VWVortex.com - No Power to 12v outlets in the front and rear?!?!
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 33
    Thread: No Power to 12v outlets in the front and rear?!?!
      May 14th, 2017
      2014 JETTA S 2.0L
      11-09-2017 11:01 AM #1
      hey everyone all of a sudden my two outlets don't work. What could have caused this and how can I fix it? Usually which fuse controls the outlets? Maybe I can replace it myself?
      Thanks in advance for your replies.
    2. Remove Advertisements
      Advertisements
      Apr 17th, 2014
      2011 Jetta SE
      11-09-2017 03:40 PM #2
      Fuse. VW changes their location from year to year. You can find your layout in the dealership.
    4. Member
      Feb 4th, 2017
      Louisville, KY
      2018 VW Passat 2.0T
      11-09-2017 06:25 PM #3
      Yeah some liquid probably got in there or something
    5. Remove Advertisements
      Advertisements
    6. Banned
      Dec 9th, 2014
      www.volkswagenownersclub.com
      11-10-2017 12:01 AM #4
      IT will be a 20AMP fuse in the long rectangular section, the larger fuses.
      Just pull each 20A one at a time, inspect, and put back in if okay.
      Everything was changed with the Gen3 EA888 motor.
      Feb 17th, 2017
      11-10-2017 01:55 AM #5
      Quote Originally Posted by PowerslavePA View Post
      What about the EA211?
      Mar 11th, 2017
      2014 Jetta SE 1.8
      11-10-2017 10:05 AM #6
      Quote Originally Posted by suziej View Post
      Like everyone said, most likely a fuse. Did you plug/unplug anything into them with the car running lately? I think it's safe to plug/unplug with car off and then turn the car on... not 100% but I guess a safer play. I had to replace mine after plugging in an air pump and I did it with the car on and blew the fuse. I linked a picture of what fuse I changed (20 amp - 2014 Jetta SE 1.8). Sorry it's blurry best I could find.
    9. Banned
      Dec 9th, 2014
      11-11-2017 01:24 AM #7
      Quote Originally Posted by Poetic50 View Post
      You're just gonna have to pull each 20A fuse, one at a time and check them.
      Not the SMALL ones, the bigger ones, as I said. I don't know what your
      fuse box looks like, but that does NOT matter, just check them, simple as
      that. I had to when mine first went, didn't take more than a few minutes,
      not many 20A fuses there. Look at the picture the other person put up,
      there are only four of them there, that will take LESS than a minute to
      check...
      Not only that, as usual, you didn't specify what YEAR car, they changed
      significantly from 2015 and up. Totally different positions, and the small
      fuses are now on the right side, not the left...
      MK6 covers 2011 to current, that's a lot of years...
    10. Member
      Feb 17th, 2017
      11-11-2017 02:32 AM #8
      check...
      Sorry 17 Mk6 Jetta 1.4T
    11. Banned
      Dec 9th, 2014
      11-11-2017 03:34 AM #9
      Then your fuse box will look like this one:
      There are a bit more 20A fuses in these ones.
      2nd fuse from the top left is Hi-Beam Power
      3rd one over is is Lo-Beam Power
      SO, you can not bother to check those ones, I know what they are for.
      I did not go through the fuses, but one of those 20A will be for your AUX ports.
      Again, there ARE NO diagrams out there, so you are going to HAVE TO pull them
      one at a time to check them. I see you don't like that answer, but that's all there
      is too it, unless you want to pay $65.00 for the service manual fore your car...
      I am not going to go out to mine and pull them all to find out for you...
      Feb 17th, 2017
      11-11-2017 05:19 AM #10
      Bro thanks but calm down I never asked for you to do it for me just really wanted to know the fuse Amp for it. I appreciate the help man.
    13. Junior Member
      May 29th, 2017
      11-11-2017 04:06 PM #11
      I dropped a penny in my outlet once on a different car and blew that fuse. Make sure you don't have any liquid or metal in your outlet before you slap the new fuse in.
    14. Member
      Feb 17th, 2017
      11-11-2017 05:43 PM #12
      Checked all 20 A fuses all of them are good and none of them are broken
    15. Member
      May 14th, 2017
      2014 JETTA S 2.0L
      11-11-2017 10:23 PM #13
      Thanks a lot guys, I will do it tomorrow and give you guys an update.
