 01357 011 00200
    4. Junior Member
      Feb 10th, 2011
      South Jersey
      2010 Jetta WE 2.0T FSI DSG; 2015 Sportwagen TDI/DSG
      02-20-2011 08:41 PM #3
      Today I've checked every single combination for Byte 18 (00-99; A0-A9; 0A-9A; B0-B9; 0B-9B; C0-C9; 0C-9C; D0-D9; 0D-9D; E0-E9; 0E-9E; F0-F9; 0F-9F and AA-FF) and result is all of them set fault code except for two 06 and 4C but 06 uses amber lights along with regular brake lights and 4C makes front parking and side marker lights very dim and amber/red combination for rear parking lights.
      2010 Jetta Wolfsburg
      Address 09: Cent. Elect. Labels: 1K0-937-08x-09.clb
      Control Module Part Number: 5K0 937 085 G HW: 5K0 937 085 G
      Component and/or Version: BCM PQ35 B++ 111 0128
      Software Coding: 2D200B3E902D3EE480000081400000040300??8641008D625C 8020000000
      Work Shop Code: WSC 00066 000 00000
      VCID: 3777C4F83FCB
    5. 03-30-2011 01:49 PM #4
      Quote Originally Posted by WhiteWolfie10 View Post
      VCID: 3777C4F83FCB
      I just purchased the 087 G Z5Y for my 2010 Jetta TDI Sedan, wondering what code I need to use for Byte 18 to make sure I get no faults
    6. Junior Member
      Jun 14th, 2007
      Denmark
      03-30-2011 02:02 PM #5
      Have you seen this german thred about byte 18 issues?
      There might be som usefull information.
      http://www.motor-talk.de/forum/led-r....html?page=269
    7. n00b
      Apr 27th, 2011
      Königswinter in Germany
      Audi A3 8P 1.4 TFSI Sportback, 2010
      04-27-2011 10:27 AM #6
      After many searches at several internet places I found that [email protected] is really competent and my last hope.
      It seems VW/Audi have provided a big cuckoo's egg (Kuckucksei) with their new coding philosophy for the 2010 and newer cars.
      For my2010 A3 8P Sportback with BiXenon headlights, Rain/Light Sensor, conventional tail lights, I would like to have american style DRL (LED row in front, nothing else on, activated by position "0" of light switch or by FIS).
      May be I missed a posting where the actual and more or less complete meaning of the long coding of the new Central Elect. ECU was given. Please advice.
      Is there a version of VCDS label files which includes all (most) relavant bit settings ?
      In the cited MotorTalk posting many codings for Byte 18 are given. What can I do if my actaul car configuration is not included there ? Can I set and keep some other setting (at least a Audi Workshop will reset it ? Would the procedure given by Dana earlier do this ?
      Thank you for your patience. greinig
      Jul 16th, 2010
      Sacramento, CA
      2010 A3 TDI, 2013 Chevy Volt, 2014 Fiat 500e
      04-27-2011 03:31 PM #7
      I have a 2010 A3 with Xenon and LED DRL, in VCDS there is a setting for Byte 18 that specifies "NAR" version, which would do exactly what you need! I believe the coding was 62, or 2B... it was one of those though One was ROW (Rest of World), other was NAR (North American Region). Good luck!
      Quote Originally Posted by greinig View Post
      Jul 16th, 2010
      Sacramento, CA
      04-27-2011 03:33 PM #8
      OH! And in regards to position "0", my DRLs only work in the "AUTO" position since I also have the RLS. Position "0" is all OFF.
    10. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      04-28-2011 09:03 PM #9
      If you haven't already resolved the issue please post the complete Auto-Scan here. I suspect this is a Byte 18 setting and some of them are documented as bmw511 mentioned.
      Quote Originally Posted by bmw511 View Post
      Yes, and that can be modified. If you'd like to test the DRL in both Auto and Off positions please look at Byte 26 "Daytime Running Light (DRL) only active with Assistance Driving Light (ADL) active"
      Dana Marie
      P.S. No Scan = No Soup
    11. n00b
      Apr 27th, 2011
      04-29-2011 05:26 AM #10
      Quote Originally Posted by Dana @ Ross-Tech View Post
      Thank you! I'll try out your advice.
