VWVortex.com - Windshield Wiper Replacement Recommendations
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 41
    Thread: Windshield Wiper Replacement Recommendations
    1. 11-05-2017 01:51 PM #1
      Hi all, looks like my wipers got screwed by the ash this summer. I even tried some graphite grease but no go. Can anyone recommend what's a good replacement for the 2018 Atlas?
    2. Remove Advertisements
      Advertisements
      May 1st, 2009
      Colorado Springs, CO
      Current: 2013 BMW X5 35d, 2011 VW Tiguan SEL
      11-05-2017 02:53 PM #2
      Quote Originally Posted by walksonair View Post
      If not OE, then Valeo. Valeo is probably making them for VW.
      Previous vehicles: 1981 Zastava 101/ 1988 Opel Ascona Irmscher 2.0i/ 1990 BMW 318i/ 1991 BMW 520i/ 1996 Opel Vectra 2.0 16V/1996 Alfa Romeao 146 1.6 Boxer/ 1998 Mazda Millenia 2.5 V6/1999 Lancia Lybra 2.4jtd/ 2002 Peugeot 307 2.0i A/ 2005 Passat B5.5 1.8T/ 2007 Skoda Octavia 1.9tdi/ 2009 BMW 525d/ 2010 VW CC 2.0T/ 2011 Skoda Octavia 1.9tdi/ 2012 Peugeot 508 2.2hdi GT.
    4. 11-05-2017 08:02 PM #3
      Wouldn't hesitate to go with Bosch either.
    5. Remove Advertisements
      Advertisements
    6. Member OEM Dubber's Avatar
      Apr 17th, 2008
      Toronto
      '11 GTI
      11-05-2017 11:17 PM #4
      Hearn back to the dealer and get them swapped under warranty. Covered for the first year.
    7. 11-28-2017 02:14 PM #5
      Has anyone found any high-quality, 3rd-party replacement wiper blades?
      In particular, I'd like sometime more robust that's particularly good in snow and ice. (We don't have a garage.)
      I was hoping to install some Bosch Icons, but they don't seem to be compatible.
      Any advice appreciated!
      May 10th, 2010
      Parts Unknown
      2016 Tiguan SE 4Motion
      11-28-2017 03:37 PM #6
      The stock ones are fine, in conjunction with a de-icing fluid.
      There should be Bosch ICON OE with the PTB, as well as Valeo ones (both supply VW with wiper blades)
      APR Stage 1/DDM Tuning Ultra HID 5500K/Neuspeed P-flo/AEM Dryflow BruteForce filter
    9. 01-18-2018 04:28 PM #7
      Quote Originally Posted by BsickPassat View Post
      any part numbers? or should one go by the size (inches)?
      Amazon shows me 3 matching sizes: 11 inch (rear I guess) and 22 and 26 inches.
      Are the front ones of different sizes?
    10. Member
      May 1st, 2009
      01-18-2018 04:39 PM #8
      Quote Originally Posted by blerg View Post
      Probably driver side is longer.
    11. Member kootenaydub's Avatar
      May 15th, 2009
      Kootenays, BC
      '08 GTI, '18 Atlas Highline
      04-02-2018 01:49 PM #9
      Has anyone confirmed aftermarket wipers that will fit?
      I tried some Michelin ones hanging around and the adapter was noticeably wider that the slot in the wiper arm. I checked my '08 GTI that works fine and confirmed that they are in fact thinner on the Atlas.
      I also looked at some Bosch wipers in a local store and saw that the required adapter was too wide as well.
      Really not looking to pay $35/ea CDN at the dealership for $10 parts.
      FYI, after 6 months my oem wipers are toast. Despite a clean window, they skips and chatter and squeak in all sorts of conditions. I can see the top ends are not flexing very hard onto the glass. I might try to bend them in, but usually I replace them when this happens.
    12. Member ChubbaDub's Avatar
      Apr 21st, 2008
      Potland, OR
      MKIV Supercharged R32, MKI Atlas SEL 4Motion
      04-02-2018 05:56 PM #10
      Apparently they are under warranty for 1 year so you might be able to get a free set. Call your local dealer.
      You just gotta keep livin' man........L-I-V-I-N
    13. Junior Member
      Sep 8th, 2004
      San Francisco Bay Area
      07-07-2018 07:24 PM #11
      Don't bother trying the Bosch Icon blades. Their catalog will tell you the 26OE fits the Atlas. That is wrong. There are two models for the Icon 26OE, "Extreme" and "ClearMax 365" They both do not fit. The Atlas WIPER arm has two extra hooks that interfere with sliding the Bosch blade hinge down the top lock channel of the arm.
    14. Member
      Nov 28th, 2017
      2018 VW Atlas SEL Premium; 1997 Acura NSX; 2009 Toyota Camry; 2013 Jayco 29KS RV
      07-07-2018 09:12 PM #12
      While checking out options for wiper blades I came across this company that sells you blades at $1 each + $3 S&H, after a one-time $19 registration charge. You would save money very quickly over what I see as list prices on most options from BOSCH, Trico, VW etc.. I wonder if this is a similar model as "Harry's" razor blades (that I love) which are just a good as the big guys, but $2 a blade. Anyone, I'm curious if anyone has tried them on the Atlas or other vehicle?
      https://thewiperbladecompany.com/
    15. Member KarstGeo's Avatar
      Jan 19th, 2018
      Richmond, VA area
      2018 VW Atlas SEL 4Motion 2018, VW Golf Sportwagen S 4Motion DSG
      09-09-2018 08:06 PM #13
      8 mos. and they just are skipping so bad I ordered a complete set from ECS. I tried everything in terms of cleaning them and the window. I blame the Rain-X washer fluid/window treatment I used/did shortly after getting it. Nothing but Krystal Klar mix now so hope the new blades sort it out.
