VWVortex.com - Turning an old 1920's Ford Garage into a DIY Garage
    The Car Lounge
    Page 4 of 15 FirstFirst 1234567814 ... LastLast
    Results 76 to 100 of 366
    Thread: Turning an old 1920's Ford Garage into a DIY Garage
    1. Member TheDeckMan's Avatar
      Sep 26th, 2004
      W.Mass
      GMC, SAABs,VW's, MG
      11-27-2017 03:14 PM #76
      Quote Originally Posted by Air and water do mix View Post
      But it'll look great!
      It would, perhaps using the same color green that I used in the offices would work well or the mustard color. First up is to get the Corrado back up and running after being apart for nine years So the big push is to get up and running to be able to tackle that car starting after the first of the year and then the 996 gets a motor drop.
      Quote Originally Posted by Aonarch View Post
      Looks really good!
      Thanks
      -Noah
      Corrado| 996 Turbo |997 Turbo |TT|
      "Life is tough, but it's tougher if you're stupid" - John Wayne
    2. Remove Advertisements
      Advertisements
    3. Member G0to60's Avatar
      Jun 23rd, 2003
      Milwaukie, OR
      90 VW Corrado, 02 Audi allroad, 03 VW GTI 20TH, 96 BMW 318ti, 17 JKU
      11-27-2017 03:24 PM #77
      Quote Originally Posted by TheDeckMan View Post
      I would love to see some pics of both of these coming back together and being torn apart respectively.
      The shop is turning out great. What a fantastic space.
    4. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      '66 Beetle (X2) '08 Fit
      11-27-2017 04:05 PM #78
      That'd be fine.
      Of course you won't be able to use the same kind of paint, but that's not a problem. It should be a simple scuff and paint. That'd be a cinch compared to the dumb waiter or the Corrado.
      Quote Originally Posted by G0to60 View Post
      It really is. I am sooooo jealous.
    5. Member secondgen's Avatar
      Jan 9th, 2004
      Stuff with wheels
      11-28-2017 03:27 PM #79
      Please no. It's brand new, just leave it be.
      Proud Customer of Phenix Engineering
    6. Member TheDeckMan's Avatar
      Sep 26th, 2004
      W.Mass
      GMC, SAABs,VW's, MG
      11-28-2017 05:19 PM #80
      Quote Originally Posted by secondgen View Post
      A voice of reason on TCL?!
      -Noah
    7. Member TheDeckMan's Avatar
      Sep 26th, 2004
      W.Mass
      GMC, SAABs,VW's, MG
      12-04-2017 12:16 PM #81
      This weekends progress was scattered with a proper case of ADD. First up was to get some new heat ducting run into one of the offices prior to it getting really cold. Using a strap and some duct tape to hold the heat ducting in place while getting things positioned worked like a charm. Once positioned using some self tapping screws to secure everything in place.
      Providing the heat directly into the new office space worked like a charm with only some small blood letting from those pesky sharp sheet metal edges.
      Next up was to get the base plate bolted down. The install kit from Greg Smith Equipment did not come with this type of hardware. So turning down some bushings I had kicking around from building control arms would work the trick to keep the base plate from pushing down on the hoses/cables.
      With the wall next to the lift all painted, it was time to get some of the old posters up to add some much needed flair to the room.
      Nick (vwjunkie42) and Jeremy stopped by and lent a much needed hand to build the new doors between the center bay and the east bay.
      Closing off the east bay was a substantial gain in no longer needing to heat non-work space, but still allow easy access into the area if needed.
      -Noah
    8. Member Smooremin's Avatar
      Jan 10th, 2006
      Chicago, Il
      16v I4, Supercharged V6, Gas drinking V8, High revving V10
      12-04-2017 01:16 PM #82
      Asking OT for relationship advice makes about as much sense as asking TCL what car to buy.
      Quote Originally Posted by ChillOutPossum View Post
      About 5 oclock I realized I needed to go to Costco for some white people stuff.
    9. Member cwescapexlt4x4's Avatar
      Jan 2nd, 2003
      623 PHX AZ area
      2017 Subaru Forester Touring 2.5i /2016 Ford Explorer/Previous 2013 & 2011 JSW TDI/97 Jetta
      12-04-2017 01:42 PM #83
      Very nice, keep up the good work and posting the progress!
