VWVortex.com - VEMS iac help
    Results 1 to 23 of 23
    Thread: VEMS iac help
    1. Member chrgdVR's Avatar
      Aug 2nd, 2004
      Hartford, CT
      86 golf 1.8t VEMS, 96 jeep zj 5.2v8 awd
      09-03-2012 06:59 PM #1
      ok so i have a 1.8t awp engine code
      im using a 24v75mm vr6 cable throttle body
      im trying to figure out how to wire the idle motor on this TB
      some info from the bentley...
      pin8/1 br/li~ grd
      pin8/2 ro/li~ im thinking thats my power
      and then pin 8/3 and 8/7 are my idle switch
      now my problem is in the bently it looks like theres power and grnd to a motor in the throttle body along with an idle tps and an idle switch
      i wired my tps no problem but the motor to control my throttle im pretty confused cause it doesnt look like the iac types shown below from the vems website
      got this info here....http://www.vems.hu/wiki/index.php?pa...assiveThrottle
      im trying to figure out how to wire this up and control it with my VEMS
      heres the info on the iac off the vems website....hopefully someone can help and this will prolly help anyone else in the future trying to do this
      Idle Air Controller (IAC)
      An Idle Air Controller (IAC) is used on most fuel injected engines to provide a method of controling the engine's idle speed. When the car is warming up or an additional load is put on the idling engine such as the additional current of an electical fan or air conditioning compressor it is necessary to raise the engine's idle speed to stop it from stalling.
      IAC Types
      There are a number of different idle speed controllers:
      Wax is the simplest and most common on Japanese cars and are not controllable by the ECU in that they use a wax filled piston which opens the throttle slightly when cold and closes it when the heat causes the wax to expand.
      Solanoid IACs use a single coil to open or close a valve in the inlet (in some cases to actually move the throttle plate). The simplest can be either opened or closed and will cause small increase in idle speed. More sophisticated types can be pulsed to provide a variable increase in RPM.
      Multicoil and Stepper motor IACs allow a more complex level of control, in its simplest form it will have two coils to open and close the idle valve.
      Choosing the correct IAC connection
      Single coil types are relatively simple to connect, the only thing you need to know is the resistance of the IAC's coil by measuring it with a DVM. Once you have the resistance value use Ohms law to calculate it's current load. I=V/R.
      Examples:
      The IAC coil for a Nissan 200SX is measured at ~11 ohms a voltage of 13.8V would mean a current of ~1.26A (13.8/11) which means that a spare high current port (EC36-pins6, 9, 17 or 18) would need to be used.
      The Toyota "Idle Up Valve" found on the early 4A engines has a solanoid coil with a resistance of ~44ohms, which gives a current of 313mA(13.8/44). As this is less than the maximum 350mA value for EC36-pin3 (Fast Idle) it would be possible to connect it, but this is only advisable if you are using all the other high current pins. In all other cases its advisable to use one of the spare pins.
      Dual Coil Solenoid IAC Control
      Found in some BMWs (Bosch) along with Toyota & Subaru, These have three pins, one of which is common, one is a solenoid that opens the idle valve, the other is a solenoid that closes the valve. If neither coil is activated the valve remains in a 50% open poisition (preset-spring type), or moves freely between opened/close position (no spring type).
      EC36-pin6 to IAC close pin
      EC36-pin17 to IAC open pin
      Configuration
      Set IAC actuator speed/pwm freq
      stepper speeds : 0 - 976 steps/s, 1 - 488, 2 - 326, 3 - 244, 4 - 195, 5 - 163, 6 - 139, 7 - 122, 8 - 108, 9 - 98, 10 - 89, 11 - 81, 12 - 75, 13 - 70, 14 - 65, 15 - 61.
      pwm freq: 0 - 244 Hz, 1 - 195, 2 - 163, 3 - 139, 4 - 122, 5 - 108, 6 - 98, 7 - 89, 8 - 81, 9 - 75, 10 - 70, 11 - 65, 12 - 61, 13 - 57, 14 - 54, 15 - 51.
      Stepper Motor IAC
      One of the most common types of IACV after the single coil solenoid is the Stepper motor type. The 4 pins of the 2 coils are connect to the 18pin Econoseal plug.
      The coils are preferrably connected between A-B and C-D stepper outputs:
      EC18-pin4 Stepper-A
      EC18-pin10 Stepper-B
      EC18-pin5 Stepper-C
      EC18-pin11 Stepper-D
      Configuration
      Using the dialog Extras->Idle Settings General
      Set Control Type to PWM/Stepper
      Initially IAC actuator speed/PWM freq should be set to 10, this number will need to be reduced to speed up the stepper, this needs to be done once the idle control is working.
