VWVortex.com - Coolant leak?
    Page 1 of 8 12345 ... LastLast
    Results 1 to 25 of 199
    Thread: Coolant leak?
    1. Member tetedelinotte's Avatar
      Jul 17th, 2007
      Tucson, AZ
      10-27-2014 12:48 PM #1
      Hi guys. So, I've had the car for a grand total of six days. Was just showing off what's under the hood to a coworker when I noticed droplets of pink and the coolant tank is almost at minimum. Leaking already?! Has anyone had this problem? Calling the dealer now...I'm gonna have Mark 4 flashbacks/PTSD if this is a preview of coming attractions.
    2. Remove Advertisements
      Advertisements
    3. Member RjRacing's Avatar
      Nov 14th, 2008
      Philly
      15' GTI PP (Daily), 05' Evo 8 (Track), 05' Ram 2500 Cummins 4x4 (Tow&Plow)
      10-27-2014 01:05 PM #2
      Its not uncommon to have fluids that are not topped off from the factory. Bring it in to have the dealer check to make sure there are no leaks and top it off.
    4. Member tetedelinotte's Avatar
      Jul 17th, 2007
      Tucson, AZ
      10-27-2014 01:06 PM #3
      There are pink droplets below the tank, so I think it's already leaking. But I did see a thread on golfmk7 about an expansion cap replacement, so hopefully it's something simple.
    5. Remove Advertisements
      Advertisements
    6. Member
      Nov 19th, 2012
      Dallas, TX
      2015 GTI SE w/DSG
      12-30-2014 05:00 PM #4
      Hi all,
      So I bought my GTI on 7/20 and it has 3800 miles now. Today I noticed the coolant level in the reservoir is slightly below "Min", when the engine's cold. If I remember correctly, it should be on the right level when the car was delivered in July. Is this normal? Anybody else has the same problem?
      BTW, with no G13 available here, should I visit my dealer or just adding some purified water instead? Thanks a lot!
    7. 12-30-2014 05:14 PM #5
      Could be a water pump failure.
    8. Junior Member kjmiv's Avatar
      Mar 9th, 2010
      WI
      2015 GTI
      12-30-2014 08:35 PM #6
      Mine has been doing the same thing. I noticed it when I put the car away for winter. I have about 6,000 miles on it now. I plan on taking it to the dealer in spring and having it pressure tested. I haven't found any leaks, coolant droplets or even smelled coolant so I have no idea where it is going. Good luck.
    9. Member 16plus4v's Avatar
      May 3rd, 2006
      Rossland, BC
      M235i , MK7
      12-30-2014 08:46 PM #7
      What's the level at when running the engine at operating temperature ?
      Reason I ask is that It's an expansion tank, not a reservoir so it's a bit redundant to focus on the fluid level as it's constantly fluctuating with the pressures throughout the temperature range. My VW's have always seemed to stay just under the fill mark, but it does fluctuate. If you don't see any leaks I wouldn't worry. It could be a simple case of an overlook on the PDI too, so I'd ask your dealer to look into it on your first service
      Black - '16 Golf TSi 1.8t - Trendline/Auto, Carplay, B/U Cam, 35% tint, mud flaps (future: 18x8.5 V810's, LCI headlights/tails) - Hers
      Black - '15 M235i Performance Edition w/LSD 6MT, Brembo GT BBK's, track prepped - His
      Black - '17 Toyota Tacoma TRD (on the hunt)
      White - '15 GTI Autobahn 5dr - DSG APR Stage 2, Quaife - Hers (gone)
    10. Member
      Dec 14th, 2004
      Elk Grove
      1988 GLI 1.8 16V, 1992 GTI 2.0 16V, 2006 Audi A3 2.0T, 2015 GTI
      12-30-2014 09:48 PM #8
      Ignore this reply.
      Trust and agree 100% with this one.
      16plus4v
    11. Member Ohio Brian's Avatar
      Aug 13th, 2001
      Willoughby, OH
      12-30-2014 11:13 PM #9
      About the first 1000 miles I had my car it went from the full line to halfway between max and min. Sometimes I'd smell coolant. From ~1000 miles to now (4400 miles) the coolant level hasn't moved, and I haven't smelled it.
      19 Tacoma TRD Pro
      Aug 15th, 2014
      Colorado
      15 GTI SE PP 2DR 6MT
      12-30-2014 11:29 PM #10
      I wouldn't worry to much, fluids expand/contract with changes in temperature. Which is why you have an expansion tank. Chances are it's cooler now than when you got your car, hence the coolant has contracted.
    13. 12-30-2014 11:33 PM #11
      Quote Originally Posted by Zipcoolie View Post
      So basically what this guy said all over again,
      Quote Originally Posted by 16plus4v View Post
    14. Member
      Nov 19th, 2012
      Dallas, TX
      2015 GTI SE w/DSG
      12-31-2014 12:55 AM #12
      Quote Originally Posted by g60_boost View Post
      Thank you for all the input.
      But someone above did remind me something~ I can smell coolant coming out from AC. It was pretty strong when I first switched to heat. The smell now is lighter but still noticeable. This is probably something I need to ask my dealer
    15. 12-31-2014 01:42 AM #13
      Quote Originally Posted by gtimaneg View Post
      Ignore this reply.
