VWVortex.com - Eos 3.2 battery replacement
    Results 1 to 15 of 15
    Thread: Eos 3.2 battery replacement
    1. Member chocoholic_too's Avatar
      Jan 1st, 2007
      Ohio
      2007 VW Eos 3.2l , 2004 Audi TTR 3.2l
      12-11-2012 03:59 PM #1
      Has anybody here replaced the batteries on their 3.2l themselves? If so, is it difficult? I was just quoted 2 different prices by 2 dealerships.
      First off, it seems that the replacement cost for the batteries was less than anticipated. I always assumed that each battery was priced individually at $408 MSRP but talking to the parts department, they said that price included 2 in a set. Well, one dealership quoted $480 for it....But they also quoted installed price of $760!!! So they charge $300 to install a battery????
      The other place quoted $580 and they said it was because they have to remove part of trunk. Well, I've removed the carpet cover before and it didn't take long but there's supposed to be more to it than that? I also don't have a bridge battery so I don't loose any settings when removing the old ones.
    2. Remove Advertisements
      Advertisements
      Mar 10th, 2009
      2006 Passat 2.0t 6mt
      12-28-2012 10:13 AM #2
      Quote Originally Posted by chocoholic_too View Post
      Call up your local interstate dealer or optima dealer and see what type deal they can work with you. They are just 2 6volt 3cell yellow top batteries ran in series.
    4. Member chocoholic_too's Avatar
      Jan 1st, 2007
      Ohio
      12-30-2012 04:42 PM #3
      Quote Originally Posted by Boosted2003! View Post
      VW has a contract with Optima that prohibits any distributor to sell these to anyone but VW dealers.
    5. Remove Advertisements
      Advertisements
    6. 05-04-2013 12:30 PM #4
      Doesn't look too hard to replace. The cheapest I could find the batteries was for $326 at 1stVWParts.com http://bit.ly/126TZRB. They have a parts explosion chart there too. [see pics below]
      I highly recommend getting the Optimate 6 Charger. $85 on Ebay. It will bring your dead battery back to life and claims that with routine maintenance will add 400% longer life. http://www.tecmate.com/u_optimate_6.php
      I noticed a big improvement with Optimate 6 and I hope it does what it says. BTW you can buy a similar device directly from Optima for $107.
      I finally dove in to the trunk to reveal these babies. [see pix below] From what I researched, and I've spent away too much time doing so, Optima only sells these batteries to VW. There is no direct Optima part number. They are not even on the Optima website. DO NOT BUY the "Red Tops" they are not deep cycle and will not last.
      Note:
      Combined Cold Cranking Amps 1500.
      Total Amp Hours 110
      Combined Cranking Amps is 1740.
      Combined Reserved Capacity is 240.
      That's a lotta power!
    7. 05-10-2013 04:34 PM #5
      i contacted Optima, the battery is only available in europe, and is not available anywhere in the US but the VW dealer.. i asked about having some shipped in, and was told that since they carry sulfuric acid, they can't ship them. yuck.. i am thinking about putting it on a charger? would anyone here know how or where to connect a trickle charger to the batteries, figured i would put it on some sort of connector in the trunk, the just put a break away in the wire so i can disconnect the charger when driving.... was also told by Optima that if you use the wrong charger, these puppies will explode.
    8. 11-22-2015 01:00 PM #6
      I have done a TON of homework/ related to this EOS optima battery issue. I can confidently give you the best advice since I spent several years researching this issue.
      Absolutely YES you should buy the optima RED top 6 volt batteries instead of the dealer yellow top batteries.
      There is virtually NO difference between the RED top optima battery and the dealer yellow top optima battery that the dealer sells. Both are made by optima.
      The only difference is that the yellow top version that the dealer sells has a minuscule higher voltage at full storage capacity ( 13.9 volts for yellow tops vs 13.7 volts for the red tops) because it has one more AGM layer wound inside the case, BUT this is the reason the YELLOW top optima battery that the dealer sells fails so often. Unlike the red top, the yellow tops that the dealer sells are prone to short out some internal "plates" from any minor impact to the case. Once a optima battery has an internal short, the battery is garbage.
      So, the dealer yellow tops batteries are actually more problematic and have a much higher failure rate.
