VWVortex.com - The Frankenturbo setup thread
    Page 2 of 8 FirstFirst 123456 ... LastLast
    Results 26 to 50 of 182
    Thread: The Frankenturbo setup thread
    1. Member asylum's Avatar
      Jan 11th, 2000
      Toronto, Canada
      Golf R, 01 Golf 1.8t, 09 hayabusa
      12-17-2012 09:01 PM #26
      Quote Originally Posted by RodgertheRabit II View Post
      ^^ What high flow manifold are you using?
      im using the xs−power
    2. Remove Advertisements
      Advertisements
    3. Member asylum's Avatar
      Jan 11th, 2000
      Toronto, Canada
      12-17-2012 09:22 PM #27
      Quote Originally Posted by GTIRACER2.0t View Post
      WOW how are you making that kind of power with out W/M installed?
      maybe its the high flow exhaust manifold and/or intake manifold that helped. timing isnt set very aggressive at all until the water/meth goes in
    4. 12-17-2012 09:24 PM #28
      Post pics asylum!
    5. Remove Advertisements
      Advertisements
    6. Member
      Apr 4th, 2005
      Georgia
      12-17-2012 09:46 PM #29
      I will be running the martindale's and xs-manifold with my F23 setup. My car is going to Eurotech Performance Group in Marietta GA in 2 weeks to get everything installed and tuned via maestro to start drag racing in the spring for Beat the Heat!!
      No pics, but this is what I will be running:
      F23 Turbo
      Divertinator DV
      Injector Dynamics 725cc injectors
      Martindale Cams
      XS-Power exhaust manifold
      2.0T coils with INA Adapters
      INA Engineering in tank fuel pump
      Eurojet SMIC with dual smic setup from eurospec
      S4 Throttle Body
      S4 Maf
      AEB Head
      Custom catch can with -10 AN pressure line
      3" exhaust (no cat)
      Phatty TIP
      DM Forged Rods
      Looking into an intake manifold right now. Thinking about waiting on the 034 Intake Mani
      Matte Black Drag GLI / Frankenturbo / INA Internals / Bell Intercooler / AWE Tuning / New German Performance / PAG Parts
      http://www.inaengineering.com/
      http://www.bthgwinnett.org
      www.frankenturbo.com
    7. Member woodywoods86's Avatar
      Jul 28th, 2008
      B-More
      MK4 VW JETTA GLI K04-02x, B5 A4 1.8TQ
      12-18-2012 12:36 PM #30
      Quote Originally Posted by mk4boost View Post
      lol been tempting fate for over a year now, but yes I'll be up around 30psi and running e85 eventually... i have a mk1 rabbit I'm putting my focus into right now, it will also be running an f23 on e85... 400whp 400ft/lbs in a 1700lb car will be quiet the fun weekend ride
      ridiculousness
      Constant, State of Change!
      "Too close for Guns Switch to Missiles"... but, SIR!
      Robkwoods @IG
    8. 02-05-2013 02:03 AM #31
      more need more lol
      I'm Phat cause I'm force fed.
    9. 02-05-2013 03:15 AM #32
      My car is in the workshop at the moment being built.
      Hope to get it on the road in about two to three weeks.
      It is a VW Polo GTI 2006.
      Installing:
      Bought a crate AGU motor with AEB head
      IE 2.0l stroker kit
      F23
      3"maf with phatty TIP
      DNA custom software
      Bosch EV14 550cc Injectors
      Bosch 044 Fuel Pump
      Relentless V3 ceramic coated manifold.
      Phenolic Intake Manifold Spacer
      Standard intake manifold for now
      THS dual pass intercooler
      Forge dv008 diverter
      Wavetrac LSD
      42 draft designs stealth catch can
      Custom 3in turbo back exhaust
      Ebay 3in Carbon CAI
      Maybe Doug can help out with some Martindales at a later stage.
      Polo's only weigh 1190 kg, about 2600lbs so it should be fun
      A couple of older pics. More once build is done.
    10. Member
      Oct 17th, 2008
      Northern Ireland
      2002 RSI Cup Kitted 18T BUG
      02-05-2013 04:03 AM #33
      My 2002 18T AWU Bug
      F4t-h, 3" MAF, forge 007 DV
      JBS exhaust mani
      19mm forged THS rods
      Peloquin LSD
      Tyrolsport converted AWIC
      3" milltek exhaust with sport cat
      Just off RR on Sat 2nd Feb
      253 BHP and 303 torque
      386cc injectors with custom remap
      ps nearly forgot to mention the 044 bosch fuel pump
      and 034 sport surge tank
    11. 02-05-2013 05:09 AM #34
      Quote Originally Posted by ausredliner View Post
      Installing:
      IE 2.0l stroker kit
      F23
      DNA custom software
      Bosch 044 Fuel Pump
      Wavetrac LSD
      Ebay 3in Carbon CAI
      and that is the car i expect to beat my 1/4 time for fastest polo in aus making me salivate redliner.
    12. 02-05-2013 05:54 AM #35
      ^ POLO
      Quote Originally Posted by Marcus_Aurelius View Post
      If you're going to come like this, why don't you come correct? I think you mean Samuel Langhorne Clemens. What's next, you want the work cited to be mentioned as well, on a car forum sig in quotation? How about you fail me professor
    13. Member joeyyphillips's Avatar
      Apr 17th, 2012
      Toms River, NJ
      86 MK2 Gti
      06-04-2013 11:51 PM #36
      wish this thread was still kicking. would love to see some more setups and results, i ordered my f21 transversal kit. cant wait for it to come.
      instagram:@joeyyyphillips
    14. Junior Member
      Jun 15th, 2005
      Central Va.
