VWVortex.com - Change comfort turn signals count in MKVI
    Page 2 of 4 FirstFirst 1234 LastLast
    Results 26 to 50 of 99
    Thread: Change comfort turn signals count in MKVI
    1. Junior Member
      Jul 21st, 2010
      MA
      2011 GTI, Autobahn, 6MT, Tornado Red
      01-05-2011 11:16 PM #26
      Quote Originally Posted by Enriquez View Post
      I did it successfully.
      I habe 1K0 937 087 H module. I just went to the adaptation in 09 module. Engine was ON. I changed value from 3 to 5. I didn't went out from adaptation menu. Then changed channel from 31 to 30 and to 31 again. The value was 5. Then i clicked on TEST button then SAVE. Then exit from adaptation and from module to main menu. Stop the engine, remove the key from ignition, and open driver door. After that I have 5 signals.
      Great. but what car is this? 2011 owners are having issues, if you have a 2010 or earlier, then this is most likely not a solution for those of us with 2011 cars. Thanks for posting!
      VWVortex.com
      Jul 16th, 2010
      Sacramento, CA
      2010 A3 TDI, 2013 Chevy Volt, 2014 Fiat 500e
      01-06-2011 05:27 PM #27
      Update:
      Modified the channel from 3 to 5, tested while it was running and it worked fine. Now once I shut the car off and restarted it, it has reverted back to only flashing 3 times, even though the adaptation value says 5.
      This is a 2010 Audi A3 TDI
    4. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      02 Gti, 12 Tiggy SEL
      01-07-2011 12:01 AM #28
      Quote Originally Posted by bmw511 View Post
      Update:
      Thanks and I'm linking your module for future reference: https://forums.vwvortex.com/showthrea...1#post67113235
      Do you have this Turn Signal menu option? If so..what options are listed?
      http://i778.photobucket.com/albums/y...0A3/photo1.jpg
      Comfort Light turns the comfort turns On or Off on my cluster, I don't have any additional options.
      http://i778.photobucket.com/albums/y...e/DSC02301.jpg
      Dana Marie
      P.S. No Scan = No Soup
      Jul 16th, 2010
      Sacramento, CA
      01-07-2011 12:11 AM #29
      Dana!
      Wow good memory :-) I have the Turn Signals menu, with Convenience Turn Signals with a check box. I could take a picture of it tomorrow if you'd like
    6. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      01-07-2011 12:23 AM #30
      Yes please do. It probably won’t' really help in this matter..but screen shot references are helpful when you don't have a car to play with.
      I went a little crazy with mine and just fitted a 9W7 BT module with more goodies on the display, time to add to this soon:
      http://s778.photobucket.com/albums/y...ster/Complete/
      Dana Marie
      Jul 16th, 2010
      Sacramento, CA
      01-07-2011 12:36 AM #31
      Sweet! I'm having a blast with this car... finding lots of neat stuff in VCDS. I need a Euro light switch thought so I can get my rear fogs going. I'll upload the picture in the morning for you, it seems like its a glitch, or something is overriding it. Especially since it worked fine until I shut off and restart the car.
      Jul 16th, 2010
      Sacramento, CA
      01-07-2011 11:28 AM #32
      Here is the screenshot of the image!
    9. Member quailallstar's Avatar
      Dec 2nd, 2001
      Ormond Beach, FL
      @LuvGermanCars
      01-10-2011 07:34 PM #33
      Any luck on 2011+ MY Golf models? I've tried this on my Sept 2010 built Golf TDI with no luck. Won't save the 4 or 5 as others have attempted.
      2Ø16 Golf 7 Variant Highline R-Line Pure-Weiß 1,8t FSI « 2Ø11 Golf 6 2,0 6-Gang DPF 2,0 TDI BLUEMOTION Technologies™ Highline Candy-Weiß 5-Türen« Ø8 Golf 5 .:R32 Deep Blau Perleffekt 3,2 VR6 DSG 4-MOTION™ 3-Türen « Ø6 Golf 5 GTI 2,0 FSI DSG Tornadorot 3-Türen « Ø2 Indigo Blau Perleffekt Passat 3BG Trendline 1,8T 4-Türen. I Euro-spec OEM Mods
    10. Member iamgap's Avatar
      Jan 17th, 2010
      Hubert, NC
      2010 Golf
      01-10-2011 08:03 PM #34
      Quote Originally Posted by Dana @ Ross-Tech View Post
      I dig the compass display. Did this come from changing to Zone 10? Mine is set for Zone 8, and I only get single/double digits in top left corner of the display. Or is it a difference between the GTI and Golf 2.5L?
