VWVortex.com - Stopping LED DRL Dimming
    Page 2 of 2 FirstFirst 12
    Results 26 to 44 of 44
    Thread: Stopping LED DRL Dimming
    1. Member Tim S's Avatar
      May 7th, 2002
      '12 GTI 2dr TR Sunroof/Nav w/DSG
      03-05-2013 11:57 AM #26
      I'm glad this is working for people. In an earlier post, I included a link to a post I made at another site that is no longer valid. So let me re-create the post here, so that Google will index it.
      After reading this post --> https://forums.vwvortex.com/showthrea...1#post72689246
      I decided to try setting Central Electronics (09), Byte 25, Bit 1 to on.
      Since you can't alter Bit 1 via the Long Code Helper, you need to add "2" to the value of Byte 25 in the long string. So for me, that meant changing in from "84" to "86". (After you make the change, bit 1 should now be set in the Binary window--- it's the blue-highlighted digit above)
      Bottom Line: It works! My LEDs no longer drop in brightness when switched from OFF to Parking.
      Enjoy.
      VWVortex.com
    3. Member helement2003's Avatar
      Aug 2nd, 2004
      SoCal
      2008 R32 / 2017 Volt / 2018 Bolt
      03-05-2013 11:59 AM #27
      Quote Originally Posted by Tim S View Post
      I'm loving this fix (as I said before)...but just as a side note, my LED's dim in parking position when I pull the ebrake.
      Totally fine, just throwing the notice out there. I'm just happy that my LED's stay full bright when in parking, and still dim when the full headlights are on.
      My Flickr Stream // 2008 R32 #138 // 2013 Chevy Volt // 2017 Chevy Volt
    4. Member Tim S's Avatar
      May 7th, 2002
      03-05-2013 01:05 PM #28
      Quote Originally Posted by helement2003 View Post
      According to this --> https://forums.vwvortex.com/showthrea...1#post70341178
      It looks like Byte 11, Bit 0 controls this. Turn that bit off by subtracting "1" from the value of Byte 11. That should keep your LED DRLs bright while the parking brake is set. (It worked for me, but I reverted this particular tweak since I don't care for it).
    5. Member helement2003's Avatar
      Aug 2nd, 2004
      SoCal
      03-05-2013 01:28 PM #29
      Thanks for the info. I maaaay just leave it as is, as I don't mind it dimming when I park.
    6. Member PDXA4's Avatar
      Oct 9th, 2001
      Austin, TX formally Bay Area, CA
      Audi D2 S8...
      03-06-2013 07:42 PM #30
      Tracks thread, tks for the post...
      Current: Golf-R Rising Blue 4-door loaded, Mazda MX-5, several mods #333
      Former: Audi D2 S8 Ming Blue
      Former: VW mkV GTi United Gray, B6 A4 Avant 1.8TQ Atlas Gray
      B5 A4 1.8TQM Santorin Blue J31-K04 Beauty
      B5.5 Passat TDi, Euro model...
    7. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      02 Gti, 12 Tiggy SEL
      03-06-2013 08:58 PM #31
      Hi guys. I added two tweaks here:
      http://wiki.ross-tech.com/wiki/index...K/52%29_Tweaks
      * LED DRL Dimming for Xenon equipped vehicles with factory LED DRLs
      * Remote operation when engine is running
      The LED DRL simply points to Tim's post above but I'd like to search around in the forums before adding that to the A3/TT/R8 Wiki page. If we are 100% that the 8P0 BCMs behave the same way WITHOUT touching Byte 18 I believe that wold be a great one to confirm and add.
      The remote tweak should apply to any KESSY with Golf based BCM system but I was reluctant to add that because it allowed me to lose one of the 2012 Tiggy keys.. which was found locked in the car much later. I'll add that to the other Wiki tweaks pages at some point but I know the Mk6 guys had that figured out before I had the Tiguan.
      Dana Marie
      P.S. No Scan = No Soup
    8. Member PDXA4's Avatar
      Oct 9th, 2001
      Audi D2 S8...
      03-09-2013 04:19 PM #32
      Enjoy.
      Today I tried to do something similar on my 2012 Golf-R.
      I tried this today, but the "lcode2" brings nothing up.
      Should be noted that I have stock light switch, not the Euro one.
      Anyway I changed byte25 from 84 to 86, I can see no change (not that I was expecting to), but was hoping that would bring up some option for byte 11 so that I could uncheck bit 0. But bit 0 is not visible, at least as a option that I can tick. Or maybe this bit 1 is meant to appear on the byte 25 screen, but when I change is from 84 to 86 bit 1 does not appear still, I'm wondering why not ?
      Here is my byte 25 with 84:
      Here is my byte 25 with 86:
      And here is byte 11: (looks the same when I change byte25 to 86 or my default 84.
