VWVortex.com - So, my girlfriend surprised me with a car - Ford Festiva content...
    The Car Lounge
    Page 14 of 14 FirstFirst ... 41011121314
    Results 326 to 348 of 348
    Thread: So, my girlfriend surprised me with a car - Ford Festiva content...
    1. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      1990 Volvo 240 sedan, 1972 VW camper van, 1993 Volvo 240 wagon, 1989 Ford Festiva, 2014 Ford Fiesta
      08-23-2019 01:25 PM #326
      Moved the blue car along, it just wasnít in the budget to fix/track it. Found it a great home with someone who works as a fabricator in the aerospace industry who was massively excited to get going on it.
      Also made a decision on the engine. I know keeping the B3 is not a wise choice, but I truly enjoy how the car drives with it in that I can push it to its limit and not really get myself into trouble. Iím hoping to pull the engine this winter for a refresh and a few modifications for next year to get slightly more pep out of it. Given that decision, I sold the B6T swap to a local member of the Festiva community.
      With less than 1500km on the suspension swap, the RR strut has started to leak somehow, so Iíll have to deal with that. I bought one of the pre-made sets that were offered a few years ago, and I donít know if I can swap the Southwest Speed sleeve over to a new shock or what other modifications were done to the shock.
    2. Remove Advertisements
      Advertisements
    3. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      '66 Beetle (X2) '08 Fit
      08-23-2019 02:05 PM #327
      I get it. I need to downsize as well. I have the two '66 Beetles (one fairly easy project and one nice turn-key) as well as a big project '59. Which do I keep? I don't know!
      Good luck with the suspension. I hope you can get a pair of struts and bolt 'em in.
    4. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      09-20-2019 10:58 PM #328
      Found these kickass Intra Phonedials on Facebook marketplace for a whole $100 Canadian. They need a complete restoration, but I couldnít pass them up. Hoping to have them done for next season.
    5. Member Bad Rabbit Habit's Avatar
      May 5th, 2005
      Manteca, CA
      A Rabbit with a snail.
      09-21-2019 11:57 AM #329
      Those are awesome!
      -Jon
      ig:badrabbithabit Formerly known as: monoaural
    6. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      09-21-2019 06:21 PM #330
      Quote Originally Posted by Zman86 View Post
      Yesss!
    7. Senior Member DonL's Avatar
      Feb 28th, 1999
      SE Michigan
      A blue oval and a bowtie. Domestic swill.
      09-21-2019 10:57 PM #331
      Nice pickup on the dials. Are you thinking the same color, or something different?
      Smooremin: "Dont worry. My corset really fills me out ."
      Sold Over Sticker: "The only difference between innuendo and flirting is the desired result. "
      KidL: "Dammit, Chippy! You're making bad choices!"
    8. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      09-22-2019 09:15 PM #332
      Quote Originally Posted by DonL View Post
      Undecided on the colour, but Iím kinda digging the bronze. They need a total restoration, a couple have bends that are apparently only visible on a balancer, and one looks like it may have been run loose since the mounting holes are a bit ovaled...
    9. Senior Member
      Nov 7th, 2001
      The Village
      KAR 120C
      09-23-2019 11:59 AM #333
      Great wheels. Definitely worth finding a shop who can restore them properly...
      No B6T swap, eh?
    10. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      09-23-2019 04:13 PM #334
      Quote Originally Posted by Numbersix View Post
      No B6T swap, eh?
      Nah, decided that swapping engines just isnít for me, mainly because Iíd have to convert the car to EFI. Going to look into building up the stock engine a bit, bike carbs, cam, some porting/polishing, etc. That however is well off in the future...
    11. Member PainKiller's Avatar
      Oct 3rd, 2007
      by the mountain
      02 24V GTI - outback - 84 Softail
      09-23-2019 04:17 PM #335
      Looking good man !!! Kant wait to see those wheels on it
      Quote Originally Posted by Mr Miyagi View Post
      Please tell me how this does. I have a massive amount of stuff I need to kill
      Sprinkle some of your personality on it.
      PSN: PainKiller-sas-
    12. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      09-23-2019 05:21 PM #336
      How hard is that to do and how does it affect drivability?
    13. Member Jettaboy1884's Avatar
      Jan 20th, 2004
      North, NJ
      '85 VW Golf & '17 Honda Fit Base - 6-speed
      09-23-2019 08:36 PM #337
      Good Plan
      Quote Originally Posted by Air and water do mix View Post
      Speaking from a VW 8v perspective it is relatively easy to do. Hardest part (in my opinion) is fabricating an intake manifold and dealing with little stuff like hardware and linkages... I can't speak to the Fiesta, but '80's VW ignition systems are practically an independent simple system that functions on a hall sensor (like a cam position sensor) and has vacuum advance. Fuel is pretty straightforward, you just need to get filtered fuel to the carbs at about 3-4 PSI. I wasted a lot of time over-thinking this part...