      gap
    11. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      01-10-2011 09:38 PM #35
      Quote Originally Posted by iamgap View Post
      gap
      The RCD-510 with the compass module was installed from the factory and I had the little indicator:
      http://i778.photobucket.com/albums/y...e/DSC02285.jpg
      This didn't happen until I installed the RNS:
      http://i778.photobucket.com/albums/y...e/DSC02286.jpg
      I never unplugged the compass module because I already had the rear of the car reassembled from the LED/Byte 18 /Rear fog episode...and I didn't feel like pulling any more trim. It hasn't caused any fault codes or functional concerns...but I don't think it's normal.
      Dana Marie
    12. Member Code3VW's Avatar
      May 5th, 2004
      Gilbert, AZ
      '10 CW JSW TDI 6MT
      02-16-2011 12:06 PM #36
      There still isn't a fix for this?
      I used my vagcom to enable this on rockstar's 2011 GTI and after a bunch of turning the car on and off, and enabling and disabling the comfort turn signal, it worked.
      My girlfriend just bought a 2011 Golf TDI and I can't get this to stick at 5, it keeps it at 3.
      OEM+ Bi-Xenon HIDs | Front & Rear Fogs | Highline CECM | Euroswitch | RNS-510 HW:08 SW:1140 w/ Software VIM | Backup Camera | 9W7 | Dash Cubby | Aspherical Mirrors | GTI Steering Wheel w/ .:R Badge | GTI 6MT Shift Knob | GTI E-Brake Boot | GTI Pedals | GTI 18" Detroits
      Not so OEM+ Koni Coilovers | Gentex Homelink Mirror | Yaesu FTM-350AR
    13. Member quailallstar's Avatar
      Dec 2nd, 2001
      Ormond Beach, FL
      @LuvGermanCars
      02-16-2011 12:08 PM #37
      Quote Originally Posted by Code3VW View Post
      Same here with my 2011 TDI No luck so far.
    14. Member phatz314's Avatar
      Jan 13th, 2011
      SF bay area
      2011 Golf TDI
      02-16-2011 09:58 PM #38
      Yes, I'm bummed there's no solution for 2011's yet. One of the major reasons I bought a VCDS cable from Rosstech was for this feature
      Can you elaborate on this? Like others on this board, I tried on my 11 TDI and found that even though I can enter a "5" and it keeps the value stored on the ECU, the actual number of flashes is always 3. When you had success with the 11 GTI, did you mean to say that the number wasn't stored after several unsuccessful attempts, and only when it was stored in memory did it work? Or did you mean that you entered say "5", it stored the value, but still only flashed 3 times, but after re-entering 5 a few more times, it worked?
    15. Member
      Feb 11th, 2004
      Magdeburg, Germany
      '67 Ford Mustang Conv.
      02-17-2011 05:10 AM #39
      As mentioned in other places, we are looking into it but so far it appears that this is indeed an issue with the control module firmware and not VCDS. Once we have a solution you can be certain that we will keep you informed.
    16. n00b
      Feb 17th, 2011
      Spain
      2011 Golf 1.6 TDI Sport (Highline) DSG7 MKVI MY11 >WK45 EU
      02-17-2011 07:56 AM #40
      I have successfully encoded the flashing of comfort turn signal.
      I have a MY11 Golf MKVI purchased in February 2011, made after week 45, with European specifications, and through the VCDS (first with the 10.63 and after with the 11 beta) adapted the channel for 4 flashes and recorded (without errors) and did not change (although the scan appeared to the value 4 instead of 3).
      Yesterday, through the FIS (I have factory-installed premium FIS), turn off the flashing of comfort turn signal and I went to turn on ..... and finally it works!
      Now I have 4 intermittent flashes.
      I hope that helps
    17. Member phatz314's Avatar
      Jan 13th, 2011
      SF bay area
      2011 Golf TDI
      02-17-2011 08:30 PM #41
      Quote Originally Posted by joserogo View Post
      I hope that helps
      Well, you inspired me to try again on my MY11 NA Golf TDI, but no luck.
      What is FIS? Is that the same as the MFI?
