VWVortex.com - Back at it again - Slammed Supers
    Page 5 of 6 FirstFirst 123456 LastLast
    Results 101 to 125 of 143
    Thread: Back at it again - Slammed Supers
    1. Member Jade Wombat's Avatar
      Oct 20th, 2004
      Houston, TX
      '66 Bus, '08 Volvo S80
      10-10-2011 09:49 PM #101
      Saw this over the weekend at Cruisin' the Coast show in Mississippi. '73 on airbags, electronic everything inside.
    2. Remove Advertisements
      Advertisements
    3. 10-17-2011 07:31 PM #102
      Stumbled on this through google and was happy to see it's not dead. Definitively gonna keep an eye on this. I'm building a 74 super myself, but the front is as low as i can get it before the pitman arm hits the control arm when i steer. Have you run into this problem as well? I'm considering a rack and pinion setup from a 75 super, if i can find one. What have you done?
    4. 10-18-2011 09:12 AM #103
      It is not dead... I am in Texas right now. I have some pics to update with. I will do it while I am here. I will be back on the project by this weekend!
    5. Remove Advertisements
      Advertisements
    6. Member 71DubBugBug's Avatar
      Dec 3rd, 2006
      Chicago
      91 Audi D11 V8, 71 Super, 07 E320 Bluetec, 05.5 Jetta 2.5
      10-19-2011 11:08 PM #104
      What do you guys do to lower the rear?
    7. 10-20-2011 07:03 PM #105
      The back was lowered in the pic above just dropping the spring plates a couple clicks.
      The way we are doing it now is by actually cutting up the rear trailing arm thanks to loosenutz! We will have a 4" drop with stop suspension travel.
    8. Member 71DubBugBug's Avatar
      Dec 3rd, 2006
      Chicago
      10-20-2011 08:25 PM #106
      Quote Originally Posted by gsusmaniac View Post
      Do you have pics?
    9. 10-27-2011 12:53 PM #107
      I know how you guys feel about the slammed supers thing....
      I like the skidplate but I think you would be better off changing the inner pickup point
      of the lower contol arm. Say moving it up 1-2" on the pan. Not that you really care about
      handling when it is this slammed but this will help and also eliminate the chance of hitting
      those tabs the hang really low. On my super I have bent/folded them over a little bit from
      driving around slammed.
      Slammed on those ATS wheels looks dope btw.
    10. Member GEETi's Avatar
      Jun 30th, 1999
      Plympton MA
      57 Bug 07 GTI 07 Eos
      10-27-2011 01:11 PM #108
      Quote Originally Posted by vw1303 View Post
      Nice looking Bug
      Now drift that thing around (like this one) and be the SB super star
      Low & Slow___(o\ ! /o)___
    11. Member 71DubBugBug's Avatar
      Dec 3rd, 2006
      Chicago
      10-27-2011 04:24 PM #110
      Yours? Thats awesome! Was watching that vid a few days ago.
    12. 01-28-2012 10:19 AM #111
      Well... I haven't died. Just had a crap load going on through the holiday season. We were still getting work done, just not getting the pics and time I wanted to keep up with this thread.
      So here we go, this will be a long reply but will show you guys what we have been up to! And I will try a little harder to maintain it.
      Quote Originally Posted by 71DubBugBug View Post
      Do you have pics?
      First, yes here are some pics of the drop on the rear. I thought I took some pics of the jig and cutting, but I think they were on the Iphone that got sucks into the angle grinder
      We have been contemplating raising the control arm mounts, just havent put any thought into it yet. Definitely something that I want to figure out though!
      Anyways, here are the best ones I could find of the drop, if you have any questions, I could get some better pics.
      In hindsight, we realized we should have done a 3" drop plate instead of 4" cause we ran into some issues with the lower shock mount. It pretty much sat on the ground before the wheel. So we cut it in half and then redrilled the hole higher and now have about an inch of clearance underneath it.
      We also finished up the coils and got them all installed... pretty easy process building them. But we were a little ambitious the first time with lowering. We set the perches just high enough that they took up the slack in the spring and in they went!
      And of course, the skid plate set down right on the ground!
      So we raised them till we have about a half inch under the skid plate-
      And this is our final product... I think we are gonna through some 16" porsche wheels with a little fatter tires, then pull the fenders and lower it some more. The wheels will raise it and fill in the fenders and I think give it a little better look. But for now I am happy!