      My coolant level was below min and there was a humming noise coming from the car. I took it in to the dealer and turns out it was water pump failure. I would be curios to know why you think he should ignore my reply?
    16. Member AdamSheikh's Avatar
      Mar 29th, 2014
      Ft. Lauderdale, FL
      2015 GTI | Autobahn | CSG | DSG | LP | OEM+
      12-31-2014 02:03 AM #14
      Quote Originally Posted by sonerb81 View Post
      When were you hearing the humming noise? Our cars have an after-run coolant pump to keep the turbo and other components from roasting after a long run. Shuts off about 2 or 3 mins after the car turns off.
      2015 GTI | Autobahn | CSG | DSG | LP | OEM+ | MTM | Delivered June 2, 2014
      S F L M K 7 / / /
      A D A M S H E I K H . C O M
    17. Member ABATurbo's Avatar
      Feb 10th, 2010
      2015 GTI
      12-31-2014 02:07 AM #15
      Are you sure you don't drive a MK6 GTI? I would seriously be amazed if VW has not managed to fix the water pump issue by now. We replace multiple water pumps weekly on MK6 GTIs and I doubt they want to continue paying for that through warranty.
    18. 12-31-2014 03:13 AM #16
      Quote Originally Posted by AdamSheikh View Post
      I hear it during driving. It sounds like a fan is having a hard time turning.
    19. 12-31-2014 03:15 AM #17
      Quote Originally Posted by ABATurbo View Post
      Unfortunately it's a mk7. Bought it new in October. I was pretty disappointed to hear the water pump failure because just like you I thought vw would have fixed the issue in the new model.
    20. Member Gregv's Avatar
      Aug 9th, 2013
      Bologna, Italy
      3 Door MK7 Golf GTI, Performance Pack , Manual, CSG
      12-31-2014 10:04 AM #18
      I noticed my coolant was down to the bottom of the tank a couple weeks ago. added a glass of water to bring it to the right level. This after a year of ownership.
      Not worried. Could have been at the min line, a little bit oozed out while the seals broke in, who knows. Unless you're topping it up once a month I really don't think it's a big deal.
      2013 MK7 GTI - CSG, 2 Door, Manual, P-Pack, Bixenon HIDs, Mirror Pack, Park Assist, DynAudio, DAB+
      Mods: Eurodyne Stage 2 98RON tune, BCS 100 cell DP, USP Tear-Duct intake, Spullen Silicone intake hose, DIY dogbone mount, DIY turbo muffler delete, DV+, ST 20/20mm springs, 5mm rear spacers, 17x8 OZ Alleggerita HLTs, Water/Alcohol injection, Soundaktor delete.
    21. Member 08CandyWhite's Avatar
      Jan 31st, 2003
      Westminster, CO
      18' Tiguan SE 4Mo 00' TT 5MT
      12-31-2014 12:07 PM #19
      Every single one of my VW's have done this, during the first cold weather season when I had bought them new. Just like others have said, it is an expansion tank. Coolant just like any fluid contracts when cold and expands when warm. Just adding a little distilled water or coolant will correct this.
      Also OP G13 is the main use coolant now. G12 is hard to come by at this point.
      Part # for G13 gallon concentrate: G-013-A8J-1G
      2018 Tiguan SE 4Motion - Pure White - Sunroof - 3rd Row
      2000 TT - Denim Blue - Denim Blue leather
    22. Member stainlineho's Avatar
      Aug 20th, 2011
      Atlanta
      '12 Tiguan SE
      12-31-2014 01:02 PM #20
      No car should be consuming coolant. Normal? Seriously?
      2012 Reef Blue Turbo Beetle - GONE
      2012 Tiguan SE - Stock
    23. Junior Member
      Aug 2nd, 2014
      Portland, OR
      2015 GTI SE
      12-31-2014 03:58 PM #21
      Quote Originally Posted by chengong910 View Post
      Hi all,
      i noticed this in mine as well, only at about 1200 miles. i went and bought some g13 just in case, but haven't added any yet, because when i checked the levels after driving a bit, they were higher.
      still concerning that it would be so low, though...
    24. 02-12-2015 10:43 PM #22
      So this happened on the way home..
      Popped the hood, level not lookin' so good...
      Taking it in tomorrow.. hope it's not a failed water pump...
    25. Member milan187's Avatar
      Mar 15th, 2009
      On, Canada
      2015 GTI 6MT
      02-12-2015 10:57 PM #23
      Sucks, first I have seen of this, guess its nothing common. Let us know what it is, a leak somewhere thats for sure.
      Watch your temperature going to the dealer do not let the engine over heat, in worst case scenario you can add some water. I am assuming they will do a flush anyway when they fix the issue. Good luck.
    26. Member AdamSheikh's Avatar
      Mar 29th, 2014
      Ft. Lauderdale, FL
      02-12-2015 11:10 PM #24
      Mine was slightly low a few months ago. Didn't get a warning or anything, just happened to notice it. Didn't think much of it, just topped it off. It's been fine ever since.
      S F L M K 7 / / /
    27. Member jhnr's Avatar
      Nov 30th, 2006
      SoCaL818//ENCINO
      2015 MK7 GTI Autobahn, 2004 CLK55 AMG VERT
      02-13-2015 12:02 AM #25
      mine is on minimum.... bruh....
