Brighter and Better Fog LEDs for your Atlas - 100% Error Free / Plug and Play & Matches your OEM Headlights perfectly! Includes FREE Shipping & a TRUE
76K views 255 replies 48 participants last post by  deAutoLED.com
#1 · (Edited)
Brighter and Better Fog LEDs for your Atlas - 100% Error Free / Plug and Play & Matches your OEM Headlights perfectly! Includes FREE Shipping & a TRUE Lifetime Warranty
Upgrade the look of your Atlas today while creating a safer and more enjoyable riding experience.
Listing:
Please choose "Fog Model for ATLAS only" on the drop down menu
http://deautokey.com/product/new-de360-complete-led-fog-light-kit-fits-2015-mk7-golf
NEW FRONT TURN SIGNALS for 2020 ATLAS with halogen (PWY24W) LEDs.
Upgrade to a brighter LED to match the LED look of your Atlas.
-Bright deeper amber color
-CAN be seen in direct sun light and doesn't vanishes like other models (the most important feature)
-NO Hyperflashing
-NO Errors
-Plug & Play
LISTING:
https://deautokey.com/product/pwy24...-in-white-or-amber-fits-2020-atlas-volkswagen
These will NOT flicker when they are activated as cornering Lights, they will instantly turn on
They are BRIGHT but they also create a better beam pattern that creates a wide spread of light past your headlights and on the corners where you need the light most
-PERFECT for darker roads
-PERFECT for cornering
Our LEDs matches the headlight color temperature for a clean uniformed look
These are small but powerful, easy to install with included 3m tape for the small driver that is attached to the LED, this is 100% error free without any outside hot resistors.
These are 100% error free / plug & play install.
ALL of our LEDs include a TRUE Full Lifetime Warranty - you are set for life when you purchase these LEDs!
Real life photos below - as you can see in the photo these are a clean cut-off but extremely bright so they will shine light where you need it most without blinding other drivers.
These were TESTED in the ATLAS before being sold.
---------------We have a complete lineup of LEDs for your entire Atlas:
Interior LED includes Red blue or White footwells:
http://deautokey.com/product/complete-error-free-interior-led-kit-fits-volkswagen-atlas
Features of our Interior LED kit:
-Works without issue
-Plug and play
-Error Free
-No footwell spotting (clean smooth light)
-Fades in/out like OEM bulbs
-Won't stay dimly lit when your car is off
Brake/Tail kit:
http://deautokey.com/product/complete-brake-tail-led-kit-bright-error-free-fits-volkswagen-atlas
Rear Turn signal:
http://deautokey.com/product/amber-red-or-white-rear-turn-signals-fits-volkswagen-atlas
Reverse:
http://deautokey.com/product/bright-error-free-reverse-leds-fits-volkswagen-atlas
License Plate LEDs:
http://deautokey.com/product/licens...mkvii-2015-volkswagen-golf-gti-sportwagen-gsw
FOG LEDs:
Quickly search all LEDs:
http://deautokey.com/category/shop-by-car-model-vw-atlas-all-years-trims
Big thank you to forum member "CiDirkona" who helped tirelessly to test all LEDs for the ATLAS!
Checkout his interior kit DIY:
DIY: Atlas LED interior lighting upgrade
-NO Hyperflashing
-NO Errors
-Plug & Play
LISTING:
As always:
FREE SHIPPING within the US
Fair shipping rates overseas / Canada:
http://deautokey.com/international-shipping-quote
True no hassle Lifetime Warranty
Customer Support
-Plug and play
-Error Free
Brake/Tail kit:
Rear Turn signal:
Reverse:
License Plate LEDs:
FOG LEDs:
See less See more
19
#185 ·
I had some cheap LEDs from eBay and Amazon, had some issues with them, so I ended up getting the full interior kit from deAutoLED along with some fog lights and they are great.
I've seen some people saying why spend the money, the cheap ones are fine, etc.
As someone who has had both, the deAutoLEDs are definitely worth it. Color is better, no bleed or spots, they are solid, and they last.
Cheap ones work for sure but there is definitely a difference and once you see it you know.
