VWVortex.com - The Rabbit TDI Project Part 7: Drive By Wire
    Results 1 to 5 of 5
    Thread: The Rabbit TDI Project Part 7: Drive By Wire
    1. 05-12-2003 10:12 AM #1
      Or: people fear change
      If you read the forum posts on people asking questions about 1.8T conversions,
      everyone says "avoid the drive by wire cars: too difficult"
      That's a load of crap.
      All TDI engines are drive by wire.
      It's no big deal. No, really.
      6 wires to the throttle potentiometer.
      1 custom bracket.
      Total time investment for installation: well under 1 hour.
      (I was so tempted to do a Mastercard spoof here, but decided not to)
      The top bolt goes thru a hole in the firewall, the bottom bolts thru the original
      cable pedal mount.
      Sorry for the quality of the second picture, but it gives you an idea of the early
      stages of wiring...
      The only problem is that the pedal sits about 1 inch too far to the left. There is no solution without hacking up the pedal, because on the right it is almost hitting the airbox. I'm debating if I should bother messing with it.
      Note: This is a car without A/C. I've never seen an A/C airbox, so I can't say
      how everything would fit in an air conditioned car.
      If you have big feet, it's easy to hit the throttle at the same time as you hit the brake.
      Another addition as part of this project was the pedal cluster out of a Cabriolet.
      The reason: Provision for the pedal switches for cruise control.
      Basically, a lego swap.
      More about Cruise Control later.
      summary: DBW AOK
      Stay tuned...
      -Dave
      Part 1: Introduction
      Part 2: Installing the Engine
      Part 3: Transmission
      Part 4: Wiring 1
      Part 5: Speedometer and Cluster
      Part 6: ImmobilizerIII
      Part 8: Intercooler
      Part 9: Intake and Exhaust
      part 10: MFA and Cruise Control
      Part 11: The Dash
      Part 12: The Little Things
      Part 13: The End (for now)
      Part 14: 6spd transmission and brake upgrades
      One Year Later
      Dyno results
      Who Needs a VR6
      TDI Rabbit
      Last edited by MrDave; 02-16-2015 at 03:42 AM. Reason: VWV messed up links and formatting
    2. Remove Advertisements
      Advertisements
    3. 05-13-2003 04:32 PM #2
      wow that looks easy compared to what i have heard about it!!
      thanks!
    4. 05-13-2003 04:58 PM #3
      Ain't it better to replace DBW by a cable set-up? IIRC DBW forbids heel and toe. Not that I heel and toe much with a Diesel though...
      Anyway keep up the good work!
    5. Remove Advertisements
      Advertisements
    6. 05-13-2003 05:38 PM #4
      Quote, originally posted by Frenchguy »
      On the TDI engine, if you go with full electronics, there is no other way to control the fuel pump than to use the DBW. There is no mechanical way to do it, other than replacing the injector pump with a manual unit, and that can be quite expensive, plus you would lose the real fancy stuff that the ECU controls.
      As for heel/toe, when you clutch or brake, the engine kills power. I'm not sure if it's a 100% or 80% or something else for the power reduction, but the boost sure drops off fast... (Luckily, with the VNT, the boost comes back pretty quick too)
      Anyhow, if the switches for the clutch and brake are disconnected, (or grounded, or put to +12, I'd have to check the wiring diagrams) the ECU would never know that you were clutching or braking, so you could still have your fun. I have the pedal switches connected, because I'm lazy and like cruise control for highway driving.
      There is a guy who rallye's his TDI over on TDIclub. He did an interesting writeup once about the joys of overcoming the DBW shortfalls.
      The TDI is no ordinary diesel.
      I don't have the thing chipped yet, nor do I have upsized injectors,
      and I'm still running the 1.5" OEM exhaust,
      but I can spin the 195/50/15 wheels thru first gear, and chirp second.
      -Dave
    7. Banned
      Jan 2nd, 2003
      05-18-2003 02:40 PM #5
      On my DBW 1.8T i didn't connect brake or cluch switchs and runs perfect! Heel and toe/ left foot braking is all good!