      Question is can this binary number be changed in byte11 ? And if so what should it be changed to ? Or is it as simple as changing "C1" to something else ?
      Basically I would just like to have my front DRL LED's stay on when my handbrake is up.
      Any help would be appreciated.
      I have rear LED's tailights BTW, non-fog.
    9. Member PDXA4's Avatar
      Oct 9th, 2001
      Audi D2 S8...
      03-10-2013 03:22 AM #33
      As an update...
      Later this evening I took a look at it again...
      Ah got it !!!
      For sure on on software "lcode2" is not showing up anywhere on the desktop. But keeping byte25 at 84, I just worked on byte11.
      I changed "C1" to "C0" and that worked... Success, now I have my LED DRL's working with the parking/e-brake/handbrake engaged.
      No need for Euro switch in this case.
      Version of software I'm running...
      byte 11: my default of "C1"
      Just changed "C1" to "C0"
      And accepted:
      Mar 26th, 2008
      Dirty Jersey
      List wouldn't fit here.
      03-22-2013 01:31 PM #35
      Now that we have the LED's at full bright with the parking lights on/handbrake up, is there any way we can keep the LED's full bright with the low beams on? Not especially useful with GTI's or GLI's, where the LED's are in the headlights, but for Golf R, it would be good.
    11. Member Calkulin's Avatar
      Dec 27th, 2012
      Central FL
      '15 Audi S3
      04-17-2013 03:28 PM #36
      I actually would like to do the opposite, I wanna disable the LED DRLs when the headlights are on but have yet to find the bit that controls it. Anyone?
    12. Junior Member
      Jul 29th, 2012
      Ohio
      2012 Golf TDI 4-door w/ tech pkg & 6-spd manuaL
      06-01-2013 02:11 PM #37
      I have a 2012 Golf TDI with factory xenons and LED DRLs and this did not work for for me. I changed byte 25 from 84 to 86, but bit 1 never appeared. Has anyone been able to successfully disable DRL dimming with parking/city lights on a mk6 TDI w/ xenons and LED DRLs? This should be an easy one...very frustrating. Thanks in advance!
    13. Member Tim S's Avatar
      May 7th, 2002
      06-01-2013 04:34 PM #38
      Quote Originally Posted by dhectorg View Post
      Can you post your long code string for Central Electronics? I want to confirm that Byte 25 is actually set to 86 now. If it is then bit 1 is set (see it circled in the screenshot below?)
    14. Junior Member
      Jul 29th, 2012
      Ohio
      06-01-2013 07:14 PM #39
      Here it is...
      Here is a complete auto-scan I just did. There is a fault in Cent. Elect. for the euro switch, but I don't know if that if causing this not to work. Not sure how to clear the switch fault. I'm definitely a VCDS noob!
      Saturday,01,June,2013,19:08:08:64062
      VCDS Version: Release 11.11.5 (x64)
      Data version: 20121222
      Chassis Type: 7N0
      Scan: 01 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 52 55 56
      62 72
      VIN: WVWNM7AJ3CW215108
      01-Engine -- Status: OK 0000
      03-ABS Brakes -- Status: OK 0000
      04-Steering Angle -- Status: OK 0000
      05-Acc/Start Auth. -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: Malfunction 0010
      15-Airbags -- Status: OK 0000
      16-Steering wheel -- Status: OK 0000
      17-Instruments -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      25-Immobilizer -- Status: OK 0000
      2B-Steer. Col. Lock -- Status: OK 0000
      2E-Media Player 3 -- Status: OK 0000
      37-Navigation -- Status: Malfunction 0010
      42-Door Elect, Driver -- Status: OK 0000
      44-Steering Assist -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      47-Sound System -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      55-Xenon Range -- Status: OK 0000
      56-Radio -- Status: OK 0000
      62-Door, Rear Left -- Status: OK 0000
      72-Door, Rear Right -- Status: OK 0000
      Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
      Part No SW: 03L 906 019 EE HW: 03L 907 309 AA
      Component: R4 2,0L EDC G000SG 1181
      Revision: 12H14--- Serial number:
      Coding: 0050072
      Shop #: WSC 01357 011 00200
      VCID: 72C53A006D551F88278
      No fault code found.
