VWVortex.com - dry sump?
    Results 1 to 15 of 15
    Thread: dry sump?
      Mar 28th, 2007
      iowa
      '09 TT quattro
      01-17-2013 03:08 AM #1
      I saw bluewater was running a dry sump setup on their built E85 2.5T, anyone else running a dry sump or have info? Most of the setup could be pieced together, but the pan is obviously a bit of a stumbling block. The TTRS has a dry sump, but I'm pretty sure the bw setup was aftermarket.
    2. Remove Advertisements
      VWVortex.com
      Advertisements
    3. Former Advertiser
      Mar 1st, 2005
      5780 Main street center valley PA 18034
      a few.
      01-17-2013 09:27 AM #2
      why? are you tracking it? real track time, hardcore racing?
    4. Member
      Jan 8th, 2012
      the netherlands/europe
      2.5 T corrado syncro 1997/4 motion 2018
      01-23-2013 07:03 AM #3
      Quote Originally Posted by iowarabbit View Post
      The TTRS has not a dry sump!
      Mar 28th, 2007
      iowa
      '09 TT quattro
      01-25-2013 09:51 PM #4
      Quote Originally Posted by stef 4x4 View Post
      you seem pretty sure of that...
      "Dry-sump lubrication is an essential part of the TT RS’s engine - another innovative technology perfected on the racetrack. It allows the turbocharged engine to cope with extreme cornering forces without being starved of oil, which means it’ll perform perfectly under lateral loads of up to 1.2 g."
      -taken straight from the promo materials on the audi website.
      as far as why, i'm evaluating my options at this point. if I were to pick up a spare longblock, I wouldn't want to leave it on stock internals. if I were to build it out, I would probably shoot for big-ish numbers. if I were going that far, then yeah i'd definitely want to track it. snowball effect.
    6. Member
      Jan 8th, 2012
      01-26-2013 04:19 AM #5
      I am sure indeed.
      Looking on ETKA the TTRS has the same oilpump as the BGQ engine.
      I called a friend who is working on these cars, he knows it for sure: no dry-sump.
      You are right about the benefits of dry-sump, no doubt about that!
      Mar 28th, 2007
      iowa
      '09 TT quattro
      01-26-2013 02:48 PM #6
      I am sure indeed.
      this must be something they're changing moving forward, because their current literature on the 2.5 TFSI is pretty clear. I do see that in ETKA now though, points to you. put my smart ass in check.
      in addition to the direct benefit of oil pressure management, I like the sound of pulling vac in the crankcase, decreasing the amount of oil in the sump, and increasing the flow rate of a viscous fluid. probably negligible performance-wise, but less inertial resistance sounds like a happier engine to me.
      Jan 8th, 2012
      01-27-2013 05:04 AM #7
      I do not think the internal resistance will better with dry-sump because in the 2.5 engine the oil sump is sepated from the crankcase by this beautiful "schwabbelblech" the germans call it (I do'nt know the english word but you know what I mean I guess).
      If you like the sound there are much easyer ways: put a disc with dry-sump noise in your radio.
    9. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      01-27-2013 09:16 PM #8
      Windage tray. The crank is separated from the sump via a windage tray.
      underrside of the motor.
      Windage tray off
    10. Member
      Jan 8th, 2012
      01-28-2013 03:33 PM #9
      Quote Originally Posted by Pat @ Pitt Soundworks View Post
      Windage tray off
      O.K. thanks! I'll try to remember but you know how it works: if you do'nt use a strange word for a longer time there is a big change you will forget it.
    11. Member
      Mar 28th, 2007
      iowa
      '09 TT quattro
      01-31-2013 07:33 PM #10
      duh, forgot the i5 had a windage tray. i'll chalk that up to not getting my hands dirty in one yet, i was even looking at this exact picture the other day. loving the 1000hp thread btw, following with great interest.
      nice shameless plug fred!
    12. 02-17-2013 08:17 PM #11
      If you need flanges for the pan, I made some.
    13. Member
      Jan 8th, 2012
      02-18-2013 02:53 AM #12
      [QUOTE=URHank;80798430]If you need flanges for the pan, I made some.
      For wich purpose you use this flange?
    14. 02-18-2013 10:03 AM #13
      To make oil pans for longitude swapped quattros. There is no way in hell a stock oil pan would ever come close to clearing the subframes or swaybars in any longitude swapped car.
    15. Member
      Jan 8th, 2012
      02-18-2013 11:18 AM #14
      That makes sense.
      I did not think about it that way.
      Thanks for the answer.
    16. 02-18-2013 12:15 PM #15
      Not a problem! Glad to help.