#186 ·
WOW! This really means the world to us. I know what you mean because many customers contact the team with the same feedback. What I can guess people try the cheap stuff (which is really not that much less) and are not happy or they have issues. When you compare the build quality and brightness to deAuto there is really no comparison.
Thanks again for your feedback!
#200 ·
Curious, what does the fog look like at night when just one is on when you use your turn signal or the tires are turned far enough in one direction? Is the cut off good with the diodes at the 3 & 9 position or did you have to adjust in order to get the proper pattern?Also, which H size did you get and did you need the optional plug and play decoders?
Thanks! Appreciate any help you can provide.
#202 ·
Awesome! Thank you! I’ll get in the housing here to confirm. I had the Tiguan kit in white to match the headlights and was very happy with them before I traded the Tig in for the Altas. I agree the OEM halogens are barely noticeable, even when activated during turns or when the turn signal is on, you can’t really tell that they’re on. Do you find the yellow to be annoying during turns? I also plan to tint the fogs with Lamin-X since I like the look on the black Atlas.
  • Like
Reactions: deAutoLED.com
#203 ·
I have always liked the appearance of yellow lenses on black cars (and on white cars). Please post photos when you get this set up.
My 2021 Atlas has the fog lights integrated into the headlights, so yellow lenses are not really possible. :unsure:
  • Like
This post has been deleted
#9 · (Edited)
Yes, there are a lot of fog LED options on the market, but...
Will it produce as much light as ours? Probably not.
Will it have a lifetime warranty? Most likely not.
Will it have been tested in your Atlas for the best beam angle and brightness on the road? We highly doubt it.
Our fogs are meant to spread wide, low to the ground and past your headlights for added visibility and safety, hundreds have already saw the difference our kit makes in their Atlas - do not wait:
#12 · (Edited)
Our fog LEDs are made and meant to shine PAST your headlights and further down the road and on the sides!
Listing - choose ATLAS model on the drop down - these were made specifically for the ATLAS reflector housing (the GSW/ALLTRACK model will not look as good as the ATLAS specific model):
Photo showing the difference between headlights on/off:
#13 ·
These are using high power LED diodes so these shine past your headlights and far down the road.
There are tons of LEDs that are run-of-the-mill that won't provide much visibility.
Our LEDs also are clockable / rotate 360 degrees so you can choose the best beam angle!
Don't miss out on installing something worth installing. You can save a few $ buying other kits and we never deny this but you are going to be missing out on the added benefit of purchasing something that is tested to work and look good in your car and actually provide more visibility. :)
:thumbup:
#14 ·
Thanks for the orders and support - get the best for your fogs: shines further down the road, brighter, turns 360 for the best beam angle, if you have other fogs and don't see the best beam angle you are stuck with it! Being able to turn your LEDs 360 allows for the best possible beam pattern and light distribution, don't be fooled by cheaper kits that do not offer authentic bright diodes.
#17 ·
#18 · (Edited)
We have been receiving a lot of emails about an amazon Philip LED vs ours - while they are similar in price we feel ours it worth the little extra it does cost and for the high price tag of the Philips many feel it isn't much brighter than halogen.
1- From reviews and photos, ours are brighter.
2- We are using a new 2017/18 LED diode technology when the Philips has been out for awhile, it is rated at 840 lumens which is not much brighter than a halogen.
3- With our LED Kit you are able to turn the bulb 360 for the best light output, VW is notorious for changing the housing/reflector – what works now might not work in the next production but with our LEDs you can turn the didoes within the reflector to get the best light output. This is also good if you want to switch our fog LEDs into another reflector housing
4- We FIRST tested our bulbs in the Atlas to be bright and we made sure it doesn't produce any blinding glare prior to selling this product so you know you have our guarantee
5-Our fogs fit cleanly & tightly in the OEM ATLAS adapter – no modifications are necessary!
6-When using yellow laminx our bulbs create a clean yellow not a green tinted bulb color like many bulbs in the higher 6k+ range might produce.
Some feedback from that amazon Philip listing that should be taken into consideration, being that these are over $100 you should have the brightest and not simply paying for a "brand name":
"I purchased these and have to say they are mediocre fog lights not too bright as being advertised i was disappointed.”