      Readiness: 0 0 0 0 0
      Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
      Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
      Component: ESP MK60EC1 H31 0121
      Revision: 00H31001
      Coding: 114B400C492300FF880C02E492210042B70000
      VCID: 7BDB1724FA1F5EC074E
      Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
      Part No SW: 5K0 959 434 B HW: 5K0 959 434 B
      Component: VWKESSYPQ35GP 085 0902
      Revision: 00085000 Serial number: 0160540923
      Coding: 030C0C
      ASAM Dataset: EV_KESSYPQ35G A02013
      ROD: EV_KESSYPQ35G_VW36.rod
      VCID: 3449FC189FC151B8F54
      Address 08: Auto HVAC (J301) Labels: 7N0-907-426.clb
      Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
      Component: AC Manuell H19 0404
      Revision: 00001016
      Coding: 0000001002
      ASAM Dataset: EV_ACManueBHBVW36X A01010
      ROD: EV_ACManueBHBVW36X_VW36.rod
      VCID: 8021E0C81BF9BD18A1C
      Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
      Part No SW: 1K0 937 086 P HW: 1K0 937 086 P
      Component: BCM PQ35 M 110 0651
      Revision: 00110 AC
      Coding: 6F180A3A90272AC4108800C170008DC448052086574D85B080 8620248040
      VCID: 3D5FD93CA48B90F00AA
      Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
      Component: Wischer 29111 26 0512
      Coding: 009795
      1 Fault Found:
      01800 - Light Switch (E1)
      008 - Implausible Signal - Intermittent
      Freeze Frame:
      Fault Status: 00101000
      Fault Priority: 3
      Fault Frequency: 3
      Reset counter: 230
      Mileage: 25684 km
      Time Indication: 0
      Date: 2016.14.14
      Time: 18:51:19
      Freeze Frame:
      Term 15 Off
      Voltage: 12.25 V
      OFF
      ON
      Term 50 Off
      OFF
      OFF
      Address 15: Airbags (J234) Labels: 5K0-959-655.clb
      Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
      Component: AirbagVW10G 013 0724
      Serial number: 003GVRA13GK+
      Coding: 00003131
      ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
      ROD: EV_AirbaVW10SMEVW360_VW36.rod
      VCID: 3FA3A334A68782E0186
      Seat occupied recognition:
      Subsystem 1 - Part No SW: 5K0 959 339 B HW: 5K0 959 339 B
      Component: BF-Gewichtss. 006 0001
      Serial number: ---0000R--000026LZ00
      Crash sensor for side airbag; driver side:
      Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
      Component: S.Sens.Fahr.V H01 ----
      Serial number: 3572MSME7F15044AZZZ$
      Crash sensor for side airbag; passenger side:
      Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
      Component: S.Sens.Beif.V H01 ----
      Serial number: 3582MSME50453267ZZZQ
      Crash sensor for side airbag; rear driver side:
      Component: S.Sens.Fahr.H --- ----
      Serial number: 3512QSME7033681CZZZV
      Crash sensor for side airbag; rear passenger side:
      Component: S.Sens.Beif.H --- ----
      Serial number: 3522QSME464A6710ZZZU
      Crash sensor for front airbag; driver side:
      Component: F.Sens.Fahr --- ----
      Serial number: 35527SME702C3629ZZZH
      Crash sensor for front airbag; passenger side:
      Component: F.Sens.Beif --- ----
      Serial number: 35627SME06312629ZZZ6
      Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
      Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
      Component: LENKS.MODUL 014 0140
      Revision: FF010040 Serial number: 20111207301387
      Coding: 100A140000
      ASAM Dataset: EV_SMLSNGVOLWSXS A01004
      ROD: EV_SMLSNGVOLWSXS_VW36.rod
      VCID: 7DDF193CEC0B50F04AA
      Multifunction steering wheel control module:
      Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
      Component: E221__MFL-TK6 H06 0022
      Coding: E20000
      Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
      Part No SW: 5K0 920 972 C HW: 5K0 920 972 C
      Component: KOMBI H03 0607
      Serial number: 00000000000000
      Coding: 270F01
      ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
      ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
      VCID: 3041F0086BD96D9891C
      Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
      Part No SW: 7N0 907 530 M HW: 1K0 907 951
      Component: J533 Gateway H42 1623
      Revision: H42 Serial number: 081211F1000132
      Coding: 350002
      VCID: 3A55D220B5A5A7C82F8
      Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
      Part No SW: 5K0 953 234 HW: 5K0 953 234
      Component: IMMO H03 0607
      Coding: 000007
      ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
      ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
      VCID: EAF5A2600D8557481F8
      Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
      Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
      Component: ELV-PQ35 H20 0230
      Revision: 00000000 Serial number: 11000266405005
      Coding: 4100000000000000
      ASAM Dataset: EV_ELVMarquMPVW36X A01001
      ROD: EV_ELVMarquMPVW36X_VW36.rod
      VCID: 2E7DEE7071ED7B68830
      Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
      Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
      Component: SG EXT.PLAYER H13 0240