      Oh to answer the questions I usually keep one of those cheap usb plugin cup looking devices plugged in so I can easily charge my phones.
      Maybe that could be it.
    16. Member
      May 14th, 2017
      2014 JETTA S 2.0L
      11-12-2017 09:02 PM #14
      Hey guys mechanic says it seems it was my car charger that I left plugged in. Fusebox below steering near door and he changed a yellow fuse.
      All is well now. Thanks again for the replies.
    17. Member
      Feb 17th, 2017
      11-12-2017 10:19 PM #15
      What the heck all my fuses are good and mine still don’t work they don’t look broken
    18. Banned
      Dec 9th, 2014
      11-13-2017 04:31 AM #16
      All, as in every single fuse looks good? If you did check every single fuse, then
      I have no idea why they would not work.
      I read some people have 15A fuses in theirs. If you checked all the 20A, and
      not any others, then look for 15A fuses, if not, then move on to the 30A fuses.
      When I got mine, I had made all the fuses facing the same direction. Then, if I had to
      change one, turned it the other way so I knew which ones I had changed, in case
      it goes again, I can go right to it.
    19. Member
      Feb 17th, 2017
      11-13-2017 12:26 PM #17
      Hmmm I see then I checked some 30 and 15 but I’ll check them all. Btw the way to know if they’re good is if the middle part is not broken right? Or is there another way of knowing?
    20. 11-13-2017 02:09 PM #18
      They don't always burn in the middle. Only way to 100% know, is to check it with a test light... Pulling out every fuse and visually checking is a good way when you have no tools.
    21. Banned
      Dec 9th, 2014
      11-13-2017 02:33 PM #19
      The only other issue, would be, if the power wire toasted. They both
      run off the same lead. People have reported toasted grounds on these
      too.
      I almost believe the fuse boxes in these were simply installed, rotated, 180-degrees
      clockwise. On my '13 TDI, the small fuses were on the left, and power came
      from the TOP legs of all the fuses. On this '15, the smaller fuses are to the
      right, and feed power is at the BOTTOM leg of all the fuses, like it's upside
      down and flipped... The exception is the fuse designations changed drastically.
      Instead of two 15A fuses for each lo-beam, I now have one 20A fuse.
      They're also using PWM for the headlights, and I want that disabled...
    22. Member
      Sep 24th, 2017
      Los Angeles CA
      2014 Jetta SE, 2016 TiguanSE
      11-13-2017 03:09 PM #20
      You already were instructed to check and replace the fuse.
      But to add my experience, when I was inspecting my Jetta before purchasing, i noticed the same issue. Brought it up and the dealer checked and changed the fuse. That was the fix.
    23. Member
      Feb 17th, 2017
      11-13-2017 03:42 PM #21
      Quote Originally Posted by cesvilmal View Post
      Hmmm okay I see then I can buy one at autozone right?
    24. Member
      Mar 11th, 2017
      2014 Jetta SE 1.8
      11-14-2017 10:11 AM #22
      Quote Originally Posted by AlphaBetaJetta View Post
      Yea I thought the same :
      1. Asks for assistance
      2. Gets it
      3. Takes to Mechanic
      ...OK then
    25. Member
      May 14th, 2017
      2014 JETTA S 2.0L
      11-14-2017 11:22 PM #23
      what is wrong with you people? Did you ever consider that may be I had difficulty getting the fuse and it was more convenient to go the mechanic who lives two minutes from me and charged me exactly $0 to change the fuse.
      The assistance is valuable since when he is doing the changed I observe from an informed position.
    26. Member
      Feb 17th, 2017
      11-15-2017 01:51 AM #24
      Some of the people here are smart assses I asked a question about some cars and info on them and who would pick which and they started bashing me and making me feel bad like I just want a response not a child attitude ya know.
    27. Member
      Mar 11th, 2017
      2014 Jetta SE 1.8
      11-15-2017 07:32 AM #25
      Glad you got it fixed ultimately, people want to see you, or anyone for that matter, succeed. That's all. People on here are taking time out of their day to help others out and it's nice to see a result, just my perspective.
