VWVortex.com - GIAC Stage2/Bolt On GTI, WOW REALLY 260+WHP???
    Results 1 to 25 of 25
    Thread: GIAC Stage2/Bolt On GTI, WOW REALLY 260+WHP???
    1. Member Blu--Pearl's Avatar
      Mar 31st, 2008
      Olrando Fl.
      2010 GTI
      04-21-2013 08:58 PM #1
      OK folks so this is my 1st time back to modding cars since the death of Old Blu! If anyone rememebers:
      [IMG][/IMG]
      So always wanted a GTI. So last fall, picked one up used from dealer " awesome deal" Gray 2010 GTI and started the modding HAHAHAHA. Im good friends and long time customer of FORGEMOTORSPORT and the team there helped with modding and losts of support.
      mods as follow:
      Giac stage2, race, pump, stock all that jazz....
      Forgemotorsport wintake
      Forgemotorsport DV
      Forgemotorsport twincooler
      3" Downpipe "not cat"
      3" magnaflow exhaust
      AWE discharge pipe
      BSH TB pipe with meth bong
      Devilsown duel meth set up 0.75 nozzle before map sensor and and DOT 3 before TB
      NGK bkr7eix plugs
      Oil catch can
      Blk forest motor mounts, yellow stuff
      also cleaned intake mani and valves a few months ago
      Ok so did some logs last week on pump file and though the timing was kinda low 15* So i called GIAC and had good talk with [email protected] and learned a few things, also was gonna get a more aggressive file with more timing and etc and they wanted to see logs due to the fact my boost was low. 15psi most of the time and 17psi once in a while. Went to forgemotorsport on friday and found out i had a boost leak, small but was there, forge hooked it up with new hoses for the intercooler, also change oem intercooler pipe o-rings and gaskets. Thanks to forgemotorsport and [email protected] for the support.
      Good friends with the peps over at CFT went there 1st thing Sat morning and hit the rollers, well Ill let pics do the talking.
      P.S.. only thing added on top of mods was a gallon or so of sunoco 260 gt 100 oct and added meth that was in the freezer over night "cold as f*%k!" not sure if this help or not, but whatever!
      [IMG][/IMG]
      3pull
      [IMG][/IMG]
      4th pull
      [IMG][/IMG]
      last pull
      [IMG][/IMG]
      log for the last pull
      [IMG][/IMG]
      Not sure if these numbers are a lil high or not but whatever car is crazy fun to drive on race file.
      Keep an eye out for my next project, doing something outta the box.
    2. Remove Advertisements
      VWVortex.com
      Advertisements
    3. Member ViRtUaLheretic's Avatar
      Aug 16th, 2008
      Kansas City
      2009 GTI
      04-22-2013 11:47 AM #2
      Racegas + w/m FTW
      :APR -stage 2 :BSH -Intake,Mounts,RSB,TB Pipe :Whiteline -A.L.K. :Porsche 17Z BBK
      :Devils Own -DVC-30+Direct Port Injection :BC Racing -BR Coilovers :Flik-FTD :OSIR
      :Eurojet -Ceramic Coated TBE :DEFI :Unibrace :Tyrolsport :Bildon :Hawk :034
      TSI FAQ: https://forums.vwvortex.com/showthread.php?4042736
    4. Member Blu--Pearl's Avatar
      Mar 31st, 2008
      Olrando Fl.
      2010 GTI
      04-22-2013 01:21 PM #3
    5. Former Advertiser
      Jul 1st, 2009
      04-22-2013 02:42 PM #4
      Those dyno numbers look accurate in my experience. We've dynoed a Unitronic Stg2 car and got ~255whp. Airflows were within a couple of grams of yours, but that was lacking your strong ignition advance. I'd say it's very fair to call that a 260+ whp car.
    6. Member Blu--Pearl's Avatar
      Mar 31st, 2008
      Olrando Fl.
      2010 GTI
      04-22-2013 04:06 PM #5
      nice good to know
    7. Member Blu--Pearl's Avatar
      Mar 31st, 2008
      Olrando Fl.
      2010 GTI
      04-23-2013 01:35 PM #6
      May 25th, 2012
      San Tan Valley, AZ
      CC
      04-24-2013 12:10 PM #7
      Yea those numbers seem good and on par....i dynoed mine as well and hit 276whp 290wtq on race file with w/m....i couldnt get an accurate torque reading cuz we didn't know how to hold the dsg in gear....but ill be going back next wknd for a more thorough pull and some graphs
    9. Member ViRtUaLheretic's Avatar
      Aug 16th, 2008
      Kansas City
      2009 GTI
      04-24-2013 05:55 PM #8
      Quote Originally Posted by AZ_CC View Post
      Upshift using the paddles except when you upshift keep the paddle pressed and that will hold the gear.
