VWVortex.com - The Rabbit TDI Project Part 5: Speedometer and Cluster
    Results 1 to 6 of 6
    Thread: The Rabbit TDI Project Part 5: Speedometer and Cluster
    1. 04-28-2003 12:39 PM #1
      Part 5: Wiring 2: the cluster and speedometer
      Or: CXVII kph (117 kph)
      My TDI engine has an Immobilizer.
      For this engine to run, the engine ECU has to talk to the cluster to get the OK to run.
      You start the car, the engine computer talks to the cluster to get the OK to run,
      the cluster scans the key, and if everything is OK, tells the engine to keep running.
      Ok, so I have to use one of those fancy backlit clusters. Cool.
      No, wait, I have to fit that behemoth into a Rabbit dash. (shudder)
      But that's all another story.
      My engine didn't come with a cluster, I had to find one. I ended up talking to Komet on TDIclub and buying a new European cluster with MFA.
      If it's worth doing, it's worth doing right.
      So anyways, wiring the cluster was pretty simple, though I still don't have the fuel gauge working, but that's a little thing.
      Ok, wait. How will I get the speedo to work? The A4 gearboxes are totally different, and drive an electronic speed sensor off of the final drive. My 020 gearbox had a mechanical cable driven off the secondary shaft. Not only that, the tires on my truck are totally different in size than the footwear of the A4 cars.
      Solution: Mixing generations, and a wonderful black box.
      The A3 cars use an 020 transmission and run an electronic speedo.
      But then there is the issue of tire size and the reading location of the sensor.
      The solution came from http://www.dakotadigital.com/Detail....Dakota Digital and a neat little SGI-5 speedometer and tach interface. This little unit is designed to manipulate a speedometer signal to scale up or scale down.
      On the first drive of the truck, using a buddy's GPS, I found out that my speedometer was reading about 42% slow.
      69 kph on my speedometer was ~117 kph in the eyes of the law. Flip a few dip switches on the SGI-5, and 117kph is 117kph.
      Dakota Digital also makes the SGI-6 for Harley Davidson Motorcycles.
      "Allows simple push button correction
      of speedometer reading (from 200% to
      50% of current reading) after a
      transmission, gearing or tire size change"
      Or, install this unit and when your speedo says 25MPH, you're actually travelling 50MPH, so you can cut in half the number of miles you put on your Harley.
      summary: magic black box for the speedo
      Stay tuned...
      -Dave
      Part 1: Introduction
      Part 2: Installing the Engine
      Part 3: Transmission
      Part 4: Wiring 1
      Part 6: ImmobilizerIII
      Part 7: Drive By Wire
      Part 8: Intercooler
      Part 9: Intake and Exhaust
      part 10: MFA and Cruise Control
      Part 11: The Dash
      Part 12: The Little Things
      Part 13: The End (for now)
      Part 14: 6spd transmission and brake upgrades
      One Year Later
      Dyno results
      Who Needs a VR6
      TDI Rabbit
      Last edited by MrDave; 02-16-2015 at 04:38 AM. Reason: VWV messed up the links and formatting
    2. Remove Advertisements
      Advertisements
    3. 04-28-2003 01:01 PM #2
      I love this, so you have actually driven it?
      has all the torque pulled the front off the car
    4. 04-28-2003 06:39 PM #3
      That's sweet, nice work.
    5. Remove Advertisements
      Advertisements
    6. 04-28-2003 11:56 PM #4
      Looks great. Keep us posted! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. 06-16-2003 03:07 AM #5
      Nice! I've always wanted to put a tachometer in my diesel, but have been stumped as to how to doit. My 1.6 mk1 has no elictrical systems whatsoever inthe engine (not including the battery) so how do I tie in a tach to my Instrument panel
    8. 06-16-2003 02:42 PM #6
      Great looking work! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      However, if it were me, I would anodize the alloy cluster surround black. I just think the raw aluminum looks a little out of place. But that's just my personal preference.
