The below is some VCDS Tweaks what I did on my 2018 VW-Atlas(Execline) and tested all work well.
2018 VW-Atlas(Execline) Some VCDS Tweaks
1. Disable the Auto Start/Stop system (Voltage Method):
1). On Select Control Module screen, click "Select"
2). Select “19-CAN. Gateway”
3). Select “Adaptation - 10”, click “Channel” list
4). Scroll down channel list and find the below 1 channel:
IDE08348-Start/stop start voltage limit
( change “Stored value” {7.6v} to -> “New value” {12.0v}, then click “Do it!” )
*****So far, I didn’t use the above method, I use a “Start-stop automatic disable with memory function” module, that made by Arduino Nano. *** **
2. Open and close windows with key fob (Security access 31347 is required):
2). Select “09-Cent. Elect.”
3). Select “Security Access - 16”, enter the access key: 31347, click "Do it!"
4). Select “Adaptation - 10”, click “Channel” list
5). Scroll down channel list to the end and find the below 2 channels:
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen
( change “Stored value” {not active} to -> “New value” {active}, then click “Do it!” )
3. Change the number of blinks of tap turn signal from 3 to 5 (Security access 31347 is required):
5). Scroll down channel list to half and find the below 1 channel:
ENG141649-ENG116587-Au*nlicht_Blinker-Komfortblinken Blinkzyklen
( change “Stored value” {3} to -> “New value” {5}, then click “Do it!” )
6). Exit the VCDS software
7). To active this function, have to reset the “Personalization” setting in the MIB unit
“CAR” – “Setting” – “Personalization” – “Reset all”
or “CAR” – “Setting” – “Factory settings” – “Personalization”
8). After resetting, turn ignition OFF then ignition ON, then “turn signal time change” will work.
4. Setup some climate control when “remote start”:
2). Select “08-Auto HVAC”
4). Scroll down channel list and find the below channel:
IDE07301-Remote start function: activation of seat heating
( change “Stored value” {Seat heater front} to -> “New value” {Without seat heater and ventilation} )
IDE13676-Remote start function: rear window defogger
( change “Stored value” {active} to -> “New value” {not active} )
IDE07304-Remote start function: activation of seat ventilation
IDE07302-Remote start function: interior climate control status
( change “Stored value” {Remote start function with fixed rated temperature value active} to -> “New value” {Remote start function with last set value active} )
5. Show the A/C fan speed when operating in “Auto” mode:
3). Select “Coding - 07”
4). Select “Long Coding Helper”
5). On the long coding windows:
select(highlight) “Byte 11” area, then tick “ON” the “Bit 6” selection
6. Gauge needle sweep when ignition on:
2). Select “17-Instruments”
select(highlight) “Byte 1” area, then tick “ON” the “Bit 0” selection
7. Show Lap timer in the digital cockpit cluster:
select(highlight) “Byte 1” area, then tick “ON” the “Bit 3” selection
8. Operate all windows after ignition off and doors opened (Security access 31347 is required):
5). Scroll down channel list to end and find the below 1 channel:
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen
( change “Stored value” {active} to -> “New value” {not active}, then click “Do it!” )
9. Show “DRL” control option in MIB (“Car--Setting--Light--Daytime Running Lights”) (Security access 31347 is required):
5). Scroll down channel list about 45% and find the below 1 channel:
ENG141647-ENG116594-Au*nlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich
10. DRL off with Handbrake on (Security access 31347 is required):
ENG141647-ENG122184-Au*nlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten (The function already default set to “active”)
11. Change the “digital cockpit” background visuals to a carbon-fibre style:
4). Scroll down channel list about 15% and find the below 1 channel:
IDE02489-Display depiction
( change “Stored value” {Version 1} to -> “New value” {Version 3}, then click “Do it!” )
12. Change the “digital cockpit” style:
4). Scroll down channel list to end and find the below 1 channel:
ENG153766-Tube_version
( change “Stored value” {variant_0} to -> “New value” {variant_4}, then click “Do it!” )
Note: from “variant_0” to “variant_4” have different style, after from “variant_5” to “variant_F” nothing change
13. Turn on change ambient light color(4 to 10 kinds of color) function (Security access 31347 is required):
5). Scroll down channel list and find the below 1 channel:
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig
6). Then you can go this web site (
https://www.rapidtables.com/web/color/RGB_Color.html) to pick what you like color’s “R-G-B” value set as “new value” for the below channel (max 30 colors):
IDE*****-ENG******-Ambient light color list-Rotwert Farbe 1 (R)
IDE*****-ENG******-Ambient light color list-Gruenwert Farbe 1 (G)
IDE*****-ENG******-Ambient light color list-Blauwert Farbe 1 (B)
IDE*****-ENG******-LIN Ambient light color list-Rotwert_Farbe_1_lin (R)
IDE*****-ENG******-LIN Ambient light color list-Gruenwert_Farbe_1_lin (G)
IDE*****-ENG******-LIN Ambient light color list-Blauwert_Farbe_1_lin6 (B)
The above 6 channel for the 1st color, then you can set 2nd color with “*************Farbe 2”, and 3rd color with “***********Farbe 3”, ……, until to 10th color.
