VWVortex.com - My quest for a 1,000,000km- Volvo 240 content...
    The Car Lounge
    Page 2 of 11 FirstFirst 123456 ... LastLast
    Results 26 to 50 of 258
    Thread: My quest for a 1,000,000km- Volvo 240 content...
    1. Banned
      Mar 8th, 2011
      Bellevue Hospital Center
      10-27-2012 11:13 AM #26
      Love me dat brick
    2. Remove Advertisements
      Advertisements
    3. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      1990 Volvo 240 sedan, 1972 VW camper van, 1993 Volvo 240 wagon, 1989 Ford Festiva, 2014 Ford Fiesta
      10-29-2012 07:15 PM #27
      Ran into our first problem on the weekend. Since I did the plugs/wires/cap and rotor, the car had a slight miss accelerating after coming to a stop. The issue cleared up after the car was being regularly driven, but this past Saturday on our way to a stag n die, the car started missing badly under load all the time. Spent a large part of Sunday afternoon eliminating ignition parts as the cause. After not having any luck, I paid a visit to a local Volvo specialist at 6 on a Sunday, he was closed, but was nice enough to offer a few suggestions, one of them being that the in tank fuel pump had died. I came back home and pulled the plugs to find them white. Pulled up the rear floor and removed the lines from the sending unit, sure enough, no flow. Smacked the sending unit and fuel started pumping. Took it for a drive, problem solved. Also found the fuel pressure regulator leaking, so all the parts are on order and should be in tomorrow or Wednesday. Pictures to come!
      Also contacted Volvo and got the radio code, nice having a radio again!
    4. Member Eg2Driver's Avatar
      Jul 9th, 2007
      Canada
      '19 Kia Forte, '01 996TT
      10-29-2012 08:26 PM #28
      That car is liking the attention you have put into it. Good work!
    5. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      11-01-2012 01:15 PM #29
      All the fuel system parts are arriving tonight. Work is very slow today, so I was allowed to bring the car in the shop and get some work done. The alternator was loose so I tightened it up and did a rear brake service/machine the rotors.
      Machined the front rotors, replaced the grease seals, cleaned and re-packed the front wheel bearings and balanced the front tires a few days later.
    6. Senior Member
      Nov 7th, 2001
      The Village
      KAR 120C
      11-01-2012 02:35 PM #30
      Did you check the rear trailing arm/locating arm bushes while you had it in the air?
      Judging by the rear shocks (I know, it's a salt belt car) I'd bet the rear susp. bushes are shot. They are usually gone by 100k miles.
    7. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      11-01-2012 02:50 PM #31
      No doubt they are toast. The suspension will be getting a comple re-build next year as I just don't have the time or money at the moment.
    8. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      11-06-2012 10:36 PM #32
      Did the in tank fuel pump, sending unit, fuel pressure regulator and swapped out the NGK plugs for a set of Bosch ones at the advice of a Volvo guy tonight. Car is running much better, but the float on the sending unit must be getting snagged on something as the fuel gauge will only read 2/3 tank. Will fix it at a later date, car is back on commuter duty tomorrow. Curious to see what kind of mileage it get now.
      The Cat always loves to help me
      Pressure regulator and associated lines replaced
      Old one in the left, new one on the right awaiting assembly.
    9. Member Fettes Brot's Avatar
      May 25th, 2001
      Calgary, AB
      2008 Rabbit
      11-06-2012 11:14 PM #33
      Quote Originally Posted by Zman86 View Post
      For the love of god, never, ever, ever, drop that float ball in the tank.
    10. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      11-07-2012 08:11 AM #34
      Did that, twice. Not really enough room to get the sending unit in, had to use a set of tongs to retrieve it.
    11. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      11-13-2012 11:54 PM #35
      Had some more mechanical problems. My girlfriend told me that on her way to work Friday the belts were squealing really bad. Inspection found that one of the alternator belts was missing and the other was loose. I already had belts waiting to go on, so I put off changing them till Saturday. Tightened up the belts and headed off to my parents house. On the way there, the dash lights kept getting dimmer and dimmer. I shut off all the electrical loads I could and limped it to my old work where they let me charge the battery. The remaining alternator belt was on the verge of falling off, and the alternator mount bushings had pretty much disintegrated. I tightened the belt up best as possible and limped it home
      Picked up some replacement bushings on Saturday, got those installed and replaced the rest of the belts. Who wants to place bets on what fails next...
      My forever present "helper"
    12. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      11-22-2012 09:40 AM #36
      Turned over 688,000km yesterday
    13. 11-30-2012 09:57 PM #37
      I radio code was written on a yellow sticky note in the driver's door pocket. But you wouldn't have known what it meant.