      2018 Atlas SEL VR6 4Motion - K&N drop-in, deAuto interior, fog, and full tail LEDs
      2018 Golf Sportwagen S 4Motion DSG - Unitronic St2 IS20 ECU/St2 TCU/downpipe/K&N drop-in+air box/duct mods+block off/CTS TIP+TIH+TMD/034 dogbone insert/Golf R RSB
    16. Member
      May 10th, 2010
      Parts Unknown
      09-09-2018 08:29 PM #14
      Use Rain-X Xtreme clean to help remove the silicone off of the windshield
      Sent from my SAMSUNG-SM-G930A using Tapatalk
    17. Member KarstGeo's Avatar
      Jan 19th, 2018
      Richmond, VA area
      09-10-2018 06:23 PM #15
      Yep...did that too.
      Sent from my SM-G950U using Tapatalk
    18. Junior Member
      Jan 22nd, 2018
      Sammamish, WA
      2018 Atlas SEL V6 4Motion
      09-10-2018 06:57 PM #16
      I don't use Rain-X, but I have used just regular spray wax on one of my car windshields that was older and had lots of scratches and pits. It worked better and lasted longer. I also conditioned the wiper rubber with 303 Aerospace Protectant to keep the rubber from cracking. My original wipers are a year old and still going.
    19. Member DasCC's Avatar
      Feb 23rd, 2009
      West Coast
      '15 RSM e-Golf SEL | '15 CW Passat TSI SEL
      09-12-2018 01:33 PM #17
      Quote Originally Posted by KarstGeo View Post
      try clay barring your windshield.
    20. 09-13-2018 03:29 PM #18
      The stock ones were awful, I replaced them within a month with a pair of Bosch blades, and they've been great for almost a year.
      1993 Corrado, 70k
      2016 GTI SE PP MT LP DCC
      2018 Atlas SE
    21. Member RCDheliracer's Avatar
      Jan 7th, 2012
      Westbrook, ME
      1996 Jetta, 2000 Jetta, MKV R32 #1517, 2016 Tiguan SE 4Motion, 2018 Atlas SE w/ Tech 4Motion
      09-17-2018 09:37 AM #19
      Quote Originally Posted by Lopan View Post
      Which Bosch blades did you use? I bought a pair of Icons and they wouldn't fit even though Bosch's site said they would.
      2018 Atlas SE 4Motion w/ Tech
    22. 09-18-2018 04:11 PM #20
      The Icons, if I recall correctly. There's 2 versions though, and you need the "OE" version.
      1993 Corrado, 70k
      2018 Atlas SE
    23. Member KarstGeo's Avatar
      Jan 19th, 2018
      Richmond, VA area
      09-18-2018 05:52 PM #21
      Replaced all 3 with OEMs from ECS Tuning. Raining here today...work perfect...nice and quiet.
    24. Member RCDheliracer's Avatar
      Jan 7th, 2012
      Westbrook, ME
      09-19-2018 09:04 AM #22
      Hmmm...those are the ones I got but they wouldn't slide all the way in. Maybe I'll have to grab another pair and try again.
    25. 09-22-2018 04:21 PM #23
      Just a heads up. I don’t know if it was a bad day at the factory or what but the 22OE wipers from Bosch do not have the required “4” adapter. The 26OE for the drivers side does... the guys at NAPA checked several packages and none of 22OEs had it.
    26. Member RCDheliracer's Avatar
      Jan 7th, 2012
      Westbrook, ME
      09-24-2018 02:37 PM #24
      Unfortunately not a bad day at the factory. I ran in to this same issue when I went to put a set on my Atlas a few months ago. Hoping it's fixed soon as I would like to put a set on mine.
    27. Member AudiVW guy's Avatar
      Feb 7th, 2006
      Where Horses Roam and Royalty live
      02-04-2019 03:33 PM #25
      I replaced the factory wipers at our Mr Lube location - free wipers every spring.. [ free with oil change ]
      they replaced the factory wipers with Michellin wipers not realizing it used a special adaptor for the PTB narrow wiper arm..
      so fast forward today it is about a year and they are horrible now, so i head over to costco buy Michellin wipers, they dont come with the adaptors; during my attempt at reusing the adaptor i brake them upon removal..
      Then i head home with one working wiper, spend about 3 hours on the internet researching wipers for the Atlas..
      Damn it the Narrow PTB arm is the worst ever, Rain X or other brands wipers are not sold everywhere specially for that wiper arm..
      So i end up at my local auto shop Canadian Tire - Bosch ICON 365 climax - they have the adaptor .. but in the process which the instructions say push down and lift i rip open my finger lol
      seriously it should not be that hard. i return the broken wiper and they gave me a new one, i ask the tech there for assistance - they said $6 for help i laugh and show them the blood and hole in my finger and the instructions, he feels bad and then says you need a flat head pry at it and lift at an angle.. I replied seriously - the instructions don't say that.
      lesson learned - Bosch ICON 365 climax and bring a flat head.. i love them they work silently and dont streak.
      Seriously VW and their bloody not standard wiper arms.
      2018 VW Atlas Execuline v6 4motion with captain chairs - Loving it!!!!!!!!! [ when the features work lol ]
      2016 Jeep Cherokee - LTD High Altitude Edition - Loaded
      2008 Jeep Patriot - Silver