      Can you post an autoscan?
      What happens if you try to change the number of flashes to another value -- does it take it immediately, or do you have to cycle the engine multiple times?
    18. Member phatz314's Avatar
      Jan 13th, 2011
      SF bay area
      2011 Golf TDI
      02-17-2011 08:47 PM #42
      HOLY CRAP I GOT IT TO WORK
      1. Change the number of flashes to the desired number. Close out VCDS.
      2. On the MFI, Navigate to Settings --> Light & Vision --> Factory Setting
      3. At the prompt "Set to factory settings for lights & vision?", select OK.
      4. Marvel in amazement as the turn signal magically flashes 1, 2, 4, or 5 (yes 5) times.
      No more, uh, tired left index finger for me!
      I have a 2011 Golf TDI, North American, build date 7/2010.
      Here's my autoscan, not that it's likely that relevant:
      Code:
      VCDS Version: Release 10.6.3 (x64)
      Data version: 20101206
      Thursday,17,February,2011,17:44:06:55943
      Chassis Type: 7N0
      Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 47 52 55 56 62 72
                77
      VIN: WVWNM7AJ5BW041198
      01-Engine -- Status: OK 0000
      03-ABS Brakes -- Status: OK 0000
      04-Steering Angle -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: OK 0000
      15-Airbags -- Status: OK 0000
      16-Steering wheel -- Status: OK 0000
      17-Instruments -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      1C-Position Sensing -- Status: OK 0000
      25-Immobilizer -- Status: OK 0000
      2E-Media Player 3 -- Status: OK 0000
      42-Door Elect, Driver -- Status: OK 0000
      44-Steering Assist -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      47-Sound System -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      55-Xenon Range -- Status: OK 0000
      56-Radio -- Status: OK 0000
      62-Door, Rear Left -- Status: OK 0000
      72-Door, Rear Right -- Status: OK 0000
      77-Telephone -- Status: OK 0000
      Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
         Part No SW: 03L 906 019 DA    HW: 03L 906 019 DA
         Component: R4 2,0L EDC G000SG  7271
         Revision: 12H08---    Serial number:
         Coding: 0050072
         Shop #: WSC 01357 011 00200
         VCID: 6DFF1E2D0D17
      No fault code found.
      Readiness: 0 0 0 0 0
      Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
         Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
         Component: ESP MK60EC1   H30 0106
         Revision: 00H30001
         Coding: 114B400C492600FB880C02ED92210042B70000
         VCID: 74C90B496E3D
      Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
         Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
         Component: Climatic      H14 0305
         Revision: 00009001
         Coding: 0000001002
         ASAM Dataset: EV_Climatic A01005
         ROD: EV_Climatic_VW36.rod
         VCID: 75CF364D6547
      Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
         Part No SW: 1K0 937 087 L    HW: 1K0 937 087 L
         Component: BCM PQ35  H   104 0615
         Revision: 00104 AE
         Coding: 6D180A3A80252AC40088008574008D04402D1F86534D8560648020200040
         VCID: 3A55E5710CD9
         Part No: 1K1 955 119 F
         Component: Wischer 23061  21  0512
         Coding: 009795
      Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
         Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
         Component: AirbagVW10G   021 0706
         Serial number: 003C4R00JPHL
         Coding: 00003031
         ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
         ROD: EV_AirbaVW10SMEVW360_VW36.rod
         VCID: 3957FA7D09DF
         Seat occupied recognition:
         Part No SW: 5K0 959 339     HW: 5K0 959 339
         Component: BF-Gewichtss.  007 0002
         Serial number: ---0000R--00058E2J00
         Driver's Airbag Crash Sensor:
         Part No SW: 5K0 959 354     HW: 5K0 959 354
         Component: S.Sens.Fahr.V  H01 ----
         Serial number: 3572MSME11213354ZZZD
         Passenger Side Airbag Crash Sensor:
         Component: S.Sens.Beif.V  H01 ----
         Serial number: 3582MSME542B2154ZZZS
         Driver's Rear Airbag Crash Sensor:
         Component: S.Sens.Fahr.H  --- ----
         Serial number: 3512QSME12036526ZZZG
         Passenger's Rear Airbag Crash Sensor:
         Component: S.Sens.Beif.H  --- ----
         Serial number: 3522QSME26046467ZZZR
         Driver's Front Airbag Crash Sensor:
         Component: F.Sens.Fahr  --- ----
         Serial number: 35527SME06070323ZZZ/
         Passenger's Front Airbag Crash Sensor:
         Component: F.Sens.Beif  --- ----
         Serial number: 35627SME2E0E5022ZZZG
      Address 16: Steering wheel
      Cannot be reached
      Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
         Part No SW: 5K0 920 971 C    HW: 5K0 920 971 C
         Component: KOMBI         H03 0406
         Serial number: 00000000000000
         Coding: 270F01
         ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
         ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
         VCID: 2F43C425C79B
      Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
         Part No SW: 7N0 907 530     HW: 1K0 907 951
         Component: J533  Gateway   H27 0602
         Revision:   H27       Serial number: 260610F2001345
         Coding: E9817F0610161200000002
         VCID: EDFF9E2D8D17
      Address 1C: Position Sensing        Labels: 1Kx-919-xxx-1C.lbl
         Part No SW: 5N0 919 879     HW: 5N0 919 879
         Component: Kompass         001 0001
         Revision: 00001000    Serial number: 1225223R9BHR06
         Coding: 0000002
         VCID: FEDDA961D071
      Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
         Part No SW: 5K0 953 234     HW: 5K0 953 234
         Component: IMMO          H03 0406
         Coding: 000000
         Shop #: WSC 00000 000 00000
         ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
         ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
         VCID: EAF59531BCF9
      Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
         Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
         Component: SG EXT.PLAYER H13 0111
         Revision: A1001003    Serial number: 7668227646
         Coding: 010000
         VCID: 27732C05EF6B
      Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
         Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
         Component: Tuer-SG         009 2113
         Coding: 0001204
         VCID: 3147C25DD1AF
      Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
         Part No: 1K0 909 144 J
         Component: EPS_ZFLS Kl. 70     3001
         Revision: 00H17000
         VCID: 3147C25DD1AF
      Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
         Part No SW: 5K0 035 456     HW: 5K0 035 456
         Component: KonzernAmp 8K H06
         Revision: --------    Serial number: BP218109093456
         ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
         ROD: EV_AudioVerst8KanalBNO1_VW36.rod
         VCID: E7F3EC05AFEB
      Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
         Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
         Component: Tuer-SG         009 2139
         Coding: 0001204
         VCID: 3449CB492EBD
      Address 55: Xenon Range        Labels: 5M0-907-357-A.lbl
         Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
         Component: AFS-Steuergeraet    0142
         Revision: 00H04000    Serial number:
         Coding: 1446940
         VCID: 3449CB492EBD
         Part No: 7L6 941 329 B
         Component: AFS-Lst.-Modul l    0004
         Coding: 00000022
         Component: AFS-Lst.-Modul r    0004
         Coding: 00000022
      Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
         Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
         Component: Radio Prem-8  H13 0043
         Revision: -----26S    Serial number: VWZ4Z7K1147551
         Coding: 0101000001
         VCID: 61E7721DC1CF
      Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
         Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
         Component: Tuer-SG         007 2101
         Coding: 0001168
         Shop #: WSC 01357 011 1012552
         VCID: 3449CB492EBD
      Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
         Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
         Coding: 0001168
         VCID: 354FF64D25C7
      Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
         Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
         Component: TELEFON       H05 0440
         Revision: 1B001001    Serial number: 00007668223608
         Coding: 0A00000000010100
         ASAM Dataset: UHVNA A01007
         ROD: UHVNA_VW36.rod
         VCID: 3245CD51D4A9
      End   ---------------------------------------------------------------------
    19. Member quailallstar's Avatar
      Dec 2nd, 2001
      Ormond Beach, FL
      @LuvGermanCars
      02-17-2011 09:15 PM #43
      Quote Originally Posted by phatz314 View Post
      Code:
      Chassis Type: 7N0
                77
         Coding: 0050072
         VCID: 6DFF1E2D0D17
         Revision: 00H30001
         VCID: 74C90B496E3D
         Revision: 00009001
         Coding: 0000001002
         VCID: 75CF364D6547
         Revision: 00104 AE
         VCID: 3A55E5710CD9
         Coding: 009795
         Coding: 00003031
         VCID: 3957FA7D09DF
      Cannot be reached
         Coding: 270F01
         VCID: 2F43C425C79B
         VCID: EDFF9E2D8D17
         Coding: 0000002
         VCID: FEDDA961D071
         Coding: 000000
         VCID: EAF59531BCF9
         Coding: 010000
         VCID: 27732C05EF6B
         Coding: 0001204
         VCID: 3147C25DD1AF
         Revision: 00H17000
         VCID: 3147C25DD1AF
         VCID: E7F3EC05AFEB
         Coding: 0001204
         VCID: 3449CB492EBD
         Coding: 1446940
         VCID: 3449CB492EBD
         Coding: 00000022
         Coding: 00000022
         Coding: 0101000001
         VCID: 61E7721DC1CF
         Coding: 0001168
         VCID: 3449CB492EBD
         Coding: 0001168
         VCID: 354FF64D25C7
         ROD: UHVNA_VW36.rod
         VCID: 3245CD51D4A9
      Oh snap! Im going to go out and try this ASAP.