      We also picked up this nice little kit at BugJam this year that extends the pedal cluster. Gives you and extra inch between the brake and clutch pedal and make the assembly a lot smoother all around. I will get some pics up of that soon as we just got it put all together.
    13. Member Pineapplegti !'s Avatar
      Dec 17th, 2008
      Las Vegas NV
      2015 f150 2.7eco scsb.2014 brown/brown TDI t-reg .Berg Mk1.Turbo rail
      02-08-2012 02:50 AM #112
      Lookin good.. I have my german look hammered super all worked out in my head
      autocrats...
    14. 06-14-2012 04:34 AM #113
      This thread is a dream come true. I only thought air ride would get a super real low. So let me ramble a bit and tell me if I'm correct. You have the front struts on a 150# spring, with a coil over from where exactly? And you have a 4" drop plate, but a 3" would be more suitable. Minus the skid plates did I get that correct? Did you need a different stabilizer bar? and are the tie rods flipped or did you not do that?
      Anyways major props on the super. This is an awesome thread.
      cheers
    15. Member jkallhoff's Avatar
      May 9th, 2010
      cleveland ohio
      2006 gti
      07-18-2012 07:58 PM #114
      this is like a super builders dream thread. i too have 73 super and i was totally ready to find some old strut and start hacking away and mounting some air cylinders in them. this is so much easier. good thread keep us updated.
    16. Senior Member 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      1971 VW Super Beetle, 1958 VW Double Door Panel, 2018 Tiguan, 2018 GM Sierra SLT 4x4 6.2L Crew Cab
      07-19-2012 02:14 AM #115
      Like this one?
      http://www.thesamba.com/vw/classifie...php?id=1220896
    17. Senior Member 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      07-20-2012 01:01 PM #116
      Lowered my 71 Super another 1.5" yesterday :p ...... now I have to do some work in the trunk and well, it's harder to do :p
    18. Member tonytalksalot's Avatar
      Oct 29th, 2011
      Miami...
      bagged 2012 beetle, 1992 golf gl, 1970 beetle
      07-28-2012 12:14 AM #117
      My favorite thread in the aircooled section. Let's keep it alive!
      BROKEN.CO
      Instagram @tonytalksalot
      We miss you oneethree
    19. 08-02-2012 05:55 PM #118
      Quote Originally Posted by Pineapplegti ! View Post
      Get it started and lets see it....
      Quote Originally Posted by Superbeet View Post
      cheers
      Yes you have that about right... all the parts we bought were from a company called QA1, I thought I posted a DIY for the coils, but if not- here it is again We do have flipped tie-rods, and will be adding a lowered 7/8" front sway bar and a 3/4" rear.
      This has part numbers and prices for what we used-
      http://www.superbeetlesonly.com/foru...howtopic=12693
      Quote Originally Posted by jkallhoff View Post
      We have been working out engine issues, so it has been slow.
      Quote Originally Posted by 71sbeetle View Post
      Looks like the exact one... and it is AWESOME!
      Pics Garey, you can't say that and not show us!
      Quote Originally Posted by tonytalksalot View Post
      Sorry, I didn't think many people were checking this thread so I haven't updated it much. I will try and do more in the keeping it alive section
    20. Senior Member 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      08-02-2012 06:28 PM #119
      Alright, but I promise they're boring!
    21. 08-02-2012 08:21 PM #120
      Looking good... at least you drive yours!
    22. Senior Member 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      08-02-2012 09:11 PM #121
      Hmm, let's see, from May 2011 to July 20th 2012, I drove it ..... a whopping 49 miles!!! I used to drive it 24,000 a year!!!
    23. 08-05-2012 01:38 AM #122
      Do you rub fenders? Looks really good though
    24. Senior Member 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      08-05-2012 01:42 AM #123
      Nope no rubbing. Now running 205/65/15 rears and 175/65/15 fronts.
    25. 08-06-2012 02:06 AM #124
      Just lowered my 74 super beetle the other day with adjustable struts! Love the looks of it but it rubs on the fender too much because my rims are a bit wide... I have no idea what i could do to widen the fenders, i tried to bend them out but the fender didnt have enough support... Has anyone done anthing to theirs to make their stock fenders a little wider? I will post pictures of it soon.
    26. Member westypoo's Avatar
      Jan 17th, 2010
      Durango, coloRADo, USA
      75; super beetle germanlook turbo WBX powerplant
      08-24-2012 03:21 PM #125
      what wheels and tires you running? that will help a lot for getting extra clearance. but i flaired my front fenders. im gonna buy windend fenders tho in the future.