      I have even found that the RED top optima version is BETTER quality and lasts longer because it has a few less layers wound in the case which actually give the "plates" more room and prevents them from shorting from any impact to the battery case which is the problem with the dealer yellow top batteries. And there is NO need to have " deep cycling" yellow top optima's batteries because the 4 cylinder turbo EOS version use a standard NON deep cycling battery and actually do NOT have any of these battery issues that the 6 cylinder versions have. The reason VW chose the deep cycling yellow tops as original equipment on the 6 cylinders is because VW assumed the yellows have more reserve power to power the energy drain of an owner operating the hardtop with the engine OFF.
      So with out getting technical, the answer is YES the red top batteries are identical and swap out for your yellow top batteries perfectly.
      I threw out my dealer yellow top optima batteries and I myself replaced them with the optima red tops and have been PROBLEM FREE SINCE I DID !!
      I do not know if you are in the USA, but you need to buy TWO 6 volt red top optima batteries. They are an EXACT fit replacement and cost around $150 each shipped.
      If you are in the USA, Summit Racing sells the shipped for about $140 each. You need two. Any mechanic can swap them out in less than one hour. I did it myself . So if you buy two red tops and pay a mechanic one hour labor you should be under $400 total.
      And the red top optimas are actually better than the yellow tops. ( this was confirmed by an past employee of optima), I have his post as proof.
      Also, make sure that your batteries are actually "bad". The dealer may tell you your batteries are bad but they may actually be OK. My dealer erroneously tested them installed in the car which 100% will give you a reading on a tester that they have very low CCA (cold cranking amps) and are "bad" because the cable connecting them has resistance that throws off the tester.
      To test the 6 volt batteries they must be tested individually as 6 volts and not in series as 12 volts because if they are tested as 12 volts in series the testing device will 100% erroneously tell you they are bad even if they are good BECAUSE the cable connecting them has resistance that tester assumes is internal battery resistance. I personally spoke to the engineer at optima regarding this. So many VW dealers not knowing this test the batteries together as 12 volts which causes the CCA reading to be less than 180 yet if tested individually would be normal at around 850. I have personally verified this myself. So be cautious if the dealer tells you your batteries tested bad.
      They MUST BE TESTED individually as 6 volts and not connected together and tested as a 12 volt.
      Last piece of advice...IMPORTANT..
      If you are swapping out batteries you need to keep all the computer settings. In the 2.3 NON turbo cars this is easily done when swapping out batteries since the engine compartment has the jumper cable connections in the engine compartment in front and the batteries are in the rear trunk.
      You must first attach jumper or booster cables to the front engine compartment jumper connections from another car ( or good 12 volt battery) before you remove the batteries in the trunk so that your EOS does not loose its computer memory settings. Keep the jumper cables connected in the front engine compartment the entire time until the rear battery swap is completed. This is what I did to keep all my computer settings.
      Mark.
      PS I am posting this on the forums to help others
    9. Junior Member
      Mar 8th, 2014
      Washington, DC
      '07 EOS 3.2 VR6; Eismeer Blue; Moonrock Leather; 3SDM .05Wheels/Conti DWS06; UM Stage 1 DSG & ECU
      11-25-2015 01:11 AM #7
      [QUOTE=mikemaan;81736167]Doesn't look too hard to replace. The cheapest I could find the batteries was for $326 at 1stVWParts.com http://bit.ly/126TZRB. They have a parts explosion chart there too. [see pics below]
      I highly recommend getting the Optimate 6 Charger. $85 on Ebay. It will bring your dead battery back to life and claims that with routine maintenance will add 400% longer life. [URL]http://www.tecmate.com
      Note:
      Combined Cold Cranking Amps 1500. INCORRECT
      Total Amp Hours 110
      Combined Cranking Amps is 1740. INCORRECT
      YES, I realize it is 2.5 years since this post was made; but the info is bad and needs to be corrected for the benefit of mankind
      When connecting batteries in series the voltage increases but the current output remains the same.
      Thus 2, 6V yellow top batteries rated at 765 CCA result in a 12volt set up capable of the 765CCA not twice that at 1530.
