VWVortex.com - wiring diagram for automatic dimming rear mirror
    Results 1 to 10 of 10
    Thread: wiring diagram for automatic dimming rear mirror
    1. Semi-n00b
      May 7th, 2015
      2015 Volkswagen golf variant 2.0 TDI 110kw
      05-07-2015 10:33 AM #1
      Hello,
      please if you can help me find wiring diagram for automatic dimming rear mirror for golf 7.
      peter
    2. Remove Advertisements
      Advertisements
      Nov 1st, 2013
      Australia (Melbourne)
      VW Golf mkVII 103TSI Highline (1.4L Turbo)
      05-07-2015 11:04 PM #2
      Quote Originally Posted by Peter30 View Post
      Hello,
      peter
      Peter: Hi. Here's the wiring arrangement for the stock-standard anti-dazzle mirror in a Golf mk7
      As you can see there are basically four wires as follows:
      1. Battery Positive - This comes from fuse position #34 on the C fuse box (via the rotary light switch). The "C" fuse box is the one on the lower LHS of the steering wheel for those car that have the steering wheel on the wrong side!!
      2. Battery Negative - This is also taken from the rotary light switch
      3. Input signal from the front interior light - this ensures that the antidazzle mirror doesn't dim when the interior light is switched-on. I guess that you leave this wire out if you didn't want this function
      4. Input signal from the reversing lights (also via the BCM)- again, this ensures that the antidazzle mirror doesn't dim when the car is reversing
      Hope this what you wanted
      Cheers
      Don
    4. Member LIJetta18t's Avatar
      Jul 5th, 2011
      Island of Long, NY
      Past: 2001 Mk4 Jetta 1.8t w/slushbox, 2012 Mk6 2.5L Golf 3Dr 5MT. Now: MK7 Golf 5Dr 5MT
      05-07-2015 11:29 PM #3
      One day Ill install one of these (Along with the RLS for auto lights/wipers).
      VCDS Coding in Long Island, NY. PM for details. I specialize in all things Mk7.
      2015 Mk7 Golf 1.8TSI S w/Sunroof, LP, DAP
      Track my Fuelly page
    5. Remove Advertisements
      Advertisements
    6. Member
      Nov 1st, 2013
      05-08-2015 02:12 AM #4
      Quote Originally Posted by LIJetta18t View Post
      Tom: isn't it strange? I have an auto-Dimming mirror on my mk7 and I don't like it! It never dims correctly (IMO). I've fixed the problem on my car by placing a piece of black electrical tape over the light detector on the windshield side of the mirror. When I want the mirror to dim, I simply switch on the button on the mirror and it dims to the max level. Very low tech, but effective!
      Cheers
      Don
    7. Semi-n00b
      May 7th, 2015
      05-08-2015 02:51 AM #5
      Thanks for the quick reply.
      Today, I will install the mirror.
      I hope it will work as it should.
      Peter
    8. Semi-n00b
      May 7th, 2015
      05-13-2015 03:32 PM #6
      hello,
      if anyone has?
      I need a description of the pins on the connector A, B and C at (BCM) MK7 golf.
      Peter
    9. Member Mike1082's Avatar
      Jul 21st, 2014
      Parsippany, NJ
      90 Talon TSi AWD, 90 240SX, 95 Talon TSi AWD, 04 350Z Touring, 15 GTI PP/LP/DCC
      05-13-2015 04:08 PM #7
      Anyone have the part number for the OEM MK7 mirror with auto-dim?
      MK7 GTI SE DSG PP/LP/DCC
      "Build" Log Here
    10. Member
      Nov 1st, 2013
      05-13-2015 08:44 PM #8
      hello,
      if anyone has?
      Peter
      Peter: I can recall that someone here put-up a copy of the BCM pin-out some time ago, but I can't find the link now- sorry. Anyhow, here's some info that I put together last year. It might be useful. Please be aware that the information in the table is for an ROW model
      https://www.dropbox.com/s/x1m8xn012v..._out..pdf?dl=0
      Cheers
      Don
    11. Member
      Nov 1st, 2013
      05-13-2015 09:00 PM #9
      Quote Originally Posted by Mike1082 View Post
      Mike: Here are the numbers that are embossed on the bottom of the antidazzle mirror on my car
      905-3541 7N0 857 511 L SMA
      43054069 122112
      Cheers
      Don
    12. n00b
      Dec 6th, 2015
      France
      Golf Mk7
      12-13-2015 07:41 AM #10
      hello,
      i am looking for pin reference for the BCM pin 64.
      If someone else have the exact reference ?
      (Thanks to DV52 for the reply)
