VWVortex.com - How do you remove the hood hinges from a 92 cabby?
    Results 1 to 5 of 5
    Thread: How do you remove the hood hinges from a 92 cabby?
    1. Junior Member steveinphoenix's Avatar
      Aug 12th, 2011
      Phoenix, AZ
      1992 Volkswagen Red w/ Tan Top Cabriolet Wolfsburg Edition 5 speed
      08-24-2011 06:22 AM #1
      I have a 92 cabby wolfsberg and i would like to know how you go about removing the hood hinges from under the raintray area.
    2. Remove Advertisements
      Advertisements
    3. Member Big CADDY's Avatar
      Aug 28th, 2001
      Mt. Holly Springs, PA
      08-24-2011 04:16 PM #2
      If you reach under there you'll feel a post with a clip on it. the clip is tricky to get off if you've never done it. you have to pry and slide it. You can do it with your fingers but sometimes it's easier with a short flat driver. You pry/lift only the top part of the clip the lower will slide off.
      Here is a pic of the same type of clip.
    4. Junior Member steveinphoenix's Avatar
      Aug 12th, 2011
      Phoenix, AZ
      08-24-2011 04:48 PM #3
      Quote Originally Posted by Big CADDY View Post
      That worked! Thanks so much. By the way...how the hell did you take that picture???
    5. Remove Advertisements
      Advertisements
    6. Senior Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      90, 92, 93 Cabriolet They own you.
      08-24-2011 06:15 PM #4
      Quote Originally Posted by steveinphoenix View Post
      I would think with a Camera.
    7. Member Big CADDY's Avatar
      Aug 28th, 2001
      08-24-2011 08:50 PM #5
      I found it on google. I knew there was a pic somewhere out there.
