VWVortex.com - 65 beetle build thread...
    Page 2 of 15 FirstFirst 12345612 ... LastLast
    Results 26 to 50 of 367
    Thread: 65 beetle build thread...
    1. Member 86vwgti8v's Avatar
      Aug 2nd, 2004
      Greenville S.C.
      96 Cabby, 65 type 1, 03 B5.5 wagon, 80 scirocco
      05-06-2011 04:58 AM #26
      CB performance dropped spindles and new bearings.
    2. Remove Advertisements
      Advertisements
    3. 05-06-2011 07:55 AM #27
      Coming along nicely Sam.
    4. Member 86vwgti8v's Avatar
      Aug 2nd, 2004
      Greenville S.C.
      05-06-2011 07:49 PM #28
      Painted the tank, ran the brake line to the rear, replaced the soft lines up front. And installed one door panel.
    5. Remove Advertisements
      Advertisements
    6. Member 86vwgti8v's Avatar
      Aug 2nd, 2004
      Greenville S.C.
      05-09-2011 07:32 PM #29
      Got the firewall stuff installed and the rubber seals. How much fun was that?
      Began to instal the fuel talk and I realized I needed a small peice of soft line.
    7. Member JDII's Avatar
      Apr 1st, 2011
      14 C7 A6 SOLD! ,1965 TYPE 1, 1956 TYPE 1, 1948 SPLIT ,1997 Jetta GL
      05-10-2011 08:25 AM #30
      lookin good , whats up with the shower curtain?
    8. Member 86vwgti8v's Avatar
      Aug 2nd, 2004
      Greenville S.C.
      05-10-2011 10:31 AM #31
      Rear window leaks, I got the seal just hadn't done it yet.
    9. Member 86vwgti8v's Avatar
      Aug 2nd, 2004
      Greenville S.C.
      05-18-2011 08:48 AM #32
      Drivers side, new bearings, drop spindle and wheel cylinder and brake shoes after work!
    10. Member 86vwgti8v's Avatar
      Aug 2nd, 2004
      Greenville S.C.
      06-02-2011 11:34 AM #33
      Tried to do with out a"built beam" for now but that's not going to happen. I need to narrow one for sure. And smaller tires are a must. I'm at a finacial stand still on that.
    11. Member 86vwgti8v's Avatar
      Aug 2nd, 2004
      Greenville S.C.
      06-07-2011 06:04 PM #34
      here ya go..
      Ghetto jig.
      Laid out the slout and the cuts using the mill off the original center.
      Bolted it up to the jig
      tah dah!!
      gonna finish grinding and paint it tomorrow. will also do the tie rods tomorrow.
    12. Member JDII's Avatar
      Apr 1st, 2011
      06-08-2011 10:42 AM #35
      Looks good man. How many inches you take out? 4" -6"?
      Smile it will get Worse!!
    13. Member 86vwgti8v's Avatar
      Aug 2nd, 2004
      Greenville S.C.
      06-08-2011 11:17 AM #36
      6. And I lengthened the slot for the adjusters so I can get a little moar low. That coupled up with the drop spindles should set it really close to sea level.
    14. Member JDII's Avatar
      Apr 1st, 2011
      06-08-2011 01:13 PM #37
      6 is what mine is. you may want to modify your head light buckets for tire clearance. I left mine stock but cant do any u- turns and they rub if you turn shap to park.
    15. Member 86vwgti8v's Avatar
      Aug 2nd, 2004
      Greenville S.C.
      06-08-2011 01:29 PM #38
      In the agenda, thank you though.
    16. Member 86vwgti8v's Avatar
      Aug 2nd, 2004
      Greenville S.C.
      06-15-2011 06:29 PM #39
      narrowed beam with adjusters installed still needs to replace the monster truck tires, and install gas tank. will prob get about 1.5 to 2" lower
    17. Member 86vwgti8v's Avatar
      Aug 2nd, 2004
      Greenville S.C.
      06-26-2011 09:17 AM #40
      Replaced the rear wheel brake cylinder, shoes, soft lines, E brake cables, axle seals, notched the spring plates.
      Still haver to install the 145/65/15' s, the motor, gas tank etc. moar low to come!
    18. Member
      Feb 2nd, 2011
      Taunton Ma.
      06-26-2011 10:49 AM #41
      Looking good bro!
    19. Member dubhavoc's Avatar
      Feb 14th, 2009
      Highland Park CA
      16 GTI
      06-26-2011 05:44 PM #42
      Lookin really good.Like where this is going.
      Instagram @buggywill
    20. Member JDII's Avatar
      Apr 1st, 2011
      06-26-2011 10:31 PM #43
      keep up the good work dude, looks great.
    21. Member 86vwgti8v's Avatar
      Aug 2nd, 2004
      Greenville S.C.
      07-01-2011 08:14 AM #44
      Scored this gem, media blasted then gonna paint it flat black.
      Motor supposed to go in tuesday!
    22. Member JDII's Avatar
      Apr 1st, 2011
      07-01-2011 08:40 AM #45
      Looks loud! I like loud.
    23. Member
      Feb 2nd, 2011
      Taunton Ma.
      07-01-2011 12:24 PM #46
      I painted 1 of those 1 time with high temp paint. Smelled like a sack of azzholes for a week while the paint burnt off....And yup..loud!..I'm a fan of loud myself.
    24. Member 86vwgti8v's Avatar
      Aug 2nd, 2004
      Greenville S.C.
      07-01-2011 01:27 PM #47
      Quote Originally Posted by JDII View Post
      I
      That's what I'm hoping for!
    25. Member 86vwgti8v's Avatar
      Aug 2nd, 2004
      Greenville S.C.
      07-04-2011 06:12 PM #48
      Replaced the running boards, did a alignment on the front wheels, and half way installed the decklid. Hopefully thr motor goes in tomorrow
    26. Member GEETi's Avatar
      Jun 30th, 1999
      Plympton MA
      57 Bug 07 GTI 07 Eos
      07-04-2011 08:31 PM #50
      (I wanna see the smaller tires!)
      Low & Slow___(o\ ! /o)___