      2004.5 GLI
      06-22-2013 11:45 PM #37
      Just curious, if there is anyone out there running a high flow fuel pump with the base uni ft (F4/F21) tune, and if there are any benefits over keeping the oem fuel pump. Currently I am undecided on whether i'm going to upgrade the stock block, so just trying to squeeze all I can out of it...within the limits of the stock block of course... basically looking for power gains in the higher rpms...
      F21 Frankenturbo, Genesis 415cc Injectors, Sprint Throttle Booster, AFe Air Intake, Tyrol Sport SMIC, Stratmosphere Hyperboost Diverter Valve, Unitronic Stage 2+ ECU, BoostValve MBC, 25 mm H&R Rear Sway Bar, BFI Stage 1 Mounts, 42DD 3” Turbo Back Exhaust, Callahan Drilled and Slotted Rotors, South Bend Rally Clutch/Flywheel Kit w/ NLS shims, USP Motorsport Stainless Steel Clutch Line, Fluidamper Engine Damper Crank Pulley.....in progress
    15. 06-23-2013 05:47 AM #38
      Quote Originally Posted by vectortyen View Post
      No benefit unless your current fuel pump is inadequate. Log some full throttle pulls and monitor injector duty cycle and Lambda.
    16. Junior Member
      Jun 15th, 2005
      Central Va.
      2004.5 GLI
      06-23-2013 08:05 AM #39
      Thanks spartiati, much appreciated
    17. 06-23-2013 11:22 AM #40
      Plus if you are running the stock pump and have a high milage car it wouldnt be a bad idea to get a genesis intake pump from USRT. I was having fueling problems with my stock pump at 90k...USRT pump took care of that...keep an eye on those logs...
    18. Former Advertiser
      Jul 1st, 2009
      06-23-2013 12:01 PM #41
      A mid-range pump upgrade, the USRT in-tank unit pairs nicely to any F21T build. It is capable of supporting 300bhp, even at an elevated 4bar fuel rail pressure. Plus it is a simple replacement for the pump hardware in your Mk4 car.
    19. Junior Member
      Jun 15th, 2005
      Central Va.
      2004.5 GLI
      06-23-2013 05:51 PM #42
      Thanks for the feedback guys, it looks like i will be giving this additional consideration as i hadnt even thought about the wear my stock unit has on it (+108k and counting)
    20. Member woodywoods86's Avatar
      Jul 28th, 2008
      B-More
      07-03-2013 03:41 PM #43
      Doug, what are you seeing as far as setups, for the guys with Longitundinals? I'm looking for a little something more in my B5 A4.
      Robkwoods @IG
    21. 07-03-2013 04:02 PM #44
      F23
      IE rods
      Gonzo tune stgIII/E85
      Lots of other stuff in my sig. No dyno numbers yet. Still getting everything dialed. Right now Im pushing 27-28psi.
      Forge WG actuator (pretty necessary)
    22. Member War Machine's Avatar
      Jun 30th, 2011
      Bowmanville, ON
      04' 2.7t K04 B6A4
      07-03-2013 10:15 PM #45
      in my old mk3
      2001 AWD 20v. Converted to ME7.1 wideband.
      Stock internals
      eurospot dv
      No ac
      No ps
      Cold air intake
      New south power gasket
      Fmic kit
      Deleted evap/combi/n249
      3" turbo back, no cat
      550cc injectors (440 is a typo)
      Walbro 255 inline pump
      F21 kit
      Custom tune locally
      262whp 290lbs.
      lol, Nope.
    23. Member
      Apr 4th, 2005
      Georgia
      07-03-2013 11:04 PM #46
      Ported F23
      Dm Forged/INA Engineering 2.0L Stroker
      AEB large port heat with martindale cams from Doug
      Relentless V3 exhaust mani
      SEM large port intake with audi s4 tb
      60-62mm intercooler piping up until the tb where it change to 3" for about 1 foot
      Garrett 500hp intercooler
      USP Race Exhaust
      ID725's
      E85
      No numbers yet. Car should be running by next week or the week after. Dyno and logging soon after.
    24. Member War Machine's Avatar
      Jun 30th, 2011
      Bowmanville, ON
      04' 2.7t K04 B6A4
      07-08-2013 10:02 PM #47
      It seems like most people run MBC and bypass the N75 mechanically. Why? My setup used the N75, no MBC, No surging, no spiking, worked like OEM.
      lol, Nope.
    25. 07-08-2013 10:11 PM #48
      Quote Originally Posted by War Machine View Post
      Its all in the tune and also the wastegate actuators are having some issue/not being set properly. Its sorta hit or mis. Gonzo was able to tun my car without the MBC where I needed it with the Unitronic tune.
    26. Member War Machine's Avatar
      Jun 30th, 2011
      Bowmanville, ON
      04' 2.7t K04 B6A4
      07-08-2013 10:52 PM #49
      Quote Originally Posted by Twopnt016v View Post
      First thing my tuner did was check WG pressure via no n75 lol What issues are going on with them?
      lol, Nope.
    27. Member
      May 13th, 2010
      Oklahoma 405
      2002 VW GTI
      07-10-2013 05:29 PM #50
      2002 vw gti
      awp block w/aeb pistons and 20mm forged rods
      aeb head
      stock ported intake manifold w/newsouth gasket
      f23 w/FT tubular manifold
      FT phatty inlet pipe
      3" catless turbo-back
      eurojet FMIC
      devilsown w/m single nozzle
      siemens 630cc injectors
      eurodyne maestro
      have pics of the setup i'll add later
