VWVortex.com - FAQ Thread for Sciroccos
    Page 1 of 5 12345 LastLast
    Results 1 to 25 of 109
    Thread: FAQ Thread for Sciroccos
    1. Global Moderator Paul@VWvortex's Avatar
      Apr 2nd, 1999
      Milk was a bad choice -- AZ
      '17 A3 E-Tron, '17 TT Alum Ford, '96 VRT Cabrio, TDi Tristar Syncro, 1980 Scirocco S "Der Ott"
      01-17-2003 01:23 PM #1
      Information
      01) How to buy a Scirocco (PPI)
      02) Common Maintenence items
      03) What are my first upgrades?
      04) Engine swaps
      05) Brake maintenence
      06) Brake upgrades
      07) Suspension maintenence
      08) Suspension upgrades
      09) transmission swaps
      10) clutch updates
      11) Wheel and tire threads (pics)
      12) Project Car Threads
      13) Bodywork and paint
      14) Forced Induction
      15) Picture Collections
      16) Important Links (Vintage Watercooled, Scirocco.org list, etc)
      17) Trusted Vendors (parts4vws, NGP, etc..
      Trouble Shooting
      01) Car won't start
      02) Engine not cranking
      03) Engine stalls - cold
      04) Engine stalls - warm
      05) Overheating
      06) Weird electrical problems - general
      07) Blowing fuses
      08) Handling problems/suspension issues
      09) Brake noise
      10) Soft brake pedal/no brakes
      11) Drivetrain noise (clunking, grinding)
      12) Water leaks (into car)
      13) Loosing coolant
      14) Smoke from tailpipe
      15) Oil leaks
      16) Other oil loss
      17) Horn not working
      18) Hesitates when accelerating
      19) No power
      20) Engine misses at idle
      21) Knocking/pinging
      22) Noisy fuel pump
      23) Shifter problems (can get into 1st, etc.)
      Miscellaneous Tips
      JH Build
      Intake Port and Polish
      eBay H4 Upgrade
      Prevent Dash Cracks
      Remove Side Moldings
      NA Bumper Mod
      Mirror Switches
      Sloppy Shifter Bushing
      Cluster Overhaul
      Cutting NA Bumpers Down
      Cutting NA Bumpers Down II
      Project Cars
      kenny_blankenship
      My Old Roc
      [email protected]
      Waagenz
      polov8 (1.8T)
      talx (1.8T)
      MK1Scirocco1980
      Megasquirt Projects
      From CIS-E / Motronic
      8v Megapost
      kalvinlk's 16v Install
      Water Leaks
      Hatch Leak
      Sunroof Leak Part II
      Another Leak
      Hatch Leak [Not Lock Seal]
      Rear Passenger Wet Carpet
      Fuse Box Leak
      Trunk Leaks
      Sunroof Holds Water
      Floor Leak
      Bentley Repair Manuals
      Scirocco 1975-1978
      Scirocco 1980-1984
      Scirocco 1985-1988
      Parts Links
      Missing Linkz Shifter Upgrade
      Autohausaz
      Carmadillo
      German Auto Parts
      JC Whitney
      Memo Imports
      Mr. Auto Parts
      Parts 4 VWs
      Parts Express
      Rabbit Parts
      The Scirocco
      World Impex
      Vintage Rubber
      Tuners
      Auto Tech
      Bahn Brenner
      Euro Sport Accessories
      Neuspeed
      Techtonics Tuning
      Info
      Drivers Found/
      Model Guide
      Scirocco.org/
      Vintage Water Cooled Technotes
      Euro Headlights install
      Relay your headlights
      Stereo Wire colors
      Instrument Cluster Lights
      Starting FAQ
      Better Ground
      Air/Fuel Ratio Guide
      Megasquirt Technote
      Rebuild and cleaning of CIS fuel distributor
      Fuel Filter
      Fixing the Sunroof
      VW wheels (with Pics!)
      Gauge Faces
      Fix Odometer
      A1 Engine Mounts!
      Belt Routing technote
      Cooling System
      Engine Database
      Emissions FAQ
      Clutch Technote, with DVD
      Gear Oil Change
      Clutch Cable change
      Rear disc brake conversion
      10.1" Front brake conversion
      22mm Master Cylinder
      Alternator stuff Including removal of A/C
      Wheels
      Twelve-Spoke
      Mk1 Scirocco (5 x 13 ET45)
      also
      European Mk1 Golf GTi and Mk1 Passat
      Multispoke
      Mk1 Jetta (5¬? x 13 ET 38)
      Nine Spoke
      Mk2 Scirocco and Cabriolet (5¬? x 13, ET 38)
      also euro Mk1 Golf GTi
      Rabbit GTI and Quantum Synchro (6 x 14, ET 38) Mk2 Scirocco California Edition and Mk2 Scirocco Slegato
      (There is a non-painted version on some A2 cars)
      Hockenheim (5¬? x 13, ET 38) 1985 Scirocco Wolfsburg edition
      Le Castellet
      (6 x 14, ET 38) Used on last european Scirocco GTX's
      (6 x 15, ET 35)
      (6¬? x15, ET33)
      (Option on Golf/Jetta in 85-89 USA)
      Montreal (6 x 14, ET 38mm)
      Used on some later Mk2 sciroccos
      Pirelli P-Slots(6 x14 , ET 38mm)
      Sebring (6 x 15, ET 35) Corrado G60
      Silverstone (Tear Drop) (6 x 14, ET38)
      Golf Mk 2 16v Scirocco 16v - USA
      Zandvoort
      (6 x 14, ET38) 90-93 Cabriolet
      (6 x 15, ET35) European Corrado 16V
      Modified by [email protected] at 9:11 AM 11-8-2006
      Modified by [email protected] at 8:10 PM 4-24-2007
      Modified by [email protected] at 8:11 PM 4-24-2007
    2. Remove Advertisements
      VWVortex.com
      Advertisements
    3. 11-08-2006 08:09 PM #2
      Most of this isn't MKI specific, do we need two FAQs?