      Or get a DSG flash
    10. Member
      May 25th, 2012
      San Tan Valley, AZ
      CC
      04-24-2013 08:04 PM #9
      Quote Originally Posted by ViRtUaLheretic View Post
      Or get a DSG flash
      No paddles, just the + & - on the shift knob....so u have to go manual mode to 3rd gear and get to ~2k rpms and then press gas 90% down until u feel u hit the pedal "wall" then once u pass ~4500 rpm u press it the rest of the way....gonna try it and hopefully get some torque numbers over 300
    11. Member Blu--Pearl's Avatar
      Mar 31st, 2008
      Olrando Fl.
      2010 GTI
      04-25-2013 09:41 AM #10
      Whaaaaatttt!!! i thought 260whp or so was pretty much the max for stock turbo. I gatta see yur dyno sheet. Yea man dsg is a pain in a$$ on dyno the 1st 4 pulls or so bastard kept kicking down a gear. So had to rev to like 3800 them WOT it! But im happy with number for a mustang dyno and it really fun to drive!
    12. Member Blu--Pearl's Avatar
      Mar 31st, 2008
      Olrando Fl.
      2010 GTI
      04-25-2013 09:42 AM #11
      Or get a DSG flash
      damn didnt know this! hmmmmmmm im going back to dyno!
    13. Member
      May 25th, 2012
      San Tan Valley, AZ
      CC
      04-26-2013 08:47 AM #12
      Quote Originally Posted by Blu--Pearl View Post
      Idk but the car is extremely fun to drive and I've had some nice matchups....i will be going back to the dyno next Saturday and will make a new thread with results.
    14. Member recognized1's Avatar
      Aug 30th, 2002
      Orlando
      2011 VW GTI DSG
      04-26-2013 09:39 AM #13
      Very impressive numbers!
    15. Member Blu--Pearl's Avatar
      Mar 31st, 2008
      Olrando Fl.
      2010 GTI
      04-29-2013 04:33 PM #14
      damn that awesome, keep me posted, deff wanna check dyno sheet and see power curve on yur setup!
    16. Member Blu--Pearl's Avatar
      Mar 31st, 2008
      Olrando Fl.
      2010 GTI
      04-29-2013 04:34 PM #15
      Quote Originally Posted by recognized1 View Post
      thanks bro, im interested on seeing yur dyno number if u wanna hit the dyno for a good $$$ and get more pulls than normal let me know. now get yurs on the dyno also.
    17. Member
      May 25th, 2012
      San Tan Valley, AZ
      CC
      04-29-2013 07:48 PM #16
      Thx man....ill post up ASAP
    18. Member recognized1's Avatar
      Aug 30th, 2002
      Orlando
      2011 VW GTI DSG
      04-29-2013 08:26 PM #17
      I ran it on the dyno last year. I talk about it in my build thread on post 54(I think). I would be interested on seeing the difference since I added the Neuspeed pipes.
      I actually knew a few people that would be down for a group dyno day if something like that can be set up.
    19. Member Blu--Pearl's Avatar
      Mar 31st, 2008
      Olrando Fl.
      2010 GTI
      04-30-2013 02:00 PM #18
      oh for real ima go back and check yur build again. but yea man i can deff setup a dyno day @ CFT for sure. feel free to call my cell 4077394494 for info and if truly serious.
    20. Member greasyginzo's Avatar
      Apr 18th, 2006
      North Jersey
      93 LX 5.0, 00 GTI vr6 / 99 R6 / 20th / 08 R32 / 06 is350 / 08 M3 / 11 GTI Autobahn, + more
      04-30-2013 05:40 PM #19
      Then you don't have an accurate hp reading...can't get hp without tq
    21. Member
      May 25th, 2012
      San Tan Valley, AZ
      CC
      05-02-2013 07:18 PM #20
      Quote Originally Posted by greasyginzo View Post
      Well if u would've read through the whole thread and read my first post, it was due to not being able to hold the dsg in gear and couldn't get a reading below 4k rpm, where my real peak torque would've been instead of 5k where the HP was
    22. Member Patrick@Spintech's Avatar
      Jun 9th, 2009
      South Florida
      BT MK6 GLI, and other non VW stuff..
      05-09-2013 02:42 PM #21
      Yeah buddy! keep up the good work!
    23. Member Blu--Pearl's Avatar
      Mar 31st, 2008
      Olrando Fl.
      2010 GTI
      05-10-2013 01:47 PM #22
      Quote Originally Posted by pattrick02 View Post
      thanks homie, cant wait to get new turbo on and hit the track!
    24. Member Waterfan's Avatar
      Aug 9th, 2012
      SoCal
      84 Jetta 2.0L 8V Conversion (sold); 99 Passat 1.8t APR S1, Suspension, 17's (current)
      05-10-2013 07:39 PM #23
    25. Member Blu--Pearl's Avatar
      Mar 31st, 2008
      Olrando Fl.
      2010 GTI
      07-19-2013 10:17 AM #25
      Quote Originally Posted by ilie.vw.tech View Post
      Thanks Homie!
      Oh sent u a new log to look at!
