VWVortex.com - TT MK2 Wheel/Tire Fitment Thread - Ask all your questions here and post up pictures
    Page 17 of 17 FirstFirst ... 71314151617
    Results 401 to 412 of 412
    Thread: TT MK2 Wheel/Tire Fitment Thread - Ask all your questions here and post up pictures
    1. 08-21-2017 02:09 PM #401
      Quote Originally Posted by ChiCityS4 View Post
      Looking at getting these wheels for my 2010 audi tt (Non-RS/Quattro) I did a test fit and will need to order a set of rings. Hoping someone can give .02
      Specs:
      OEM audi A5 titanium Ti Package 19''x9'' et33 peels wheels. Tires are 255/35/19.
      Any help would be greatly appreciated
      It will rub pretty aggressively. Plus the hub is 66.56 so unless you get precise hub rings it will shake.
      Sent from my LG-H830 using Tapatalk
    3. n00b Zer0_Cool's Avatar
      Feb 23rd, 2018
      Atlanta
      2008 Audi TT
      02-23-2018 10:18 PM #402
      S5 OEM 19x9 et33 fit on MK2 TT
      After a bunch of searching I wanted to share the final result.. the 255/35/19's that came on the wheels rubbed in the rear on big bumps even after grinding down the rear tabs. Although I don't think it would have damaged the tires or rear bumper much. The wheels werent balanced that I purchased so I decided to go with new tires Continental DWS 235/35/19. I havent heard any rubbing since. Would obv. like to lower the car in the future, but really like the difference in look already.
    4. Member northendroid's Avatar
      Sep 16th, 2014
      Cornwall, Ontario, Canada
      1991 Corrado G60 in progress, 1998 GTI VR6, 2012 Audi TTRS Black Panther
      01-21-2019 02:07 PM #403
      Staggered setup on my TTRS:
      • Rohana RC10 Matte Black 5 x 112 - 66.5 hub
      • Stock ride height
      • Continental Extreme Contact - 255/35/19 all around
      • 19" x 8.5" Front ET 42 + 13mm spacer = ET29
      • 19" X 9.5" Rear ET 47 + 5mm spacer = ET 42
      42 Draft Design 51.7 - 66.5 hubcentric
      http://www.42draftdesigns.com/vw-aud...wheel-spacers/
      Restoring: 1991 Corrado G60
      Corrado Buddy MK3 GTI VR6
      2012 Audi TTRS
      ACNA Eastern Canada Communication Director
    5. Member goodhews@comcast.net's Avatar
      Oct 7th, 2008
      muncie, indiana
      01-21-2019 08:39 PM #404
      I am building a website/dedicated place for 8j/mk2 TTdiy's and information! I have use all the setups I could from this thread.
      http://goodhewsauto.com/stance-wheel-fitment-examples/
      If you have anything you would like to add to my site post it here or message me. Thank you
      ------------RustyVolkswagenOfAmerica.com------------
    6. 07-27-2019 06:24 PM #405
      Will these wheels fit on MK2 TT?
      Original Audi wheels from A3
      18x8 46 offset with the 5 lug 112mm bolt pattern
      Tyres are 225/40/R18
      Thanks!
    7. Member northendroid's Avatar
      Sep 16th, 2014
      07-28-2019 10:20 PM #406
      Mk2 TT yes, on an RS not sure it 18" wheel will clear front callipers
      2012 Audi TTRS
    8. Member ThePhoenix's Avatar
      Aug 29th, 2012
      Rancho Santa Margarita, California
      pending
      09-11-2019 04:25 PM #407
      in hope someone can answer this
      I have 18x9 et52 with 245/40/18 tires on now
      I found some 18x8 et48 with 245/40/18 tires
      I want to be SURE that my tires will work on those rims... It is an inch narrower.... is that OK?
      I checked I have lots of clearance so the -14 offset is ok....
      Chaz
      The British Leyland Rule: It's better to go fast in a slow car, than slow in a fast car.
    9. Member RedATPGti's Avatar
      Nov 25th, 2002
      MK2 TTS/C6 A6 Avant
      09-17-2019 05:48 PM #408
      Quote Originally Posted by ThePhoenix View Post
      It should work but you can always look up your tire specs on the manufacturer website to see what is recommended. Tirerack.com also has this information if they carry your tire. I also recommend using this website for checking fitment: https://www.willtheyfit.com/
      STaSIS MK2 TTS
      C6 A6 Avant 3.0T
      15 GTI SE APR Stage 2+ SOLD!
      The APR MK6 GTI SOLD!
      15 Audi A3 2.0T Quattro APR Stage 2+ SOLD!
    10. Senior Member Wimbledon's Avatar
      Nov 25th, 2005
      Phoenix, AZ
      10-16-2019 07:09 PM #409
      The factory 18" bi-color wheels needed to be refinished so I decided to powdercoat them in gloss black a few months ago. They turned out even better than I expected! I then installed a new set of tires that tremendously improved the car -- I highly recommend a set of Michelin Pilot Sport 4S.
      2018 Fiat 500e
      2008 Audi TT 3.2 quattro manual
      2006 Lotus Exige
    11. 11-13-2019 03:42 PM #410
      My new winters are Continental VIKING CONTACT 7 sized 225/50/17 on 17/7 steel rims with a 50mm offset.
    12. Member OrangeA4's Avatar
      Oct 31st, 2000
      Los Angeles
      '17 A4 Allroad
      11-29-2019 01:15 PM #411
      [IMG][/IMG]
      Sadly Sold this car but the wheels are for sale PM if interested.
      19x8.5 48j BBS Speedline OEM wTPMS
      '17 A4 Allroad
      '17 Honda Ridgeline
      '08 A4 Avant 2.0t S-line Titanium
      SOLD ->v'11 TTS Coupe, '01 A4 Avant 1.8t S-line, '95 "Getta" VR6, '90 Coupe Quattro 20v <-SOLD
    13. 02-14-2020 01:36 PM #412
      My wife has a 2009 Audi TTS convertible. Bought her Niche Methos 19x8.5 wheels with +42 Offset for Christmas and having issues.
      I checked with a local tire guy I know and he researched and said to use 6mm spacers but they made it worse. They are rubbing on the inner wheel well.
      Car is stock other than wheels, rotors and pads (no clearance issues with rotors) and APR Stage 2 which includes downpipe, fuel pump, water pump, intake and tune.
      Any guidance is greatly appreciated!
      HERE IS THE SETUP'S WE'VE TRIED
      1.) Stock wheels 19x9 with Stock Tires 255/35 - worked great
      2.) Stock wheels 19x9 with Track Tires 245/35 - worked great
      3.) Niche wheels 19x8.5 +42 with Stock Tires 255/35 - rubbed some but not horrible
      4.) Niche wheels 19x8.5 +42 with Stock Tires 255/35 with 6mm spacers - rubbed a lot worse
