VWVortex.com - Shifter knob does not move correctly after being installed, left to right movement
    Results 1 to 8 of 8
    Thread: Shifter knob does not move correctly after being installed, left to right movement
    1. Member crazynorweegian's Avatar
      May 8th, 2006
      Portland, OR
      1990 Corrado 1.9L G60-ST5 Black, 01 stage 3 allroad 6MT
      02-28-2011 02:16 PM #1
      I just replaced the bushings in my shifter because I was getting some weird shifts into 1st and second and reverse. I took it all apart, replaced the bushings, and added MOS2 grease. That made it feel so smooth it was like it was floating on air. The shifter was also very springy and returned to the center from both right and left with a sharp "boing."
      However, after I put the cables back in and reinstalled the box into the car, the shifter is slightly slow to come back from the right, and barely comes back from the left at all by itself. It still shifts fine, I just have to maneuver the shifter without assistance of a spring.
      I know I assembled the shifter correctly because upon discovering this I took it back out, disassembled it, cleaned it, reassembled it, greased it, tested the movement, reinstalled it, and tested it again only to find the same results.
      So, bad cables? Bad shift tower?
      Stephen
      Portland, OR
      Black 1990 1.9L Stage 5 G60 - keeper
      Corrados decay in a way that can only be measured using quantum physics
      http://sites.google.com/site/corradoproject/
    2. Remove Advertisements
      Advertisements
    3. Member CorradoMagic's Avatar
      Apr 11th, 2008
      Long Island
      94' Corrado VR-SC'd, 00' A4 Q/Avant, 82' Jetta, 12' Countryman All4
      02-28-2011 03:29 PM #2
      there is an exact adjustment procedure to make it perfect. but on a vr, there are 2 basic movement adjustments at the trans cable ends.I dont have a pic but the one to the left(IIRC) when looking into the bay adjusts the L to R position. A little will do a lot.
      loosen nut, push left, push right, center, have friend lock in place/tighten. make adjustments.
      umm, that last sentence doent sound right
      The DubNutz OEM & Performance parts in Long Island. Autotech, Quaife, ST, KW, Koni, Tein, JE, ClutchMasters, StopTech, Samco, Whiteline, TT, VF-E, Euro body accessories, TDN performance Mounts and lots more. Lowest Prices on ST Coilovers! ask
    4. Member crazynorweegian's Avatar
      May 8th, 2006
      Portland, OR
      02-28-2011 04:19 PM #3
      I was under the impression that those adjustments had to do with alignment of the shifter to the tower (getting gears engaged, not the rebound of the side to side movement of the shift knob inside of the car). It engages gears just fine.
      Stephen
      Portland, OR
    5. Remove Advertisements
      Advertisements
    6. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      1943 Flugkreisel, 1945 VRIL-7
      02-28-2011 04:36 PM #4
      Centering spring positioned properly?
      The original Dub and Dubber.
      Manche VWs sind einfach schneller als andere.
    7. Member dogger's Avatar
      Jul 29th, 2005
      Pasadena, CA
      1990 Corrado 2L 16V, 2004 Audi TT 3.2 Quattro, 2014 Audi RS5
      02-28-2011 04:49 PM #5
      I had the same problems every time I've disassembled the shifter. There is adjustment like CorradoMagic mentioned. If its not correct it won't move correctly. The bolt by the centering spring and how that metal piece is lined up is critical.
    8. Member crazynorweegian's Avatar
      May 8th, 2006
      Portland, OR
      02-28-2011 05:21 PM #6
      Are we talking about the bolt being tightened in the picture above? The one that holds the assembly into the casing?
      Or, are we talking about the one that goes up and down, threads from the front of the car, and holds that lever in place?
      Stephen
      Portland, OR
    9. Member NoCYet's Avatar
      Feb 10th, 2001
      Watertown, MA
      '94 Corrado, '13 S5
      02-28-2011 05:28 PM #7
      It's just below, and a little left of the head of the ratchet on the picture. You can't actually see it from that angle. Mine had marks from where it was before so I lined it up on those.
      I do not understand why some coupes make the grade and others do not. Everyone knows, for instance, that the Corrado was as tasty as an East End prize fighter with the looks of a Benetti super-yacht. The four-cylinder was good, but the VR6 was about as close as you could get to Ferraridom without buying a Ferrari. And what happened? You all went to the pub instead. -Jeremy Clarkson-
    10. Member crazynorweegian's Avatar
      May 8th, 2006
      Portland, OR
      02-28-2011 05:31 PM #8
      Awesome! I did not realize that was an alignment bolt. I suppose it says so in the Bentley....
      I will try that. I noticed the cable wobbling more than I thought it should, so that should tighten it up I hope.
      Stephen
      Portland, OR