    4. 11-09-2006 12:36 AM #3
      Quote, originally posted by frrtbkr »
      lets put in parenthasis after every link whether or not its Mk specefic. for example. . .
      Wheel and tire tips (Mk1 Mk2)
    5. 11-15-2006 01:23 PM #4
      why is this thread still sticky even tho the first 23 topics don't work?
    6. Senior Member Chris16vRocco's Avatar
      Apr 29th, 2006
      Maryland
      Scirocco x2, QSW, FJ40, E30, S4, W123, Golf7 TDI
      11-15-2006 11:06 PM #5
      This is a new FAQ, so it's still under construction. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Also, this should be an all-inclusive FAQ for all Sciroccos (except the IROC), and should be named as such.
      Nil Satis Nisi Optimum
    7. Member G-rocco's Avatar
      Sep 10th, 2004
      270 & 495, Maryland.
      84 Scirocco, 09 Crown Victoria, 18 Alltrack, passenger in a 16 CC 3.6 4mo
      11-28-2006 11:15 AM #6
      I once pulled up all these Scirocco buyers guide (sorta) threads..
      https://forums.vwvortex.com/showthread.php?2539489
      It's not organized, but is this the sort of stuff we want for the "How to buy a Scirocco" thread at the top os this sticky?
      Or, does it need to e sorted out and indexed?
    8. Member TheTimob's Avatar
      Sep 13th, 2003
      85 Scirocco
      12-17-2006 08:18 PM #7
    9. 12-20-2006 06:33 PM #8
      I see your point, and actually I'd be more inclined to suggest 3 sub-divisions...MKI, MKII, and 16V....
      Or perhaps it would be simpler and more practical to create another sticky thread that explains the differences between the various versions of Scirocco that would help guide the 'less-familiar' toward topics that are more specific to their car.
      Also, what about a topic that gives hints on parts from other cars that are salvageable/useable on the Scirocco? For example, you can rebuild an 8v's control pressure regulator with the similar part found on many Audis and Mercedes Benz models from the late 80's/early 90's. Things like that could be a major help to some people. - Just a thought.
    10. Member vdubCorrado's Avatar
      Nov 8th, 2001
      Baltimore MD
      17 GTI - 91 Corrado
      02-02-2007 07:14 PM #9
      if it help the name of the last wheel is Estoril [IMG]http://*****************.com/smile/emthup.gif[/IMG] came in a 4 and 5 lug...
    11. Member badpenny's Avatar
      Jan 13th, 2007
      Hurst, Tx
      82 scirocco
      02-13-2007 05:29 PM #10
      The Zandvoort's also came in 13's
      The entire tool selection at Sears or the contents of a Snap-On truck will do you no good if you do not know how to use them.
    12. Member TheTimob's Avatar
      Sep 13th, 2003
      85 Scirocco
      03-24-2007 05:23 PM #11
      This is for an 84.
    13. 04-01-2007 11:45 PM #12
      Quote, originally posted by timbo2132 »
      This is for an 84.
      makes me think bout my problem wit my 16v
    14. Member JonnyPhenomenon's Avatar
      Jan 27th, 2005
      Lewiston, Maine (USA)
      88 Scirocco, 78 bus, 91 Vanagon
      04-03-2007 09:57 PM #13
      Scirocco Fuel Tank Recall information
      there was a recall made on some roccos due to them rusting out along a seam. if it hasnt been done yet, then Presto, you get a free, dealer installed gas tank, along with all of the extra stuff needed to complete the operation.
      more info on the recall
      http://www.scirocco.org/faq/mi....html
      https://forums.vwvortex.com/showthread.php?4150893
      punch your vin number in here to see if yours has been done.
      http://www.vw.com/myvw/yourcar...en/us/
      if the recall has been done but your tank is shot, then you can get a new one for cheap. brand new tanks are about 120$. Just do a quick google search for online suppliers.