      Here is the requested AutoScan:
      Thursday,21,January,2010,17:38:48:46862
      VCDS Version: Beta 912.0
      Data version: 20091201
      Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
      Control Module Part Number: 8P0 920 932 D HW: 8P0 920 932 D
      Component and/or Version: KOMBIINSTR. VDO H03 0990
      Software Coding: 0004028
      Work Shop Code: WSC 46523 133 78358
      No fault code found.
      Address 19: CAN Gateway Labels: 1K0-907-530.lbl
      Control Module Part Number: 1K0 907 530 AC HW: 1K0 907 951
      Component and/or Version: J533 Gateway H17 5223
      Software Coding: E9A17F06000242042102
      Work Shop Code: WSC 06314 000 00000
      3 Faults Found:
      01305 - Databus for Infotainment
      004 - No Signal/Communication
      Freeze Frame:
      Fault Status: 01100100
      Fault Priority: 1
      Fault Frequency: 254
      Reset counter: 23
      Mileage: 13452 km
      Time Indication: 0
      Date: 2011.02.07
      Time: 16:34:57
      01304 - Radio
      Freeze Frame:
      Fault Priority: 2
      Reset counter: 23
      Mileage: 13452 km
      Time Indication: 0
      Date: 2011.02.07
      Time: 16:35:00
      03406 - Control Module for Battery Monitoring
      004 - No Signal/Communication - Intermittent
      Freeze Frame:
      Fault Status: 00100100
      Fault Priority: 2
      Fault Frequency: 1
      Reset counter: 63
      Mileage: 13712 km
      Time Indication: 0
      Date: 2011.02.20
      Time: 10:44:04
      Address 19:1K0 907 530 AC recoded (Installation List) from E9A17F06000242042102 to E9A17F06000242042102
      Address 09: Cent. Elect. Labels: None
      Control Module Part Number: 8P0 907 063 A HW: 8P0 907 063 A
      Component and/or Version: BCM PQ35 M 105 0563
      Software Coding: 06000A2CB0051AC0207240E82100095C437E2BAA216DD92AE4 008F840041
      Address 61: Battery Regul. Labels: None
      Control Module Part Number: 1K0 907 534 HW: 1K0 907 951
      Component and/or Version: Batt.regelung H17 5223
      Software Coding: 03030864
      Address 17: Instruments (8P0 920 932 D)
      17:45:06 Group 005: Service Reminder
      -- Distance since Service exceeded
      -- Time since Service exceeded
      163 Remaining Dist. until Service
      238 Remaining Time until Service
      17:56:15 Group 002
      13780 km Mileage
      Test OFF Remote Clock (Test Mode)
      37.0 l Tank Content
      9.5°C Ambient Temperature
      17:56:23 Group 003
      30.0°C Coolant Temperature
      00:54 Standing Time
      9.0 % Dimming Signal (Terminal 58d)
      0.0 % Dimming Signal (Terminal 58s)
      17:56:30 Group 004: Supply Voltage && Outside Temperature
      12.00 V Supply Voltage (Terminal 30)
      -- Outside Temp. (Climate Control)
      9.5°C Outside Temp. (Display)
      0.0 % Phototransistor
      17:56:35 Group 005: Service Reminder
      17:56:42 Group 006
      400 ml Min. (M2) Oil Level in Service Interval
      0 ml Max. (M2) Oil Level in Service Interval
      100 ml Long Time Average Oil Level Dif.
      Closed Engine Hood Contact
      17:56:53 Group 008
      0 ml Short Time Mean Oil Level Dif.
