VWVortex.com - Scratched Glass...repair or replace?
    Results 1 to 4 of 4
    Thread: Scratched Glass...repair or replace?
      Feb 8th, 2003
      Northeastern/Mid-Atlantic/Southern CA USA
      08/VW/MKVR32
      08-14-2015 10:42 AM #1
      Need advice about how to repair scratched rear glass as a result of vandalism. It is definitely noticeable and pretty bad. Can it be repaired with a glass polish or is there any other means of repair? Do I need to replace it? Any advice will be appreciated.
    2. Remove Advertisements
      Advertisements
    3. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      1943 Flugkreisel, 1945 VRIL-7
      08-19-2015 12:05 AM #2
      Cerrium Oxide works. Google for video examples.
      You'll also find many other products for different types of window damage.
      The original Dub and Dubber.
      Manche VWs sind einfach schneller als andere.
    4. 05-30-2017 05:31 PM #3
      Try the diamond polishing pads. I used them on ceramic and marble which is similar in hardness to glass. Use them wet and work slowly. There are a variety of grades...start with course 600 then go to 2000-3000.
      https://www.amazon.com/s/?ie=UTF8&ke...l_486o6dzw50_e
      I also have a rear glass for an 84 GTI or rabbit. looks good except for small scratch...your for $10 + shipping.
    5. Remove Advertisements
      Advertisements
    6. 05-16-2018 03:44 PM #4
      If you can feel with your fingernail,the scratch is too deep to do anything about it.