      Modified by JonnyPhenomenon at 8:50 PM 4-8-2010
    15. Member TheTimob's Avatar
      Sep 13th, 2003
      85 Scirocco
      04-08-2007 02:38 PM #14
      This is what your transmission code looks like. As you can see, I have a 4K transmission made on 12/10 1983 (last digit is the year)
      This is how you get off those stupid springs on 8v Mk2s
      Click here To see how to do a Mk3 alternator install...
    16. Member JonnyPhenomenon's Avatar
      Jan 27th, 2005
      04-13-2007 06:45 PM #15
      Here is my contribution to the fuse/relay panel information.
      one thing about fuse number 17, on my car it affects the fuel pump. when I unplug it, and plug it back in (when the car is off but key in the on position) the fuel pump buzzes like it does when it primes up. I wonder if Mine is swapped with fuse number 2?
      Modified by JonnyPhenomenon at 3:52 PM 4-17-2007
      Modified by JonnyPhenomenon at 3:54 PM 4-17-2007
    17. Member TheTimob's Avatar
      Sep 13th, 2003
      85 Scirocco
      05-01-2007 07:02 PM #16
      Here's the box that makes the OXS light turn on:
      The box counts to 30K, and turns that light on. Push the button way in to reset it.
      Modified by TheTimob at 9:29 PM 2-20-2009
    18. Member JonnyPhenomenon's Avatar
      Jan 27th, 2005
      05-02-2007 10:16 AM #17
      good pic timbo.
      do you think we should all replace our O2 sensors after 30k? lol
    19. Member TheTimob's Avatar
      Sep 13th, 2003
      85 Scirocco
      05-02-2007 05:17 PM #18
      Quote, originally posted by JonnyPhenomenon »
      good pic timbo.
      I think 50k... MAYBE!
      But really - if you have your car tuned right, and it does not run rich or lean or any of that - the sensor can last for a long damn time. I'd change it just so it doesn't sieze in the pipe though!
    20. Member jettadriver509's Avatar
      Apr 22nd, 2005
      Spokane Wa.
      87 shopping cart
      05-07-2007 09:17 PM #19
      Does anyone have a detalied pics of the back of a fuse box? Like were all the single wires go and what color. Thanks
    21. Member badpenny's Avatar
      Jan 13th, 2007
      Hurst, Tx
      82 scirocco
      05-19-2007 07:28 PM #20
      Model and years courtesy of Chris16vRocco
      A1 platform:
      75-84 Rabbit a.k.a. Golf Mk1
      83-84 GTI
      80-84 Jetta Mk1
      75-81 Scirocco Mk1
      82-88 Scirocco Mk2
      80-93 Cabriolet
      80-84 Rabbit Pickup
      A2 Platform:
      85-92 Golf/GTI
      85-92 Jetta
      A3 platform:
      93-98 (and early 99) Golf/GTI
      93-98 (and early 99) Jetta
      94-01 Cabrio
      A4 platform:
      98- New Beetle
      99-05 (early) Jetta
      99-06 (early) Golf/GTI
      99-06 Audi TT
      A5 platform:
      05- Jetta
      06- GTI
      07- Rabbit
      05- Audi A3
      07- Audi TT
      Modified by badpenny at 10:16 AM 5-21-2007
      Modified by badpenny at 10:20 AM 5-21-2007
    22. Member 206vw's Avatar
      Sep 11th, 2003
      Seattle, WA
      2000 Mercedes ML320, 1979 MK1 Golf 2.0 16v, 2010 Moots Titanium Compact
      07-01-2007 09:08 PM #21
      Quote, originally posted by badpenny »
      A1 platform:
      83-84 GTI
      80-84 Jetta Mk1
      75-81 Scirocco Mk1
      82-88 Scirocco Mk2
      80-93 Cabriolet
      80-84 Rabbit Pickup
      A2 Platform:
      85-92 Golf/GTI
      85-92 Jetta
      89-93 Corrado
      A3 platform:
      94-01 Cabrio
      A4 platform:
      98- New Beetle
      99-05 (early) Jetta
      99-06 Audi TT
      A5 platform:
      05- Jetta
      06- GTI
      07- Rabbit
      05- Audi A3
      07- Audi TT
      Added the corrado for you
    23. Member TheTimob's Avatar
      Sep 13th, 2003
      85 Scirocco
      07-13-2007 08:11 AM #22
    24. Member TheTimob's Avatar
      Sep 13th, 2003
      85 Scirocco
      07-17-2007 07:02 PM #23
      Here's a pic that'll help you identify if you have hydro lifters.
      If #4 is missing, you have hydro lifters. If it's there, Solids!
    25. Member sciroccokartei's Avatar
      Nov 2nd, 2005
      Frankfurt/M.
      Scirocco MK1
      07-19-2007 01:30 PM #24
      Nice links.
      Thanks for Information
    26. Member JonnyPhenomenon's Avatar
      Jan 27th, 2005
      07-20-2007 11:15 AM #25
      I hate to say it, but I dont know what the difference is between hydro and solid lifters. does the 16v have solid or hydro? (or one or the other?) is there an easy way to tell with the 16v?