      60 ml Current (M2) Value
      17:57:00 Group 010: Adaptation Channels 003 && 004
      3 Adaptation Channel
      100 Consumption Correction
      4 Adaptation Channel
      1 Language
      17:57:07 Group 011: Adaptation Channels 009 && 019
      9 Adaptation Channel
      1378 Mileage
      19 Adaptation Channel
      10 Remote Control Clock Synchron.
      17:57:12 Group 012: Adaptation Channels 040 && 041
      40 Adaptation Channel
      137 Mileage since Service
      41 Adaptation Channel
      492 Time since Service
      17:57:19 Group 013: Adaptation Channels 042 && 043
      42 Adaptation Channel
      150 Minimum Mileage to Service
      43 Adaptation Channel
      300 Maximum Mileage to Service
      17:57:21 Group 013: Adaptation Channels 042 && 043
      17:57:27 Group 014: Adaptation Channels 044 && 049
      44 Adaptation Channel
      730 Maximum Time to Service
      49 Adaptation Channel
      365 Minimum Time to Service See Adaptation Channel 049
      17:57:32 Group 015: Adaptation Channel 045
      45 Adaptation Channel
      2.0 Oil Quality
      56 Chan. Number
      511 Count
      17:57:37 Group 016: Adaptation Channels 047 && 048
      47 Adaptation Channel
      0 Soot Entry
      48 Adaptation Channel
      168 Thermal Load
      17:57:42 Group 017
      53 Chan. Number
      137 Count
      55 Chan. Number
      492 Count
      17:57:49 Group 019: Adaptation Channel 030
      30 Adaptation Channel
      128 Fuel Gauge Sender 1
      17:57:55 Group 020: Adaptation Channels 035 && 037
      35 Adaptation Channel
      0 Engine Speed Threshold
      37 Adaptation Channel
      1 Breake Wear Indicator Install.
      17:58:00 Group 021: Adaptation Channels 038 && 039
      38 Adaptation Channel
      1 Oil Minimum Detection Sensor
      39 Adaptation Channel
      1 TOG Installation
      17:58:06 Group 022: Adaptation Channels 018 && 020
      18 Adaptation Channel
      0 Auxiliary Heating
      20 Adaptation Channel
      111 Configuration
      17:58:11 Group 023: Adaptation Channels 080 && 081
      80 Adaptation Channel
      2102 Day/Month of Delivery
      81 Adaptation Channel
      2011 Year of Delivery
      17:58:17 Group 024: Adaptation Channels 082 && 033
      82 Adaptation Channel
      2 Comfort Menu
      83 Adaptation Channel
      1758 Full Calibration
      17:58:22 Group 025
      33 Chan. Number
      128 Count
      36 Chan. Number
      1100 Count
      17:58:27 Group 026: Fuel Level Sender
      130 Fuel Sender 1 (Resistance)
      38.0 l Fuel Sender 1 (Tank Content)
      0 Fuel Sender 2 (Resistance)
      0.0 l Fuel Sender 2 (Tank Content)
      17:58:31 Group 027
      213 Count
      0.0 l Tank Cont.
      0 Count
      0.0 l Tank Cont.
      Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
      Control Module Part Number: 1K0 907 379 BA HW: 1K0 907 379 BA
      Component and/or Version: ESP MK60EC1 H45 0109
      Software Coding: 11424012092800FB880F02E7901E00503800
      Address 61: Battery Regul. (1K0 907 534 )
      18:04:16 Group 020
      4.8 mOhm Resistance
      4.6 mOhm Resistance
      47 Ah Charge
      12.40 V Voltage
    12. n00b
      Apr 27th, 2011
      04-29-2011 06:00 AM #11
      Thank you.
      Dana, for the change in Byte 26, could you please advice how/where to obtain an actual label file for the new (2010) BQM PQ35.
      The latest 8P0-907-063.clb I found was from 08. Apr. 2011, it was only 17 kByte long.
      Another older one of Sebastian Stange seems not to apply to the new BQM PQ35.
      Best Regrads
      greinig
      P.S. My Autoscan was supplied with another answer.
    13. Forum Sponsor Andy@Ross-Tech.com's Avatar
      Jun 5th, 2002
      2018 Audi A3 e-tron
      04-29-2011 09:22 AM #12
      Thank you.
      Best Regrads
      greinig
      Your AutoScan was from a very old Beta version. Please try using the latest one, which has the most complete set of labels:
      http://www.ross-tech.com/vcds/downlo...a/current.html
    14. n00b
      Apr 27th, 2011
      04-29-2011 02:34 PM #13
      Quote Originally Posted by [email protected] View Post
      Dana, thank you for the fast response.
      The Change of Byte 18 from 2B to 2C did not change anything (I performed the full procedure as proposed by you earlier).
      I did not try To change Byte 26 because I don't know which bit to change.
      I downloaded the current VCDS-1120_Beta und used its label files with my VCDS-912.
      The label file in VCDS-1120_Beta is 8P0-907-063.clb 08. Apr. 2011 with 17 kByte only (as mentioned in my last email).
      Did I wrong to use the old VCDS with new label files ?