      Revision: A1001003 Serial number: 7661396117
      Coding: 020000
      VCID: 29771D6C40031C50562
      Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
      Part No SW: 1K0 035 274 B HW: 1K0 035 274 B
      Component: RNS315-NAR H33 0265
      Serial number: VWZAZ2L8483700
      Coding: 04050001010005000000100A
      ASAM Dataset: EV_RNS315NARV2UDS A01004
      ROD: EV_RNS315NARV2UDS_VW36.rod
      VCID: 236B0F442A2FC6001CE
      Data medium:
      Subsystem 1 - Part No: 3AA 919 866 B
      Component: NAR_V2 0002
      1 Fault Found:
      1048669 - Tuner for Satelite Radio
      B11CF 53 [009] - Deactivated
      Confirmed - Tested Since Memory Clear
      Freeze Frame:
      Fault Status: 00000001
      Fault Priority: 7
      Fault Frequency: 1
      Reset counter: 167
      Mileage: 10401 km
      Date: 2010.14.01
      Time: 08:44:35
      Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
      Part No SW: 5K0 959 701 H HW: 5K0 959 701 H
      Component: Tuer-SG 009 2105
      Coding: 0001204
      VCID: 3753CB1446B7BAA0D06
      Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
      Part No: 1K0 909 144 M
      Component: EPS_ZFLS Kl. 70 3201
      Revision: 00H20000
      VCID: 3449FC1857C151B8F54
      Address 47: Sound System (R12) Labels: 5K0-035-456.clb
      Part No SW: 5K0 035 456 B HW: 5K0 035 456 B
      Component: KonzernAmp 8K H07 0368
      Revision: -------- Serial number: EAA085A0009012
      ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
      ROD: EV_AudioVerst8KanalBNO1.rod
      VCID: 29771D6C48031C50562
      Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
      Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
      Component: Tuer-SG 009 2119
      Coding: 0001204
      VCID: 3245FA00ADD55F88E78
      Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
      Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
      Component: AFS-Steuergeraet 0148
      Revision: 00H04000 Serial number:
      Coding: 1446940
      Subsystem 1 - Part No: 7L6 941 329 B
      Component: AFS-Lst.-Modul l 0005
      Coding: 00000022
      Subsystem 2 - Part No: 7L6 941 329 B
      Component: AFS-Lst.-Modul r 0005
      Coding: 00000022
      Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
      Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
      Component: Tuer-SG 007 2101
      Coding: 0001168
      Shop #: WSC 01357 011 1012552
      VCID: 354FC11C5CBB48B0C2A
      Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
      Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
      Coding: 0001168
      VCID: 364DC61041BD43A8CB0
    15. Member Tim S's Avatar
      May 7th, 2002
      06-01-2013 07:47 PM #40
      Well, the good news is your Byte 25 coding is correct for "bright" LED DRLs.
      Did you double-check the trigger wire you ran for your Euro switch to enable Parking Lights Only? Maybe it's connected to a wrong pin? That could cause a fault.
    16. Junior Member
      Jul 29th, 2012
      Ohio
      06-01-2013 07:53 PM #41
      I tried it again and it seemed to work this time. The only thing I did differently is ran another auto-scan before trying, and this time I selected my vehicle from the list instead of letting VCDS figure it out automatically. That may have been the issue. I don't think my repair wire is an issue, since the fogs are working perfectly via the euro switch. Thanks!
    17. Junior Member
      Aug 9th, 2013
      Tianjin, China PR
      MK7 R (2014) / MK6 1.4TSI (2009)
      06-28-2014 01:34 PM #42
      Quote Originally Posted by Calkulin View Post
      if you get the Light and Rain Sensor installed, then you can activate the option of only turn on the DRLs when LRS is activated. that will make your DRLs turned off when headlights are on. hope this helps. it works on my car.
    18. 07-31-2014 06:33 PM #43
      Am I the only one who can't get it to work? It accepts the code, but they still dim. I wonder if it is because I didn't update my CECM. Everything else works fine, they dim when turn signal is on and are at the correct brightness as DRLsv
    19. Junior Member
      Mar 28th, 2016
      CO
      2018/VW/Alltrack SEL
      06-01-2016 07:19 PM #44
      i'm reviving this!!
      has anyone figured out how to stop them from dimming in parking position when fogs are pulled on??? or even when headlights are turned on???
      I've looked everywhere and read every post. I've looked and searched everywhere else. I even found some info in an A3 forum but their VAGCOM instructions didn't match for my '16 GLI SEL.
      I have a theory though... I've found that if I put my euro switch in the parking position (fogs off still) and turn my drl's off and on from my MFI, they dim when I turn them off, then go full brightness when I turn it on, and back and forth...
      This leads me to speculate that the led drl's have 3 modes, just plain off, "drl" on (full brightness) and "drl" off (half bright) which makes sense cause you don't need drl's when fogs or headlights are on, meaning the led's turn into regular lights.
      Someone needs to experiment with this please!!!