      Set Max steps to extend to a low number, as this defines the number of steps that the controller will allow the stepper to make, too many steps will cause the controller to open too far and potentially jump the IACV. Initially start at 50 steps and increase the number once you have stable idle.
      Under Iac Hardware setup
      Set Type to Stepper
      The stepper pattern is defined as a binary pattern where:
      Coil A=00 Coil B=01 Coil C=10 Coil D=11
      So to define your pattern use the Windows Calculator in binary mode and convert to decimal mode, then put the result in the Iac step sequence box.
      For example the typical patterns are
      D->B->C->A which is 11->01->10->00 11011000 or 216 in decimal.
      D->A->C->B which is 11->00->10->01 11001001 converted to decimal is
      201
    2. Remove Advertisements
      VWVortex.com
      Advertisements
    3. Member Crispy222's Avatar
      Mar 9th, 2008
      Syracuse, NY
      98 Passat 20/20, 01 A6S 2.7TQM, 01 S8 4.2QM
      01-17-2013 02:53 PM #2
      Good questions, but I'm not quite there yet with my configuration.
      Find anything new somewhere else? Looks like VEMS developement isn't quite there as a whole yet.
      B5 Passat Variant, Blk, 5-sp, 2008cc, JE, IE, 50-trim, SPA T3, Unitronic 440, Fuelab, RC 550, Precision 600hp FMIC, AHA V6 TB, 2.75" piping Stock AEB head, 3" back, Magnaflow, 4" angle down
      Further Performance
    4. Member chrgdVR's Avatar
      Aug 2nd, 2004
      Hartford, CT
      01-17-2013 04:18 PM #3
      Oh wow hey man I just replied to your pm... I didn't see this post until now.
      This thread is from when I first started with my vems install
      I'm not using the TB motor for idle control as implementing an idle switch to disable the tps isn't there in the vems firmware yet... Hopefully in the future they will have control for this type of idle control.
      I'm actually controlling my idle via the ignition by using 10* advance and retard to control idle... Works great but stalls when cold at times
      I'm actually trying I install a Iacv from 034. It's a gm stepper valve.. Hopefully I'll have it working tonight when I get home from work..
      If you need help with your coils and config setup let me know. I'd be more than happy to help you out with what I can.. I know it took me forever to figure out alot I things when I first started
    5. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      15 Jetta 92 Corrado VR6
      01-17-2013 11:13 PM #4
      Tps is pins 4,5,7 just like the diagram. 1/2 is the iac, its a 2 wire, controlled dc motor. The best driver seems to be a half h-bridge but one side pwm can work in open loop.
      -Paul
      1992 Corrado - ALL MOTOR Drag Project [email protected] and falling
      KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    6. Member Prof315's Avatar
      Jan 5th, 2009
      Melbourne, FL
      1992 Corrado ABA-T and MS3-Pro powered, 84 Honda V65 Sabre
      01-18-2013 06:55 AM #5
      Quote Originally Posted by need_a_VR6 View Post
      Actually I'm finding that one side pwm works better with closed loop, at least with MS3. It's not perfect and if someone could decipher the components needed here: http://www.msextra.com/forums/viewto...p?f=67&t=47346 , I'd be willing to have some boards made up and sell them at cost.
      The Professor
      Melbourne, FL
      92 Corrado OBD2 ABA-T (BW EFR 6258) Powered by MS3Pro
      Linfert Performance: The Megasquirt guy in central Florida Like my Facebook page....
      Sandy Linfert 11/4/1991 - 5/13/2013
    7. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      01-18-2013 10:43 AM #6
      That thing seems overly complicated, it would be more useful on an OBD1 car where you can't change the idle frequency.
      I am bench testing a push/pull TIP120/125 pair once I find another tb that isn't broken.
      -Paul
    8. Member Prof315's Avatar
      Jan 5th, 2009
      Melbourne, FL
      01-18-2013 12:32 PM #7
      I have several Paul.....
      The Professor
      Melbourne, FL
    9. Member chrgdVR's Avatar
      Aug 2nd, 2004
      Hartford, CT
      01-19-2013 09:36 PM #8
      Haha all this electronic talk is Greek to me.. No idea what an hbridge is lol
    10. Member chrgdVR's Avatar
      Aug 2nd, 2004
      Hartford, CT
      01-19-2013 09:44 PM #9
      Quote Originally Posted by Prof315 View Post
      Wait so you've gotten the idle control to work with the vw TB and ms3 or are u still working on it?
