VWVortex.com - The Bring A Trailer (BAT) watch thread
    The Car Lounge
    Page 207 of 210 FirstFirst ... 107157197203204205206207208209210 LastLast
    Results 5,151 to 5,175 of 5247
    Thread: The Bring A Trailer (BAT) watch thread
    1. 05-22-2020 10:05 AM #5151
      Quote Originally Posted by iliveoncaffiene View Post
      Saw this one added due to me stalking Rennlist:
      https://bringatrailer.com/listing/20...18-cayman-gt4/
      New 718 GT4 stripper ($109k MSRP) being sold after 300 miles.
      Owner didn't like the sound as much, and has plenty of other vehicles.
      Hot damn, my eyeballs just love that blue Porsche. So sweet!
    2. Remove Advertisements
      Advertisements
    3. Senior Member UncleJB's Avatar
      Jul 2nd, 2002
      NH Lakes Region
      15 GSW, 19 Tiguan SE, 03 20th, 88 Cabby, 64 Yamaha
      05-22-2020 11:35 AM #5152
      Quote Originally Posted by geofftii2002 View Post
      Damn.
    4. Senior Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      Somewhere North of Lyon Mountain.
      SR71 C30 t53a/b/b
      05-22-2020 01:20 PM #5153
      Quote Originally Posted by Cabin Pics View Post
      In 2020 I think I can find much safer ways to hit 200MPH with four wheels on the ground...
      Though none would probably be as exhilarating.
      Audi RS6?
      Quote Originally Posted by Tavarish
      The car's best safety feature includes ejecting you in the moment of impact and wishing you the best of luck.
    5. Member TheDeckMan's Avatar
      Sep 26th, 2004
      GMC, SAABs,VW's, MG ect..
      05-22-2020 03:42 PM #5154
      Quote Originally Posted by Sporin View Post
      Not silver, and the turbo 996 didn't have any IMS issues, correct?
      https://bringatrailer.com/listing/20...-911-turbo-89/
      24k-Mile 2001 Porsche 911 Turbo 6-Speed
      Current Bid: $35,000 Ends In: 7:23:07
      (I do not like those wheels )
      Some major maintenance was done on that one, Meger cars are very reliable however they are getting to a point later in life when it is time to pay the piper with gaskets/hoses ect. Some cars had issues in the early cars with lifters requiring tear downs. Clutch accumilators are now ~$600 in parts to replace and they are a consumable depending how much or little you drive. Driving these cars more generally has less issues than the cars that are only taken out on sunny weekend days.
      01 and early 02's had issues with gear box detents because of poor shimming of the main shaft. This results in the 2nd gear syncro being destroyed and the cars will pop out of gear under decel load. If this happens figure $6-10k to go through the box let alone anything else you end up with going in there.
      They make fantastic sounds and are wonderful cars but with age comes cost as well as finding someone to work on them that knows what they are doing. While these are 20 year old supercars, they can be maintained in your own garage with a good selection of tools and plenty of time on your hands. Power is addicting with them and often ends up going down the rabbit hole until either your 401k has been wiped out or you cry mercy.
      No IMS to worry about on the Mezger motor, however the following are major issues:
      Front Differential bearings
      Coolant fittings leaking or blowing out $,$$$
      Damaged radiators $1600-2400 to replace all 3
      Coolant hoses are aged and there are a **** load of them $$$ and can be hard to get some times due to stock in the USA. Most come from Germany so figure a couple weeks at this juncture to a month.
      2nd Gear syncro wear & pop out $,$$$-$$,$$$
      Pinnion bearing wear $,$$$-$$,$$$
      Seized wastegates on turbos / leaking turbos $$$$
      Vacuum leaks/IC leaks $$$-$$$$
      Lifter failures $$,$$$
      Worn suspension items can get pricey if catching up on neglected maintenance $$$-$,$$$
      Interior rattles
      Spoiler hydraulic failure $1500-2500 to fix.
      Keeping $3-7k for upkeep or a major repair on hand is plenty to stay ahead on these cars. Turbos eat tires, figure 8-12k max for a set of tires, more so if you are heavy with the throttle and dont have a perfectly set up suspension.
