VWVortex.com - Seat Leon Streetlegal Supercopa with TTRS Engine, Sequential Gearbox and 4Motion
    Page 3 of 3 FirstFirst 123
    Results 51 to 55 of 55
    Thread: Seat Leon Streetlegal Supercopa with TTRS Engine, Sequential Gearbox and 4Motion
    1. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      D2 S8, B5 A4 V8
      02-04-2015 04:05 PM #51
      This is an AHU for reference 'scuse the slight melty-ness of number 2
      and the flange I was talking about:
      This is much more substantial than the Golf version which follows the outline of the sump closely. I think this gives the Audi / Passat versions more torsional strength, although not sure why the need it.
      Quote Originally Posted by shwak23 View Post
      You could always call your insurance and say that some vandals tried to swap your car to rwd while you weren't looking.
    3. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      D2 S8, B5 A4 V8
      02-04-2015 04:18 PM #52
      Head bolts:
      Top is the standard 1Z / AHU / AFN bolt - 10.9 grade. Bottom is the PD150 bolt - longer and 12.9 grade, same thread. These are an upgrade for the AFN by cutting them to length and swapping the washer from the AFN bolt. I reckon these are the key to bolting the 16V head to the TDI block, unless of course you have custom studs made
      Crank gear is an interesting challenge, as the diesel and petrol crank noses are different so the sprockets don't easily swap over. Been looking at this for running a TDI crank in a petrol block, although I actually prefer your way of doing it!
    4. Member Iku's Avatar
      Mar 11th, 2009
      Saskatchewan
      MKIV VR Jetta on Accuair, MKIV R32 Turbo
      03-17-2015 09:43 PM #53
      Wonderful thread with LOTS of photos. Thanks for sharing. Subscribed!
    5. Member jamesr88's Avatar
      Oct 9th, 2007
      Lima, oh
      94 gls, 85 gti, 84 rocco, 02 w8 4-motion, 91 gti aba, 92 carat vr, 93 aba-t, 84 jetta
      01-14-2016 11:54 AM #54
      no updates??
      PSN: god_damn_name88
    6. n00b endhyr@hotmail.com's Avatar
      May 4th, 2019
      Barcelona España
      05-05-2019 06:53 AM #55
      Hi.
      I'm new around here.
      I can not see the photos of DutchWilco.
      What do I have to do to see the photos?