      Here is the AutoScan (BCM PQ 35 portion only):
      Friday,29,April,2011,16:50:59:46862
      Data version: 20110305
      Chassis Type: 1K0
      Scan: 01 03 08 09 10 15 16 17 19 20 25 42 44 46 52 55 56 61 62 72
      VIN: WAUZZZ8P3AA061435 Mileage: 15140km/9407miles
      01-Engine -- Status: OK 0000
      03-ABS Brakes -- Status: OK 0000
      04-Steering Angle -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: OK 0000
      10-Park/Steer Assist -- Status: OK 0000
      15-Airbags -- Status: OK 0000
      16-Steering wheel -- Status: OK 0000
      17-Instruments -- Status: OK 0000
      19-CAN Gateway -- Status: Malfunction 0010
      20-High Beam Assist. -- Status: OK 0000
      25-Immobilizer -- Status: OK 0000
      42-Door Elect, Driver -- Status: OK 0000
      44-Steering Assist -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      55-Xenon Range -- Status: OK 0000
      56-Radio -- Status: Cannot be reached 1100
      61-Battery Regul. -- Status: OK 0000
      62-Door, Rear Left -- Status: OK 0000
      72-Door, Rear Right -- Status: OK 0000
      Address 01: Engine (CAX) Labels: 03C-906-016-CAX.clb
      Part No SW: 03C 906 016 S HW: 03C 906 016 S
      Component: MED17.5.5 G01 4985
      Revision: L5H09--- Serial number: AUX7Z0I8FNM11C
      Coding: 0000072
      Shop #: WSC 06314 000 00000
      Readiness: 0110 0001
      Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
      Part No SW: 1K0 907 379 BA HW: 1K0 907 379 BA
      Component: ESP MK60EC1 H45 0109
      Revision: 00H45001
      Address 08: Auto HVAC Labels: 8P0-820-043.lbl
      Part No SW: 8P0 820 043 BL HW: 8P0 820 043 BL
      Component: KlimavollautomatH09 0140
      Revision: 000028 Serial number: 8P0820043BL
      Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
      Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
      Component: BCM PQ35 M 105 0563
      Revision: 00105 AI
      Coding: 0A000A2CB0051AC0207240E82100095C437E2CAA216DD92AE4 008F840041
      Part No SW: 8P1 955 119 F HW: 8P1 955 119 F
      Component: Wischer AU350 H10 0040
      Coding: 00DD13
      Part No SW: 8K0 910 557 HW: 8K0 955 559 A
      Component: REGENLICHTSEN H04 0003
      Coding: 024C2D
      I would be very grateful if you could tell me:
      a) which bit to change in Byte 26 and of course - if possible -
      b) to advice how/where to get a full actual label file
      Best Regards
      greinig
    15. Forum Sponsor Andy@Ross-Tech.com's Avatar
      Jun 5th, 2002
      2018 Audi A3 e-tron
      04-29-2011 02:59 PM #14
      Yes, you did wrong. Please post the AutoScan using Beta 11.2.
    16. n00b
      Apr 27th, 2011
      05-07-2011 06:54 AM #15
      Hi Dana or Andy,
      could you please explain what was wrong to use the 11.2 label file with my 912
      (as you can see from the AutoScan the label was accessible and I could open the long coding;
      what I missed was the byte coding details with the exception of the 1.Byte).
      Regards greinig
    17. Forum Sponsor Andy@Ross-Tech.com's Avatar
      Jun 5th, 2002
      2018 Audi A3 e-tron
      05-09-2011 09:26 AM #16
      Hi Dana or Andy,
      Regards greinig
      Please email [email protected] with your full contact information. I think you *KNOW* exactly what the problem is.
    18. Member
      Jul 16th, 2010
      Sacramento, CA
      05-09-2011 12:21 PM #17
      Have you guys seen the coding on the new 2011 Jetta SportWagon? My parents just got one and I hooked up my VCDS to it, it was coded to a value of "00", then if you modified it to something, then back to "00" it would keep the last coded value as if it was still on 02 for example. I was knocking my head on the door frame because I couldn't find a value that worked after that point except for the Golf NAR setting. Learned my lesson
    19. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      06-16-2011 10:12 AM #18
      Sorry for the delay, I have received reports of 02 and 03 working on the JSW. If this isn't resolved post the scan.