      Mods are anything you can imagine with most Cup/RSR parts able to be swapped over as well as much later items from GT2/3/RS cars. Power can easily get into the 600whp range without going to crazy, however over that is when things start getting really expensive, if you want 700-850whp then figure head bolts and taking the motor all the way down. This will run $25k in parts easy and thousands in labor, it is easy to throw six figures at these car in going for 1000whp and they will do it, but be warned.
    6. 05-22-2020 06:39 PM #5155
      Quote Originally Posted by UncleJB View Post
      Any of you guys ever tried to sell wheels on BaT or know what their parameters are for acceptance? Thinking about selling on the Schmidts I bought right before the corona hit but don't want to deal with CL and I am not on FB.
      Would these be "special" enough?
      I doubt it but who knows unless you try
    7. Moderator aar0n.'s Avatar
      May 7th, 2004
      PNW
      MK4 R32, 987.1 Cayman S, Outback wagon
      05-22-2020 07:54 PM #5156
      I think you'll have better luck if you can find a MK3 guy to post them for you in some MK3 FB groups (assuming they're 4x100 VW fitment). Moderlines usually move fast since they're timeless on those cars
      The Car Lounge summed up
      Quote Originally Posted by Fined View Post
      lots of people who post on this forum are not car OR driving enthusiasts. they just come here and post tirades/smarmy comebacks
      Flickr™
      DubCult.
      Feb 3rd, 2006
      North Las Vegas
      2017 Chevrolet SS 6M
      05-23-2020 03:12 AM #5157
      Sub-19K mile E39 M5:
      I don't like the angles of the exterior shots (and getting in the backseat of an executive sized sedan for a cockpit shot is, as always, a real ballbuster for some), so you'll just have to click the link. This car should fetch a pretty penny.
      Quote Originally Posted by Broduski View Post
      TCL would suggest a Bi-Turbo to a single mother of 4 just for sh*t's and giggles.
      Quote Originally Posted by Sold Over Sticker View Post
      Here we can all drive like Colin McRae in his prime, earn $25k a month and bang super models. We can also text and drive.
      You only live once, and you can file for Chapter 7 Bankruptcy every 8 years.
    9. Moderator Harv's Avatar
      Oct 31st, 2004
      PA
      W116 - W123 - AMG - W463
      05-23-2020 03:23 AM #5158
      Brace yourself for the price on this one. Holy mother. https://bringatrailer.com/listing/19...uiser-fj62-40/
    10. Senior Member UncleJB's Avatar
      Jul 2nd, 2002
      NH Lakes Region
      05-23-2020 06:31 AM #5159
      Quote Originally Posted by aar0n. View Post
      They are. Good call maybe I will give that a shot. Thanks.
    11. 05-23-2020 07:43 AM #5160
      Quote Originally Posted by Harv View Post
      Yikes. Interesting that it sold for $55k back in 2017.
    12. Member Taco1933's Avatar
      Nov 1st, 2017
      GLE350 4Matic
      05-23-2020 07:56 AM #5161
      Quote Originally Posted by TJSwoboda View Post
      I wish I was in a better spot to buy a spare car. I need to own an e39 M5 before I die and the value on those is increasing everyday. And, wow, is that one sure a fine looking example.
    13. 05-23-2020 07:58 AM #5162
      Quote Originally Posted by stealthboost View Post
      80k with four days left? Why?
      We've revamped our website - please check it out! www.chirostandard.com
    14. Member
      Dec 3rd, 2011
      The NATO garage: 3 British, 2 German, 2 American.
      05-23-2020 10:45 AM #5163
      Quote Originally Posted by Taco1933 View Post
      It’s a beauty, for sure. What do you think this one goes for? $40k?, 60k? I’d sure be curious what the original owner sold it for earlier this year!
    15. Member
      Jul 6th, 2012
      F
      05-23-2020 11:17 AM #5164
      Not normally my style, but do want
      https://bringatrailer.com/listing/19...-benz-250se-5/
    16. Senior Member Sporin's Avatar
      Feb 17th, 1999
      Vermont, USA
      '94 Miata - '16 RAV4 - '10 Prius
      05-23-2020 11:54 AM #5165
      Quote Originally Posted by Chiropractor JW View Post
      Yeah, I don’t get it. FJ60 & 62 values are certainly rising but nothing less that a nuts and bots resto is worth those numbers imo.