"These LED's are ok but not worth the money for the output. They produce no more light output than Halogen, they are just pure white instead of yellow. Beam pattern is ok but again not much beyond what Halogen will provide."
Feedback for our LEDs:
"These are insanely bright and exactly what I needed for the country roads I ride on at night"
"You get what you pay for and this price tag now makes sense when I see the amount of light I am achieving on the road from these fogs, thank you for a great product"
We are not here to put down any brand or any fog LED, our purpose to bring the best and what you will be happiest with, many might be happy with having a whiter light that isn't much brighter than halogen but others that have an ATLAS wants to make a statement and have more usable light on the road. This is what you will achieve with our LEDs vs many others on the market.
Listing (choose ATLAS on the drop down - these are the models tested in your specific model)
If you have any questions please let us know
Thank you
#19 ·
What about LEDs can cause errors that I read about? What is the extra bit in-line with LED "plug n play" sets? Is your connector more solid than the Phillips? I had to tape mine as it's not very secure and wiggled loose. I actually think the Phillips are fine in terms of output.
Sent from my SM-G950U using Tapatalk
#20 · (Edited)
What do you mean by errors? Our LEDs will not cause any errors and they are very secure, no wiggling or loose wires. And the most important part it turns 360 so you can aim the light in the best area of your reflector.
As we said, if you feel philips works for you that is ok, we are just pointing out that it is a very expensive LED setup for not that much output and why you might be saying the light output is "fine" vs "amazingly bright", similar LEDs with similar lumen ratings go for less than half of that of philips, at some point we assume it is simply paying for a brand name?
We had plenty of people contact us with not liking the lumen output of the Philips and asked if ours will be brighter. We will say we charge what we put into our LEDs. And our LEDs are much brighter vs Philps
We know the Fog LEDs didn't catch your eye but we have plenty of LEDs for everyone - our rear turn signals are a bright amber that are visible in direct sun light - no hyper flashing - no errors - brightest reverse with no radio interference or errors - brake/tail/turn that are brighter, lights more of your housing - you can check it all out here:
Recent feedback:
First let me say, this was the easiest upgrade I have ever done to a vehicle. daAutoLed's box was in my mailbox three days after placing my order, all the LED's were clearly marked and installed without any issues! I love the brighter white light inside, but my favorite LED is the turn signal, its soo freakin bright and crisp! Thanks for the quality product daAutoLed!
If you have any questions just let us know :)
Thank you
#23 ·
Don't worry, you win...it's your thread and I don't think anyone won't know that yours are very bright and superior quality vs. the competition...however, you still haven't answered my 2 original questions:
What about LEDs can cause errors that I read about? I was not talking specifically about the Atlas, but just in general? You hear/read on various forums comments regarding aftermarket LEDs causing error codes etc.
Thanks.
#24 ·
We are not trying to win anything, we are only sharing the truth so people can then make an informed decision on what is best for them, as we said if people feel the Philips is good for them we are not here to say otherwise but only share what our product offers vs competitors.
We cannot speak for other LEDs that cause errors, ours do not cause errors due to our custom built in resistor setup that is able to work with the VW electronics so they don't know it is a LED replacing the regular bulb.
We appreciate the questions and your interest - even though we did not "win" you with the fogs we feel you can find a lot of LEDs to complete the look of your Atlas - these are again tested to 1) work without errors 2) look good 3) be bright so others can see you 4) not blind others and look OEM/classy:
Thank you
#26 ·
Thank you - we really appreciate your support and trusting our company, we honestly wouldn't be here if we didn't think we offered the best LEDs for your Atlas.
We know Philips is a big brand name but honestly they do a lot, they are in healthcare, appliances and many other markets - we know many issues with their LEDs that customers point out to us from dimly lit glowing when the car is off, to flickering, to them simply not being bright enough or the wrong color temperature (too yellow at times for their headlights). We feel Philips is a fine company and have no issues with them but if they are going to compete we don't mind to share what we offer vs their brand.