    11. Member Prof315's Avatar
      Jan 5th, 2009
      Melbourne, FL
      01-20-2013 07:53 AM #10
      Quote Originally Posted by chrgdVR View Post
      It works, just not perfectly.
      The Professor
      Melbourne, FL
    12. Member chrgdVR's Avatar
      Aug 2nd, 2004
      Hartford, CT
      01-20-2013 08:02 AM #11
      How did you get it to work? Hardware changes? Do u have to short the tps to ground somehow?
      I'm interested in knowing how yours is working?
    13. Member Prof315's Avatar
      Jan 5th, 2009
      Melbourne, FL
      01-20-2013 09:27 AM #12
      Actually it wasn't too hard. I wired up the idle motor part of the throttle (pins 1 and 2) backwards so pin 1 is PWM control and pin 2 is switched 12V. Then I set the MS3 PWM idle control to run inverted. I'm running the valve at 200hz and the DC range is roughly from 40% to 100%.
      The Professor
      Melbourne, FL
    14. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      01-20-2013 10:40 PM #13
      I have customers running those tb as well, 200hz seems to work ok.
      -Paul
    15. Member chrgdVR's Avatar
      Aug 2nd, 2004
      Hartford, CT
      01-21-2013 08:27 PM #14
      when do you have the idle motor set to come on around 3% tps or so? how does it affect the tps? since the motor is moving the blade and all the tps must obviously move too right...and it seems to be working alright?
      im thinking i might wire mine up and give it a try sometime, im curious to how well it works. i dont really need it since im using a gm stepper valve to control my idle, but if i like the way it works maybe ill ditch my current iac setup.. thats one less thing in the engine bay.
    16. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      01-22-2013 05:49 AM #15
      For all the iac's I have run, i have left them active all the time. No downside that I have seen from this.
      TPS changes a bit when active but at least with ms every critical setting is %tps change so the little it moves is insignificant.
      -Paul
    17. Member chrgdVR's Avatar
      Aug 2nd, 2004
      Hartford, CT
      01-22-2013 08:19 AM #16
      cool are you guys using any ignition advance to help control idle or can the tb motor control it well enough on its own?
      i think i'll try this out this week and see how it works. i might need some help with the settings, so you guys are prolly going to hear from me about this.. cool to see that people are using this kind of idle control
    18. Member Prof315's Avatar
      Jan 5th, 2009
      Melbourne, FL
      01-22-2013 12:05 PM #17
      Yeah I'm using MS3's Idle Advance feature. I run a seperate 4x4 table for idle only.
      The Professor
      Melbourne, FL
    19. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      01-22-2013 04:00 PM #18
      I would just lock advance at a tps threshold and let the valve do the rest. Depends a lot on the setup, how much cam it has, etc. I was running a 24v with stock cams at the time and it idled really nice compared to other things I have tuned.
      -Paul
    20. Member Prof315's Avatar
      Jan 5th, 2009
      Melbourne, FL
      01-22-2013 04:15 PM #19
      Essentially that's what I do with the idle advance table.
      The Professor
      Melbourne, FL
    21. Junior Member
      Apr 18th, 2011
      1995 Audi 80Q AEB, 1996 Audi S6
      02-10-2017 01:55 AM #20
      I have followed these instructions, but my idle speed is even lower now. I am not sure what I am missing.
      TB pin 1 to VEMS EC36-6 inv. and TB pin 2 to switched 12v. Valve at 200hz and DC range 40 to 100. It now idles with AC on at 620rpm, AC off 830 which better than before (1050).
      My IAC DC shows 83%.
    22. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      02-10-2017 01:15 PM #21
      Do the whole sweep of idle duties and watch the TB behavior. It sounds like you need the output non-inverted.
      -Paul
    23. Junior Member
      Apr 18th, 2011
      02-22-2017 04:45 AM #22
      It's getting better.
      Seems like the IAC motor and gears needed to get unstuck. It helped to spray the butterfly and venturi with WD40 and cleaning it. Maybe some WD40 went into the IAC part and lubricated a little.
    24. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      02-22-2017 10:41 AM #23
      Most of the TB are like this put the push-pull driver in the factory ECM can actually free it up during the adaptation if it isn't too bad.
      -Paul