7). Last step, very very very important !!!
After this done, you need shut off the vehicle ignition power and waiting the digital cockpit screen totally off(nothing display), then turn the vehicle ignition on, turn on MIB unit, go “CAR” – “Setting” – “Ambient lighting” to see what happen on there and change the color then check the digital cockpit(Instrument) what happen too.
Because my car don’t replace the original “WHITE” ambient light LED tube(hardware) to multicolor LED tube, so I can’t check the really ambient light color changing in the car.
14. Set left, right “inner” “upper” tail light for brake light (Security access 31347 is required):
5). Scroll down channel list and find the below channel:
For left side inner upper tail light:
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23
( change “Stored value” {not active} to -> “New value” {Brake light}, then click “Do it!” )
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23
( change “Stored value” {0} to -> “New value” {127}, then click “Do it!” )
For right side inner upper tail light:
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24
15. Set left, right “inner” “lower” tail light for brake light (Security access 31347 is required):
Left, right both side inner lower tail light only control by one sequence-number “27”:
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27
( change “Stored value” {Brake light} to -> “New value” {Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) }, then click “Do it!” )
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27
( change “Stored value” {127} to -> “New value” {10}, then click “Do it!” )
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27
( change “Stored value” {maximize} to -> “New value” {minimize}, then click “Do it!” )
16. Using keyfob to lock and unlock the car with car engine running (Security access 31347 is required):
5). Scroll down channel list about 95% and find the below 1 channel:
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein
17. Turn on adaptive lane tracking function:
2). Select “A5-Frt Sens. Drv. Assist”
select(highlight) “Byte 14” area, then select the “Bit 5-7” @ “80 Point of Intervention: early (Changeable via Menu)”
( change “Stored value” {40 Point of Intervention: late} to -> “New value” {80 Point of Intervention: early (Changeable via Menu)}
18. Turn on 3rd high-mounted brake light when lock or unlock the vehicle (Security access 31347 is required):
5). Scroll down channel list to end and find the below channel:
ENG141649-ENG122204-Au?enlicht_Blinker-ZV_Blinken_auf
ENG141649-ENG122203-Au?enlicht_Blinker-ZV_Blinken_zu
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22
( change “Stored value” {not active} to -> “New value” { Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken }, then click “Do it!” )
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22
19. Change the fog light type to avoid error code with “LED” fog light (Security access 31347 is required):
5). Scroll down channel list to half and find the below 2 channel:
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12
( change “Stored value” {10 - allgemeine Scheinwerfer } to -> “New value” { 5 - LED Abblendlicht } )
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12
( change “Stored value” {100} to -> “New value” {127} )
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13
20. Turn on front wiper tear drop wipe function (Security access 31347 is required):
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status
6). go “CAR” – “Setting” – "factory settings" – “mirrors and wipers” then reset it.
21. Show Radio Station Logo in the digital cockpit cluster:
2). Select “5F-Information Electr.”
