VWVortex.com - 16V Brakes on a Fox....Pictures
    Results 1 to 9 of 9
    Thread: 16V Brakes on a Fox....Pictures
    1. Awaiting Email Confirmation 90quattrocoupe's Avatar
      Feb 6th, 2002
      Long Beach, CA.
      90 Audi S8coupe, 90 Fox Wagon, 2010 Jetta TDI
      10-18-2010 07:21 PM #1
      One of the problems with the FAQ on front brakes, is there is no pictures. You can describe something all you want, but pictures speak tons.
      I had these parts laying around, so I thought I would put a little picture show together.
      This first picture shows why you can't most VW carriers, except the Scirocco type carrier on a Fox strut. The spacing for the carrier holes are too far apart.
      Using a Fox strut and one 16v Jetta rotor I had laying around to do the mock up.
      This picture shows a 16v Scirocco carrier mounted to the Fox strut with a Jetta 16V rotor.
      The second picture is an end view of the same carrier and rotor.
      The next pictures are with the Jetta 16v caliper bolted up to the Scirocco 16v carrier with a Jetta 16v rotor on a Fox strut.
      You can tell this is a Jetta 16v caliper, because of the little hard brake line that loops around, before going to the brake line. This is the only difference between a Scirocco 16v caliper and Jetta 16v caliper. You can remove the hard brake line and just use the standard Fox brake line, if you use the Jetta 16v caliper.
      Next 2 pictures show a Scirocco 16v caliper bolted up to a Fox strut with a Jetta 16v rotor.
      The next 2 pictures show a Audi 4KQ front caliper bolted up to a Fox strut with a Jetta 16v rotor.
      See any difference in these calipers and carriers. Nope all the same.
      Jetta 16v rotor part # 321-615-301D. This rotor can be found on some of these cars.
      Obviously, 84-89 Scirocco 16V
      95-99 Rabbit/Golf Cabby
      93-96 Golf
      89-99 Jetta
      90-97 Passat
      85-88 Quantum Syncro
      16V Scirocco front brake carrier, part# 853-615-215. This can also be found on these cars.
      85-87 4000
      84-87 4000Q
      85-87 Coupe GT
      16v Scirocco calipers. Girling G54s. 1984-1989
      Left front part# 357-615-123A
      Right front part# 357-615-124A
      These can be found on some of these cars.
      85-87 4000
      84-87 4000Q
      85-87 Coupe GT
      95-96 Rabbit/Golf Cabby
      89-92 Jetta
      90-97 Passat
      Now if you can't find all this stuff in the junk yards, you aren't trying hard enough.
      Greg W.
    2. Remove Advertisements
      VWVortex.com
      Advertisements
    3. Member JaguarDoc504's Avatar
      Jan 3rd, 2005
      Lewiston, ME
      2013 LR4 HSE LUX
      10-19-2010 08:53 AM #2
      Just did mine.... waiting on a new caliper as the OG i got from the scrap yard had a stripped bleeder screw. Should get the new one tonight...... can't wait to see the improvement.
      Great pictures, i took a bunch and was going to post them. Thanks for saving me some time
    4. Member
      Oct 1st, 2007
      Ontario, Canada
      '90 VW Fox Turbo, '93 Grand Cherokee V8
      10-19-2010 04:15 PM #3
      This is golden information, great thread!
      Feb 14th, 2007
      Allentown PA
      1993 VW Fox 1994 Chevy S-10
      10-20-2010 08:12 AM #4
      This will be a nice addition to the FAQ's. I have a set of calipers/carriers from a Coupe GT, but I don't know what year it was. Hopefully I got the right stuff. Thanks for posting a meaningful thread.
    6. Member
      Apr 16th, 2009
      Wild Wonderful Wv.
      1965 Beetle, 1987 Triple White, 1988 cabriolet, 1993 2dr Fox gl, 1999 Jetta GL
      10-20-2010 08:53 AM #5
      Nice thread and explanatory pics !!! I agree, you can never have to many pics when you're doing something you're unfamiliar with and the explanations help so much more !!!!
    7. Member veedubb7's Avatar
      Apr 20th, 2002
      Pflugerville, Tx
      Couple Mk4's and a Mk3
      11-20-2010 09:16 PM #6
      Those calipers are the same as Mk3 2.0 calipers, right? Aren't the 16v brakes the same as the Mk3 2.0?
    8. Awaiting Email Confirmation 90quattrocoupe's Avatar
      Feb 6th, 2002
      Long Beach, CA.
      11-21-2010 01:45 PM #7
      Quote Originally Posted by veedubb7 View Post
      The part numbers listed above show the cross referenced car on the VW parts manual. They may be the same, I don't know. Get a set and find out. Take some pictures and add it to this thread.
      Greg
      Aug 23rd, 2013
      Maine
      1984 GTI
      11-21-2013 03:08 PM #9
      THANK YOU!
      i am building a tarmac rally MK1 GTI - and while my fabricator does the chasis work - was on engine and brakes today.....
      came up with this puzzle
      16v Calipers, but Jetta Carriers
      thank you thank you thank you
      $60 for the cardone carriers - and i am back in business with my 10.1 front upgrade