      A clean set of carbs should be able to fire up and run with a little tuning to the idle circuit. Driveability is heavily dependent on the fine-tuning, which is made a lot easier if you have a wideband O2. Usually you'll need to increase the size of the main jets to get the air fuel ratio right. The nice thing about bike carbs is that most of them are Constant Velocity (CV) type which are not nearly as sensitive to temperature and atmospheric changes. Also, finding a set of carbs and parts is pretty easy as they were available through the 80's into the 2000's.
    14. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      09-23-2019 09:40 PM #338
      Quote Originally Posted by Jettaboy1884 View Post
      Good Plan
      ďLikeĒ
      Fabbing a manifold doesnít scare me and linkage requires a little tenacity and patience, but without knowing where to start on jetting is a bit perplexing to me.
      I suppose since the displacement is so much higher and the rev range so much lower that it works out pretty well, size wise.
    15. Member Stromaluski's Avatar
      Jun 15th, 2005
      G'vegas, SC
      '67 Deluxe Bus, '80 Rabbit Truck, '92 Corrado, '01 S8, '13 CC
      09-24-2019 08:41 AM #339
      No B6T swap, eh?
      At first, I read that as 6BT swap and thought to myself "There's no way that would fit in there..."
    16. Senior Member dubdaze68's Avatar
      Oct 29th, 2001
      '81 Sportruck, '82 Jetta Diesel
      09-24-2019 11:48 AM #340
      I haven't seen a set of those in a few years.
      DCIVW
      CE.
    17. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      09-24-2019 09:45 PM #341
      Iíve not done any research on the bike carb conversion. The festiva community is generally against modifying these engines since swaps are so easy, but Iím stubborn. The B6T apparently turns these cars into an absolute monster, but Iím not after a monster, just a bit more zip.
    18. Senior Member Iroczgirl's Avatar
      Feb 17th, 2007
      Bend, OR
      Hot hatchback coupť heaven
      09-24-2019 10:45 PM #342
      Epic wheels. I also haven't seen a set of those for quite some time.
      Lots of VW stuff|Rare Scirocco parts!
      The family: 1955 Customline 351C | 1970 TR6 262Olds | 1977 Capri Cologne | 1980 Rabbit AAZ | 1984 C30 350 | 1988 Scirocco 9A | 1988 Scirocco LP7Y | 1992 Pickup 22RE | 1997 D21 KA24E | 2000 Grand Marquis Modular
      Quote Originally Posted by Crimping Is Easy View Post
      You're always better off with a CitroŽn.ô
    19. Member Jettaboy1884's Avatar
      Jan 20th, 2004
      North, NJ
      09-26-2019 08:36 PM #343
      ďLikeĒ
      Good! The linkage was actually one of the more fun parts that I had to figure out, and you are right-on with the sizing.
      At a basic level, carbs function by fueling for a given air flow. They fuel pretty well on motorcycle jetting because a 2.0L at 7k RPM is flowing a similar amount of air as a 1.0L at 14k RPM... Obviously it's not that cut & dry but conceptually that's the deal.
      Also convenient is that bike carbs are very similar in size to our engine ports. My 1.8L is running on 36mm Keihins from a Kawasaki Ninja 750. Most VW 16v guys aim for larger 40mm carbs typically from 1000-1200cc bikes.
      Motorcycles have a TON of aftermarket, and carb tuning and upgrade knowledge is readily available. They can get a little pricey if you have to rebuild them (four independent carbs) and I have learned the hard way that they are sensitive to sitting around with Ethanol gas...
      Here's my (still incomplete) setup:
      I wholeheartedly encourage you to look into it! I've always been a fan of the underdog motors (VW 8v enthusiast) as long as they have some redeeming qualities... In my opinion, it's also a lot of fun to wring out a little high-strung motor on a regular basis, than to have to drive around timidly with a motor that's too powerful...
      If you want to go this route, feel free to shoot me a PM. I get on here every few days, and although I am far from an expert I would be happy to help!
    20. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      09-26-2019 10:10 PM #344
      Iíll be sure to get in touch when the time comes! The car is most likely not going to get touched this winter unfortunately along with the rest of the cars, but eventually Iíll be able to get back to them.
    21. Member Stromaluski's Avatar
      Jun 15th, 2005
      G'vegas, SC
      09-27-2019 11:44 AM #345
      Very much this. The ethanol basically eats everything in the system. I do not like Ethanol gas at all.
    22. Member SICKVDUB1's Avatar
      Sep 1st, 2008
      GOLF 99, 18 Nismo Econobox
      01-14-2020 04:54 PM #346
      Is this still thing going on?
    23. Member Zman86's Avatar
      Apr 5th, 2010
      Onterrible, Canada
      01-18-2020 06:52 PM #347
      Quote Originally Posted by SICKVDUB1 View Post
      Car is in storage for the winter at the moment off my property. Iím hoping to start buying some engine goodies in the next year, thereís a guy working on a bike carb intake manifold for the B3 engine, and the Festiva store is now carrying a B3 header. Those along with a regroups cam should provide some extra zip, and I have a 5speed trans to swap in as well.
    24. Member SICKVDUB1's Avatar
      Sep 1st, 2008
      Today 01:27 PM #348
      Nice thanks for the update.