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart
( change “Stored value” {OFF} to -> “New value” {On}, then click “Do it!” )
22. Show “Refuel quantity” in the digital cockpit cluster:
(This function does NOT work on Atlas Execline or Atlas SEL premium that equiped with digital cockpit, the "Refuel quantity" will always show "--- L")
select(highlight) “Byte 10” area, then tick “ON” the “Bit 4” selection
23. Fog-lights are turned-on with high-beam lights (when the left-hand stalk behind the steering wheel is pushed towards the windscreen and the rotary light switch is in "Auto", or "On" position) (Security access 31347 is required):
5). Scroll down channel list to half and find the below 4 channel:
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12
( change “Stored value” {not active} to -> “New value” {Left high beam} )
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12
( change “Stored value” {0} to -> “New value” {127} ) (note: LED fog light change to “127”)
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13
( change “Stored value” {not active} to -> “New value” {Right high beam} )
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13
24. Setup the sunroof NOT tilting or open when open windows with holding key fob “unlock” button(Security access 31347 is required):
5). Scroll down channel list to the end and find the below channels:
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen
25. Turn on driver seat “easy entry/exit” function (driver seat move backward about 1 inch when driver side door open, move forward back to last position when ignition on):
2). Select “36-Seat Mem. Drvr”
select(highlight) “Byte 3” area, then tick “ON” the “Bit 1” selection
26. Folding external both side mirrors with holding “lock” button ( key fob or door handle) 2 seconds (Security access 31347 is required):
(make sure, in the MIB menu “CAR” – “Setting” – "Mirror and wiper settings" – “Fold in when locking” have been selected)
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus
( change “Stored value” {by look command via remote control key}
To ->
“New value” {by convenience operation via remote control key}, then click “Do it!” )
This function is good for me. Usually when I parking the car, I don’t want to fold the mirrors, but sometime when I get out the car and find the parking lot is too tight, so now I don’t need go into the car and turn on the ignition manual folding the mirrors, just holding the key fob or door handle “lock” button 2 seconds, the both side mirrors will be folded. And when you unlock the car, the mirrors will be opened automatic.
27. Change rear turn signal light type to LED to avoid error code when using LED light bulb (Security access 31347 is required):
5). Scroll down channel list to half and find the below channel:
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18
( change “Stored value” {12 - Blinkleuchten} to -> “New value” {43 - allgemeine LED} )
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19
( change “Stored value” {12 - Blinkleuchten} to -> “New value” {43 - allgemeine LED})
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19
28. Change reverse light type to LED to avoid error code when using LED light bulb (Security access 31347 is required):
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28
( change “Stored value” {9 - allgemeine Gl?hlampe 27W: auch H15} to -> “New value” {43 - allgemeine LED} )
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29
( change “Stored value” {9 - allgemeine Gl?hlampe 27W: auch H15} to -> “New value” {43 - allgemeine LED})
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29
29. Automatic lock the vehicle after all door closed(Security access 20103 is required)---NOT TRY:
2). Select “05-Acc/Start Auth.”
select(highlight) “Byte 2” area, then tick “ON” the “Bit 4” selection
6). Select “Security Access - 16”, enter the access key: 20103, click "Do it!"
7). Select “Adaptation - 10”, click “Channel” list
8). Scroll down channel list and find the below channel:
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock
( change “Stored value” {not activated } to -> “New value” {activated} )
9). After above done, find below 2 channel:
ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open
(it means all door close then automatic lock vehicle)
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open
( change “Stored value” {activated } to -> “New value” {not activated} )
(it means any door close then automatic lock vehicle)
30. Open which side door then turn on which side brake light (Security access 31347 is required):
[Note: vorne(de)-front(en), hinten(de)-rear(en); links(de)-left(en),rechts(de)-right(en)]
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20
( change “Stored value” {not active} to -> “New value” { Tuerausstiegslicht vorne links } )
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20
( change “Stored value” {not active} to -> “New value” {Tuerausstiegslicht hinten links} )
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21
( change “Stored value” { not active } to -> “New value” {Tuerausstiegslicht vorne rechts})
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21
( change “Stored value” { not active } to -> “New value” {Tuerausstiegslicht hinten rechts})
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21
31.Install MQB 2.0 direct TPMS on Atlas(Execline) VCDS coding:
(You have to install the MQB TPMS module first)
This is the install instruction PDF file (include VCDS coding and ODIS Engineering XML data transfer) link:
https://www.dropbox.com/s/azq0x3wrplu39hg/2018%20VW-Atlas%20Install%20Direct%20TPMS.pdf?dl=0
1. 19-CAN-Gateway: (activate tire pressure module in MQB HIGH gateway)
4). Scroll down channel list and find this channel:
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1
( change “Stored value” {Not coded} to -> “New value” {coded}, then click “Do it!” )
5). On Select Control Module screen, Select “Installation List”
6). Select “65-Tire Pressure”, activate it, then click “Save coding” on upper right corner.