For example their brightest reverse LED model really doesn't come close to ours in terms for brightness.
listing:
Here is an honest customer review:
So awhile back I purchased Philips reverse bulbs from Amazon for my GTI. I was looking for something that was an LED, pure white, and had a bit more light output (I park in a very lowly-lit area). I got them, installed them, and quite frankly was not all that impressed. Yes the light was white, they lit up instantly and looked pretty cool. The light output was the same, if not slightly less than the stock incandescent bulbs. I left them in for a few months and then decided to look for something else. I didn't want to go the eBay route, so I turned to deAutoKey. I know they've been around for a bit and cater to the VW/Audi community. I was one of the first to get their front turn signal LEDs and still rave about them and get compliments. I'm really glad I went with their reverse bulbs. I would estimate at LEAST 25% more light output than the Philips versions, great quality, got them in 2 days. These are way more than adequate if you want a pure white LED with more light output for your car. Here is a comparison:
Philips Reverse LEDs:
deAutoKey LEDs:
A couple more things to point out, notice that the deAuto bulbs are whiter. The Philips bulbs definitely have a yellowish "tint" to them (sort of similar to a 4300k HID bulb). Also, the lighting in the garage was similar, but not exact. There is more light in the deAuto picture but they are still brighter. I was going to take a picture of them in total darkness but in all honesty picture would be washed out with the light output. I wanted to give the most realistic depiction of the light output of both bulbs. These are obviously super easy to install. But check your housings, my bulb holders just pull right out whereas some need to be twisted out. Really loving these so far. Now I need the LED tail bulbs!
#28 ·
Hurry Hurry! We are down to our last batch until the new one comes in, buy now so you don't have to wait!
Thanks again for trusting our product is brighter and better - we will have reviews coming soon.
:thumbup:
#31 ·
OK, I will ask here. I just received my fog LEDs. I installed them with the LEDs at 9 and 3 o'clock. Is there a recommended orientation? I'm not getting the projection I hoped for. They are definitely very bright and they illuminate the road right in front of the car well.
#32 · (Edited)
We apologize if the email was missed, normally emailing them is the quickest way to get a response: Support@deAutoLED.com
They should either point right/left or up/down - it varies in each car, VW never really uses the same exact reflector for every single car even in the same production, we have seen each position create a different beam angle in each car.
Can you try to aim them in a different direction? You should get a nice spread of light and it should have a similar beam angle on the wall as seen here:
The fogs should shine on sides more than OEM low beams.
Please keep us updated
Thank you
#35 ·
Great DIY By forum member: bajan01
The easiest way is to pry from the inside of the cover, slowly going around the inside against the glass. Do this on the top and bottom and to the grill side. There are two tabs on the wheel side so if you pull from the grill side you don’t have to mess with those two tabs. There is nothing to break here as this outer cover is not attached very securely to begin with.
Next remove the single T25 Torx screw.
Similarly, the fog light housing itself also has two tabs securing it to the bumper on the wheel side. Once the Torx screw is removed the entire housing can pivot out.
Installation is the reverse of removal. For the outer cover, install the two tabs on the wheel side first and then make sure that the remaining seven tabs fit on the outside of the fog light housing and it will easily snap back in...difficult to see in the below pic but it won’t go on otherwise. If you are forcing the cover on then you don’t have the tabs on the outside and may break or bend them.
** No bulbs were harmed or replaced in the pictorial.[emoji12] **
#36 ·
Doing a similar mod on my SQ5 this weekend...I hate the factory fog light halogens.[emoji12]
#41 ·
OEM VS LED - no need to say which side is which:
SAFER!
Quicker light-up times = faster reaction times - people NOT using their turn signals is the # cause of car accidents. Be seen when using your turns.
Deeper amber LED color that matches front of Car LEDs.
100% error free
Plug & Play
NO Hyper-flashing
**BRIGHTER in direct sun light** (most important part):
Don't miss out - this is something you use everyday when locking/unlocking your car & of course while driving - give the finishing touch to your car.
#43 ·
I need to write up a DIY but this should help...
Locate grill cover in trunk...
Disconnect wire...
Twist off plastic nut. This is the only thing holding in the rear light assembly...
Remove rear light assembly...
Carefully pry back 4 plastic tabs and wiggle out the circuit board...
Locate and remove factory bulb and replace with LED...
Reinstall and test...