      2017 Subaru Forester Touring 2.5i - 2016 Ford Explorer Limited
      **GONE VW #DasPolluter 2013 JSW TDI Oo>=====v=====<oO 2011 Kia Optima SX(Turbo)/2013 Ford Explorer XLT 4x4/2011 JSW TDI/2006 Ford Explorer EB 4x4 V8/2001 Focus wagon/2001 Ford Escape/97 Jetta GT
    10. Member TheDeckMan's Avatar
      Sep 26th, 2004
      W.Mass
      GMC, SAABs,VW's, MG
      12-04-2017 07:49 PM #84
      Well tonight’s fun was to get some winter preparations done on the Saab. With 211k miles and climbing I️ noticed a bit of engine play. Traced back the slight clunk to the transmission mount located inside the frame rail.
      Silly Saab’s
      Since I intend to get this one to 300k miles going with FCP to get a new factory mount was the way to go. If I need to replace I‎t again then no money out of my pocket.
      New mount in without much of a fuss.
      Next up was to replace the dead window shield washer pump which decided to fight me and end up dumping all the fluid on the nice clean floors....well that is one way to christen the fresh floors.
      -Noah
    11. Member
      Mar 2nd, 2016
      81 Rabbit, 85 Gti, 94 Jetta, 87 Gti16V, and 01 Gti.
      12-04-2017 08:28 PM #85
      yeah better washer fluid than oil or tranny fluid to break it in!
      Sent from my SM-T230NU using Tapatalk
    12. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      12-04-2017 08:33 PM #86
      Quote Originally Posted by dviking mk2 View Post
      yeah better washer fluid than brake fluid!
      Fixed. I hate brake fluid on clean floors so much!
    13. Member
      Mar 2nd, 2016
      12-04-2017 08:35 PM #87
      Buddy, that's why you put a bucket under your bleeders!
    14. Don't be me. Don't be a 'Rick' Cabin Pics's Avatar
      Mar 19th, 2008
      In The Woods
      2004 E46, 2018 SQ5
      12-04-2017 08:36 PM #88
      Just saw this thread, it's awesome. Keep up the good work sir!
      Instagram - efrie004
    15. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      12-04-2017 08:48 PM #89
      You know if you do it that way it'll miss the bucket, right?
      Added hose to coil into the bucket is the only way, and even that will somehow get onto the floor. That's what brake fluid does. it looks for the nicest painted surface and aims for that.
    16. Member TheDeckMan's Avatar
      Sep 26th, 2004
      W.Mass
      GMC, SAABs,VW's, MG
      12-05-2017 09:34 AM #90
      Oh so true!
      -Noah
    17. Senior Member UncleJB's Avatar
      Jul 2nd, 2002
      NH Lakes Region
      15 GSW, 15 Passat Sport, 03 20th, 88 Cabby, 64 Yamaha
      12-05-2017 02:10 PM #91
      Yes this.
    18. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      12-05-2017 02:39 PM #92
      Oh so true!
      I'm halfway convinced that brake fluid has at least insect level intelligence to be able to pull that off.
    19. Member TheDeckMan's Avatar
      Sep 26th, 2004
      W.Mass
      GMC, SAABs,VW's, MG
      12-05-2017 02:48 PM #93
      That and never seize. Use a brush to put it on a couple bolts and then you have it on your back, on the seats and on your beer
      -Noah
    20. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      12-05-2017 03:01 PM #94
    21. Member TheDeckMan's Avatar
      Sep 26th, 2004
      W.Mass
      GMC, SAABs,VW's, MG
      12-11-2017 11:21 AM #95
      Despite the snow some solid progress was made this weekend with some insulation and moving things around to get space freed up to move a couple cars inside for the winter. Along part of the goals this weekend was to move in my lathe that was wrapped up outside as well as the Bridgeport stuffed into a storage container....lets just say the Bridgeport did not make it in after nearly getting the fork truck stuck in the snow
      Friday night consisted in machining up the door latch to fit the new door between the east and center bays. Using a 3/8" end mill and the Bridgeport at the shop it made quick work of it. Next was attaching it up to be able to remove the cider shakes holding the doors shut. Next up for the doors is some paint and handles.
      Mounted up
      Moving the lathe in was a bit tricky as the only way I could pick it up was by moving the slide to the back of the machine and picking carefully under the ways. Just as I was moving it in from the back yard it began to snow which began to give some traction issues with the big wide tires on the fork truck. Once in I needed to spin it 180° to put the operation side towards the wall as the Bridgeport will face the back of the lathe to catch chips.