2. 17-Instruments: (show tire pressure in dash board)
“Byte 3”---“Bit 7”: activate
“Byte 4”---“Bit 0”: deactivate
“Byte11”---“Bit 2”: activate
3. 03-ABS Brakes: (disable the original ABS TPMS)
2). Select “03-ABS Brakes”
“Byte 27”
01011000 -> 00001000
X111XXXX -> X000XXXX
It means: On Byte 27, the 2nd,3rd,4th Binary number should be changed to “0”.
Can use this website (
https://www.binaryhexconverter.com/binary-to-hex-converter) tool to do.
For example:
The old Binary value is “01011000”, the matching Hexadecimal is “58”, you want to get new
Binary value “00001000”, use the above website tool to get the matching Hexadecimal is “08”,
so just input Hexadecimal value “08” to replace the “58”, then you get the new Binary
value”0001000”. After that, exit and save.
“Byte 28”
11000010 -> 01000010
1XXXXXXX -> 0XXXXXXX
It means: On Byte 28, the 1st Binary number should be changed to “0”,
The old Binary value is “11000010”, the matching Hexadecimal is “C2”, you want to get new
Binary value “01000010”, use the above website tool to get the matching Hexadecimal is “42”,
so just input Hexadecimal value “42” to replace the “C2”, then you get the new Binary
value”0100010”. After that, exit and save.
4. 5F-Information Electr.: (show tire pressure in MIB)
2). Select “5F Information Electr.”
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus
( change “Stored value” {Suspension data bus} to -> “New value” {Databus extended}, then
click “Do it!”
Double check this channel
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07
should already be “activated”
5. 65-Tire Pressure: (set up the value of specified pressure)
2). Select “65 Tire Pressure”
IDE03511-Front-axle SPECIFIED pressure fully loaded
IDE03512-Rear-axle SPECIFIED pressure fully loaded
IDE08521-Front-axle SPECIFIED pressure comfort
IDE08522-Rear-axle SPECIFIED pressure comfort
IDE08523-Front-axle SPECIFIED pressure standard
IDE08524-Rear-axle SPECIFIED pressure standard
( change all “Stored value” {255} to -> “New value” {24}, then click “Do it!”
In new value has to input the tire pressure number without decimal point and the unit is bar,
so input “24” means the tire pressure set to 2.4 bar = 35 psi.
After all this coding done, please run one time “Auto-scan” and click “clean all DTCs” icon to
clean error code.
*6*. Show Tire Pressure value select menu in the MIB (with VAS6154 and ODIS Engineering
9.2.2), (if do this step 6, you can ignore the step 5)
1). First use this website
http://htmlpreview.github.io/?https....com/joltcoke/rdks-tool/master/generator.html)
RDKS Generator tool to create the “tire pressure XML” file, if you use VAS5054 or VAS6154,
select the Dataset type as “ODIS”, and select RDKS ECU as “5Q0907273B”.
2). Load the XML file by ODIS Engineering with VAS6154 or VAS5054, I use ODIS Engineering
9.2.2 and VAS6154 (Windows 10), the VW Atlas mapping code is “VW416” in the ODIS software.
One thing I want you know, if you install the ODIS Engineering software that come from internet,
please be aware that your computer time have to be changed back early Sep 01, 2019,
otherwise the software CAN NOT work properly.
3). After finished ODIS data transfer, please run one time “Auto-scan” with VCDS and click
“clean all DTCs” icon to clean error code. (Because after ODIS done the data transfer, the
vehicle will show out lots of error code, it is normal, don’t worry, just clean all the error code
one time).
32. Turn on “Air Care Climatronic” function:
select(highlight) “Byte 15” area, then tick “ON” the “Bit 5” selection
33. Can open sunroof all the way alone, but don’t need open sunshade: (use with OBDeleven)
1). Connect “OBDeleven” to vehicle
2). Select “08-HVAC”
3). Find “Necessary_linkage_sunroof_blind”
( change “Stored value” {active } to -> “New value” {not active} )
34. Disable “Auto unlock all door function when shift to park”, change to unlock all the door until open any door after park:
ENG141654-ENG116706-ZV Autolock-Autounlock NAR
( change “Stored value” {active} to -> “New value” { not active } )