      Dana Marie
    20. Junior Member
      Oct 6th, 2011
      California
      2010 Vw Jetta TDI, Build date 8-10
      10-06-2011 07:23 PM #19
      Hi,
      I have a 2010 vw jetta tdi. I will be installing hella cherry red led tail light set. I have a vcds. What do i need to change in coding to make my turning light signal amber? I know i have to swap pins at the tail lights. If i leave the 2 inner stock tail lights (reflective) on the vehicle and just replace the 2 outer led tail lights, do i still change Byte 18 to Hex 05 (VW Jetta (1K2/VW351) Rest of World (RoW)? Am i going to get the amber turn signals? Am i going to get a no fault because i have no rear fog light? Am i going to damage the led outer tail light because the cold diagnostics is still on? How do i turn it off?
    21. Member vw siej's Avatar
      Sep 20th, 2009
      Coventry, RI
      2014 Jetta 1.8T SE; 2013 Beetle TDi
      01-15-2012 12:39 AM #20
      I need help with coding my golf 2.5. I have recently upgraded my halogen headlights to the Bi-xenon + LED. I am having issues trying to get the LEDs to function properly. I tried searching through postings of others who have attempted the coding, but none of it seems to work. Plus, I have the LED taillights w/ fog installed.
      I made several attempts with byte 18 and could only get the left side to function. I changed byte 18 back to 22. Here is my most current auto-scan:
      Monday,09,January,2012,05:12:14:33337
      VCDS Version: Release 11.11.1
      Data version: 20111209
      Chassis Type: 7N0
      Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
      VIN: WVWDA7AJ7BW019479
      02-Auto Trans -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      1C-Position Sensing -- Status: OK 0000
      2E-Media Player 3 -- Status: OK 0000
      56-Radio -- Status: Malfunction 0010
      77-Telephone -- Status: OK 0000
      Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
      Part No SW: 07K 906 055 BC HW: 07K 906 055
      Component: 2,5l R5/4V G01 7640
      Revision: T4H04--- Serial number:
      Coding: 0000075
      VCID: 70C9E25363B8334
      Readiness: 0000 0000
      Address 02: Auto Trans Labels: 09G-927-750.lbl
      Part No SW: 09G 927 750 LM HW: 09G 927 750 LM
      Component: AQ 250 6F 1734
      Revision: 00H90000 Serial number:
      Coding: 0000840
      VCID: 873B298FF63694C
      Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
      Component: ESP MK60EC1 H30 0106
      Revision: 00H30001
      Coding: 114B400C49230003880F02EB92220041B70000
      VCID: 74C1EE43D7A00F4
      Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
      Part No SW: 3C8 907 336 AH HW: 3C8 907 336 AH
      Component: Climatic H14 0305
      Revision: 00009001
      Coding: 0000001002
      ASAM Dataset: EV_Climatic A01005
      ROD: EV_Climatic_VW36.rod
      VCID: 73C3ED5FDAAE08C
      Part No SW: 1K0 937 087 M HW: 1K0 937 087 M
      Component: BCM PQ35 H+ 104 0614
      Revision: 00104 AF
      Coding: 67180A1A80272AC40008008130000DCC40052286534D8920E4 8828240040
      VCID: 3B53057FBA7E80C
      Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
      Component: Wischer 03061 21 0512
      Coding: 009795
      Address 15: Airbags (J234) Labels: 5K0-959-655.clb
      Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
      Component: AirbagVW10G 021 0706
      Serial number: 003C4R00EGKA
      Coding: 00003031
      ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
      ROD: EV_AirbaVW10SMEVW360_VW36.rod
      VCID: 395F1F77B842B2C
      Seat occupied recognition:
      Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
      Component: BF-Gewichtss. 007 0002
      Serial number: ---0000R--000571R800
      Crash sensor for side airbag; driver side:
      Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
      Component: S.Sens.Fahr.V H01 ----
      Serial number: 3572MSME06223252ZZZF
      Crash sensor for side airbag; passenger side:
      Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
      Component: S.Sens.Beif.V H01 ----
      Serial number: 3582MSME2C166353ZZZW
      Crash sensor for side airbag; rear driver side:
      Component: S.Sens.Fahr.H --- ----
      Serial number: 3512QSME3E23614EZZZ
      Crash sensor for side airbag; rear passenger side:
      Component: S.Sens.Beif.H --- ----
      Serial number: 3522QSME060A5D24ZZZW
      Crash sensor for front airbag; driver side:
      Component: F.Sens.Fahr --- ----
      Serial number: 35527SME260F0822ZZZB
      Crash sensor for front airbag; passenger side:
      Component: F.Sens.Beif --- ----
      Serial number: 35627SME0A190922ZZZA
      Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
      Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
      Component: Lenks.Modul 008 0080
      Revision: -------- Serial number:
      Coding: 1882100000
      ASAM Dataset: EV_SMLSNGKUDS A05001
      ROD: EV_SMLSNGKUDS_VW36.rod