      Using a hand cart and a couple car dollies was able to rotate the lathe into place and pick it up and place it on the ground. Now time to clean the lathe and wire it up in the coming weeks.
      Next up was to move into the west bay and do some cleaning Sunday and move some of the work benches into the center room after a good cleaning. This old green work bench was filthy, using some gun wash and good amounts of elbow grease it was cleaned up to move in and be used as a transmission bench. Along with the benches was to move in the band saw to be able to cut up materials needed for some fabrication projects on the Corrado.
      After getting some plowing done, pulled in the truck to chase down some un-wanted guests that had gotten into the heater box. Damn rodents! The truck had sat for a couple weeks out back without any drier sheets in the cab and seemed to attract the suckers.
      I see your tell tale sign!
      Gross fan parts. After a good cleaning now this should be so much better in the truck. The smell of mice is just terrible!
      Being tired of messing with the garage, snow and moving heavy things I decided it was a nice time Sunday afternoon to turn up the Led Zeppelin and go to work on taking apart a Corrado 02A transmission on the new work area to install a Peloquin limited slip differential.
      Pulling off the 11mm bolts to hold the 5th gear cover is first means of business. Notice the blue tray with a drain hole to allow any gear oil to drain into the bucket down below, this makes life much easier when dealing with oily items.
      After removing the 5th gear fork and two retaining bolts for the 5th gear assembly using a little heat to warm up the gear and then slide off using a puller does the trick.
      After removing all the case bolts the next part is to pull the drive flanges off. The drivers side flange you can use two 1/2" steel blocks and the bolts to back the flange out. The passenger side can be tapped off with a dead blow.
      With that then the case can come apart
      Gear stacks get pulled next after reverse is removed
      Reverse assembly
      And finally the diff is out, next up will be cleaning and replacing the seals, removing the ring gear and installing it on the new differential. Once that is done the back lash will be checked, a shim will be made up to ensure the correct pre-load and then assembled.
      Not a bad way to wrap up a weekend!
      -Noah
    22. Member Smooremin's Avatar
      Jan 10th, 2006
      Chicago, Il
      12-11-2017 12:35 PM #96
    23. Member TheDeckMan's Avatar
      Sep 26th, 2004
      W.Mass
      GMC, SAABs,VW's, MG
      12-20-2017 02:47 PM #97
      Garage progress has been slow the past couple weeks with some work projects taking over the weekends. The major work has been moving things around to get ready for the long winter. Secondgen stopped up and we moved cars around after lots of stuff that had been moved out of the rental office areas that was taking up garage space.
      First little thing tackled was to add two more hinges to the door going into the east bay and put some handles on to make opening it a piece of cake, this area will act as overflow for long term projects that might be waiting for major work. Since this area is kept on a different heating zone, put in a gasket at the top of the door to help with the heating costs.
      Next up was to add some flair to the doors with all the wall art from the old garage.
      The East bay will also work as the wood working/building materials area, some organizing will be needed here at some point once the major stuff is done and some sanity is resorted.
      The main work bench needs some love and cleaning but that will have to be a spring project
      Once some last things finish up these coming weeks then attention to putting the Corrado back together will be a priority, so it was time to get it pushed hopefully for the last time up onto the scissor lift for putting the MS3 in and interior back into the car. I can say nice clean floors help so much for pushing around cars on dollies!
      -Noah
    24. Geriatric Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      12-20-2017 02:56 PM #98
      Gosh I don't know how to tell you this, but your scissor lift needs to be green and tan/brown too.
    25. Member TheDeckMan's Avatar
      Sep 26th, 2004
      W.Mass
      GMC, SAABs,VW's, MG
      12-20-2017 03:57 PM #99
      Sounds like someone is volunteering if I provide the beer and paint
      -Noah
    26. Senior Member LT1M21Stingray's Avatar
      Sep 13th, 2006
      Foothills of the Adirondacks.
      SR71 C30 t53a/b/b
      12-20-2017 06:02 PM #100
      Scissor lift is cool.
      Quote Originally Posted by Tavarish
      The car's best safety feature includes ejecting you in the moment of impact and wishing you the best of luck.
      Buy my couch!