      No patience for this LOL nonsense. If you do not find it humorous, by all means take it seriously
    10. 11-26-2015 09:12 PM #8
      [QUOTE=CUCURELLO;90363753]
      Quote Originally Posted by mikemaan View Post
      I highly recommend getting the Optimate 6 Charger. $85 on Ebay. It will bring your dead battery back to life and claims that with routine maintenance will add 400% longer life DO NOT BUY the "Red Tops" they are not deep cycle and will not last
      The red top 6 volts are an exact replacement and work the same and fit exactly the same as the yellows .You do NOT NEED yellow tops from the dealer at 3 times the price. The turbo cars with 4 cylinder engines do not use deep cycle batteries. The deep cycle is actually only .3 higher voltage fully charged with no load.
      Do NOT waste you $$ on an optima charger like I did. The reason is because once an optima AGM battery goes bad or drops below 10 volts and sulfates they are impossible to bring back to life.
    11. Member mark_d_drake's Avatar
      Aug 16th, 2006
      Bay Area, CA
      2017 Q7 Prestige, 2018 A5 Convertible Prestige, 2014 Corolla S, 1995 Cabrio
      07-13-2016 01:14 PM #9
      How have the Red Tops worked out.. My Yellow tops just died again and I'm waiting to see of they get replaced under warranty or not
    12. 11-16-2016 10:55 PM #10
      Hello everyone,
      I am glad I found this post and wanted to update everyone as I recently replaced our 6 volt yellow top Optima with the red top batteries. I took the car to the mechanic to have them replace the batteries as I couldn't get the clips on the battery connectors off but told them these were installed in series and to replace them accordingly. They had reprogrammed the eos before but they didn't need to reprogram it. We have been driving it around for over a week without issues and it starts up perfectly.
      Year: 2008 Make: VW Model: EOS 3.2L VR6 - AUTOMATIC
      Old Yellow Top Batteries:
      Optima 1Q0 915 105
      6V 50ah 380A DIN
      New batteries (purchased on Amazon):
      New
      Optima Batteries 8010-044 6V RedTop Starting Battery
      •6-Volt, 800 Cold Cranking Amps
      •Reserve capacity of 100 minutes for constant performance
      •Optimal starting power even in bad weather
      •15 times more resistant to vibration for durability
      •Weight:18.5lb, Length:10.06, Width:3.63, Height:8.13 inch
      Before and After Images
    13. 01-04-2019 11:46 AM #11
      Hello. I just read your post from a little over 2 years ago and was wondering (if you still have the V6 EOS) how those red top batteries are holding up. A 2007 V6 EOS that I purchased earlier this year for my aunt is beginning to crank a bit slowly. It has been sold here in San Diego and the car hasn’t seen much use for the past month. It does still start up fine after about two disturbingly slow rotations every try so far, but even after driving it for awhile it doesn’t seem to be getting revived at all.
      So after looking it up I have just now become aware of the crazy-expensive battery situation in this car, so here I am. Any follow-up advice would be greatly appreciated. I live far away so I need this car to start for her. If there is any doubt about the red tops then I guess I’ll have to take it to VW and bend over while they have their way with me!
      Thanks.
    14. 01-03-2020 05:45 PM #12
      Just following up to help out anybody else grappling with this expensive battery situation. I bought two of the red top Optima 8010-044 batteries on Amazon for $189 each and replaced the absurd $$$ yellow ones with no problems whatsoever. All I did was buy a battery charger and hooked it up to the jump points under the hood before disconnecting the old batteries, it was enough to retain all settings. To sum up, don't worry, it's a super simple operation that in no way requires an expensive trip to VW service. I will update if any problems arise as it's only been about a week as of this writing.
    15. 03-19-2020 02:56 PM #13
      Been running red tops for 2 years. been fine so far.
    16. n00b
      Feb 22nd, 2020
      Western NC
      2012 EOS Executive
      03-24-2020 09:18 AM #14
      Thanks for everybody's posts. This will save us all some money! I am a new owner and new nothing about my 2012 has two 6-volt batteries. What was VW thinking with this approach? But I now know to get the Red Tops when replacement time comes around.
    17. 03-24-2020 10:08 AM #15
      Quote Originally Posted by wcumming View Post
      Looks to be a space issue. cant fit in engine compartment and cant put a full size battery in trunk because of roof.