    20. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      02-18-2011 08:54 AM #44
      Hi! This sounds like good news. Do the 2011 clusters have the menu like this "Comfort light"?
      http://i778.photobucket.com/albums/y...e/DSC02322.jpg
      If the setup is different and this is the fix, please post a picture and I'll link it from the sticky.
      Dana Marie
    21. Member quailallstar's Avatar
      Dec 2nd, 2001
      Ormond Beach, FL
      @LuvGermanCars
      02-18-2011 10:01 AM #45
      Dana yes they do. Mine does have this menu.
    22. Member
      Jul 16th, 2010
      Sacramento, CA
      02-18-2011 11:58 AM #46
      Does this apply to the A3?
    23. Member phatz314's Avatar
      Jan 13th, 2011
      SF bay area
      2011 Golf TDI
      02-18-2011 12:58 PM #47
      Dunno, try it! I suspect yes.
    24. Member phatz314's Avatar
      Jan 13th, 2011
      SF bay area
      2011 Golf TDI
      02-18-2011 01:24 PM #48
      Yes, I can confirm that my car looks similar to that.
      Here is a more detailed version of the procedure that I followed, with pictures from my MFI:
      AFTER changing the desired # of flashes using VCDS, disconnect the cable and cycle the ignition for good measure. (I did not start the engine, as others have reported.) Re-insert the key to the ACC position if you haven't already.
      Then, on the dashboard MFI, navigate to "Settings":
      Click "Lights & Vision" (highlighted above). This takes you to the following submenu (your options may be different; e.g., "Coming home" is not enabled by default):
      Click "Factory setting" (highlighted above). This takes you to this submenu:
      Click "OK" (highlighted). This seemingly does nothing, and takes you back up to the parent menu.
      Once you have done this, the # of flashes you set in VCDS will work correctly. From what I could tell, nothing else is changed -- I had guessed that I would have to re-enable "Coming home", for example, but it left all that stuff alone.
      Obviously, this additional step is only required for some 2011s.
      Just my observations:
      I've noticed sporadic reports of people having had success by flashing it multiple times, turning the engine off and on, etc. In my experience with embedded controllers and the like, sometimes they can be a little "squirrelly", and the VAG ECU seems to be no different. With VAGCOM, I've found you have to very deliberate/slow, changing one thing at a time, disconnect and power cycle between each change, and so forth. If you go too fast, you can get unpredictable results, and simply cycling the ignition or re-flashing a code fixes it. I bet the folks who have had success by flashing multiple times, etc. basically took advantage of a bit of instability in the PIC and effected a reset without knowing it, perhaps.
      Here's what really intrigues me though. I wonder what other settings can be enabled on the mk6 using this general procedure (VCDS + MFI reset). There are many interesting-looking settings I have found in VCDS that don't seem to do anything when I toggle them, so I switched them back -- but I wonder if I should try these settings in combination with the MFI reset as well.....
    25. Member GenDV138's Avatar
      Jul 16th, 2010
      Northern VA
      2011 VW GTI, 2010 Yamaha FZ6R
      02-18-2011 01:25 PM #49
      I'll have to see if this works on my 2011 GTI tonight or tomorrow, thanks for the info phatz! I'll report back whether it works or not.
    26. Junior Member
      Jul 21st, 2010
      MA
      02-18-2011 03:30 PM #50
      phatz314, U da Man!
      Thank you, thank you, thank you!!!
      This has been a source of frustration for while now.
      All I had to do to get this to work was reset lights to factory settings since I had already coded VCDS to a value of 5, many months ago.
      This is on a 2011 GTI.