      VCID: 76C5D44BC9DC1D4
      Multifunction steering wheel control module:
      Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
      Component: E221__MFL-TAS H05 0010
      Serial number: 0010631
      Coding: 820000
      Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
      Part No SW: 5K0 920 971 B HW: 5K0 920 971 B
      Component: KOMBI H03 0406
      Serial number: 00000000000000
      Coding: 270F01
      ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
      ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
      VCID: 2E753C2B710C654
      Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
      Part No SW: 7N0 907 530 HW: 1K0 907 951
      Component: J533 Gateway H27 0602
      Revision: H27 Serial number: 300510F1002170
      Coding: ED807F0600161200000002
      VCID: EDF77B27F48A5EC
      Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
      Part No SW: 5N0 919 879 HW: 5N0 919 879
      Component: Kompass 001 0001
      Revision: 00001000 Serial number: 1225223R96ZJ06
      Coding: 0000002
      VCID: FED54C6BA9ECD54
      Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
      Part No SW: 5K0 953 234 HW: 5K0 953 234
      Component: IMMO H03 0406
      Coding: 000000
      Shop #: WSC 00000 000 00000
      ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
      ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
      VCID: EAFD703B0D64494
      Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
      Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
      Component: SG EXT.PLAYER H13 0090
      Revision: A1001003 Serial number: 7667674672
      Coding: 010000
      VCID: 2665C40B51FC2D4
      Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
      Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
      Component: Tuer-SG 009 2113
      Coding: 0001268
      VCID: 314F2757A8327AC
      Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
      Part No: 1K0 909 144 J
      Component: EPS_ZFLS Kl. 70 3001
      Revision: 00H17000
      Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
      Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
      Coding: 0001268
      VCID: 324D285BAD34414
      Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
      Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
      Component: Radio Prem-8 H10 0035
      Revision: -----20S Serial number: VWZ4Z7K1112400
      Coding: 0500040004
      VCID: 61EF971778528AC
      1 Fault Found:
      02635 - Tuner Not Enabled/Activated
      000 - -
      Freeze Frame:
      Fault Status: 01100000
      Fault Priority: 3
      Fault Frequency: 1
      Reset counter: 217
      Mileage: 30285 km
      Time Indication: 0
      Date: 2016.14.19
      Time: 15:24:39
      Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
      Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
      Component: Tuer-SG 007 2101
      Coding: 0001232
      Shop #: WSC 01357 011 1012557
      VCID: 34412E4357204F4
      Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
      Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
      Coding: 0001232
      VCID: 354713475C5A56C
      Address 77: Telephone (J412) Labels: 7P6-035-730.clb
      Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
      Component: TELEFON H05 0440
      Revision: 1B001001 Serial number: 00007668139069
      Coding: 0A00000000010100
      ASAM Dataset: UHVNA A01007
      ROD: UHVNA_VW36.rod
      VCID: 324D285B6534414
    22. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      01-15-2012 09:05 AM #21
      Hi,
      It looks like whitehatch has this sorted:
      https://forums.vwvortex.com/showthrea...8#post74342038
      If you didn't reconnect the blue/green wire please try it and my explanation of that (and why it wasn't applicable before) is here.
      Dana Marie
    23. Member vw siej's Avatar
      Sep 20th, 2009
      Coventry, RI
      01-17-2012 07:29 AM #22
      Hi,
      Thank you for your help. This fixed it
    24. Semi-n00b Chef347's Avatar
      May 11th, 2010
      Tampa, FL
      2010 Carbon Steel GTI
      04-07-2012 12:36 PM #23
      Hi Dana,
      I am kinda new here, and was hoping you could take a look at this scan I ran last night. I just recently installed rear LED tails and LED bulbs in the front city lights. Afterwards, I got the bulb check warning. I tried changing Byte 18 to 03 but had the left turn signal stay on when I turn the lights on. I set it back to Golf NAR and still got the bulb check warning, so I tried setting it at GTI NAR and still no luck. Also, this is a 2010 GTI, and it was set at Golf NAR, I set it at GTI NAR. As for the light switch, my fog lights will not opperate with the headlights on. Is there multiple switches and is it possible that I have the wrong one? I will try a few of these tips listed in this thread when I get home, Thanks in advance for your help!