      1255?
    14. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      11-30-2012 10:54 PM #38
      I called Volvo and they gave me the radio code with the vin, 1255. I didn't find a a sticky note when I cleaned it out.
      First snow of the year! So much fun having rwd in the snow, I missed it alot
    15. Member MRVW00's Avatar
      Oct 30th, 2000
      Everywhere you want to be.
      B5 2.8Q, Buell XB9S
      12-01-2012 05:19 PM #39
      Cool thread!
      RIP Cosmic TDI
    16. 12-01-2012 05:42 PM #40
      great looking wagon.
      i hold a special place for older vehicules in my heart.
      i have had a couple of toyota vans; the originals( 84 to 89); a 85 mazda lx liftback with 50000 miles on it; a few early 90's passats and i now drive a not so popular or little known 93 nissan axxess.
      one day i want to get in a volvo of this vintage.
      what i love the most about these older vehicules is the fact they are trully " serviceable".
      grease nipples everywhere; take things apart; clean them; lube or grease them; and reassemble. ENJOY.
    17. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      12-03-2012 04:26 PM #41
      Ya, I only drive older stuff because of that reason, I really hate how cars and everything else have become "throw-away" items. Newest car I've owned in the last 8 years since ive been driving in my own was a '98, before that, a '91. My girlfriend, who is currently commuting 100km/day in the Volvo, does not share my enthusiasm for older cars as much as I do!
      Anyways, had a bunch of problems with the sending unit after it was replaced, ended up getting it warrantied and replacing it again. The float arm in the first one was 1/4" longer than the old one, jammed in the tank, then it fell apart removing it and refused to work properly. It's all sorted out now, and I finally got to run through an entire tank of fuel, averaging 21.4mpg or 11.2L/100km roughly. I though these numbers were pretty bad, but according to some fuel economy websites, they were only rated for 23mpg new, so I guess I can't complain.
    18. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      12-09-2012 11:33 PM #42
      Took the old girl out for a 900km round trip north of kingston to pick up a manual transmission swap for my Mercedes. Ran great, the trip reset button broke however...
      R
    19. Member -teknien-'s Avatar
      Sep 7th, 2004
      Long Island NY
      83 GTI, 03 GOLF
      01-02-2013 09:39 AM #43
      Great thread. I just picked up a 90 240dl sedan for cheap. 135k on the clock, still a baby in terms of Volvo life.
      I purchased a tune up kit from http://www.fcpeuro.com/. Awesome prices and they package together nice service kits.
      Good luck with wagon!
      Quote Originally Posted by g60vw View Post
      If I thought like that I would have gotten out of mk1's back when they were still A1's
      Quote Originally Posted by goosler View Post
      screw all of you & your stupid cars.........see you at madness!
      I'm a 1%er
    20. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      02-23-2013 01:39 PM #44
      Turned over 697k yesterday, 700,000 is in the near future...
    21. Member Lupo TDI's Avatar
      Mar 11th, 2000
      Not Cologne, Deutschland
      Keksdose; Elch, Hugo, Rennsemmel, Alfa mit Identitätskrise und BusBus.
      02-23-2013 03:17 PM #45
      Fiat 126 bis build thread here. Error 404: 0-60 not found.
      Fiat 128, the stroppy cow.
    22. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      03-16-2013 12:31 PM #46
      First breakdown, at 699030km. Somehow the new alternator belts I put on 3-4 months ago stretched and stopped turning the alternator. I picked my girlfriend up and took her to work, then went back to fix it later. A quick belt re-tension and it's back on the road. Ordered new belts and will replace them tomorrow while it's in for an oilchange.
    23. 03-16-2013 12:37 PM #47
      BTW, I forgot to tell you that her name is Bumfy.
      (The license plate I had was BMFY XXX. It seemed fitting.)
    24. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      03-16-2013 02:45 PM #48
      We have named her Thelma, or she goes by "The Lag Wagon". Bumfy also suits her looks lol
    25. Member BeaArthur's Avatar
      Mar 14th, 2003
      ATS, Civic, Miata, Versys
      03-16-2013 04:06 PM #49
      We have named her Thelma, or she goes by "The Lag Wagon". Bumpy also suits her looks lol
      All aboard the lagwagon!
    26. Member fastinradford's Avatar
      Aug 2nd, 2010
      West side of Oregon
      81 caddy VNT MTDI 02a.
      03-16-2013 06:12 PM #50
      good god is there a serpentine belt conversion or something.
      Gotta be gettin old.
      BTW, I would steer clear of "URO" parts. Super cheap-CHINA.
      Keep it going!
      smiles per gallon in a tdi rabbit are unreal
