VWVortex.com - Audi 80 2.0 5 spd at St Louis Pick-n-Pull
    Results 1 to 3 of 3
    Thread: Audi 80 2.0 5 spd at St Louis Pick-n-Pull
    1. Member QuantumSyncro's Avatar
      Apr 28th, 2000
      Des Moines, IA
      97 Jetta TDI, 1990 Passat TDI wagon, 92 300SD turbo
      01-08-2014 02:44 PM #1
      According to Row52 there's an 1990 Audi 80 2.0L 5 speed at St Louis Pick-n-Pull
      It's 6+ hours for me to drive there but if any other Foxers are around that area it might be worth a look. This would have a complete trans swap for Fox although I don't know which trans it is....Greg would know though, I think we've talking about the Audi B3 trans codes a little in the past.
      Steve
      Did you poison the coffee? Not any more than I usually do.
    2. Remove Advertisements
      VWVortex.com
      Advertisements
    3. Awaiting Email Confirmation 90quattrocoupe's Avatar
      Feb 6th, 2002
      Long Beach, CA.
      90 Audi S8coupe, 90 Fox Wagon, 2010 Jetta TDI
      01-27-2014 12:40 AM #2
      Didn't see this thread before, Steve. 90 FWD transmissions are 012s, whereas the fox is an 013.
      Greg W.
    4. Member lilgreydentwagen's Avatar
      Sep 13th, 2005
      Lake Stevens, WA
      88 fox wagon> b3 audi 90
      01-27-2014 02:33 AM #3
      Gear ratio on that tranny if you want here: (provided its a 5 speed)
      http://www.automobile-catalog.com/auta_details1.php
      Doesn't look to be a much better option than the stock fox trans aside from shorter gears. Probably to get all that weight (2600+ lbs) moving. Here's a list of gear ratios for different fwd VW/Audi boxes.
      http://www.lunaticfringe.org/vwfox/m...wap-specs.html
      I have a 2p in my fox it turns about ~3500 rpm (iirc)@ 70 with 195/50/15's. I always wished I had taller gears.
      remember to spay or neuter your politicians