      -Valentin
      VCDS Version: Release 11.11.3
      Data version: 20120401
      Friday,06,April,2012,17:47:53:09993
      Chassis Type: 1K0
      Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56 65 77
      VIN: WVWEV7AJ6AW224203
      01-Engine -- Status: Malfunction 0010
      09-Cent. Elect. -- Status: Malfunction 0010
      37-Navigation -- Status: Malfunction 0010
      65-Tire Pressure -- Status: OK 0000
      Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
      Part No SW: 1K0 907 115 AM HW: 1K0 907 115 AA
      Component: 2.0l R4/4V TFSI 0030
      Revision: AAH11--- Serial number:
      Coding: 0403010A18070160
      Shop #: WSC 13622 027 435782
      VCID: 71E3CC3668B23B1
      1 Fault Found:
      050217 - Implausible Data Received from Steering Column Control Module
      U0429 - 000 - - Intermittent
      Freeze Frame:
      Fault Status: 00100000
      Fault Priority: 0
      Fault Frequency: 1
      Mileage: 0 km
      Time Indication: 0
      Freeze Frame:
      RPM: 0 /min
      Load: 0.0 %
      Speed: 0.0 km/h
      Temperature: 98.0°C
      Temperature: 60.0°C
      Absolute Pres.: 1000.0 mbar
      Voltage: 12.319 V
      Readiness: 1110 0101
      Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
      Component: ESP MK60EC1 H30 0107
      Revision: 00H30001
      Coding: 114B600C492400FE880D06E4921C0041300800
      VCID: 78F5F112CBC86A9
      Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
      Revision: 00009001
      Coding: 0000001002
      VCID: 75EBF826D4DA171
      Component: BCM PQ35 H+ 103 0576
      Revision: 00103 AE
      Coding: 6D180A3E88252A04808800817000090441052086534D8D6064 8020200000
      Shop #: WSC 05052 444 53553
      VCID: 356B38269C5A571
      Component: Wischer 07110 21 0512
      Coding: 009795
      5 Faults Found:
      00061 - Footwell Lights
      010 - Open or Short to Plus
      Freeze Frame:
      Fault Status: 01101010
      Fault Priority: 5
      Fault Frequency: 2
      Reset counter: 10
      Mileage: 47221 km
      Time Indication: 0
      Date: 2027.14.01
      Time: 17:21:46
      Freeze Frame:
      Term 15 On
      Voltage: 12.45 V
      ON
      ON
      Term 50 Off
      OFF
      OFF
      00984 - Left Tail Light (M4)
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 2
      Reset counter: 10
      Mileage: 47221 km
      Time Indication: 0
      Date: 2027.14.01
      Time: 17:22:01
      Freeze Frame:
      Term 15 On
      Voltage: 12.25 V
      ON
      ON
      Term 50 Off
      OFF
      OFF
      00985 - Right Tail Light (M2)
      Freeze Frame:
      Fault Priority: 2
      Fault Frequency: 2
      Reset counter: 10
      Mileage: 47221 km
      Time Indication: 0
      Date: 2027.14.01
      Time: 17:22:01
      Freeze Frame:
      Term 15 On
      Voltage: 12.25 V
      ON
      ON
      Term 50 Off
      OFF
      OFF
      00987 - Lamp for Brake Light; Left (M9)
      Freeze Frame:
      Fault Priority: 1
      Fault Frequency: 2
      Reset counter: 10
      Mileage: 47221 km
      Time Indication: 0
      Date: 2027.14.01
      Time: 17:22:01
      Freeze Frame:
      Term 15 On
      Voltage: 12.25 V
      ON
      ON
      Term 50 Off
      OFF
      OFF
      00988 - Lamp for Brake Light; Right (M10)
      Freeze Frame:
      Fault Priority: 1
      Fault Frequency: 2
      Reset counter: 10
      Mileage: 47221 km
      Time Indication: 0
      Date: 2027.14.01
      Time: 17:22:01
      Freeze Frame:
      Term 15 On
      Voltage: 12.25 V
      ON
      ON
      Term 50 Off
      OFF
      OFF
      Serial number: 003C4D0A08FM
      Coding: 00003031
      VCID: 39733416B842B31
      Serial number: ---0000R--0004JW5U00
      Serial number: 3572MSME4A1A254DZZZ%
      Serial number: 3582MSME7276224DZZZ.
      Serial number: 3512QSME2C4D3F3DZZZD
      Serial number: 3522QSME10063D33ZZZL
      Serial number: 35527SME4347201EZZZB
      Serial number: 35627SME326B201EZZZG
      Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
      Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
      Component: J0527 056 0111
      Coding: 0000532
      VCID: 78F5F1120BC86A9
      Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
      Coding: 00000130
      Shop #: WSC 00000
      Cannot be reached
      Cannot be reached
      Component: IMMO H03 0305
      Coding: 000000
      ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
      VCID: EAD15B5A0D64489
      Revision: A1001003 Serial number: 7667669419
      Coding: 010000
      VCID: 2649EF6A51FC2C9
      Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
      Part No SW: 3C0 035 684 C HW: 3C0 035 684 C
      Component: RNS-MID H04 0980
      Revision: AB001001 Serial number: VWZ6Z7J6320002
      Coding: 040004000400009600
      ASAM Dataset: ------------------------- ------
      VCID: 234FF67E22CED91
      1 Fault Found:
      00875 - Treble Speaker Front Right (R22)
      011 - Open Circuit - Intermittent
      Freeze Frame:
      Fault Status: 00101011
      Fault Priority: 5
      Fault Frequency: 2
      Reset counter: 31
      Mileage: 46784 km
      Time Indication: 0
      Component: Tuer-SG 009 2111
      Coding: 0001076
      VCID: 31630C36A8327B1
      Component: EPS_ZFLS Kl. 74 3001
      Revision: 00H17000
      Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
      Component: Tuer-SG 009 2137
      Coding: 0001076
      VCID: 346D052257204E9
      Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
      Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
      Component: AFS-Steuergeraet 0142
      Revision: 00H04000 Serial number:
      Coding: 1446940
      Subsystem 1 - Part No: 7L6 941 329 B
      Component: AFS-Lst.-Modul l 0004
      Coding: 00000022
      Subsystem 2 - Part No: 7L6 941 329 B
      Component: AFS-Lst.-Modul r 0004
      Coding: 00000022
      Address 56: Radio (J0506) Labels: 1T0-035-680.clb
      1 Fault Found:
      011 - Open Circuit
      Freeze Frame:
      Fault Status: 01101011
      Fault Priority: 5
      Fault Frequency: 3
      Reset counter: 10
      Mileage: 46784 km
      Time Indication: 0
      Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
      Component: RDK 103 0521
      Coding: 018705
      Address 77: Telephone (J738) Labels: 1K8-035-730.clb
      Part No SW: 1K8 035 730 C HW: 1K8 035 730 C
      Component: Telefon H08 6600
      Revision: 00008000 Serial number: 20389520286822
      Coding: 412100
      VCID: 2953E45640E2031
    25. 04-08-2012 11:36 AM #24
      If all of your lights work as expected with one of the codes for byte 18 but you still get check bulb warning on the dash then that is probably how you will have to live with, it is your cecm that is not happy to see the led tails. Nothing wrong with tails or the switch.
    26. Member sfpegasus's Avatar
      Jul 23rd, 2009
      San Francisco
      04-08-2012 02:27 PM #25
      I don't think Chef347 knows that you can't rely on the long coding helper for the proper coding. Only a few of the codes are listed there and very few of them pertain to LED tails.
      Chef347 probably needs to manually copy the entire 09 string into the coding box and manually change byte 18 (currently showing "20") and then "do it".
      The LED Tail Discussion will provide some options for the coding.
      2010 CW Golf TDI DSG 2DR - Euroswitch - LED tails, turns - Clear corners - GTI sideskirts - Audi stainless tips - Porto alloy spare - Plastic battery box - 9W7 Bluetooth
      2013 RS Golf 2.5 6AT 2DR - Bone stock
