VWVortex.com - Best engine degreaser?
    Results 1 to 21 of 21
    Thread: Best engine degreaser?
    1. 12-19-2002 07:10 PM #1
      Alright, now that im taking a little break from working on the block of my 16v. I've been spending some time degreasing the aluminum head & intake parts of my motor. What are some good degreaser products / tools / methods you guys use to break the grease?
      -Luke
    3. 12-19-2002 07:20 PM #2
      Simple Green ... spray it on and let it sit for a few minutes or an hour if you want. then spray off with hot water ... the stuff works wonders!
      1998 Golf K2 (original owner), 1990 Porsche 964 Carrera 4
    4. 12-19-2002 07:40 PM #3
      Karcher degreaser, comes in a yellow 4 litre jug for $9 CDN. It is made for the power washers but just put in in an old Simple Green container and away you go. It is more caustic than simple green so don't leave it on aluminum for too long or it will discolor it.
      Good price and cuts grease really well
    5. Remove Advertisements
    6. 12-19-2002 07:59 PM #4
      many mechanics have a recirculating sink with diesel fuel (it smelled like diesel).
    7. Member SlowMotion's Avatar
      Jun 9th, 2002
      NNJ, NYC
      12-19-2002 08:22 PM #5
      yup or gasoline but they leave a grease film on the surface a big no-no if you want to paint it.
      have you look at the autopart store?
      they sell parts cleaner, it comes in a 1 gallon or 5 gallon metal container and it's cheap and it works.
    8. Member D.A.T.'s Avatar
      Mar 29th, 2001
      Vancouver, BC
      2006 Jetta TDI Wagon
      12-19-2002 08:28 PM #6
      Wurth makes a great de-greaser, just spendy!
      Need VW Classic Parts? Msg me with what you're looking for.
      Wide Array of NEW OEM MK II and Corrado Parts Available
    9. Member austin neuschafer's Avatar
      Apr 26th, 2002
      knoxville tn
      87 rocco 2l16v w/02a lsd 4.24
      12-19-2002 09:00 PM #7
      I know this isn't considered a degreaser, but I use the walmart. $.78 a can carbureator cleaner for quick cleanups, it doesn't leave a oily residue either. but be careful about sprayying engine internals, cause it will cause flash rust to appear in minutes
      87 rocco 2l16v MS3 02a/j with 4.24 on LSD. 91 rado geting 1.8t, 02 cabrio geting vr6, 04 r32 vf stg 2 sc, and a few other goodies
      Oct 31st, 2000
      Cincinnati
      12-19-2002 09:22 PM #8
      That would probably be Stoddard Solvent, aka mineral spirits, about $5/gal. in 5 gal pails.
      Lacquer thinner is good but don't use it except in small quantities - kaboom! Don't even think of gasoline. Frankly, I wash my blocks with good old dish soap and hot water, then blow them dry before I start final prep. AFA intakes, etc., Purple Power is pretty good.
      Mar 10th, 2000
      griffin, georgia
      1974 MGBGT
      12-19-2002 11:44 PM #9
      castrol super clean by far out cleans simple green and purple power and anything I have ever tried.
    12. 12-20-2002 03:55 AM #10
      Gunk Foamer is nice...as well as their heavy duty degreaser
    13. 12-23-2002 11:34 PM #11
      I agree - Simple Green (Automotive) works well. I have also found that Einman Fabrik works well too! It just is a little more difficult to optain. I now use it on my tires and wheel wells. Works really well - good investment (IMHO).
      Just my two cents!
    14. Member
      Dec 28th, 2000
      DFW, TX
      2001 GTI GLS 1.8T
      12-24-2002 04:26 AM #12
      How environmentally friendly is Super Clean? I can let Simple Green run into my storm drains, something I cannot do with the majority of car cleaning products and degreasers.
      My vote is simple green. Works well, won't kill you, and won't give you cancer if it makes it into the storm drains.
    15. 12-24-2002 09:24 AM #13
      It says it's good on the bottle.
    16. 12-24-2002 12:01 PM #14
      I'm surprised no one has mentioned P21S total auto wash. It's works great and has a nice odor which makes it easy to work with. It's a bit pricey and hard to find though.
    17. 12-25-2002 12:39 PM #15
      Simple green mate.. helps a lot for me when i need to find oil leaks [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    18. 12-27-2002 01:32 PM #16
      meguiars degreaser...works wonders
    19. Member
      Dec 28th, 2000
      DFW, TX
      2001 GTI GLS 1.8T
      12-29-2002 09:11 PM #17
      I checked out the stuff at the store last night, and it has warnings about burning skin and not breathing the mist. Super Clean is biodegradable, but it's still caustic and can cause health problems.
      Simple Green [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    20. 01-07-2020 06:15 AM #18
      The degreaser that you should use is a spray degreaser , It is easily available in the automobile shops , I am recommending spray degreaser because it is easy to use and easy to clean
    21. 01-08-2020 04:56 AM #19
      Quote Originally Posted by max mariner View Post
      RX Marine was established in 1996 in Mumbai, India; as chemical manufacturing company catering exclusively to the needs of the marine industry. In a short span of 12 years the company has established itself as one of the leading wholesale suppliers of a wide range of chemicals for - Marine industry internationally - and other local industires and plants. Our client list bears testimony to this. The RXSOL policy has its foundations on two pillars of strength - a continuous investment in research and development to deliver premium quality products and a commitment to service.
      Degreaser
    22. 01-16-2020 11:12 PM #20
      I use Optimum Power Clean. It works great and is safe.
    23. n00b
      Feb 8th, 2020
      Plot No 620, Road No 6, Beside PETL, GIDC, Panoli, Ankleshwar - 394115, Gujarat, India
      02-08-2020 01:32 AM #21