      Looking through the comments it seems this is just bouncing from collector to collector.
    17. Member
      Jul 6th, 2012
      F
      05-23-2020 12:00 PM #5166
      Honestly this seems to be the case with half the cars on BaT, they are just people or dealers trying to do quick flips on cars.
    18. Member
      Jan 9th, 2017
      Nuevo México
      2008 Passat 6-speed; 2017 Tiguan 4-Motion; 1981 Vanagon
      05-23-2020 01:47 PM #5167
      I looked through the photos, and could not find a Porsche badge anywhere. I am at a loss for why this is so valuable. Is somebody really planning to go off-roading in an $80,000+ truck?
      Alpinweiß 2
      2008 Passat 6-speed manual
      1981 Vanagon
      formerly Alpinweiss (Alpinweiß)
    19. Member robr2's Avatar
      May 5th, 2005
      Boston
      2015 Passat "Limited Edition"
      05-23-2020 01:48 PM #5168
      The first two bidders have bid and never won on about 400 different vehicles. Are these simply there to drive up the price?
    20. Member kiznarsh's Avatar
      Apr 10th, 2007
      SoCal
      987.2 | GTI
      05-23-2020 02:13 PM #5169
      As much as I loved mine, I could never own a MY 2000 one; the refresh took it to a whole new level IMO. Walking up to it and getting in was always enjoyable and it's because of the upgraded lights and interior.
      Fortunately there are still plenty around. Good luck!
    21. Senior Member Sporin's Avatar
      Feb 17th, 1999
      Vermont, USA
      05-23-2020 02:44 PM #5170
      Quote Originally Posted by robr2 View Post
      Interesting. I also noticed the last guy to sell it is on there really hyping it up. Is it the same group of collectors all shadow bidding and hyping each other‘s sales up to drive up values?
      Certainly possible.
      Quote Originally Posted by Alpinweiss2 View Post
      No, it’s going into a collection to be driven to the ice cream shop on occasion.
      The values are up on these, like most classic 4x4s. But you can buy a pretty nice one for around 20 grand now. And a decent driving off roader for even less than that.
    22. Member
      May 9th, 2002
      Grapevine, TX
      01 Passat 4MO Wagon, 6sp manual and 1.8T swap. 05 Golf 2.0
      05-23-2020 04:47 PM #5171
      Quote Originally Posted by puma1552 View Post
      I like the look on the coupes, but the prices are way higher than the sedans. I've always preferred sedans for the ease of entry in a parking lot or garage, but you don't park that in a lot.
      2019 Tiguan SE 4Mo Orange, temporarily stock. 2001 Passat 4Mo wagon, 1.8T/6sp swapped, Konis, coilover sleeves, A6Q H+R Race springs.
      2005 Golf GLS, 2.Slow, Auto, GTI suspension, sways.
      2001.5 Passat GLX V6, stock. (son#1), 2000 Passat GLS V6 fwd Tip wagon, stock (son#2)
    23. Member
      Feb 3rd, 2006
      North Las Vegas
      05-23-2020 05:14 PM #5172
      Here's another one with more miles, but still under 100K, that won't go for nearly as much. No reserve.
      ...And another with 64K miles.
    24. Member
      Feb 3rd, 2006
      North Las Vegas
      05-23-2020 05:23 PM #5173
      Here we have the dawn of the E39, the closest you could get to an M5 at the time: A '97 540i 6-speed with only 32K miles:
      Also has an aftermarket head unit with a backup camera.
    25. Member turbo_nine's Avatar
      Jul 6th, 2000
      the kidney people wouldn't take it
      05-23-2020 05:28 PM #5174
      The kids who grew up riding in the back of these have a lot of money to spend. Just like their parents did. It's not so weird.
      call it potatography
    26. Member
      Feb 3rd, 2006
      North Las Vegas
      05-23-2020 05:31 PM #5175
      Paging Iroczgirl, it's another one of the dawn of the 5 Series itself: A '76 530 with a four speed manual:
